View Full Version : 5th Generation Maxima (2000-2003)
  1. AC Control Swap?
  2. rattling/banging from Cattman catback exhaust
  3. Brake Pad Recommendations
  4. Question about injen CAI
  5. bose question
  6. went to dealer to get my timing advanced
  7. SES light....
  8. Need help identifyng transmission.
  9. My old Maxima on EBay - WARNING!!!
  10. 2002 maxima dragger/#1 exhaust
  11. Custom Sidemarkers
  12. front lip & rear valence
  13. 00-01 Headlight Rewire ... need diagrams, info, etc.
  14. xenon fog bulbs
  15. Pics of Hotshot headers with tranny out of the way
  16. Swapped open diff tranny with 04 6-spd HLSD
  17. "Fuel Master" device?
  18. Why doesn't the Maxima sound like the z or g35?
  19. New Exhaust?
  20. Gauge Bezels
  21. Any Sunlit Sand Owners w/ CF hood?
  22. Side view mirrors
  23. DDE's and cleared corners
  24. Stiff clutch pedal
  25. eBay stuff.....
  26. MAF Sensor? Where to buy & which one?
  27. enough is enough
  28. I30 Cluster on Maxima
  29. Need pics of CFhoods on 5thgens
  30. 5.5 Gen Manual: WEIRD SHAKING PROBLEM
  31. 5th GEN Projectors
  32. Warped Rotor dilemna
  33. Cleaning Plastic in front of Gauges
  34. how was the fit of your motostorm udp on your 00~01
  35. CAPA Certified Parts for my AE???
  36. Finally got a couple thing painted
  37. Cattman/Hotshot (Rant)
  38. illuminas with stock springs
  39. aftermarket Parts Jump In
  40. ECU - Gas Mileage Advice Needed
  41. Stripped Studs
  42. Stuck caliper
  43. 2K GXE Appears I need a MAF
  44. new brakes install problem
  45. My car's MPG is sooooooo weird.
  46. Do I have to upgrade brakes?
  47. found a hose that doesnt seem to connect
  48. y-pipe/b-pipe combo question
  49. Headlight Removal Help
  50. where to get projectors.
  51. headlights
  52. Looking for headlights/fog wiring diagram
  53. Doing my first performance mod...
  54. Anyones TCS light plus SLIP light stay on?
  55. Need resonator pipe / catback
  56. 2002 Maxima stalling problem
  57. Excellent Link To Aftermarket Airfilter Tests
  58. can't find how to fix "EVAP Canister Vent Control Valve Circuit Open"
  59. headlights how to check ??
  60. Air Filter Cleaning
  61. 2k/2k1 Y-pipes?
  62. Ebay's E46 angeleyes installed !
  63. Autovation pedals
  64. New front brakes installed, BUT...
  65. How to remove old headlamp ?
  66. codes p0138 and p0139
  67. Just Curious! Car Fax Question.
  68. my rear lip melted!!!
  69. Fed Vs Cali Spec Ecu
  70. A question about angel eyes ***PICS***
  71. gurgling.......diagnosis???
  72. Te Add-on's?
  73. 5.5 gen tranny swap
  74. Getting center console off 2k1
  75. Front lip install?
  76. Wheel piece identification
  77. Replacing drive belts in a 2000?
  78. Power retention for windows, any way to prevent opening a door from canceling it?
  79. need help buying a intake
  80. getting mudflaps off
  81. What Is The Mileage On Your Maxima?
  82. Question about advantage of Ilumunas vs Blues
  83. Haze on display
  84. HELP: Spilled a little seafoam on engine...
  85. 2k1 knocking noise...
  86. I'm hearing a rattle under acceleration.
  87. Intake Question???
  88. So I lowered just the front- pic
  89. Anyone have access to the in car navi system DVD?
  90. Wattage Question??????????
  91. Where should I buy K-sport coilovers?
  92. street scene grill painted body color
  93. both side markers out?
  94. rotors
  95. Loud Scraping sound when turning left
  96. Is this a MAF syspmtom....
  97. 6th gen spoiler?
  98. Steppin Up!
  99. LED mod for AT Shifter lights?
  100. Anybody with an E-manage Ultimate working in an 02/03 ???
  101. 2003 NISSAN MAXIMA SE Hypergrounding kit PowerPoint Presentation.
  102. anyone use 4 ga. wire for grounding kit?
  103. Need A Carfax ***please****
  104. Door squeak from touching the rubber drip strip...
  105. Possibly buying a used Stillen muffler, what to polish with?
  106. Replace Brakes/Rotors
  107. Warm weather...high idle
  108. 5th gen interior = superior to fourth gen?
  109. I need help and i searched with no result!
  110. Y-pipe and Emissions Headache
  111. 02/03 Exterior Color Options???
  112. is my car idleing too low (550)? and why?
  113. H3 white fog light recommendations 2k2?
  114. GLE vs. SE wheels
  115. SES Code P0171 Need Help!!! Can't Search
  116. 00-03 all use the same trunk mat, right?
  117. Bluetooth for your Maxima
  118. Zex Questions
  119. Rear Clear sidemarkers? how to remove....
  120. 1.5 ton Jack is that pushing it?
  121. Altima/Maxima Quaife LSD!!
  122. idling at 1000 - 900 wtf?
