- Aftermarket suspension? Please enter....
- Budget Y-Pipe
- will 5.5 gen grill fit on 5th gen
- A question for people with Nissan service agreements.
- factory 02 upper grille or aftermarket?
- Creeking noise on rev
- New struts and springs (parts question)
- need help asap headlight bulbs 9003?
- whats that little black plastic square on the front window edges?
- Resonated Exhaust Tips
- Y-pipe
- FUEL FILTER CHG @ 80k - HUGE DIFFERENCE
- 02 Motor Mount Question?
- For those with cleared out turn signal lens in HID's, what bulbs are you using?
- whats causing this metallic rattling?
- Reset ECU With Viper 791XV installed
- for non-donating members
- Question about wheel fitment
- Progress Drop and Wheel Spacers
- max watts on stock bulbs?
- nothing works!
- Kyb Agx???
- G35 rims on a 00 SE
- Strange problem anyone ever have this problem.
- Possibly Trading 02 Maxima
- optima battery reccomendations...
- 12V (Cigarette Lighter Holder) not working
- I officially have the weirdest Maxima problem ever...
- 99-01 CE Ypipe
- Custom maxima race pipe
- Does your car "Buck"?
- clutch
- Could my speedo be off?
- sorry bout the pic problem. Here are the correct ones.
- Tranny code name
- "knocking" noise during 1st gear wheel slip
- Noise coming from back of 2k during start-up...exhaust?
- boost chip for real?
- Finally changed the tranny fluid 6-spd
- 02 03 headlights OEM
- Hearing rattling when Gas is pushed half way...
- Concerns with the ses light
- limp mode?
- chrome rings or chrome bezel or both?
- Front Light Bulb Help Please?
- cheapest place to buy coils for 2k....
- where can i buy a shift boot
- what starter/security combo are you runnig in your 5/5.5 gen??
- Alot of vibration...
- does anyone have a parts list for 5.5's
- My smashed up 2k3 Maxima photos, and pics of my new rides
- 01 SE AT Tranny, Throttle body, EGR ? Please help
- LED Fogs!!!!!!!!!!!!!!!
- 2002 SE Cluster in 2002 GLE
- Radar detector not staying in place
- best bulbs for clear corners
- Check Engine Light PLEASE HELP
- Optima battery which model?
- maf award?
- Random suspension questions - opinions and rants needed.
- first thoughts on new suspension
- Tein SS adjustments/settings....TEIN OWNERS NEEDED!
- Has anyone sucessfully opened 02/03 fogs?
- ebay 00 spare key?
- Car Sputters and really laggy..
- Cheapest place to get o2 sensors from?
- Direct HIT??
- Projector Headlights
- 2k2-2k3 console
- Blown Instrument Panel Fuse....where is it?
- 6 spd. 3rd gear synchro?
- 2k2 Throttle Body idle adjustment
- anyone ever buy a xtd clutch off ebay?
- transmission question
- quick throttle question
- transmission cooler
- The turbonator?
- Pulley Question
- rapping/ping
- trans question
- How to replace front sway bar links?
- how to change the auto headlight time
- Trans filter?
- Quick question..
- HELP 5th GEN FOG REPLACEMENT
- Trouble installing front sway bar
- h&r wow! listen to what they told me
- Boring 2k1 throttle body...
- O2 Sensor Question
- INNER tie rod replacement?
- HLSD axle replacement
- Brake Caliper
- Changing suspension tomorrow, need some advice.
- ECM re-programming after installing MAF
- Whining noise after engine warms up
- 2nd gear shift lag
- Those with RSTB
- CAR Wont Start, HELP NEEDED IMMEDIATELY
- Need Opinion Trading in Max
- Replace new spark plugs?
- Smell Fuel Inside - Also MPG Not So Good
- question about strut mounts?!?!?
- Rear shock/strut for 2001 Maxima GXE?
- How to check faulty front sway bar links and bushings?
- transaxle code
- Clunk Noise when clutch is engaged and shift into reverse...NORMAL or NOT??
- signs of blown strut?
- Worried My Clutch Might Be Going Out
- 5th gen clutch question
- need pictures of a stock engine bay...
- ignition coils question
- HID Imitation Bulbs
- Any way to hook up ipod shuffle?
- Brake work
- Squeaking sound coming from engine...
- help... engine acting weirly
- Side Markers?
- 5.5 gen tranny in a 5th gen...
- Burning Rubber Smell
- clutch replacement dif.
- o2 Simulator issues
- Climate Control Question
- check engine light on... p0121 or p0212
- Need help, trying to put in new mirror- blew fuses/no dash lights
- CEL on with P0420...NYS inspection concern!!
