View Full Version : 5th Generation Maxima (2000-2003)
  1. Question after exhaust install.
  2. opinions on aluminum flywheel on a 3.5
  3. opinions on clutches for 6 speed
  4. Brake nightmare
  5. abs wire snaped
  6. HELP!!! Possible Cracked Head?
  7. ECU reflash for MAF
  8. So 2 months later and still no car
  9. can't see giving dealer $450 to replace
  10. Is this good deal for 03 Se?
  11. engine bay wash
  12. going to the dealer...question
  13. Pros & Cons
  14. Another Newbie ?
  15. Let me see your interior pics!!!56k no way
  16. Need help Guys-possible blown fuse
  17. code help!!!! PO740
  18. Which set up is better? Also Weekend Painting Project Completed (5 Pix included)
  19. seat heater issue
  20. Tranny
  21. front strut bar question
  22. Need More Performance!
  23. Bottom Front motor mount leaking - replacement?
  24. How are the options packaged on the 5.5 Gen?
  25. auto es motor mounts
  26. 20's yes or no?
  27. Header video
  28. 6spd swap
  29. VIAS question...
  30. sound clip of GAB
  31. question about my stock wheels
  32. HID Wiring Diagram (For 2K1 to 2K2 Swap) Needed!
  33. First Maxima Test Drive
  34. Just purchased an 02 SE. New to the 5th Gen family
  35. 5.5 gen, more reliable than the 4th gen?
  36. want to Change Foglight setup
  37. Question for those with 5mm wheel spacers in the front
  38. Swapping in a 3.5L
  39. nyone with H techs...any axel or other issues?
  40. 00 paint code ?
  41. Need help, Navi is not retaining is location settings
  42. Anybody here on the .org?
  43. how to prevent bolts from snapping off!?
  44. Rear clunking
  45. WTB headlight housings Both R and L
  46. What year was your Max manufactured?
  47. HOW TO: Fix Amber to Red Conversion Paint Leakage
  48. g35 18" wheels for 02 maxima
  49. So where is the thermal flasher located?
  50. AMBER TO RED CHROME TAIL CONVERSION PROBLEM: Immediate Help Needed!!!!! (Pics**)
  51. Determining which TSBs/recalls I need to do?
  52. Can anyone tell me part #'s for these interior parts? (pic inside)
  53. 00 Front Grille Photoshop **PICS** opinions needed
  54. A question about stock '03 Maxima wheels.
  55. NEW 01 for me
  56. Cleaning throttle body with Sea foam...
  57. something is clicking in throttle body area
  58. Nissan Emblem ?
  59. Should I have my VTC Sprocket Replaced
  60. Throw out bearing noise?
  61. Where To Buy A New Donut Spare Tire?
  62. energy suspension bushings
  63. Blower Motor Noise
  64. what to use on cv boots to keep from drying out?
  65. Dtc 0171
  66. 2001 max V1 wiring question
  67. BLACK projector headlights
  68. Need your advice on A/M headlights
  69. do i need a fuse on this line
  70. p0455 and p1448: FIXED.
  71. DIY Transmission replacement (11 pictures; 2.95mb)
  72. Considering getting a 5.5gen 6spd
  73. first impressins on my 4th suspension set up...
  74. POS RainEx wiper blades (do not buy!)
  75. Help: Car will not crank and start
  76. question to the masters of 5th gens..
  77. New to the 5. Gen
  78. who around jersey can do an advanced timing for me?
  79. Goodridge stainless brakelines model 22133 fit 2002?
  80. OPINIONS needed....keep new grill or leave stock?
  81. rims and acceleration
  82. Thumping Noise in Driveline problem
  83. Tranny harness?
  84. Question about my new HID low beam/mini-H3 kit
  85. where can I buy a clear brake light for my spoiler?
  86. How to properly lift car?
  87. P1320 and P0420 - Anyone had this combo?
  88. PICS NEEDED: Your 5th gen painted ABS lip & experience...
  89. Remote Starter Kit
  90. got my 2k2/2k3 headlights :)
  91. exhaust question > 4 u exhaust whores
  92. MacPherson Strut
  93. Natl Autocare warranty f@$#ed me over
  94. Headlight Plug
  95. Thoughts on Extended Warranty?
  96. how does one test O2 sensors?
  97. 2k2 Headlight Black-out Help/Advice
  98. Maxima.org Stickers
  99. HELP alternator replacement
  100. wheel size
  101. "Reprogramming ECM"
  102. my hand is to fat cannot reach
  103. 2000 GLE at 60,000 what can I expect?
  104. shaved
  105. Question on Stillen + ABS Dynamics front lip 00-03
  106. new illuminas/springs...have 3 install questions
  107. How Can I Get My Trip Control To Work Again?
  108. hey 5th genners!!!
  109. blah blah blah another question
  110. HotShot Headers
  111. Blinker bugging out
  112. Jack points,,,etc
  113. what could that be?
  114. Solinoid Valve Assy.
  115. Need help with Spring Rate for Ground Control springs.
  116. What other suspension parts are needed?
  117. Greddy exhaust
  118. maf nightmares need help
  119. Freshalloy meet?
  120. Gunmetal with silver lip OEM 17's pics
  121. Wheel spec I need Help (Advise from experience)
  122. Bad Cv Joint ????
  123. Questions about Nav Disc
  124. Walbro 255lph fuel pump
  125. Looking at a 2002 6 spd, with 35k miles, $15k
  126. Bulbs behind 02-03 Gauge cluster
  127. 2000 a/c noise....??