  123. Swapping my tranny for 04 model HLSD s-speed
  124. So my strut tower brace came today and the box was torn up...help?
  125. Suspension warranty question....
  126. need a littel help guys
  127. darn dde ballasts
  128. options other than GXE kit for 2 din DVD Screens.....
  129. 2000 maf. should i?
  130. Differences Between 5.5/6th Gens
  131. Key
  132. Had a code
  133. To Reset or not to Reset?
  134. Question about automatic transmission fluid level.
  135. part number for 5.5 gen Side Skirts/Rockers
  136. I got a P1610 Code!
  137. Resetting ECU...Which way is correct?
  138. I did 188 mph top speed test
  139. Stage 2 LTB w/ Cattman Headers Test Fit
  140. Must-have mods on a modest budget?
  141. new struts question
  142. Rotor/pad help.
  143. quick tuning question
  144. acceleration issue...
  145. Sold My Max
  146. 2000 GXE manual climate control issues
  147. Need Advice on Purchasing 02 6Spd
  148. Tein S vs. Coilovers?
  149. Parking Brake light is ON, NEED HELP!!!!
  150. Oil Consumption 2002 BOHICA!
  151. Feels like driving in the wind
  152. 2001 Max Horn
  153. door not closing and locking right.
  154. Finally hit 300 on a tank!
  155. Need a Radiator for an '02 and Air Filter
  156. natti max
  157. The Myths are true - G35c 18" rims installed and smoked tails!
  158. Which color touch up paint do I need and what would you recommend?
  159. Common 5.5 gen problems?
  160. Dynos indicate major problems
  161. One touch open/close on sunroof not working
  162. Rim color help
  163. Clutch pedal travel = too long, is it adjustable?
  164. Cleaned TB and installed ghetto CAI-
  165. Changed 6 spd fluid, and....
  166. Maintains on 5.5 Gen
  167. Flashing Air Bag Light - Help Please
  168. brembo x-drilled
  169. what kind of mileage do you guys having going?
  170. Oxygen Sensor buying time!
  171. Engine VQ30DET found
  172. Color codes for interior trim pieces?
  173. Weird sounds when I go over lil bumps
  174. Headlight Question 00/01 w/Projectors
  175. check engine light
  176. 6th gen needs help with crank pulley removal...
  177. Code P0158 and o2 Sim question
  178. New mod
  179. 2000 Maxima trans TSB
  180. Oil in spark plug valve 4
  181. Let's play the "Diagnose the brake problem" game.
  182. Ebay Euro Yellow Amber L+r Fog Light Oem
  183. If you're experiencing cold start rough idle, and power loss - READ THIS
  184. How do I remove 2000-2001 headlights I am trying to do AE mod
  185. Does brand/quality of FSTB matter?
  186. Parts swapping help...
  187. SES - P1320, New coils or what?
  188. Shift console boot part #
  189. B&M style short stifter
  190. power seat prob????
  191. Dash Clock
  192. vafc
  193. Having BIG problems!
  194. Slight "whistle" sound during acceleration
  195. Diagnose my problem - Get paypaled $5.00
  196. HELIOS H.I.D. BI-XENON Plug & Play Kit
  197. maf
  198. Another FOG question
  199. 2001 Grill Replacement
  200. Help, I keep blowing Starters!
  201. Those who have changed fluid in 6spd???
  202. B (mid) pipe questions. Info please
  203. RockAuto for Ignition Coils?
  204. Hmmm Clogged fuel injector?
  205. Lexus Capsule or HID fog?!!?
  206. HID fog install QUICK HELP, just about connection
  207. Rattling noise...
  208. Hit a chunk of metal
  209. Fog Light Problem!!!!!!!!!!!!!!!!!
  210. ses light p0300
  211. 4th Gen totalled, 5th Gen here I come!
  212. Will I35 side skirts fit a 5th gen?
  213. Leather seats install
  214. any good cf trunks yet?
  215. will 00-01 headlight LENS FIT 02 HID
  216. Brake Pads
  217. 2003 VQ35 swap in Sentra.. Lack of power!
  218. quiet clunking noise/ when moving wheel
  219. Sun Roof ???
  220. 2001 maxima trunk dimensions?
  221. Just Bought My 2002 Nissan Maxima SE
  222. P0507 Idle Control System RPM high ..SOLVED!!!!!
  223. will a 350Z thermostat help?
  224. 00~01 fuel injector flow ?
  225. how much do VQ35 engine covers cost?
  226. Exhaust Mating Question..
  227. Front 2k4 Brake Upgrade parts list needed...
  228. Pulsating idle speed on 2k3 only 18k miles
  229. muffler question
  230. how much would you pay
  231. For those with the ebay projector headlights
  232. Installed CAI, now SES light
  233. good price on maf
  234. Emission/pcm/fuel 10522
  235. tranny questinons
  236. HELP! - P0443 and now harness!!??
  237. New 02' i get to fix
  238. Can I see some pictures of 5th gens with 20% tint?
  239. 02 6 speed jerkyness
  240. How to remove vents
  241. I actually feel a difference with my new grounding kit!
  242. Upgrading suspension....
  243. Cut bumpstops?
  244. Frankencar Intake
  245. Removing Sunroof Deflector
  246. Clunking sound in front end on bumpy roads
  247. Eyebrows
  248. AUTO Tranny Flush
  249. Jet Performance V-force
  250. Ignition coil bolt ...help
