View Full Version : 5th Generation Maxima (2000-2003)
  1. Automatic Climate Control Swap Possible?
  2. energy suspension bushings
  3. Buzz sound on Cold Starts
  4. Question regarding tranny pan gasket.......
  5. maf specs
  6. Do Warpspeed SFCs Work?
  7. I35 vs. 02 se
  8. need a 2k2-2k3 grille will pay
  9. stock HId to 6000k
  10. Wiring Up LED in Foot Well To Turn on When Doors are Open
  11. dealer retarded my timing
  12. Nismo Pads 6 Month Review
  13. Wheres the antenna wire?
  14. 02 GLE Lost Drive
  15. 5.5 gen. bose + ipod
  16. window UP via key fob?
  17. DIM SES Light
  18. Tanabe test car needed SoCal
  19. drivers door window control rattle
  20. Woodview molded dash kit ?
  21. 2k3 Black Maxima SE/TE sighting on Speed Channel
  22. Rpm Needle Holds Steady At 1800 -2000
  23. Question about factory warrenty
  24. Swapping Bose 8" Sub for other?!
  25. sub issue with new radion
  26. just want yall to know...
  27. Malibu lens cover vs. no cover at all when clearing turn signals
  28. Which pads are best for a non-racer?
  29. Started the process of looking for a shop to fabricate SFCs
  30. Blower motor noise
  31. ebay aftermarket Headlights
  32. those who painted their front lips themselves..
  33. Rattling problem found underneath. PICS.
  34. RE: F1 fenders
  35. need help with engine stalling problem
  36. Does anyone have pics of stage 1, 2 and 3 Warpspeed SFCs installed?
  37. Grille Tech owners, please step in!
  38. High Mileage Oil Worth It?????
  39. Best Color Dash Molding for Beige/Tan Interior??
  40. fuse?!
  41. detailed instructions on stillen body kit install???
  42. SWEET I just bought the very last Progress RSB
  43. D2 coilover before and after install
  44. some problem....
  45. 02-03 Haynes manual...Does it exist???
  46. coolant leak from iacv, will this fix work?
  47. Aftermarket exhaust - Hangers (Nismo, Walker, etc)
  48. Speedometer recalibration
  49. Smoking at startup. Anybody else???
  50. question about SE gauges
  51. HLSD failure symptoms??
  52. Muffler?!?!
  53. Got Rid of those damn squeaks!
  54. When braking alot of steering wheel shaking
  55. New Fog Rewire feature: Accidently discovered
  56. SES code of P1320
  57. P0420 code pulled - Three Way Catalyst
  58. Got my ecu reprogrammed today......
  59. is my master/slave cylinder going bad?
  60. Redlinemax.com- Bodykit Video
  61. should i get a vb mod stage II, or get am 5 spd manual conversion?
  62. Wheel Vibrating
  63. So my ECU is toasted (?)
  64. My maxima got its Christmas gift Early LOOK
  65. catalytic converters and Sirius
  66. Power windows struggling
  67. Unable to post....
  68. Happy 30th to the Home Depot Mod King
  69. no wounder we blow our mafs, here is some investigation...
  70. LED bulbs in taillights
  71. indigo door sills help?
  72. Possible to have a y-pipe and not know it...
  73. HeadLights Gone
  74. Dimmed door light
  75. window tint ticket in pa!!!!
  76. Exhaust Diagnosis Request...with Pics
  77. OBD2 Codes
  78. Which Exhaust
  79. Where can I get a new drivers seat??
  80. Can you cancel orders from tirerack.com?
  81. new upper and lower grill idea
  82. air/fuel gauge install
  83. Headlight Aiming Sticky ...
  84. which 02 sendor wire for air/fuel gauge
  85. Where Can I get the Otto Racing FSTB?
  86. From Ticked off to well....worse...
  87. can someone please post the TSB for the 2k2 2-3 auto trans slip?
  88. anyone know OBD II - laptop scope quality?
  89. Cutting cat make different tone?
  90. Rear top window air deflector NEED HELP.
  91. GXE Kit and double din HUs
  92. Which O2 sensor is it.
  93. holy crap i got torque :)
  94. Cutting bumpstops!!!
  95. adjustable fuel pressure regulator install....
  96. Car broken into... Ground kit might have helped
  97. 03 stock antenna sucks...any functional aftermarket ones?
  98. Weird Engine behavior (5 spd)
  99. Too much torque ?
  100. Help! Car won't start after Tb cleaning
  101. Headlight cracked
  102. Driver side axle install
  103. Looking for Nice Exhaust tips for stock muffler
  104. Just got a New Engine - Help
  105. Aftermarket Halo Headlights
  106. Strut Qs, before going back to stock springs
  107. need writeup on replace lower control arm bushing, anyone
  108. Aftermarket head unit/factory amp
  109. Does nissan warranty their warrantied work?
  110. Why don't my HIDs sit flush? Please help...
  111. O2 sensor for 2K
  112. Taillight question
  113. This is a REPOST but I'm so PISSED
  114. Anyone use an ebay Tsudo catback?
  115. Any DDE / Clear turn sig installers in ATL that can help me out???
  116. Where can i get White Gauges for 02-03
  117. Lamin-X Film on fog lights...
  118. Best way to get automatic transmission fluid off cement?
  119. Front Bumper Removal
  120. short shifter for 2k2 and 2k3 Max
  121. 2K2 Bose Stereo Ghosts? Volume Resets to 0
  122. Frozen Caliper
  123. Help...major decrease in gas mileage after cleaning iacv and tb
  124. trunk liner and shocks
  125. CEL Light is Dimmed NEED HELP
  126. cheapest place to get
  127. Nissan Maxima 3.2L?
  128. People with auto trannys...
  129. Automatic Transmission Flush (2002 3.5)... Do I have enough fluid in there?
  130. How to adjust the E-brake ?
  131. wheel bearings
  132. how to replace speakers in doors?
