View Full Version : 5th Generation Maxima (2000-2003)
  1. 2k2/2k3 ingnition coils
  2. front bumper repair
  3. questions about headlight and engine cover.
  4. 5.5 fogs in a 5gen
  5. Can I get a quick photoshop 4 these rims please?
  6. My SIRIUS Satellite Radio Setup...a nice cheap option!
  7. New Brake Pads
  8. 5th Gen Muffler
  9. Its time for rims, help me decide!!
  10. Maxima fog lenses are cracked
  11. Anyone know what is this wire?
  12. Fuel Pump
  13. Dome/Map lights don't work?
  14. Parking Light on 02-03's
  15. Squeezed 18x10 on the back successfully?
  16. Any advice for header install?
  17. weight loss program
  18. misfire why why why
  19. Any word on aftermarket plenums for our cars?
  20. Spring/Strut Combo w/best Performance/Comfort Combination?
  21. Just sold my Maxima......Now what?
  22. 2002/2003 HID beam patten
  23. Voltage/Battery and Brake light on simultaneously
  24. Cause of smell?
  25. 2002-3 headlight
  26. Will a higher coolant:water ratio cause water pump failure?
  27. exhaust wind
  28. H&R Springs
  29. issues with '01 SE
  30. Installed Aftermarket deck and lost all AM radio, Help!
  31. Any ever had your struts replaced under KYB's lifetime warrenty?
  32. RPM readings at idle(park), Drive, reverse, etc...
  33. Where to purchase SS Clutch Line?
  34. I am replacing my water pump..advice?
  35. Yellow top battery question
  36. Engine Cover
  37. Opinions needed
  38. Features
  39. HELP!! y-pipe install
  40. Rebuilt Transmission questions
  41. Paint litigation
  42. 17 degree timing question
  43. Leaning to the left
  44. 02-03 brakes different?
  45. Suing Nissan
  46. Instrument cluster bulb size?
  47. changing ur fog bulbs from above. 00/01s
  48. need instructions for 02-03 lights, Got proof
  49. Need help reading Consult II print-out
  50. Screwed up Tach/Speedo...
  51. Quick ?
  52. those of you who grounded headlights
  53. I'm psyched! Finally got the opportunity to do some work under the hood!
  54. In-cabin filter write up
  55. anybody with pics of OEM Grille painted Sterling Mist?
  56. Illuminas stiffer when cold?
  57. Tranny problem, not slipping but...
  58. Squeaky Clutch....
  59. Need some specific info on the Powertrain Warranty
  60. Cleaned the throttle body, now the cars runs like kaka
  61. Identify the mystery hose!
  62. Ughhh I'm goin nuts without my car
  63. Auto Shifter Interlock Noise in Console
  64. New Years Accident
  65. Buzzing Sound... Short Circuit?
  66. Tranny Issue
  67. Lookinf for a new muffler
  68. Any non adjustable aftermarket shocks work with drops?
  69. need part list for 5spd comversion
  70. d2 coilover plates
  71. My Maxima rpm going up and down when cold
  72. Finally AE'd the Headlights...
  73. IM after TB restrictor plate
  74. Nice LED thread from a computer forum...
  75. cant find thread about intake resonator w/K&N vs midpipe w/K&N
  76. Sunova*****!
  77. 2000, 2004 Maxima....same axle hub?
  78. Max runs rough when parked on hill?
  79. Anniversary edition pedals
  80. Can someone confirm this.....
  81. Doing a 5 spd conversion.
  82. Passenger side foglight
  83. Automatic Ok??
  84. Does this sound right?
  85. Good bye every one!!!!!!!
  86. What do you think
  87. Locations of O2 sensors.
  88. 300zx BBK questions
  89. 2000 max SE - running very rough and ALL warning lights on??
  90. AE or Stillen Ground Effects
  91. Any info on a 2000 SE w/ 165K miles??
  92. Interior condensation, WTF?
  93. Weird vibration when stepping on gas...
  94. comfort and handling
  95. Alternator and Starter Installation Blues...
  96. carfax request
  97. I'm outta here .... thanks for the info!
  98. Can i sell broken Hid?
  99. Anyone have replacement HID headlights?
  100. Online Microfiche/Parts Listing Availability?
  101. engine guard clips
  102. full rebuild or replace diff bearing only???
  103. Does your Bose sub rattle ALL the time, or only with certain notes?
  104. 2002 or 2003 buying help
  105. 2002 pulling P0138 (more O2 crap)
  106. 5th gen vs. 5.5 gen OE Mufflers
  107. 02 max is over heating, I need help.
  108. okay, i cant take this clunking anymore
  109. Question: 2000SE vs GLE/GXE exhaust ??
  110. Best way to remove rotors?
  111. Auto shifter "grinding noise"
  112. 2000 Muffler Recommendation
  113. Ram Air?
  114. Colors of Wires for O2 Sensor?
  115. HELP!! Car wont stay at normal idle (No, it's not the MAF)
  116. 5spd removal question
  117. Anyone Had Their Hood And Front Bumper Repainted? Questions
  118. Reliable coilovers…..
  119. Removing stuff from window
  120. TCS question.
  121. can alcohol rub....
  122. Can you replace the headlight wiring harness??? (m)
  123. Just bought a set of illuminas and tein stech what settings do i need
  124. How to remove rear lens condensation?
  125. 2k Auto Dimming
  126. help! insane amount of wheel hop!
