View Full Version : 5th Generation Maxima (2000-2003)
  1. Body kit
  2. Photoshop gurus...Help a brother out w/ my grill
  3. I Need Pictures!!!
  4. Should I get a 4th Gen or 5th Gen? Biased opinions welcome
  5. SES light on P0021 "cam advance..."
  6. Sunroof question
  7. Need a name of the part on 2001
  8. Rear side marker bulb stolen? Need bulb part/type
  9. where can you get a stock airfilter hanger?
  10. Need answer about GAB by 10am
  11. suspension related question
  12. Those with FrankenCar Intake VQ30
  13. hid on ebay
  14. weird grinding noise from front left wheel well
  15. Japan Spec Y Pipe????
  16. hmm.. air question
  17. installing new suspension
  18. New Cattman exhaust question
  19. MY 02 6spd on the dyno
  20. UD pulley
  21. Eclipse Avn Guys Need Help!!
  22. Electrical problem ???
  23. car stuttering anyone else have this problem?
  24. Abnormal Rear Brake Pad Wear
  25. ABS Light On
  26. Strut Boot help - in need of Replacement
  27. 2k1 Fog bulb replacement
  28. SES P0430 - One owners solution
  29. Finished black Housing Mod :)
  30. nopi discount codes
  31. Led Project Need Help!
  32. Squealing noise upon acceleration?
  33. fog light fuse
  34. 1999 rear stabilizer bar on 2000-2003 car?
  35. what bulbs to use in fogs
  36. does anyone have a picture of a berk or fc intake pipe?
  37. the best fuel injector cleaner
  38. to all those who have problems with there fuel door sticking
  39. Headlight Bulbs?
  40. KYB GR-2 with maxspeed springs
  41. Bad Fuel Economy, What Can I Do?
  42. Question for tint experts
  43. 01 painted splash guards
  44. where is the fuel filter on a 2000 maxima
  45. Fuel pressure regulator install questions???
  46. Philips Ultinon
  47. Which Ypipe?
  48. where is the swirl control valve ?
  49. show me pictures of ae from the rear
  50. Taking the GAB to a whole new level :woot:
  51. rear ae for a 2k questions
  52. ae side skirts - 2002-2003
  53. K&N Air Filter HP gain
  54. Emergency Help Needed
  55. 2k2-3 hids with different k rateings post pics here
  56. I need help on head lights...
  57. 03 fuel filter question
  58. Q I installed 9004 8000k hids in my 5th gen
  59. Please help!!!... my fuel door wont open
  60. Decoding my VIN
  61. Which tires for Maxima: BFG Traction T/A or Yoko V4s?
  62. Wiring Up the Viper 791XV to Open Trunk
  63. cut bumpstops with h&R?
  64. Just GAB my se
  65. Looking to step up
  66. Apexi AFC
  67. Poll: Red,Clear, Smoked, OR SE Tails
  68. New tints
  69. Electric Window Lag!!!
  70. Spark plug recommendation??
  71. 2003 Max / Help
  72. question about umnitza (kinda)
  73. U Tell Me.......................
  74. Side Marker lights
  75. Bose Stereo Rear Deck Bracket Ordering
  76. leather cracking on drivers seat. Options?
  77. Need a favor from EVERYONE with lowering springs
  78. I want a new feature for my headlights...
  79. coil packs
  80. need opinion for tein stechs/illuminas please help
  81. maxspeed vs h&r
  82. Wire Loom, need opinions from Pics
  83. 17* timing problems
  84. short shifter
  85. The trunk mats...
  86. Coil source please
  87. Help! Seafoam Moron!
  88. Show Tinted Windows
  89. FrankenCar cattback
  90. CF hoods shaking?
  91. Body shop was trying to get me for my cookies...
  92. Anyone bought the Helios HID Bi-Xenon ?
  93. Total Noob. Please help.
  94. Side Marker Lens Replacement How To?
  95. Post Pics Of Your Dvd_navi Unit
  96. Parking light bulbs to match HIDs?
  97. stillen vs ae kit
  98. Turning PowerSlots...
  99. "custom" intake
  100. 2k1 se gauges with rings in 2k gle
  101. SeaFoam How-To....?
  102. 02 fog lamp replacements
  103. TSUDO Exhaust
  104. Switching Headlamp Relays
  105. Re: Injen Intake Replacement Filter
  106. Hood pins
  107. bad ignition coils?
  108. FWD to AWD conversion
  109. Electronic Damper Control
  110. Y-Pipe emissions
  111. I35 gauges in maxima Help
  112. What fuel pressure regulator do you use?
  113. should i cut bumpstops with maxsped and blues?
  114. SeaFoam Testimonial
  115. Can you make an intake for a 5th gen
  116. what is that scoop part?
  117. made a board for the trunk
  118. When do you replace your drive belt?
  119. 6 coils Scoped. Results inside
  120. CA vs Fed spec emissions for 02+
  121. Cloth vs Leather, is maxima leather good leather?
  122. maxspeeds and tokico blues
  123. egr valve thoughts
  124. www.hi-tecdesigns.com possible GD? Check this out..
  125. pcv valve pics anyone?
