View Full Version : 5th Generation Maxima (2000-2003)
  1. will leaving shock set to soft wear it out faster?
  2. Performance upgrades for Christmas
  3. Where do you guys go for Nissan Parts?
  4. PROJECT HEADLIGHT RETROFIT: I pwn 30,000K HID
  5. exhaust tips....
  6. HID's experts step in.....(foglight kit) Help!!!
  7. What is responsible for how fast the calipers engage when you press the brakepedal?
  8. 2000 maxima keeps blowing rear stop bulbs
  9. My new 30,000K Hid's
  10. Maxima Totaled!
  11. has anyone tried this???
  12. Who had the O-really bird animation in their sig...
  13. would these fit in my 2003 maxima?
  14. Curious Problem, Can Anyone help
  15. Is this really a GLE (check this pictures out) Help needed immediately
  16. Bedding in new brakes?
  17. VIAS Constant Open Idea
  18. 245/40/19 Tires...will i have issues
  19. Someone explain emissions please
  20. Caliper Replacement Problems
  21. D2 Coilovers
  22. Fog light help!!!!!
  23. steering wheel...
  24. rear suspension question
  25. Starting issue
  26. Those at @100k miles what problems have you had?
  27. Sorry I need some more help guys
  28. need some pics and advice
  29. K and N + MAF
  30. Covered under warrenty??
  31. Could struts go bad after repair?
  32. RWD V8 maxima LOOK
  33. cooper zeon zpt & avenger hp
  34. Battery Acid Resistant Paint
  35. Good mod if it snows where you live....
  36. ABS module connector pinout
  37. High Idle FIXED
  38. Se, Gle,or both? Not a repost
  39. Detailed AE Mod Write-up with Pictures!
  40. No Time Like Snow Time
  41. Anybody use the new Bosch Icon Wiper blades?
  42. Grounding Kit with Optima Red Top?
  43. Swapping the climate controls
  44. Intake Recommendations
  45. Just bought Stock NAV for my 02 MAX few Questions
  46. A little O/T but I need some help
  47. Anyones SES light went away on it's own after ign coil change?
  48. Airbag light reset for 2000 Max/I30
  49. Towing a trailer
  50. Where to put jack stand ? Is it safe enough...
  51. warranty question
  52. Caliper Slide Pin Question
  53. Accident happened, suspension damaged. PLEASE HELP!
  54. Rear Defroster Question
  55. RIP: My 2002 Maxima Totaled (pics)
  56. Anyone ever buy these pre cats?
  57. HEAD UNIT double din?
  58. Ive Lost My Keys
  59. Steering wheel off center... ???
  60. More suspension woes...weird noises again.
  61. throttle cable ?
  62. Annoying steering-wheel vibration @ highway speeds. :nupe500:
  63. New fog lights went out in 2 weeks!! And on the same side??
  64. Eurodezigns HID Bulbs anyone use them?
  65. Trans problem
  66. Keep that Hinny Warm
  67. Bluetooth Car Kit
  68. buying a SALVAGE
  69. Ticking in A/C-Heater blower??
  70. K&N Dropin filter vs. HKS super flow drop filter
  71. 25 minute headlight cleaning (9 pictures; 2.08mb)
  72. Dynamat, where to get it ?
  73. What fuse is for the stereo???
  74. Morning lag ..
  75. Can someone post a pic of where the EGR valve is?
  76. PIAA Ion crystal fog bulbs, good or bad?
  77. 2k3 misfire at 4-5k rpms
  78. Fixed header leak!!
  79. howl noise when turning
  80. Ontario Insurance Question
  81. Help SES light on!!!!
  82. jic continue to make noise
  83. Weird knocking noise from back of car
  84. Wierd...
  85. Project EC.....Something new for the org
  86. Speedometer Compatability
  87. Engine vibrates excessively at Low rpm in park or drive.
  88. 02/03 HID headlight question
  89. 2k1 FSM Online anyone?
  90. Hood shocks
  91. Factory Exhaust, repairable? I dont want a new muffler
  92. Thinking about this 2k3 SE 6spd..Is this a good deal?
  93. Help Diagnose DTC 01320!!
  94. Suspension Noise...clip provided
  95. Front Lip on ebay
  96. 2008 Maxima!!!
  97. Detailed Write up on Dr Mod
  98. Should there be play in the parking brake handle...
  99. For 02-03 owners This seems kool
  100. Oxygen
  101. anyone know how TPS voltage effects performance
  102. Question about heater controls
  103. Replacing my brakes this weekend, any suggestions?
  104. Struts to match my springs!
  105. Mass air flow sensor bad, what do I do to get a new one?
  106. chattering noise when accelerating, timing chain??
  107. Advanced timing impressions
  108. Belt replacement
  109. Front 02 Sensor Replacement
  110. stupid question
  111. eBay FSTB owners, washers?
  112. vi solenoid vacuum routing...
  113. Weird Issue
  114. possible car problem...
  115. <$20 and fun with homelink
  116. Should I trade the Max.....
  117. Stillen Lip: Gettin' Mine, Who Else?
  118. tire rack referral number
  119. JDM headlights??
  120. Manual Transmission *stuck* !!! please help !!!!
  121. cold start idle problem with 2000 gle..
