View Full Version : 5th Generation Maxima (2000-2003)
  1. 6speed conversion
  2. are the radiators on the 4th and 5th gen vq30de interchangable?
  3. 5th gen inother countries?
  4. What to do with the foglights?
  5. gas war
  6. any difference in grounding kits???
  7. Ypipe hardware
  8. 2000SE Needs Carfax, please.
  9. Manually shifting gears in an AUTOMATIC!?
  10. pads for z32 on a 00
  11. Starter? Overfire, misfire or something else?
  12. Just an Update on the SFCs
  13. Trans. Problems? Please Gimme Feedback
  14. 02 se 0335 dtc anyone delt with this one ?
  15. What is the '02/'03 PCV part number?
  16. Are all AE Cali Spec?
  17. Grinding noise
  18. Gas for VQ
  19. p0430 Definatve answer requested Y2K cali spec
  20. What Y Pipe Do I need
  21. 2K2 Steering Wheel Controls in a 2K
  22. metal scraping sound when turning-please help
  23. carfax request
  24. Gas Prices Poll
  25. Plenum Spacer pulled 3 times on Dyno FYI
  26. Which muffler?
  27. Clutch changing gotcha - bad ground equals starting problem
  28. Hesitation at 3500 or 4000 rpm and up
  29. High Flow catalytic questions
  30. whats that guys name and number?
  31. VIAS questions.
  32. insurance difference on auto vs 6sp?
  33. Helios HID and DRL (Daytime Running Light)
  34. Got sparks?
  35. What do the stage 3 SFCs include
  36. Blehmco LTB and headers?
  37. 03 Maxima se Vs 06 Mustang GT
  38. GAB Questions
  39. Gas Prices when up and now a hole in my muffler (factory)....
  40. Buying a 5.5gen
  41. (semi) mini interior project
  42. Budget Exhaust Website?
  43. A few security questions...
  44. Best Y Pipe and Installation cost?
  45. H-techs: somewhat dissapointing
  46. 2002-2003 stock side skirts
  47. Super Bright 5.5 gen instrument cluster w/ LED needles...PIC
  48. Help anybody who used seafoam
  49. Idle Problems? IACV for sale
  50. highway acceleration
  51. What color is the TPS on the 2k2's; where is the ECU
  52. which spacers in front?
  53. new muffler what adaptor?
  54. Help - whats causing this?
  55. Cattman Exhaust
  56. Dirty fuel filter changed at 100K *pic*
  57. D4r Bulbs???
  58. reset auto window
  59. Wheel Spacer Help?
  60. possible Cause/fix to code P0507 after TB cleaning. Long
  61. Suspension Installation-DIY or Shop-Cost?
  62. Need Help Finding A Part For My Seat
  63. Why is the 2k2 MAF much more expensive than the 2k MAF?
  64. Need advise on replace brake fluid
  65. Engine stalling immediately after start..?
  66. Ses Light On!!!!
  67. Skyline Headlights
  68. Black Halo Projectors Headlights EBAY
  69. Y-Pipe Install...PITA & Unsuccessful
  70. Blower motor clarification please...
  71. Rust & Scratch Repair
  72. What's this sound???
  73. my right (pass. side) HID wont work
  74. Window trouble...
  75. 2002 GLE vs NEW 2006 SL??
  76. Installing in Dash Gauges
  77. Advanced Timing Module
  78. Maxima Artwork
  79. 20s need help
  80. How much weight does chrome plating add?
  81. Rear Bumper cover on my 2002 - Removal
  82. Low RPMs continued...
  83. g-tech pro SS HP measure
  84. Alternator failure: Second time!?!
  85. Exhaust noise question
  86. '00 SE - idle drops too low, sometimes kills engine
  87. Unorthodox Under Drive Pully Worth or Or Useless
  88. Has anyone removed their tail light?
  89. Spectre Module Intake 00-01
  90. emission test
  91. Franken car
  92. Topspeed y-pipe is here
  93. ses light again and tuning ?s
  94. Dimmer Switch
  95. Dyno #'s for 3" custom piping on a NA with Apexi WS
  96. Show me pictures of your Invader-Style CF Hood
  97. Swapping rear section exhausts with jack & stands
  98. Clutch labor charge???
  99. How much you guys paying on insurance for the 5th gen?
  100. Digital Climate Control
  101. Spark plugs still looked good after approaching 60k miles!
  102. Gettin my Custom Subframe Connectors done Soon Step inside for More Info
  103. Stealer ship wants $700 to replace key...
  104. How-to for Blow By Catch Can
  105. Little white plastic grommet that headlight post sits in?????
  106. wiring diagram for VAFC II on a 2000
  107. HELP!!! Burning smell and tranny acting funny...
  108. best intake setup for all around torque?
  109. I heard they burn out.
  110. Possible shifter
  111. Continuation of black rim thread only a little different
  112. Hey man, Nice HiDs!
  113. Do I have the lowest milage 2002 SE?
  114. curious...how many guys have KN drop in?
  115. Question about Tokico springs
  116. Clunk...
  117. How to stop gas pedal from rattling?
  118. How much should I ask???
  119. How VIA (Nissan Variable Intake System - NVIS) Works
  120. anyone try the Fujita Intake for the 6th gen on a 5.5 gen???
  121. How reliable are DTC codes?
  122. Maintenance question....
  123. Which shops do custom work???
  124. Squeaky belt....tensioner or pulley?
  125. HELP!!!....Cant Get Rid of Mushy Brakes!!
  126. Concerns About Doing a Drop
  127. Would you have done this for a Maxima?
  128. code p0507 idle to high how to fix?
