- Not a big fan of body kits, but...
- ABS light
- Smoke Problem...anyone???
- Idle Air Relearn..same on all 5/5.5 gens?
- WTB Maxima, pillar speaker, drivers seat, front grille emblem
- a\c issue
- EYE LIDS OR NO EYE LIDS THATS THE QUESTION
- funny wheel problem while driving
- Berk Intakes
- p1572 and metal sound mean seized caliper?
- $150 to put on brake pads????
- KYB GR-2's and H&R springs installed
- Noticed some clicking
- Any of you guys try the Rain-X Latitude or Bosch Icon windshield wiper blades?
- what would u pay?
- How to beat the CEL fiasco in 5th gens for car inspections
- Driver's door locked, latch rusted. How to open?
- VQ Removal Procedure
- 5th gen drl module
- Got a Problem
- Fog light Rewire Problem?
- WTB exhaust w/connecting pipe and .....
- 1/4 rust repair
- Stalling and bucking issues
- Changing Front passenger Driveshaft
- anyone know how to eliminate knock sensor?
- Ride Height Adjustment Options...Coilover or Shock
- 2003 SE Maxima auto tranny slip questions
- Clicking/ Scraping Noise When Turning Right
- Overheating Part 2
- rotten midpipe
- Prep for paint help
- Stock 5.5 Grille Paint Code?
- Megan Racing OE-S... Anyone else waiting???
- Driver's 1 touch - doesn't
- Quick, dumb PCV valve question
- 5th Gen Exhaust Opinions
- My parking lights have a mind of their own!!
- A question to anyone here using Cryo rotors.
- 3.5 liter engine
- SPRINGS.....wut u think
- Cabin air filter
- Changed axles now struts?
- Best Strut mounts?
- Transmission/clutch issue? 6spd
- Can this be done?
- Swirl Control system
- Overheating, but before I buy a new radiator...
- 5th gen tire question
- Quick Tailight situation
- Has anyone tried these LED Tails?
- exhaust rattle...not a ypipe rattle
- TANNY PROBLEM!!!
- GoldLine Springs
- The origin of most CEL, O2 sensor, CAT problems is coolant leak?
- Brake Job Turned Nightmare!!!
- maintenance schedule for maxima
- Sunroof stuck open
- Stillen Lip kit over 01AE kit?
- A/C Problems
- went to squirell82 again
- Air Conditioning Problem
- Megan Racing Springs. serious drop...
- Gutted Pre-cats...now car smells like exhaust in cabin
- Lug pattern
- Help with P0430 code! O2 sensor Guru's step in!!
- 100k Trans Fluid Drain/Fill
- Goodbye Great Maxima Forum
- What happens if you replace MAF and do not reprogram ECM?
- Bose sub upgrade to 10"?
- CD player issues
- What is this stuff called?
- How low is considered slammed?
- sts mod question..
- Spark Plug Failure + Mess........
- muffler - rear section only?
- my very dirty engine
- Hitachi Boost Sensor?
- OEM Touch up SPRAY paint
- Radiator Replacement Writeup
- Just installed a Progress RSB – Thoughts and Questions
- Valve Cover Spark Tubes
- Door trim removal
- Where to find the paint code?
- Looking for certain pics.....
- Upper intake removal
- Radiator replaced... SES?
- Repair the Repair, Pt. #2: When in neutral, RPMs spike when wheel turned...?!
- Repair the Repair, Pt. #1: Shaky Steering Wheel...
- Ball Joints / tie rod
- G35s wheels?
- Clutch disk Q
- Help please...weird thing happening, car dies with no warning
- diminishing range on keyless entry
- Changed the Alternator and now I've got all sorts of crazy noises.
- You Gotta be friggin me%^$%
- Lower oil pan leak!
- Need Help!?! What the heck is going on with my car..?
- Rear strut is shifted out of place...pics
- heat and A/C dont turn on
- How can you make sure the a/c is cold as possible?
- anyone clear their hids without replacing lense?
- Clutch line bleeder screw size
- NWP spacers/Oil leak problem
- WINDOW SPOILER...
- TRADE IN VALUE
- TEIN'S...help
- What did I do to my exhaust??!
- $320 maintenance day!
- Camshaft Sensor Bank 1??? P0340
- Used Axles, what to look for?
- Rear Main Seal
- Strange pop/tack/tick noise
- HEaD LIGHT DIFFICULTY...HELP
- we've all heard of the 3rd gear crunch..but...
- A C Question/Noise
- Header Flange Smoothing - More Needed?
- ghetto rigging hid headlights.. opinions and answers please!
- Fan Noise
- Tips for painting my evo5 wheels
- no AUX lights, no dashboard illumination
- Remove LCR To Replace Axles/Boots
- 5th GEN Automatic blues!!
- Valve noise
- 5.5 gen engine cover swapability
- Auto rolls back on hills now...
- Ordered KYB GR2s what else to get?