  133. So-Cal resident questioning legality of window tint.
  134. Bad or Good MAF?
  135. Main Cats
  136. Heated steering wheel , is it supposed to turn off after a few mins?
  137. OEM 5.5gen HIDs in a 5.0 gen housing?
  138. AFTERMARKET clutch feel - Thread of all Threads
  139. what to get for under $200 for xmas???
  140. Manual Ventilation Air Ducts
  141. Rattle from underneath the rear.
  142. Anyone in Tampa Bay area can help me install my DDE's?
  143. Anyone who replaced their fender:
  144. Installed MAF, still problems
  145. anyone w/jic ive got a question for u
  146. Need help please! door open button is slightly glowing!
  147. Maxima.org stickers
  148. looking for a high amp alternator
  149. Timing chain maintence????
  150. SFC questions?
  151. Auto transmission solenoid pack
  152. P1445 & P0455 Codes? Dealer indicates MAF?
  153. autotrans problems please help
  154. Noisy windows with tint
  155. How to Remove Cup Holder in the back seat?
  156. Updated Haynes Manual is Out
  157. 2002 maxima wiring diagram needed
  158. How To Remove Those Ugly Lines?
  159. Windows with own mind
  160. Do you guys hear a hydraulic like "pssshhh" when you first start driving?
  161. WTH I got a ticket for parking on the street overnight!!
  162. Can anyone with Axxis Deluxe or Hawk HPS chime in please?
  163. Need to get extended warranty stuff done..
  164. Help! Engine shake, stutter, loss of voltage, rpm "stable"
  165. Luminics JDM Yellow H3!!
  166. another fog light color topic
  167. the auto climate control and myself dont see eye-to-eye
  168. carbon fiber hood questions
  169. Passenger side axle center bearing -- free play?
  170. factory radio issues.
  171. Gas smell from heater vent?
  172. Navigation software!!!
  173. Hhhheeelllpppp!!!!!!
  174. *PIX* 4th gen ICE mod on a 5th gen *PIX*
  175. Installing a new clutch
  176. Weird Noise at start-up, any ideas?
  177. Need Help-replacing Vb-autotranny
  178. Stage II Blemco Lower Tie Bars
  179. car has trouble starting in the cold
  180. Remus exhaust
  181. Oil catch
  182. Whose car is this???
  183. auto tranny reverse lockout.
  184. how to change belts
  185. Question regarding heated leather seats.
  186. Check out my Site
  187. compression belt change
  188. 4th Gen Y Pipe fitment
  189. New Brembo Brakes on Ebay.
  190. ISC idle speed control malfunction P0505
  191. Install of 02 headlights
  192. Factory 2002 Navigation AC Control Buttons Broke Off!!
  193. H&R springs with Tein H-Techs.
  194. engine almost died
  195. PIA 7500K H4 Bulbs...
  196. i'm upgrading my brakes but
  197. Fender rolling!!!! has anyone has this on their maxima?
  198. fog bulb color
  199. 5th Gen Maxima 1, Snow 0 (owned)
  200. Electrical Professionals-Please enter
  201. For people who have ordered SFCs from Warpspeed
  202. Y do our brakes suck?
  203. New MAF, any diff with ECU reprogrammed?
  204. Oil Light
  205. Clear Corner installation
  206. Safe to drive with disconnected MAF for few days?
  207. Rattling noise.
  208. '02 Driver's Seat Stuck - Tips on NTB02-001c?
  209. Does yours do this? Cold rough idle.
  210. 2k2-2k3 HLSD 6speed owners step in - weird issue
  211. What an OPTIMA difference....
  212. 235\45\R17... can this fit on my stock 17" 2k3 rims?
  213. fed spec vi pix.....
  214. car wont start
  215. Structual Foam. Looks like an AMAZING product. Check it out
  216. Is there a cheaper alternative to the oem in cabin filter?
  217. auto tranny and the cold temps...
  218. Muffler replacement
  219. Nissan Courtesy
  220. 30,000K MAF sensor installed!!!11!1
  221. Summer Tires
  222. BOSE tsb
  223. Need some info on WarpSpeed
  224. brake issues...
  225. Heater Blower Noise!!! HELP!!!!
  226. morning start rattle, timing chain?
  227. ??????? Starter and Alternator Woes ????????????
  228. 5.5 gen hood vibration/rattle
  229. PROJECT EXTERIOR OVERHAUL I: Battle Damage via SUV!!!
  230. G35 Blue Maxima Pics
  231. Steering wheel controls for sterio help please!!!!!!
  232. Front Sway Bar
  233. Installed Cattman Gen2 Headers + Catback Exhaust - Q's
  234. Pulled codes
  235. ebay lights for 00-03
  236. Power steering issue?
  237. short throw types?
  238. Anyone have trouble with heated seats?
  239. New owner 5th Gen-Also coolant question
  240. Some times I wanna get rid of her
  241. if anyone needs any part or whole wire harness for 2k...
  242. HID Fog Question.
  243. 5.5gen 16s ??
  244. Anyone else with heated cloth seats?
  245. Front stabilizer bar removal on 5th gens?
  246. Some kind of weird wheel hop...
  247. 2500 RPMS at 60 MPH? AUTO
  248. will leaving shock set to soft wear it out faster?
  249. Performance upgrades for Christmas
  250. Where do you guys go for Nissan Parts?
