View Full Version : 5th Generation Maxima (2000-2003)
  1. Should I sell or install my nitrous kit?
  2. keyless entry
  3. Diamond Plate Trunk Cover
  4. Symptoms don not math with the code HELP
  5. Service engine soon reminder?
  6. Deductable on extended warranty?
  7. E-Break Tightening Bolt
  8. Deactivating the keyless entry horn when locking doors
  9. anyone blow a tokico HP (Blue)???
  10. Tried some new headlights out. (pics)
  11. Cattman y-Pipe + Frankencar B-Pipe= LOUD!!!
  12. Tire - Center Wear. Have you seen this? What pressure do you run?
  13. Latest tranny oil change
  14. compass mirror problem!
  15. 3 VIDEOS and 6 pictures of my new mods for the interior
  16. Will a 5.5 gen Y-Pipe fit a 5.0 gen?
  17. Nismo rad cap *pics* *56k die*
  18. Need Opinion on Pre-Cat Problem
  19. my quick, cheap and easy XM install..
  20. Steering wheel became harder to turn
  21. 02 GLE Spoiler?
  22. New Owner of a 2002 GLE
  23. Photoshop experts please step in.....please!
  24. What do you like?
  25. how to flash high beams w/out HIDs flashing?
  26. Shocks/Struts Thumping/Bumping Noises
  27. Dumb Question (search found nothing)
  28. 02 Maxima Navi CD...
  29. brake light
  30. FSB noise.
  31. Wanna introduce my self
  32. Blown fuse or relay???????? Help please
  33. Part Number For The Ae Door Sills
  34. Vibration and thumping noise, please help.
  35. Maxima Christmas!?
  36. O2 Sensor problems....
  37. People With cattman headers and After market Y-pipe
  38. need help with clips
  39. 60,000 Mile Service , What do they do?
  40. New Suspension = Clunking?
  41. 03 Max Fog Lights/Lamin-X --- Rant
  42. wow wow wow one preatty slow maxima
  43. ASA AR1 18x8
  44. Speedometer Question
  45. headers or drill out precats?
  46. What do you think?...
  47. Changing paint What Color....?
  48. Pepboys Nighmare!
  49. car didnt start, then weird start...help
  50. Possible To Adjust Sensitivity Of Stock Alarm?
  51. Tires, Tires
  52. Where is the water pump on the vq35?
  53. OBD 2 Code Reader
  54. Installed: FTSB and RASB
  55. Need grill for 2000 nissan maxima se
  56. Fog Re-Wire write up
  57. PIAA Plasma Spark Blue fog bulbs
  58. driving..then the car just died...
  59. Reguarding the '02-'03 Headlights being stolen easily
  60. For those with 20's
  61. How do you remove the grill from an '02?
  62. How to tell if cat is blocked?
  63. loud whiney noise when turning the wheel..belts? 2k2 se
  64. Last wash for the season b4 i store her...
  65. Gear lube or tranny?
  66. 19's Plus Bronx, NY Roads = this
  67. Timing advance – rare question
  68. cold in my max
  69. Auto Tranny shifting at 5k rpm?
  70. funky vais fixed...kinda
  71. adding amp to bose..help!
  72. will aftermarket springs damage front struts?
  73. Got My Car Back From The Shop!!!!!
  74. HELP!!! With fog light re-wire
  75. leaking cv boot...will this fix work??
  76. Bad wheel bearings lead to damaged hubs.
  77. what horns???
  78. Can you replace foglights yourself?
  79. New idea, exhaust powered BOV
  80. problem with starter
  81. Anyone removed AC off 5.5 gen?
  82. Engine sounds like it will blow up
  83. SE gauge cluster to a GLE?
  84. Found perfect Optima Red Top to fit max/I30
  85. Climate control bulbs????
  86. ººº1 picººº All my headlight and fog bulbs.
  87. Window Problems??
  88. P0420 - I'm pissed
  89. Need Help Deciding HIDs
  90. Question about AC condenser
  91. JIC or K-sports
  92. P0300 Related to Grounding Wire kit?
  93. Tokico Illuminas -- How are yours?
  94. 02-03 DDEs??
  95. Does anyone have the Tein SS (Super Street) Coilovers?
  96. Wierd
  97. Proud new owner of my FIRST maxima....
  98. Throwing Some Help Out There
  99. foglights
  100. 2000 Nissan maxima steering wheel
  101. WHO to buy wheel spacers from??
  102. VQ35de Look
  103. P0505 code, fried ECU
  104. Suggestion for good brake pads/good price??
  105. dash kits...which one?
  106. Idler pulley disintegrated?
  107. slip light and tcs light on and wont go off.
  108. VAFC-II question
  109. Ever Bumped and Floated Like this?
  110. Unnecessary Damage
  111. lil vacation with the max AND JDUBS KIT!
  112. new JIC A2 on ebay $1200 no reserve
  113. installing oil pressure sending unit
  114. best $500 i spent
  115. anyone advise stock SE hight
  116. Jic A1 coilovers are in...first impressions...WOW
  117. knobs that work with the 2k2 boot.
  118. Taillights and interior lights not working...fuses work...HELP!!!
  119. squeaking belts and less voltage
  120. Need New Brakes?
  121. 2k3 Tranny 71,000 miles
  122. Front Lips
  123. storing the max for 3 months?
