- tokico illumina struts good, bad?
- need help
- Erebuni CF hood any good ?
- Automatic shifter loose in drive
- Lookin for H&Rs for cheap
- My brakes are fawked.
- Worried about lack of engine oil...
- headlights
- what color rims on a merlot 02?
- lights in fan switch
- Using Tein EDFC with Stillen Camber Plates...
- muffler/exhaust questions
- Canuck Motorsports Springs....?
- cattman catback
- HELP! newb changing spark plugs
- Jet performance... worth the money?
- Possessed locks, voodoo brakes and questions inside>>>
- windshield trim
- Bose== 2002/2003
- O2 sensor
- Shiftplate LED exchange
- Starts then dies unless I put it in gear
- Low Tie Bar for 5th gen
- P0430 Catalyst Efficiency BelowThreshold
- cheapest price for h-techs?
- SES p0302... Help please
- Part #'s from Autozone - P038 & P039
- Reading the Dyno posted I have a question...
- Handling idea which I'm not sure has been brough up before
- New design for SFCs
- leaning and timing
- Could I/Should I enter my car in local shows?
- Wow it makes a BIG difference!
- *Sound clip* of stock exhaust minus B-pipe resonator.
- replacement fog lights
- Let's say you had 100 bucks to spend...
- DIY Oil Catch Can....
- How many quarts of oil does a 5th gen take?
- Cloth to leather swap 5.5
- How high?
- Need some quick help
- oil and pcv valve?
- Question about mesh grille
- 5 speed whine
- Rear replacement shocks for 2001 Maxima
- removing rear pillar HELP
- Ignition Coil Question
- Cail spec Y pipe
- ••ü•• What's Going On At Umnitza!!!
- need help with redline shift boot
- battery relocation to trunk mount tray/box
- autoenginuity thread
- custom third brake light
- Who tried voltage stabilizer???
- Lost my Maxima key and remote
- New lower balljoints+tie rod ends+ES bushings+camber
- AT trouble
- Y pipe on VQ35 questions
- 5th Gen Carbonfiber Trunk?
- What offset do i need for 18x8.5 rims...plz help
- MAF dies 655 miles away from home!
- Sunroof Problem: Tilt up and down works, but sunroof won't slide back
- Water in my factory rear spoiler light
- Cattman catback rattles/burning smell after install? **please step in**
- Custom SFC update Car went in the shop today
- IACV funny story
- Is there away to test the ign. coils?
- FSTB installed
- Car Alarm
- GRINDING! Front right wheel!
- 5.5 gen side airbags
- 6speed conversion UPDATE
- Why does my car alarm keep going off by itself?
- Hood pin questions
- Any current deals on SS Brakelines right now?
- My Final MAF questions
- Anyone Have A Lightened Flywheel Please Help
- ..Budget Y-Pipe Owners Step Inside..
- Wiring Diagram for '03 Max
- Ready to post Dynos tonight but need help from someone.
- Brakes and starting issue
- HOW TO: o2 sim install.....
- 01 tailights interchangeable w/ 02?
- MTEC super white H3 fogs Vs stock
- Need Help...
- another intake question to PO everyone
- must change ECU when changing IACV?
- 02 SE with no HID and no fogs?
- caliper weight
- Anybody used Nissans corrosion warranty?
- Thermostat replacement
- Blank Key
- Headlight Aiming on the eBay Projectors
- Will an 02, 03 SE Speedometer cluster work on 01 GXE?
- sunroof shield
- start up smoke????PLEASE HELP
- YES Another HID thread...( OLLO??? )
- Nissan dealer ... getting worse
- would a 00SE muffler assy be compatible with a 02SE
- Flashing SES & Y-pipe: Coincidence or not?
- Brake caliper torque specs?
- SAFC-II low/hi settings
- Codes after Y-pipe install
- Picking up my 5.5 gen Friday CANT WAIT!
- My max and Lexus...
- WTB: 20th anniversary shifter knob
- Multiple IACV questions.
- is my max buring oil
- Anyone used KYB strut mounts in front?
- How hard to recharge or re-fill AC on 2000?
- Need Help on 2002 Headlight assemblies
- SES light on - Pulled code P0226 Pedal Position Sensor - Assistance?
- Those with coilovers... come in...
- new hood cost/installation
- oil cooler...tranny cooler
- Torque Specs for Hub.
- Please need help from folks with photochoppin skills
- do I need to upgrade the whole projectors with HIDS or can I just upgrade the blubs
- owner's manual
- Illumina settings??
- Interchangeable parts?
- #4 coil
- Might be buying a 5th Gen Tomorow..
- NextGear Thermoshiled Intake Manifold Gaskets
- FYI Fan Ampliier repairable...
- what are the better Brake kits for a 5.5 gen....what are you all using?
- Need help quick
- Z32 Maf Swap Questions
- Question on illuminas
- LED's in Fog Lights.
- HOW-TO: Super-Easy AE Pedal Install
- HOW-TO: Add LED visor lights!
