- Ignition coil bolt ...help
- O2 Sim Question
- Speedometer Recalibration?
- lug nut thread size?
- i want to take my spoiler off
- Question about Ground Controls...
- High Pitch Squeek from front at 1700-1900 rpm? 2k3
- Any1 have pics of 6th gen sl wheels on 5th gen?
- Headlight stolen in NYC.
- Does this sound right??? Dealer question
- Illuminas back on sale!
- How much am I looking at?
- How do you tell between OEM and DEPO?
- Opinions!! Want 18s or 19in wheels but what about suspension
- Window problem
- 02 se..exhaust only one side
- Does anyone know which Apexi Filter we use?
- 99' brake rotors and exhaust cat. & b-pipe interchangable?
- Is my transmission dying?
- Intakes: Berk vs Cattman vs Injen vs JWT
- SE/GLE/aftermarket suspension ???
- DDE owners w/ Yellow Fogs
- Random Disconnected Hose in Engine Bay???
- Rotating Stock Rotors
- Code P1320, P0306
- Oil Pan Warranty Question
- dyno run. wonderful surprise
- 5th Gen ???????'s
- Front sway bar = waste of money???
- helios h3 mini hid fog kit owners please step inside
- ECU Question
- Got my girl a hot new black skirt!! Pics inside!
- Tranny problem...stuck in gear.
- 2000 Maxima stands up well against Elk.(pretty long)
- looks like oil on coil packs
- Performance Parts questions
- Rubbing on one side, but not the other
- Effects of trunk weight on gas mileage.
- Which rims to buy for my 5th gen?
- 2002 DriverSide Automatic window problems
- Rotors Issues
- Alarm malfunction
- Glowing Red Rotors
- Dent in my hood
- Brakes soft after new rotors/pads...now what?
- P0139 and P0138 warranty fix possible?
- Installing an air conditioning vent please help
- Towing Capacity with 02 Max?
- 2000 fog light assembly removal
- Does your car stutter when starting?
- PDR place north or west of boston
- rpm
- Screeching Sounds!!
- aftermarket exhaust.
- Key Fob- Windows- WTF?
- 02 no balls and dies... ???
- Matching sidemarkers and Head/Fog Lights
- brake pads
- Going to by 5th gen in a few weeks and I have some questions
- headlights and bulbs : the right one :)
- Siezed wheel lug, stud issue
- Is Flywheel damaged, debris in bell housing - or worse??
- Check Engine = P0720
- How fast does your tranny shift 1-2?
- when is it time to buy a new one
- Sluggish when cold and uder 2.5K rpm
- power drops after 3500 rpm .. engine stalls during warm up period ... need help
- Rear rotor removal...feels like it's welded on
- Teaser Pics - Ipod, Sat Radio, or Aux 6 disc changer option
- Suspension Help
- finally installed my illuminas with tein stech springs, :)
- Rear blinker bulb question
- Quick Question! Which postion to face the xdrilled rotors?
- Bad CV Joints?
- HELP, car won't start!!!
- JIC A1 coilovers -- are they any good?
- Ok this is a new one. (Wiper Handle broken)
- Noise gone! but now vibartion
- Baking Headlights w/ XPel
- Max No More
- Valve Body mod for 2K1 maxima
- Location of ECU 2002 Maxima
- So I found out why I need a new MAF sensor.
- 6th gen 18's
- Pic request: H&R drop, front only
- Clunk from front passenger side?
- Problems after CAI install......
- FSTB Installation
- Too good to be true? 100 bucks for a lip?
- Power Passenger Seat Problem
- Weird rotor wear on my new rotors....uneven pads?
- Maxima.org decal
- Best Brake Pads
- Need your opinion on what size of wheel spacer
- I hate to do this...but.....
- At what point do I need longer studs for a 5th gen?
- Exhaust Stinks
- Shaving Rotors = New Pads?
- First pics of LED liscense plant lights
- Superflux LED bar pics & Exterior Overhaul Preview
- Reverse Gear Weird vibration
- Where can I find a rear window spoiler for 2k gxe?
- which short shifter
- need pic of black 5th gen w/g35 wheels
- SE Suspension same as GLE or GXE??
- Swapping 0.9 bar radiator cap for 1.2 bar ??
- Found this on EBay today!
- In need of rear exhaust...what should I get?
- Vinyl???
- Anyone have a write up on how to install the progress RSB? Get this....
- is there a good leather repair product?
- left side of bose cutting out?
- HID Help
- feedback on brake upgrade idea
- Just bought a 2002 Maxima SE...first mod suggestions?
- apexi filters.
- Why no trenz Grilles for 00-01 maximas
- In talks with two dealers right now! Tips, suggestions? Thoughts?
- Is the navigation these cars come with anygood?