  124. Super Charger for 6 spd
  125. Clear 3rd Brake light on spoiler??
  126. 02-03 Headlight housing paint
  127. need some assisstance...please help
  128. Any concerns about getting an '01?
  129. Tightening my handbrake
  130. aksed my dealer about timing advance
  131. Wiper parts ... wtf...
  132. Problems with 2k SEs?
  133. 5th gen - snow tires 'tightest' fit
  134. Cost of Painting Stillen Lip+Rear
  135. 2K max bad coils How to?
  136. Stock Parts 02 Maxima Se
  137. Who's running with the 18" G35 Coupe Rims?
  138. New Hampshire Notice - Scums Have Arrived
  139. 00VI Kick-in Point
  140. Battery Tiedown/Ground Issues
  141. warpspeed products
  142. Anybody ever had this problem
  143. jic hight adjustment question
  144. Pinging vs. Timing chain rattle
  145. Flat Spots on Tires...Urghhhh
  146. is 4th gen supposed to shift faster than 5th gen? autos
  147. upgrade help.
  148. 5spd swap. AE Diff
  149. 300zx conversion bbk
  150. plug wires built into valve cover?
  151. Weird Power Everything Interior Issue. Help!!!
  152. Just got my JIC A1s... Question about the camber settings
  153. too many hids. 02/03guys hid brights?
  154. bucking engine, clearing its throat?
  155. Whistle with Berk intake on '01
  156. URGENT In midst of spark plug change
  157. Test Fitting the Blehmco Stage 2 LTB on 5.5 gen w/ gen2 headers
  158. Bolt size?
  159. Feel every bump even on setting 2 of Illuminas.
  160. Will CD-RW's play in Stock BOSE CD Player
  161. 5/60k powertrain warranty ?
  162. What to look for in a 5th gen?
  163. HID's Vibrates
  164. I NEED HEADLIGHTS (HID, HALOS, OR WHAT?) for my 00
  165. Titanium Edition Question
  166. 02/03 Mud Flaps
  167. should i get rid of my dragon intake and change it with a place racing cai???
  168. Need help diagnosing problems with my car please!
  169. Possibly buying a 5th Gen - what year should I get?
  170. Brake Help!!
  171. Sheer Silver (light silver) vs. Polished Titanium (darker silver)
  172. 02/03 Exterior Color Question
  173. Right Front Noise
  174. 00 auto feels like it is not down shifting
  175. Fog Bulb Replacement - Stuck!
  176. So long to Maxima...and probably this board.
  177. Hid Headlamp help ?????
  178. Occasional suspension "clunk" after installing maxspeeds
  179. Replaced the spark plugs on my 2003 SE. ONE question.
  180. lookin to buy a 2002 factory 6 disc changer
  181. 02-03 Bose 6CD changer Audio cutout fix!!
  182. Battery
  183. climate control???????????????
  184. fuel economy (acetone)??
  185. 5.5 Fidanza Flywheel
  186. 20th Anniversary Front Bumper
  187. Cheapest way to ship exhaust?
  188. Fit for 01 ebay housing w/ tsx proj
  189. Got a question about the VQ35
  190. udp facts, and other mods impressions.
  191. Need Help On Installinbg RSB
  192. yet another brake pad question
  193. Possible Explanation For Oil Consumption
  194. Fixed vias, on boosted = huge difference.
  195. *pix* what do you think of these bulbs?
  196. Guage lighting????
  197. Where is the PCV Valve on the VQ30?
  198. at malfunction
  199. 2003 SE with 18" ride quality?
  200. any 00-01 sterlings with eyelids?
  201. auto shifter problem
  202. Any suggestions??
  203. Help
  204. Bosal OEM muffler replacement ???
  205. hella horns question..
  206. Nissan factory OEM rotors...why use them? (Useless!)
  207. Help w/front end problem, Transverse link maybe?
  208. Akuta rotors
  209. Helios H.i.d. Bi-xenon Plug & Play Kits H4, 9004, 9007 In 6000k & 9000k
  210. An Idea: Does it exist?
  211. Upgraded my rear view mirror with cool features
  212. For those with 15" and 16" winter steel set-up
  213. need opinions on o2 sensor options
  214. 00 cali spec max gold canaster on TB ques.
  215. Taillight wiring question
  216. Major Tire problem
  217. Fog Lights help plz
  218. apex safc2
  219. not for nuttin
  220. Does a paint job to fix a dent greatly reduce resale value?
  221. Need Help w/Gauge Cluster Change
  222. Installed Cattman Today!!
  223. Q's before Cattman Y-pipe
  224. MAF or Tranny?
  225. joined the G5 club...got some questions
  226. Exhaust piping question
  227. Cracked Fog Light...
  228. POST PICS OF stillen rear lip with pics!!!!
  229. Finished General Lighting/HID Fog and Headlight Install ( Pix included)
  230. I joined the 5th gen forums today! PICS inside.
  231. Ending a lease 4 months early?
  232. Windshield smashed! Pricing?
  233. anyone try the PIAA Super Cobalt D2R bulbs?
  234. Caliper Replacement - Please Help
  235. rattles/sqeaks/and wind noise
  236. Reading Code P0138
  237. H.I.D. Low beam to Hi/Low beam
  238. Best tool/method to remove trunk liner?
  239. Car Weight Balance?
  240. paper cefiero model
  241. Anyone have these: volk gt-c
  242. Possible to fit splashguards with stillen kit?
  243. POLL - If you have a VQ35DE please enter.
  244. warpspeed vq35de Y-pipe
  245. Flywheel replacement
  246. Just got HS Headers and Stage 2 VB Mod installed...first thoughts
  247. just installed intake
  248. Anyone with the 7000k helio kit?
  249. O2 Simulator problems
  250. What do you think about a 5th gen in the 6th gen Orange??