- HOW-TO: The Penultimate Climate Control LED mod!!!
- Tein H-Techs: Further Rant
- Intermittent wiper help
- Night shades
- need help
- Look! My car is popular! People are copying me now!
- Ceramic or Semi-metalic to stop warping rotors?
- ABS & Traction Control
- Opinions on new Solmia caliper covers?
- A/C compressor pulley needs lubricating...?
- Torque specs for OEM Spark Plugs?
- ATTN: 5th gen HID Owners.....Please come in
- where are the sparks?
- Radio static w/ defrost
- SES came and went = o2 sensor
- Power Loss at High RPMs
- 6-speed swap
- replacement front cat for CA Spec vq30 engines
- The ULTIMATE LED Climate Control & Visor LEDs...PICS!!!
- a/f ratio for 3.5
- bahhh damn ses!
- 450 miles + 2 laps around Nelson Ledges raceway = 27 mpg
- Slight jump in RPMs while shifting?
- Datadot?
- Slamed on the breaks, slipped out of gear.
- Passport 8500 x50 Hardwire w/Smartcord
- Help with a P1612 error?
- Stab. Bar Bushings 5.5 gen
- intakes (jump in here)
- New Clutch/Flywheel Question, also SES light Question
- Possible front rotor problem...?
- Relocating battery
- when is it time to change spark plugs?
- removing clock
- exhaust hangers
- problems with back up light when switching to reverse?
- Deciding between 19s and 18s...help
- Does changing the B-pipe dramatically change exhaust tone?
- LTBII Install help?
- Navigation question-Please help
- Plastic Lenses for clearing out 5.5 gen headlight
- Transmission slip from 1st to 2nd gear
- battery worth it?
- any one install a VAFC 1
- climate control bulb.. any ones whiter?
- MAF, or Knock sensor is the question
- Hydro-Gen
- 1/4 mile,dynos, and mods: Fast Maximas Please Post
- HIDS in Fogs.
- Car feels Extremely loose
- What do you think of these Nismo wheels?
- Another starter problem? 2KSE Manual
- Got P0174 Code after using Seafoam
- Double Din?
- Warpspeed y-pipe questions please
- need help on buying a max
- ideas for next mod..hmm***
- HELP!! burning rubber smell from passenger side rear wheel well!!!
- Shavings on tranny pan magnets normal? PIC
- Xterra SC motor?
- Cattman Y-pipe movie clip
- Y-pipe Saga: Oxy Sensor
- Problem with rear brakes HOME's help needed
- stock intake photo asap please
- Car Stalling
- How smooth does your maxima Idle
- Engine covers?
- Rattles are becoming embarrassingly annoying......wtf nissan?!?!
- Lease ending Should I Buy
- Small misfire @ idle ????
- PLease help, can't remove one tranny filter bolt.
- Paint matching?
- Pics needed of AE Headlight mod with corners blacked out
- E85: 85% Ethanol; 15% unleaded gasoline
- Infiniti 5 spoke touring wheels on the max(pic wanted)
- How can Maxspeeds be the same spring as H&R?
- '02 SE FSTB and Intake Mod - What to do w/that extra MAF! (Pictures)
- Anyone know if the LED angel eyes will fit on an I35
- Rear Suspension/Axle Help
- 2k2 Transmission Problems
- Tried everything, still have problems, HELP!!!
- what does an Immobilizer immobilize?
- electronic motor mounts(auto)
- Possible a projector headlight that takes HID.???
- Lookin for the Illuminas for 408$
- Super Birght 5th Gen Cluster w/ Cleared Needles...PICS
- My CD player doesn't work when it's humid. It makes me want to smash it.
- 139dB Stebel Air Horn Install
- Question about AT & MT
- Coilover question
- AE Gas-Pedal Installation..is it really that easy?
- 2k3 hid lights
- 3" Headers and Y-Pipe For 01 Nitrous
- Headlight question?
- sound problem...front right suspension sound under hard cornering...
- Gas Prices when up and now a hole in my muffler (factory)....
- code P0171 HELP!!!
- Moved throttle body butterfly, and now have codes
- 00 Maxima: Short throw shifter
- Instrument panel/Gauge Cluster swappable?
- HELP! Window stopped working In the Down Position
- Need Help with unstable steeering wheel?
- Reliability Web Sight Dogs MAX ENGINE for...
- if i take my bumper off will the air bags go off?
- Are TSB's considered "warranty" repairs?
- Gas door - 2000/2001 same as 2002/2003
- Do '01 ignition coils fit an '02
- Anyone have the Paradox LED mirror covers installed on their 5th gen with pics?
- 01 cams
- Brake Rotors, Pads, and Plugs
- Rear Caliper Dilemma
- WOW 34mpg!!!
- Differences between 02 and 03 Max??
- What Clear Epoxy for 5.5 gen fog lights?????
- To people who say the H&R drop isnt even
- 6speed conversion
- are the radiators on the 4th and 5th gen vq30de interchangable?
- 5th gen inother countries?