  128. Overheating!
  129. Anybody run the Halo fogs from ebay?
  130. 2k se gauge w/o tcs in 2k gle w tcs; workable?
  131. hints/questions on changing manual tranny oil
  132. Something to plug license plate holes with
  133. Got my car back from the shop *pics*
  134. replacing coils and MAF
  135. Bose just ate my CD...
  136. Spark Plug color... running lean?
  137. deciding on front spacers
  138. Wheel bearings..how much play is ok?
  139. Has anyone fiberglassed the Stillen AE valences into the OEM bumpers?
  140. Code pulled - P1706 how to fix?
  141. Which spark plugs to use with timing adv?
  142. Sat. Radio Install pics
  143. 02-03 maxima headlight retrofit **pics**
  144. Got my MAXIMA Fixed ***(PICS)***
  145. e-break questions
  146. Help A/C Fan or bearing makes a loud noise
  147. Vias Help Needed Immediately
  148. 00'SE Grill Opinion
  149. vias screw removal
  150. What 17" Tires for 2000 SE 5 Spd?
  151. 19s which offset and width??
  152. give me your vin and I can check it on carfax
  153. What are the difference in trims for 5th gen
  154. for thos looking into brakes
  155. Any thoughts on Burgundy colored 2002-2003 Maxima
  156. How to check continuity of MAF
  157. Illumina hardware
  158. Windshield wiper "click"
  159. need part number for 2000 fed manual ecu
  160. Trimming 3/8 off front hub?
  161. Injen intake air filter?
  162. Performance problems.
  163. Those going to performance nissan meet
  164. Brake making weird noise
  165. Need help getting educated in spring/strut combos
  166. odd question about rear bench
  167. where to get driver's leather seat?
  168. Race!!!
  169. 05 Altima SE-R exhaust, can it go on 02-03 Max?
  170. well had something break today
  171. Pay to fix or go new??
  172. OBD II scanners who has one?
  173. 1-2 Gear Slip After Tranny Flush
  174. 3rd gear grind
  175. 18" 04 SE rims on a 00-03
  176. High pitched noise when rear seats are removed
  177. Strange sounds (like lots of little rocks hitting car) after car starts
  178. 300zx bbk...w/ 2 piece rotors?
  179. 15 or 20mm spacers in rear
  180. Hlsd?
  181. where can i get O2 sensor?
  182. Where can I buy KYB Bumpstops?
  183. Exhaust Suggestion (Cattman)
  184. LED tails......pics are up!!!
  185. Videos on the .Org
  186. help with tranny pan bolts, please
  187. DDE Cold Climate Ballasts
  188. Im going to be a 5th gener soon
  189. Tein EDFC w/ FTSB
  190. opinion on springs
  191. Bulb Fitting
  192. BACK UP CAMERA was it easy to install?
  193. Where the hell is the ecu
  194. Where to go to put in a DIFFERENTIAL??
  195. tune up
  196. Steering Wheel Stereo/Audio Controls
  197. steering wheel controls
  198. Fidanza Question??
  199. Something hit my headlight, now its loose and aims low
  200. Cattman Gen II Headers Installation Experience and Related Thoughts
  201. Where can i get a good deal on stillen sides..
  202. Pictures of retrofit 02/03 hids anyone???
  203. O2 Sensors went out!
  204. 5th Gen 18" Murano SE Wheels Gallery *PICS*
  205. uh-oh o/d light flashing
  206. problems: need advice..
  207. 5.5 gen intake mod?
  208. Installed my AE modded Headlights Tonight (pics included)
  209. why does my car run like crap when warm???
  210. 5.5 gen problem
  211. Wow resale value on 02’s has dropped dramatically.
  212. My clock stopped working
  213. Remove stock 02 side skirts for Stillen's?
  214. P0420 Code - Still a Bit Confused
  215. ES Shifter Bushings & Watkins STS
  216. Illuminating clock on 5th gen
  217. just my thinking?
  218. Oem Leather Installation
  219. Broken Sunglass Holder Latch Fix
  220. WTF - This is crazy
  221. need exhaust
  222. cALIPER BOLT HELP!!!!!!!!
  223. 5TH gen tail lights
  224. MY AE MOD - pictures
  225. 5.5gen Foglight Cracking Dilemma?!?!
  226. New Tranny...AGAIN!
  227. moon roof
  228. 5th Gen Bose Fix How-to
  229. What two-tone color combos for Katzkin seats
  230. How do you get the VIAS box off?
  231. Intake poll
  232. How to AIM headlights on '01
  233. Removing power rod from Intake manifold
  234. Mobil 1 or Royal Purple?
  235. Steering wheel off/not centered
  236. Xenon headlight question
  237. Polarg Yellow Foglight Bulbs INSTALLED
  238. pcv valve question
  239. Anyone with Sterling Mist and white wheels?
  240. intake installation questions
  241. dde owners: Am I missing something?
  242. Got Angel Eyes/DDEs ? Post Pics Here
  243. How much for side skirts off a 5.5 gen
  244. Anyone with timing advance notice ...
  245. Stillen RSB
  246. limp mode.... darn
  247. noises for a newb
  248. Roll cages?
  249. Performance!!!!!!!!
  250. Would you guys want this???
