- Subframe aka Suspension Member installation?
- what should be my next mod?
- problems makin my GAB
- Check engine light after injen Cai
- footwell lights
- front brake conversion
- Handling + reliability = Non existent?
- Poll: '00 - '01 taillights vs. '02 - '03's (OEM) POST PICS!
- trip computer
- Any Fellow 5th Geners Have Sirius? How Do You Have It Mounted?
- Lifetime of OEM HID bulbs and cost in changing
- surging and bogging during acceleration...
- Stolen Headlight Lawsuit
- Leather seat switch
- CF Hood feedback
- Otto Racing strut bar is on :)
- ANother speedo question
- Got bad coils? I tested and only replaced 2. How to w/ Pics
- aftermarket strut mounts?
- Rumor I've heard before on the org is false
- Changing belts
- Aftermarket LSD options..
- crunching noise - axels?
- what is the bulb #?
- noise problem need help
- newbie question
- cant decide eibach or tien h
- Ebay Eyelids
- Mid RPM stutter, MAF bad again?
- leather seats question
- Air Conditioner Recharge
- Ethanol In Gas
- Ethanol In Gas
- Need pics of the stage 3
- (2k and 2k1) seats VS (2k2 and 2k3) seats
- Cant decide tein h or eibach w/illuminas
- OT: Freaky Altima Question
- "Black Box"? Does the 01 Maxima have a "Black Box" that records data. (speed etc...)
- Nissan Settles in Stolen Headlight Lawsuit - NJ
- loud and high pitch engine sound. What happened?
- cattman rear section...
- Odd noise after shutting off my max
- Just pulled a P0011 and P0021
- Suspension HELP PLEASE!!!!!!
- My New HU and Orange Led Climate Control, Swithces, etc
- has anyone here switched out the high beam bulb?
- Moonroof Issue please help!
- New Engine??
- question about re-wire
- d2r bulb upgrade
- screeching window noise
- Light behind the fan control went out....
- 100w foglight bulb in OEM housing
- Bumper repair...
- I don't feel very intelligent right now...
- final masterpiece
- Odd driver's window issue...
- 100w fog bulbs in 00?
- Need help removing driver's side vent
- Pimpin' tinted windshield?
- Whats up with FWD
- Part # needed
- Will this dash pocket fit?
- do you think its worth it ?
- front end links???????
- O2 sensor prob P0138 2k Max
- I hate the Power Window... arrrggghhh
- Power Window Grinding Issues
- I blew the motor, nissan's paying for it.
- VB removal write up
- Part numbers for AE auto shift knob, engine cover?
- Owners of BBK (Step in)
- engine hesitation
- New Leather Seats
- Thumping while hard cornering?
- AE headlights
- headlights
- safcII/vafcII
- How much do ya'll still owe
- dde wiring question...
- I'm Back!!!!!!
- dash repair
- Squeaky Belt
- car shuts off when i rev up the engine
- from cai to short intake, good or bad?
- AMB temp button
- speedo question
- need help on muffler/exhaust
- My Maxima got HITTT!!!**PICS H.Quality**
- Anyone know about the CP-E Intake?
- Has anybody painted their headlight housings?
- ebc brakes
- Fuse for Gauge Needles, Odometer, and Reversel lights...
- GLE Suspension or Aftermarket.???
- People with Headers
- quick question?
- Buying FSB. Anyone get the eBay ones? How are they?
- ACC light bulbs....*******it
- warranty ?
- Wiring in o2 simulator.
- removing stripped NUT! HOW?
- Back up camera, need help!!!!!!
- Need Advice
- Rear Sway Bar Project - Need Ideas
- SES question
- rear fog light
- fixing small leather scratch
- Climate Control question
- Abbreviations Terms
- Installed Alutec FSTB...but problems
- Clear/Stock Sidemarkers & Bulbs
- 2000 SE 5 Speed, Very Rough Start
- ADM Maxima Pictures
- performance help
- Troubleshooting Misfire
- B-Pipe Removal
- keyless entry
- Reset Ecu??????
- Are these taillights any different compared to...
- mileage driven till brakes needed service?
- memory seat neat feature
- Want to do it!
- When u replace one lower control amr, replace them both
- looking for a good windshield wiper
- Any other grounding kit install guides besides irish's?
- Part name? Where to buy?
- Wiring Diagram 02-03 Bose Changer?
- stock nav
- Accidental repair (look here before you condemn your trans "pics here"
- Brake Light Just Came On
- Any one had this before?
- Can someone help me find this part #?
