View Full Version : 5th Generation Maxima (2000-2003)
  1. The rest of the Cattman Header Install **56k dare**
  2. General Alignment question
  3. Very Odd issue, only happens on hard accelerations/heavy load
  4. Recalibrating the needles on the gauge cluster
  5. Brake bleed pattern???
  6. shorter shifter stalk on 6spd
  7. Strut Tower Brace
  8. Spoiler loose - argh
  9. Trunk Vibration, with Structual Expanshion Foam.
  10. New Engine, same problem. cars Jinxed.
  11. Cleaing Engine Bay
  12. Left Front Wheel Crunching
  13. Done LCA Bushings (ES)? Step inside....
  14. Fogs on While Brights Are on
  15. Favorite 5th gens
  16. Extra wire in SCO Grounding Kit
  17. Yellow Top vs. Red Top
  18. fog lights
  19. Front rotor won't come off
  20. RE-WIRING FOG LIHGTS....link doesnt work
  21. Tinting Tails????
  22. Bad experiences with Import Car Parts Plus
  23. UDP + Timing Adv = FUN!
  24. Driving impression after transmission oil flushed
  25. are these ok?
  26. Optima Red Top Fitment Issues?
  27. Installed Hp's and Eibach's Today
  28. Need pics of polished or chrome grill
  29. Lack of power/pinging.....before you change the MAF
  30. New CATTMAN headers
  31. Max wont start....
  32. VG30DETT Swap?
  33. Hard Left Turn
  34. consequence of clicking axles?
  35. Little shaking when in idle
  36. 00VI...got one?
  37. 2001 + 2002 headlights?
  38. Need wiring diagram for 2K2/2K3 HIDs.
  39. G35 rims.... Calipers what color
  40. Ignition coil install and ECU Reset
  41. es shifter bushings install qestion
  42. so called hp chip?
  43. clacking sound
  44. **NEW Helios 6000k HID Video***
  45. 90k+ miles on a 2002 way too much?
  46. Wheelspin and Wheel hop
  47. Getting Headers installed where to with 2nd O2
  48. TCM reset?
  49. Noise from right side of engine/right wheel
  50. Does this make sense??
  51. Rattling Noise When Starting Cold
  52. Scuff Mark Repair
  53. test pipe needed 02
  54. Manual trans.... shifter really hard to move in neutral position............
  55. Next time you all drive your cars, Could you check something for me?
  56. what else should I change while replacing springs?
  57. 2000 Infinity I30 cranks but does not start
  58. Performance question...larger rims = slower car? Input on performance needed...
  59. Oil Consumption / rattle with Dealer response
  60. Struts w/o Springs
  61. 00-01 Maxima Undercover Cop in NYC
  62. 2000 maxima wont start
  63. tranny problems
  64. $10 mod...better sound
  65. drivin condions..good or bad?
  66. Interesting article
  67. WTF...weird knocking noise from engine bay. Help.
  68. new 5th gen, 4th gen, cutler's miata autocross vid
  69. Aside from the engine, is there any other routine maint. we can perform to our Max?
  70. fixing the vais the american way?
  71. brake fluid container leak?
  72. Picture request: 5.5 Gen with mesh grill behind stock grill
  73. 5spd Tranny prob. @ 67k?????
  74. EGR replacement is it difficult to DIY?
  75. Cattman B-pipe and stock AE muffler?
  76. Iacv
  77. Paint Match Question
  78. Anyone have any pics of the windows spoiler on their maxima?
  79. Problem with light for changing ignition color please help =)
  80. Blinkers Acting Like Hazards?
  81. rewire extra guages for my friend car, need help
  82. Issues after starter regrease
  83. O/T: Anyone else getting spammed by Yaco Max?
  84. Y-pipe/ B-pipe and extended warranty
  85. Need pics of cleared HIDs. With snowflake/lense and without.
  86. Precaution to take when storing car for winter
  87. Spark Plugs for an 02
  88. WHAT DID I DO???? (02 6-speed)
  89. Aftermarket Side mirror?
  90. Huge buldge on side of (tire) 19's Help!!!
  91. Tein H-Tech's and G35C's
  92. Ratteling Noise
  93. 25% Nissan Discounted Parts
  94. injen intake, hot shot headers , underdrive pulley for sale
  95. Brake Cause Rim To Be Stuck????
  96. Stop 02/03 Foglights From Cracking
  97. Odd DTC code 0455, can anyone chime in ?
  98. Tcm...
  99. Cali Spec 2000 Maxima From Va
  100. HID's light bulb?
  101. Scaredy cat - changing brake pads and rotors
  102. Catalytic Converter prices please!
  103. z32 brake question
  104. exhaust shops in ny?
  105. I just got my rsb on...I had a question post install
  106. Umnitza Angel Eyes work on 2000 Max?
  107. Anyone in here install their own custom leather seats?
  108. Cheap 19" tires????
  109. Turn signals not working
  110. Wheel repair..??..
  111. 3.5L in 2k Max?
  112. kelly blue book, accurate?
  113. Nitrous
  114. cv boots/axles
  115. How do you figure out which coil is bad?
  116. anyone have spiderlite tailight pics
  117. iPod with Bose Headunit
  118. strut bearing???
  119. k&n part number anybody?