- RSB & RSTB question
- How can I get this O2 sensor out?
- Lightning strikes again
- Finally got pics with the 15mm spacers on(this ones for u Shurik!)
- There goes my oxygen sensors!
- Annoying Squeak from front end of the car? Time for…
- coilpacks
- Dothe 5.5gen have a ground point for the DRIVER's side headlight?
- STS for 6 speed
- Angel eye size?
- Another exhaust setup
- My baby took a spill.
- Stalling Problem w/ 2000 MAXIMA SE 5-SPEED
- need answer asap on clutch
- Tranny mount??
- Planning to make my own JWT POP intake
- power diminishes as car warms up... any ideas?
- Polk Tweeter Install
- 01 se needle gauge help!
- A couple of noob brake Q's
- Q's about after mkt. parts when selling car.
- Maxspeed vs. H&R -- Part 2... with review inside.
- Pully Question
- Are the 02 and 03 6-speeds intrchangeable.
- intake question
- rewire fogs so they stay on with high beam
- Where to find 02-03 HID Headlamp wiring harnesses?
- GAB, Berk, K&N what should I do?
- I found out what happened to my engine
- 01 AE tranny in 03
- Coils Or Plugs????????maxima Fans....
- Need exhaust plese help :)
- illumina settings....
- Oil in Intake Plenum??
- I found this odd....
- LSS Exhaust
- FSTB install link help request
- Can you please send me carfax report
- bulbs
- What is the 'auto entry' switch supposed to do? (6-speed)
- breaking noise
- my max got owned....
- my 02 max eats gas
- bose head unit
- Sounds like a Turbine in reverse when I stop...
- What do you guys think about these 2k/2k1 headlights?
- black rims 18 or 19
- sunroof mod
- Anyone else thought of this?
- H-Tech Front/H&R Rear Pics
- Front end feels "loose"
- Wind Noise in the Back
- Oxygen sensor
- Noticed today I only have exhaust coming out one of the muffler pipes, WTF?
- ANYONE with access to a junked 5th gen???
- VAFC-II Wiring Diagram
- Strut install headache
- Hotshot Headers on a 2K2 SE
- 2000 Maxima GXe headlights are showing wear....Need help with new headlights
- Low or normal HP results?
- 18 inch wheel Q
- Clutch question
- HELP! Check Engine Light, code P0160
- Where is the easiest spot to tap into dome light wire?
- Questions on code P0154
- just add some goodies to my car..My impression
- VHT niteshade and tails..
- Need help - multiple codes, car idles only on front 3 cylinders
- Accident/repair
- h&r or h-tech
- Help with what to say?
- does anyone have the frankencar exhaust??
- JIC users chime in...
- The hole under the spare tire?
- Jack Stand Locations
- Alright, whos good with electrical?
- Will This O2 Sim Work?
- h&r and blues rule
- My New audio system...
- I got VTEC in my Maxima!
- Key program not taking!
- Looking for the reverse indiglo gauges for a 2002 Max GLE
- Thanks!
- Help is this normal ?
- Removal of rear bumper
- The Ultimate 5th Gen Headlight Upgrade!
- Exhaust Shops
- 6spd Question
- P0171 and P0174 codes.....
- Is it worth it for me to change my struts?
- Help! SES light with P0133 and P0153
- Clutch Master Cylinder Bleeding Procedure
- Got my struts, springs coming this friday, and installation this weekend
- H&R Front Springs Arrived!
- Cabin Air Filters for 5th Gen Maximas
- question about AC
- Quick HPS Install Question
- Broken wheel stud
- question about aftermarket ebay hids?
- Maxima Taillights
- sooo expensive.
- 0138 o2 sensor discussion! Puppet, Nmex!
- Transmission Cooler
- Lower Tie Bar? Help...
- Normal or Abnormal After Y-pipe Sound
- Clunking or something.
- Almost got nailed today!
- Cali spec vs Fed spec
- Exhaust noise
- OEM airbox 5 and 5.5 gen same?
- Y-Pipe and Inspection Concerns
- Aftermarket fog light bulbs
- Place To Get Wheels Re-Finished?
- MAF Cleaner....new product!!!
- Max Tried to end Anaheim Chase
- best place for 6th calipers
- car drops RPMs on starts
- removing the shield from 02-03 fog lights
- 5000k Halogen Bulbs????
- Need Part # for 2002-03 Ballast holder
- Difference between....
- Bye Bye Max
- P0507 Idle Control System RPM high ... HELP!
- Is my 2000 Maxima a GLE, GXE, etc
- Vias Question
- Looking for a consensus on P0430 codes
- Rear brake calipers
- Alignment + New suspension question
- Change Struts, Change Springs?
- Removal of Stock Y-pipe