  126. Nissan Dealer vs Dealer vs Private party...which would you buy from?
  127. Hesitation 1-2 shift
  128. Info on European Maxima...
  129. is this rice
  130. help...rubber to metal squeek when wheel turned left
  131. Does this sound good? *Brake Pad + Rotor*
  132. Suspension sounds?
  133. Front Sway Bar
  134. Opinions on Black headlight housings...
  135. Options for side skirts?
  136. what size is the wipers side driver n pass
  137. Front Bumper Conversion?
  138. Squeaking noises from front passenger wheel well...
  139. Air Intake temperature Sensor
  140. fogs will not turn on
  141. Issue with Heated Seats
  142. where 2 get maxspeeds
  143. seat heater dowsn't work need help
  144. Hyperground installed...
  145. Generic P0300 random miss fire?
  146. Finally got my Max today!
  147. Possibly warped intake manifold question
  148. whats needed to install 2k2/3 headlights on a 2k max?
  149. A little vid testament to the Maxima Superiority!!
  150. ok, just did seafoam...a little worried..
  151. 2000 SE Coils Help
  152. Intake valve timing control bank 2........
  153. Which battery to get???
  154. Auto Climate Control Bulbs burned out.
  155. Bose unit CD player fix?
  156. blower fan... HELP
  157. Why is it always me?
  158. Oil Leak, Help!!!
  159. Want to lower car
  160. Help please...Wider in Rear? (I mean WHEELS, not my girl)
  161. Intake Question
  162. How many people bought "Nissan Certified Used?"
  163. Brake Problems...dont know if car is safe to drive
  164. VB mod question..For those who have done it.
  165. Tein EDFC + FSTB fitment issues?
  166. first new post
  167. EGR Port: Question...
  168. Effects of using cheap, regular octane gas for 60k miles
  169. Extended Warranty ??
  170. what are some common oil leaks on the de-k that i should look for..
  171. Anyone install aftermarket heated seats?
  172. Heated OXY
  173. easier way to check ignition coils
  174. 2002 Brakes Feel Low
  175. So whats the weirdest thing thats ever been stuck on your maxima?
  176. Paradox Systems Cefiro Coilover System
  177. K&N filter part number for PR CAI: anybody have a part number handy?
  178. where is the tranny grounding pt. on a 2k?
  179. JDM style headlights and 01 SE wheels painted benz silver
  180. Aftermarket struts and stock springs
  181. Considering 02/03 Maxima but I have Reliability concerns...thoughts on this???
  182. opinion on suspension
  183. Splash Guards
  184. 5th Gen. related PC software
  185. fog light bulbs
  186. headlights decision
  187. Got my new 02 today!
  188. someone make us this rear window spoiler..please
  189. Twin Turbos on a 2000 maxima
  190. Random question....battery tie downs...
  191. Accident, what options for front lip?
  192. Which theory would be right?-Coil related??
  193. basic rims question
  194. CE Grounding Kit Install..
  195. Missing Foglight 02 SE
  196. Brake woes...(Brake pads)...opinions? (Akebono Vs. Hawk)
  197. Nissan aftermarket warranty???
  198. Info f-sale 03 se maxima
  199. Accident: SideSwipe Bumper
  200. car dying on highway...dash lights on
  201. Quick help needed 2001 AE
  202. Comments on this ODB-II scanner? Good/Bad?
  203. Finally about to install coilovers....
  204. Anyone lowered just in the front?
  205. need pics of engine bay fuses, starter relay
  206. Ah... the great suspension question.
  207. Factory Anti theft alarm going off on its own
  208. Wheel Width 2000 SE 17"
  209. blown tokico illumina?
  210. My Poor baby in an accident
  211. Seafoam saved $$$$
  212. thinking of buying another Maxima questions
  213. new wheels on TSW Thruxton's...check em out
  214. battery light goes on with start-up
  215. Please help with Parking Lights/Blinker Bulbs
  216. Interior Lights & Remote Control DEAD - what the heck?? help!
  217. 2000 Max ECU cyclinder map?
  218. Install instructions for IPOD in 5.5gen
  219. Removing the BOSE Headunit.
  220. Sunroof not opening (2002)
  221. throttle cable slack
  222. 2003 max / help please.
  223. cv boots
  224. Custom Enterprise High Flow Cat
  225. has anyone tried turning up the torque bolt on the side of the intake manifold????
  226. considering some changes............... ?
  227. Yes, its an opinions thread...
  228. Does everyone with an intake have SES light ?
  229. Does everyone with an intake have SES light ?
  230. Weird voltage problem, meter says at idle I'm at 15volts
  231. no cel codes and still this problem
  232. Opinion on rear H&R 20mm spacers
  233. technosquare L-Spec
  234. HID question
  235. anybody red-out front turn signals?
  236. Cattman Exhaust System
  237. Neoprene Mounts for Exhaust System
  238. absolutly no pick up
  239. How to regrease rear axle bearings?
  240. Engine Mount/Motor Mount Noise
  241. The Best Cams
  242. tranny queries.....
  243. Shift Kit
  244. BLUE BATMOBILE overlay kits..
  245. New to the 5th gens
  246. newbie questions
  247. Clear Side Marker Installation
  248. ABS dynamics front lip owners step in..
  249. How to for ebay projector w/ TSX lense?
  250. Automotive Paint