  127. Picture of Side of DEK Motor
  128. 2k Max exhaust system? stainless steel?
  129. optima owners please step in
  130. Where can I get the pac-oem?
  131. Why does my temperture gauge bounce up and down?
  132. Vibrating side mirrors at higher speeds
  133. New Years Present-MIL light - p0140 - Warranty?
  134. power steering: GLE vs SE pump
  135. 6spd Fluid Capacity
  136. The Dreaded steering wheel shimmy
  137. Response to engine/ radiator shroud
  138. ••ü•• Customer End Of Year Showcase & Thank You
  139. headlight aiming
  140. maxima plans for the year 2006?
  141. would this cause engine light to come on?
  142. need options to replace p.o.s stock 02 fogs
  143. Looking at OEM 18's for 01' Max.
  144. Happy New Year!!!!!!!!!!!!!
  145. silver maximas - what color for calipers?
  146. 2002 clutch pedal adjustment
  147. Engine/radiator top shroud...someone make one
  148. differences??????
  149. Are 2k-2k1 headlights DOT or E-code type?
  150. whats the difference?
  151. Sold the Maxima - VQ Burning Oil - H&R/Superleggara available
  152. Fog light bulb replacement? HELP!!!
  153. code please help asap
  154. Redlinemax.com - H3 Halo Super yellow Fogs
  155. Scheduled Maintenance Questions
  156. brembo blanks
  157. Rubber strip on top of headlight!
  158. I put the Demon in Daytime Demon Eyes :grinno:
  159. Help: My ABS light is on; 2000 Nissan Maxima SE
  160. Suspension quiestions..
  161. Nissan Maxima Service Manual
  162. Key Question
  163. quick exhaust question
  164. blue fog light capsules
  165. me and my 03 are back
  166. Must i change plugs with new ignition coils?
  167. Metal Maxima Method For Window Switches
  168. Need help with Ignition coils....
  169. LOL, wouldn't it be great if prices were this low!?
  170. Help?? Got 2 questions
  171. o2 simulator question
  172. Anygood Price on illuminas for 2000-2001 maxima
  173. I30 & Max Rear Decks
  174. Reverse Glow Gauges Power Question.
  175. HOLY CRAP! Internal Engine Failure!
  176. which rims for black 2002
  177. Synthetic ATF Flush or Refill?
  178. Weird Noises when driving
  179. Auction Prices???
  180. swaping stock se manual ac control to auto?
  181. ISO rotating motor......
  182. Steering wheel controls for mpg, temp, etc rewire with aftermarket HU?
  183. Front and rear lip on ebay??
  184. 300zx brakes or 6th gen Brakes
  185. Hot to Check MAF--Write up
  186. firing order on a 2000
  187. is agx 95-99 compatible with 2000-2001 maxima
  188. "ICY" on the temperature?
  189. Anyone tested how much suspension mods really help?
  190. Need Detailed Writeup on HID Foglight Install
  191. 2K spark plugs question
  192. Has anyone purchased a set of illuminas from Ebay?
  193. Future Maxima Owner!
  194. tools to remove wheel bearing nut, what do u use?
  195. If you got 8” wide rims – come in
  196. Taillight question, please help - did search and found nothing
  197. Performance Depot HID Lights on Ebay
  198. timing chain rattle
  199. Extended Warranty
  200. Is it necessary to change spark plugs with new coil packs ?
  201. Article about cutting springs
  202. Huge problems with the Stealership I need some advice
  203. Been out of the Maxima loop for a while, quick question.
  204. wheel bearing
  205. intake install
  206. Which intake for '03 Maxima
  207. Body kit question
  208. Updated my Maxima
  209. intake install
  210. Water in tail light housing
  211. HID's & Turn Signals on 2k
  212. ECU reset and advanced timing
  213. New Sirius S-50 Install
  214. Need Wheel HELP! BBS LM
  215. Engine problems and transmission problems ohh my! Please help
  216. 2000 SE Cluster
  217. plz HELP!!
  218. iPod in '01 MAX
  219. Opinions needed please
  220. 22" Rims on a 5.5 Gen?
  221. Is it Possible to put 6th G steering Wheel into 5.5 Gen
  222. HELP! **scared**
  223. Strut replacement - Did a search
  224. The definitive Navigation CD THREAD!!
  225. will 300ZX 30mm TT iron big brakes fit our stock 17" maxima wheels?
  226. Problem with power steering..
  227. Auto Tranny Problems with 59,500 miles on the car PLEASE help
  228. Wheel question :)
  229. Import Intelligence...
  230. 2k3 max
  231. Lighting Options for a 2000 max
  232. trim level question
  233. D2's vs. Illuminas + S-Techs
  234. WTB: anniversary sills in grey and anniversary pedal for auto
  235. Options for rear valence and skirts
  236. Highway Shutdown
  237. 5th gen tranny question
  238. Maximas with the H&R drop. Post pics here.
  239. INcabin Micro air filter
  240. exterior body 00' maxima
  241. Where to buy Redline MT-90?
  242. Other possible auto trannies in a 5.5 gen
  243. wheres all the ladies???
  244. My gas mileage sucks!
  245. A32 5spd in a 5th gen??
  246. tranny clunk
  247. cold air intake
  248. timing
  249. New MAF & Dealer says no ECU Reprogram needed
  250. Rim question