  129. Is it possible to get a 02-03 Trenz Grille on a 01?
  130. I am now a proud owner of a 2k SE
  131. plenums, sort of
  132. headers for an 00?
  133. Alternatives to PIAA H3 fogs???
  134. auto to 6speed swap?
  135. WHy does my clutch pedal feel different all the time?
  136. How much potential do our cars have?
  137. MAF screens??
  138. Cleaning magnets + screen before tranny flush?
  139. Cant reset ecu / get code! Even with write up
  140. Need ignition coils? Step in...
  141. Anyone try this brake setup?
  142. A/T oil change....???
  143. Most likely a repost, But.....
  144. Bad 5sp Gearbox Design??
  145. Anyone try this brake setup?
  146. Water leaking through SUNGLASS HOLDER?
  147. Technosquare L-Tuned or F-Tuned?
  148. PIAA Xtreme bulbs?
  149. De-k Sos!
  150. Anyone familiar with the fuel sensor system?
  151. Car is pulling to the left AND right!?!?!???
  152. Was this ever done, adding a sub in the 5th gen BOSE sub “cutout”?
  153. Strut Mounts / Noise
  154. codes = more money to spend =( please help
  155. Going to Kill my max!!!
  156. windshield wipers..ne1 have this prob?
  157. BLUE BATMOBILE taillight overlays (PICS)
  158. Black Max, black Grill, black 02 headlight mod, pics inside
  159. Dealer wants to replace belts
  160. Project D2R foglights!
  161. What do you guys think of Black rims on a 5.5 gen
  162. New Oil Pan
  163. 245/45/18 tires on a 5th gen?
  164. Cracked my headlight!
  165. Headlight acting up...
  166. Need help - awful smell!
  167. Angel Eyes Ebay's E46 WHITES installed!
  168. 1st Time Brake Install Problem
  169. 100k mile maintenance
  170. Illuminas and Tein H-techs Drop Pics Inside
  171. How much did you guys use?
  172. Anyone has Tein SS w/ EDFC???
  173. For those of you who think blow by is minimal part 2! *56k* *pictures included*
  174. Cleaning the engine from the inside...
  175. hesitation particularly in 2nd gear...
  176. Sick of brake problems
  177. Hub Rings
  178. Car Pricing Help
  179. Opinion on AE
  180. 2002 HID Headlight Install
  181. Another stupid question..
  182. Replacing rear valve cover on an 03
  183. Rear Caliper Issue - Help!
  184. Pure Polyurethane Stealth Lip??? Anyone have pics?
  185. Hard hits on potholes. What's the problem?
  186. Suspension question..
  187. 2000 Geared low?
  188. Vibration after spring install
  189. ???Question on Axle parts???
  190. Preventive Maintenance = $500
  191. Brake freezing, red hot- Not e-brake
  192. HELP, rpms drop below 400 when shift to nuetral
  193. Oh no! Help! Muffler Detached!
  194. Part # - Steering Bump Stop
  195. Valve Cover replaced under Powertrain...
  196. Urgent: Uneasy bounce from front of car at slow speeds (like struts are shot)
  197. Ouch! I broke my shift linkage bracket!
  198. I want a new horn
  199. ABS Codes?
  200. apexi WS Turbo Exhaust
  201. SPEC OR Clutchmasters
  202. I'm getting a 2k SE tomorrow :woot:
  203. Drilled OEM Rotors
  204. Exhaust shops that install the y-pipe
  205. Are 5th gen factory spoilers and I35 spoiler the samething?
  206. Anybody w/ Pictures of blond and Frost carpet?
  207. Anybody w/ Pictures of blond and Frost carpet?
  208. 2000 Maxima: Lots of issues-why do we bother?(long)
  209. 4th gen AGX's on a 5th gen, top mount question...
  210. Question about shocks/springs...
  211. Is this a berk intake?
  212. Rare 6sp w/ navi in NE!!
  213. PBR/Axxis Brakes
  214. Question about A/T and coolant system.
  215. tokico hp shocks??
  216. Throttle Sensor!
  217. 18" FX35 wheels
  218. Clear Blinker Bulb - 2 output wattages?
  219. wiring problem or helios h3 kit, vets please step inside
  220. Post your pics of custom painted interior trim pieces
  221. Glass headlights
  222. Where to Buy Lexus Capsules
  223. Top Speed Y-pipe
  224. 2k2-2k3 side skirts fit 00?
  225. pcis and info of ur fpr..
  226. Could it happen to your car too?
  227. So OBX makes headers for us too now...
  228. bad habit- breaking keys and remotes..
  229. Knocking noise fixed... Link kit is the culprit.
  230. Manual Transmission leak
  231. Engine Service Soon
  232. I think i advanced my timing tonight
  233. Quick install question
  234. Intakes affecting powerband...what's the deal?
  235. Best way to keep my interior cool now that summer is here? (I have tinted windows)
  236. Tune up '02 Max
  237. Fresh wax for sping picss
  238. Rattling sound from A/T transmission... HELP!!!
  239. 00-01 white vs. 02-03 white
  240. What a rip!!!
  241. P1320 - Ignition Signal
  242. Neon Undercar Install Question
  243. Grease those Drive Axle Splines
  244. Poll: How many folks have had to replace their motor mounts
  245. O2 Simulator Installation
  246. without my max for a few days
  247. Sunroof Problem. Nissan Goodwill!
  248. What type bulbs for climate control ?
  249. place racing cai
  250. tint removal