  122. I never knew what a great resource...
  123. Some Car Trouble
  124. How often do you change brake pads?
  125. Why do rear brakes wear out faster
  126. 02 sensor tsb 02-051a
  127. Power steering noise?
  128. Bad Motor Mounts?
  129. Official Coilover Thread!! For everyones benefit!
  130. What is the correct voltage for a working MAF?
  131. Nissan Autoparts Stores in Clearwater Florida
  132. Sold the Maxima
  133. Drive Train Warranty
  134. Looking Into Full Catman products
  135. New- First Post-Getting read to purchase Maxima-few questions
  136. Need Help 2k2 highbeams... Inspection time!
  137. WTF....Auto Climate Controls are STUCK in Econ mode!!! Anyone has an idea?!?
  138. Trunk Issue
  139. Went To Have My Snow Tires Put On And Had A Huge Disappointing Surprise
  140. !!!!exghaust Asistance!!!
  141. to anyone who bought the Helios kit
  142. Recommended Clutch (one step above stock)
  143. Berk intake - remove stock snorkle?
  144. IACV valve position
  145. Has anyone made LED taillights yet?
  146. Can anyone help with camshaft sensor
  147. DDE Problem, temporary, or i gotta change?
  148. 2k maxima ate another tranny!!!!
  149. Rear window SMASHED!
  150. post up photo of your 2000-2001 engine bay
  151. 2000 maxima gxe making a whinning noise somewhere in the engine when i turn it off.
  152. question on injectors
  153. Parking break not biting
  154. 2k2-2k3 HID headlight down the road visibility...how is it?
  155. EGR problem - top of guide tube totally clogged
  156. Iginition Coil Replacement
  157. o2 sensor & o2 simulator problem
  158. anyone remove that plate between TB and intake manifold?
  159. Best 19in Tires, Not Gonna Warp or Blow Out.
  160. Happy Birthday Tim!
  161. Insured Repairs: Headlights/Front Body?
  162. 1320 code
  163. Lowering your car.....
  164. fog light problems...
  165. Car has lowered further...springs or strut issue?
  166. People with cut springs.
  167. odd smell...
  168. stock headlight problem - HELP -
  169. how to retain dimmer function on sony head unit?
  170. Cat issues??
  171. question about compatibility
  172. Stickies update??!! Spark Plugs & Fuel Filter
  173. To ex-Berk/Frankencar intake owners - how does the GAB sound compare?
  174. Is it my hood?
  175. Code P0430
  176. Burning smell coming from the driver side rear wheel area????
  177. muffler/catback question
  178. PS2 Install Question
  179. Creeking noise when i shift my autotragic gears
  180. Identifying exhaust noise
  181. price check on aisle 2
  182. Quick Question: 15" wheels on 2K SE ?
  183. 225/35/19 too small of a tire on a 5th gen?
  184. Brake Problem
  185. AE limited Slip?
  186. Slipping Clutch
  187. stupid theory...
  188. Best place to get body parts
  189. Automatic to Manual Conversion?
  190. a/c pully bearing Q
  191. help, how to remove the throttle body
  192. Never seen this before
  193. Has anybody had this problem? and what it could be?
  194. Lube vs Grease.
  195. Frankencar owners step in!!!: fitment issues- Just Me??? (pics*)
  196. Best site to buy Maxspeed Springs
  197. Help, Please. Car is throwing CODES!!!
  198. Tuning the max...
  199. unorthodox ultra SSc pulley
  200. DIE Hard Battery
  201. shock absorbers...
  202. Ehh...dying fuse? Dashboard flickered when starting car.
  203. Tranny Weird!!!!
  204. best 5th gen?
  205. Light bulb question
  206. Freezing handbrake
  207. After Market Fog Lights Install
  208. new 5th gen bumper pics???
  209. Bump stops different for SE and GLE.
  210. Terrible Gas Mileage...?
  211. question about spring squeal.
  212. Happy Thanksgiving!
  213. Loss of low end torque........HELP!!
  214. Poor gas milage, possible causes?
  215. DR mod discussion
  216. Consult II = Bad @ss!
  217. License plate relocation
  218. REEEEEEEEE freak some 5.5 gen owners out
  219. Newest Generation short shifter opinions
  220. Is there anyway to aim our fogs?
  221. hotshot vs. cattman
  222. ignition coil diagnosis
  223. Coin Box Part #
  224. I'm so tired of my aftermarket rotors warping
  225. Can run Carfax reports
  226. Eibachs and bump stops
  227. Installing silverstars in head/fogs.
  228. Anyone Know Part Number?
  229. car jerks at 1800rpm in 1st and neutral...PLEASE HELP
  230. easiest way to install clearance bulbs
  231. First long road trip W/ codes
  232. hs headers on a 00fed spec w wideband
  233. 5.5 gen Problems Query (AC/Heater Blower)
  234. My car died a slow death last night....help
  235. Newbie 02 questions, INSPECTION FAILED
  236. o2 simulator?which one?
  237. ecu flash?
  238. Map light rewire?
  239. help my car got issues
  240. installed jic, getting squeeking in rear
  241. KSport GT Lowering Springs?
  242. cleaned TB and AICV now car is jumpy
  243. Anybody buy these rotors or pads from ebay??
  244. freak some 5.5gen owners out
  245. Poll: Yellow Fogs or Fogs to match headlights?
  246. headlight question
  247. Brake Upgrade Review.
  248. Tein h tech + illumina's = SMILES
  249. 5th gen tail lights.
  250. digital rear view install write up??