- lingering smell
- misfire question
- OSCAI questions
- transmission options
- Questions about 5 Gen Maxima
- Changing LED on dash board and cd player
- Bleeding the heater-core
- Motor Mounts easy to change?
- noise from back of my o1
- H&R to be installed in the front...
- Nopi #1 Catback
- knocking sound under the pedals
- burned clutch..
- buzzing sound near the gas tank
- When a bad coil goes good - ???
- blown strut?
- 2000 I30 stalls and runs rough when cold
- need help p0138
- Is it really that hard??
- Lowering
- Post your aftermarket clutch/flywheel exp.
- EVAP question
- What can excessive wheel hop do to the car?
- hack off the muffler?
- JDM camshafts on Ebay
- Lookin For Pix Of Max With Stillen Aero Kit
- 2K/2K1 owners with OEM HIDs step in...
- to all those with replaced auto trannies
- underhood LEDs
- show off the painted headlights
- people with maxima.org sticker on tint...
- Anyone own LED Side Mirror Shells on your MAX?PICS?
- CF Molded kit for GXE Kit?
- o2 sensors covered under warranty????
- Front driver speaker cuts in and out.
- OEM wheel color
- OZ Rims
- Tire recommendations?
- $1000 for perfomance parts
- 255/40/17 zr rated tires on OEM SE rims!!
- Exhaust ?
- whiny 2nd gear?
- for people with H&R up front
- Stupid auto transmission is leaking!
- H-techs in front H&Rs in the rear. **pics here**
- Philips Diamond Vision Bulbs
- New hawk/powerslot install first thoughts
- Wife blew up the car again
- Hissing/suction sound above 3krpm
- best $1.38 I have spent....
- System too lean?
- 2002 Max Wheel Bearing Replacement
- q45 calipers on 5.5 gen?
- Throttle Body Restrictor
- Pics Wanted...Who is running more than 2.0 inches of DROP?
- Damn Dealer
- Slow Windows
- inspection help!!!
- 2k3 throttle body bore
- Body Color Matched Headlights..(kinda big pics)
- BEst Coilovers for the max BOSS CHENS
- Does anyone make a bra for AE Max's?!
- Altima Bulbs??
- Wierd Car Problem...
- What shift Knob do you have?? (pics please!)
- clutch acting funny
- hotshot headers vs. ypipe and stock headers
- Do all 6 speeds have HLSD
- how long have YOU had your apex-i filter for?
- i looked around but cant find it bulb chart for 5th gen
- Idle Isssues.....
- help fast what wire do i cut to make the clock stay on all the time
- injen hose/filter replacement
- flashlight clip on mod
- Spark Plug Install Question for 2001
- Confirmed my main issue with my maxs ride
- MPG experiment
- Expert Starting help needed!
- Project Maxima photoshop
- stupid nissan indash 6disc cd changer
- What the hell, sea foam caused an auto trans fluid leak?
- painted my interior......
- 2nd 5.5gen Written OFF - RIP 2k3 pics inside
- want to see black rims with lip
- Does anyone have 17" 350 Z rims on a 5th gen maxima
- OIL LEAK!!...need your professional input
- Stupid question about tint
- cell phone charger burns cig lighter fuse
- Transaxel Code...
- UDP questions! assistance needed
- Illuminas making squeaking noise...
- Coil spring isolators?
- Coil problem or something else?
- annoying acceleration noise
- Alternator Problem?
- Fog Lights Revisited
- Hella 2500 Optilux Fogs (How to mount?)
- 400hp+
- clicking noise near wheels...... grrr
- 2k short shifter
- Maxima with NO BRAKES= Scary!!!!
- 02-03 options help??
- black headlight link?
- Warpspeed SS Y-pipe for 5.5 gen in classifieds
- Help! may have wrecked my headlights
- Apexi Filter with Frankencar question
- 3 New Additions to my Garage!!! *NWS*
- pining noice
- Tranny noise
- What could this be?
- Free carbon fiber hood?
- ECU self test monitors
- recent mods
- Bigger airfilter = better?
- 5.5 gen VQ35 and 6-speed problems
- Climate Control NEED HELP!!!!!!!!!!!!!!
- CEL Codes.
- searched, but didn't see the answer
- NGK O2 sensors
- 02/03 brake rotors on 00/01?
- Anyone know where to buy ABS speed sensors online?
- Fog Light Issue!! Please Help!!!
- aftermarket grilles and mounting emblems
- 4th Gen intake on a 5th Gen
- Testing O2 sensors.