  120. Radiator Fan
  121. Best way to polish up metal?
  122. Stillen Classic Lip 02-03
  123. Quick question for my friend & his 3.5
  124. is this the right H&R drop
  125. Somebody talk me down!
  126. blasted vais bolts/screws
  127. Backfiring issues
  128. What springs/shocks would you be running if COMFORT were the only factor?
  129. Wheel offset question. . . .
  130. nokya bulbs
  131. front speakers
  132. Just got the Frankencar catback put on and im a bit dissapointed...
  133. Why does my tranny sound like a buzzsaw?
  134. Injen Cold Air Intake (hp question)
  135. Rebuilding front caliper Questions!!!
  136. how many people have had tranny problems
  137. Lowered car on 18" wheel, big bang on small bum, need susgestion
  138. Anyone have stock springs and aftermarket shocks
  139. 2003 SE owner's manual...
  140. computer options on a 00fed
  141. Vacuum sounding when starting car
  142. which coilovers to get + one question
  143. Live AIM Chat today at 4:30PST!
  144. Trans Flush
  145. $5 car fax report
  146. Will OEM 00-01 exhaust fit the 02-03 maxima?
  147. Rustproofing K Sport Coilovers
  148. heat shield?
  149. Redlinemax.com: Cali Meet New 5th gen bumper pics Painted!!!!!!
  150. Tensioner pulley problem
  151. How do I change the battery
  152. so what do u guys think?????
  153. 2K1SE stalls all of a sudden
  154. For those who dropped w/ H&R , did you adjust headlights?
  155. technafit ss lines
  156. where did u put your V-AFC II?
  157. Isn't it October 29?
  158. Just installed Hellas... :)
  159. Windshield washer nozzle failure?
  160. power seat problems?
  161. Motor Mounts
  162. Free Mod: Color door pillars
  163. Bleed Brakes help
  164. installed Super Plasmas....comments/pics
  165. Where to buy a Clear LED Brake Light?
  166. o2 SENSOR HELP
  167. Shock & strut dust boot Q's
  168. Jim Wolf Stage 1 high performance clutch.
  169. Happy Holidays to your Max...
  170. 02/03 hids
  171. Anyone use Carbon fiber vinyl on their car?
  172. Drive shafts?
  173. Headlight Socket or Harness?
  174. Starter is shot on 01 where to buy online...
  175. New aero kit for my 5gen!
  176. I NEED Sub-Frame Connectors!
  177. CustomMaxima.com
  178. using hose clamps to stop muffler banging
  179. HID fog kit
  180. How much are new bumper covers?
  181. who sells/where can I buy CF door/b pillar covers for the exterior?
  182. Welcoming myself to the 5.5 gen family.
  183. Front lip for 03
  184. anyone with working knowledge of the unified meter control unit? (gauge cluster)
  185. What o2 sensors do I need?
  186. 03 Bose...Will I be OK?
  187. 2002 se rear bumper install -HELP-
  188. Bug & Rock Hood Deflector... Where to buy one??
  189. 2K fog light bulb swap..
  190. need a nighttime pic of lit up oem interior please
  191. Creaking/Clicking coming from Drivers side Dash/Engine Bay
  192. FAWKING WEAK...My Battery Post just SNAPPED OFF of my OYT...how to get it out?
  193. Repair from Leaking Battery Acid
  194. Lights went off while speeding up...
  195. Has anyone done this???
  196. chrome door pillars
  197. severely confused...
  198. Smoked(black) projectors with hid set up?
  199. injen intake vs. berk or place racing or franken
  200. Scary Prollem, Pedal hit the Floor!
  201. Muffler
  202. 2000 tail lights in a 2002
  203. The cheapest RF key?
  204. Upgrade OEM strus??
  205. Whining noise with speed
  206. lowering springs
  207. Extended Warranty
  208. Gen 2 Headers are teh r0xx0r! Dyno Results!
  209. Whats a good price for a AE???
  210. Car got broken into
  211. FS 17"x9" Mille Miglia Wheels
  212. MAS in 00
  213. H-Tech and Blues Noise
  214. Something is wrong w/ my frineds max
  215. Hyper-grounding
  216. Smoked Tail Lights
  217. Mod options.......
  218. Electrical problem?
  219. Crossed drilled rotors and stainless steel lines for 02 Max?
  220. Squeaking noise goes away when clutch is depressed...
  221. Have your brake lines broken before?
  222. Horrendous squeak from left front end?!
  223. car locked by itself?
  224. gauges illumination light + tail lamps are out
  225. Rough starting...
  226. Lemon 5thgens???
  227. 6spd 5.5 gen diff. similar to Quaife ATB?
  228. Replacing lights in for gauges?
  229. Replacing lights in for gauges?
  230. 2000 SE - Tires center wearing
  231. Non TCS Gauge cluster in a GLE w/TCS
  232. EBD and Brake assist???
  233. creeking sound from front suspension on turns and dips
  234. EVAP leaking?
  235. Wifes Maxima got hit yesterday.
  236. 2k1-2k2 MAF swap
  237. Squeaking/Slow windows
  238. knocking issues close to oil change (also after timing advance)
  239. 02 I35 speedo in an 02 Maxima
  240. o2 sensor location and part #
  241. Squeaking Armrest... Agh!
  242. Rear View Mirror Swap - Adding Compass
  243. Squeaking Common with Axxis Pads?
  244. g35 sedan muffler
  245. Tinted side marker lights
  246. INSTALLATION HELP: 2k2 HID Xenon Headlights, Umnitza HID Fogs (pics)
  247. Y-pipe bees in a can?
  248. squeeking noise = wheel bearing?
  249. Thoughts on CMS (Canuck Motorsport) Springs
  250. Lugnut was cross threaded - need new stud?