- Clutch engagement
- ****. Both ABS Sensors Broke
- question about light(s) for 5th gen.
- P0430 Options
- Double Din for 5th gen??
- JWT oil pan spacer
- What do you think???
- 5 speed transmission leak consequences
- HIDs & Ebay Projectors 2k
- Technosquare ecu ????????
- Projector Headlight Retrofit 02 maxima *pics*
- 2002 – 2003 Maxima (manual) Turbo Kit for Sale!!!
- Pics after Hotshot header install 56k beware
- p0021 error code please help
- Just reached 40k in mileage...what maintenance do you suggest?
- '00 Max - Too cheap for HIDs... what do you suggest?
- Door Inserts.
- VIS Hood Latch Help!!
- P0420 ECU update help
- my JIC A1s are rusting!!! what to do use on them?
- Accelerator cable and throttle drum spring loose
- Transmission problems. 2 codes pulled.
- IPOD mounting need help!!!!!!!!!!!
- Vias problem
- question about y pipes
- 2 Quick questions..1st interior..2nd exterior.
- Few problems I have noticed
- How to make a gauge cluster brighter
- is this too cheap?
- HID reverse lights
- Do you have issues with HID going off when high-beam is on? Here's the fix...
- FSM 2001 manual
- any1 gone from auto to 6 speed on 3.5
- Ghetto Air box using coat hanger
- Lookng for sound clip
- Do you have a 1/4 mile timeslip or time for your 5th Gen?
- Dyno tune after header install
- What else do I need to install these cams?
- Power Seat Blues
- How do I fix this?
- IPOD Hookups
- Pics from dealership of Cams with Cam journal caps off
- Help With Muffler Posting
- changing PS fluid, a few questions
- ZENN springs??
- Will these fit my car?
- front rattling noise over bumps
- Would you buy a car with SFCs?
- fuel filter location?
- H&R vs Eibach coparison!!! Pics inside.
- A Weird Turn Signal Issue...
- Traded in my 2003 Max...
- New Engine & Header Install Question
- how many '00 Max with engine cover mod out there?
- Can someone tell is nissan trying to play with me?
- Updated (grey dot) Ignition Coil: GOING BAD????
- Question about installation tein s tech & illumina 2000-2001 maxima
- 5.5 gen w/OEM gauge rings - how to install chrome ones?
- Feels Like Slipping!! Help Please!!
- Really Simply Question...
- HELP!!Tried Switching LEDs doing Metals New way!! Help
- Had the shop inspect the cams and Heads Here are digital pics of them
- Question about keyless entry...
- PIAA Xtreme White Foglight Install
- clicking noise when accelerating
- MAF question
- Engine Replacement Question
- 2000-2001 Airbag light
- Anyone else having trouble with backorder parts?
- Any regrets w/ 19's & mild drop?
- Are 15mm spacers too large for the front?
- buying a 02-03 soon need advice
- Does anyone know how to change the whole windshild wiper.
- Replacement K&N cone on Injen?
- Everyone is saying H&R can't bottom out but.....
- Needs y'all opinion
- SES light: OBDII code p1336
- My car rides like stock now! I'm so f-ing happy...here's what I changed.
- Replacing Springs/ Shocks this weekend...
- I need specific VQ35 info
- Anyone has Tokico springs.
- 5th Gen Suspension Thread
- Replace parking light lens in 02-03 headlight
- Headlights and Insurance Adjuster
- Are H&R 5mm spacers hubcentric?
- Quick Question
- So, I jsut changed my ignition coils
- rpm?
- How to Properly Troubleshoot P0140 Code
- Front side markers as turn signals
- Snug fit??
- Detroit
- Any thoughts...?
- New custom gauge overlays & XM-Receiver
- Greddy Evo2
- Cattman Headers
- 02 Max what exhuast option's in '06
- THE YELLOW BULB vs LEXUS CAPSULE OFFICIAL COMPARISON...head-to-head!!
- Need to know about the Bose Head unit
- Eurodezigns HID warranty
- 4th gen hacked airbox, possible with 5th genners?
- crashed my car a while ago here are pics
- What's your opinion on this trade?
- Budget Exhaust Phone Number
- Photoshop please
- Removing rear sidemarker light
- MaxxTuning lip and stillen rear, pics...
- pre cat solution?
- Fog rewire instructions
- help...click/bang noise when turning wheel
- Best Navigation Unit ( If money is not the issue)
- Alternator Blown
- URGENT!!! Please Help! Ignition/Safety Cutoff Problem..
- Lip spoiler
- 2k2/2k3 ingnition coils
- front bumper repair