- Opinions on a possible sale of a 02 blk/blk 6 spd/nav with blown motor
- bank 2 sensor 1 where??
- Changed the Radiator....nice and easy.
- EVAP 0445 and 1448 dealer said autozone cap is problem....
- HP Design Springs
- Re doing my Tailight
- Ebay Catback exhaust.. Any good?
- Failing exhaust?? If so where do I go from here??
- Necessary to replace mounts same time as struts?
- Climate Control Temperature Problem
- Homemade intake
- What is your highway RPM?
- Brake Pedal ?
- weird shifter problem
- point me in the right direction???
- Tried to hollow out Precat = FAIL
- what are my options - exhaust
- rsb from 99 into 5th gen?
- Tire Comparison: Nitto Invo vs. Nitto NT05 vs. Nitto NT01
- Just replaced power steering high pressure hose
- ABS brake light on
- Manual swap
- THE HOLY GRAIL OF BODY KITS IS FOUND - Anniversary Edition
- 6th gen rear brake upgrade
- Anyone rebuild there progress coilovers?
- Steering is becoming loose...
- (Update with Pics) Wheel Spacers installed
- Coolant Spray... (pics) This ever happened to you???
- Comments on Autel MS300 OBD Reader?
- Strange problem: Brake light on, hard pedal
- Stillen Rear Lip Mudguards off ?
- Thinking of ordering these Wheels! Opinions are Welcome
- always something.
- Trim Question
- Just installed new ECU, car cranks, won't start
- A.C gurus please step in
- Why is car knocking at 3000 to 4500 rpms?
- 02 vs 04
- ohh boy....engine misfire problems
- how can i tell the difference of a fed-spec ecu to a cali spec ecu?
- Transmission Bolts Size and pitch
- How Long Does It Take to Break In!
- maf sensor tabs broke off.
- please help car wont start, not the bat/alt
- car shop question
- Help finding Blehmco LTB2 instructions
- 5th Gens at Maxus
- Well, Its happened.. again... THIS YEAR!!!!!!!!
- Maxspeed Springs
- Well it's been fun
- CD player sucks..
- got rust? rear fenders, next to door both sides... replacement?
- Failed Emmission
- Why do people do this?
- Advance Timing
- Seat belt thingy
- Lower control arm
- 03 max spark plugs info
- lifter noise after oil change?
- 5.5 Gen Xenon Bulb installation help
- Blower Motor
- is it just me or the car?
- Steering dead zone
- Maxima got tagged by a motorcycle
- Harder to stop =/
- Head light Removal
- Anyone else has this problem in the Heat
- best factory replacement shocks
- A shot in the dark... Megan Catback
- Trans Fluid question
- Popping out of 5th gear on the highway
- Poll: What Brand Suspension Parts Do You Prefer?
- How to paint front lip?
- Can a bad O2 sensor make the car run like crap?
- ATTN:REGARDING THE 6th GRN BBK UPGRADE FOR US 5th gens
- Rear end noise
- taking the maxima to Z-Max dragway
- DIY: Steering Bump Cap DIY Replacement
- Tokico Illumina lifespan
- Pioneer AVH-P4000DVD ipod interface doesn't charge iphone
- New exhaust system needed
- 03 trunk won't open
- ASSISTANCE PLEASE
- Thinking about getting a...
- Strut/shock mounts
- Car wont rev above 1000-1500 rpm?? Help please!!
- 02 fogs modified
- Did I install my o2 simulator incorrectly?
- Help! 02 Max 6spd 0-60 in 10.28?
- Meter Fuse Blowing when put into reverse
- Cefiro Center Console
- Precats p0420 yada yada.............
- quick bose question.. asap
- The REALLY definitive 6th Gen BBK with great pics
- I am thinking about buying this and putting a surf rack on it Dawg!!
- i got a promblem....
- No tach/Speedo/Gas/Temp or info!!?? WTF
- oil in intake tubing
- Rising RPM's??
- where did you buy your strut mounts/bearings
- P0505
- official idle relearn for 5.5 gen maxima(02-03)
- VQ35's step inside
- Cost Benefit: Put 2K Miles on Car or Just Rent
- Vibration - need to confirm mechanic's analysis
- a.c still not cool... y??
- Apexi Filter Pricing - $55?
- LEDs = No Power
- Can spark plug coils be considered a "wear item"?
- windows roll themselves down in a rainstorm?
- stillin headers
- Strange Starting Issue
- Driver Window Not Rolling Down - Motor or Switch?
- back on the road
- *Unveiled* Pioneer AVIC - U, AVIC - X and AVIC - Z Car Navigation
- Odd Tranny Issue - random downshift 4th to 3rd
- Please Check This Diagnosis
- Are you serious 1,2,3,4.....5...where is 6th?
- Sunroof Seal Replacement
- Who's Happy With their HID setup?
- Strange window problem
- question for those with Exedy clutch
- tociko blues w/ drop?
