View Full Version : 5th Generation Maxima (2000-2003)
  1. Cleared headlights on a blue 5.5 gen?
  2. MOTHA FUBBAR (large anti 56k)
  3. What exhaust set ups sound good on this car?
  4. Stupid birds...
  5. PLEASE HELP!! Big problem with strut
  6. KYB-GR2 Struts w/ Vogtland Springs (56k enter at own risk.)
  7. suspension sticky got updated
  8. '02-03 Subframe Connectors
  9. Aftermarket Clutch for a 6 speed maxima
  10. Thinking about adding some ghetto pre tension to my springs
  11. 5th gen aftermarket steering wheel adapter
  12. Need help replacing exhaust manifold stud
  13. retroed ebay lights ....jacked!!!
  14. Slotted rotors and stock pads
  15. Changed OUT Redline MT90 from my 6spd
  16. evap cuase big mpg change?
  17. Which o2 simulator do I need?
  18. *Vibration* but not from unbalanced tires
  19. I have $500 to spend
  20. To All My Maxima 2001 Se Owners Out There!!!
  21. Silicon sealant for tail lights... A question
  22. Need help from the org finding parts this shape
  23. suspension almost done, but what else?
  24. Vibration
  25. Extended Warranties... newbie question
  26. 2K Max Bad Coils DIY replacement
  27. Losing Overdrive on long highway drive
  28. Muffler difference?
  29. KYB GR-2 struts 00-01 vs 02-03
  30. LED Tailights?!?!?
  31. Polyurethane Bushings on 2003 Max
  32. Clicking and vibrating - front left '02
  33. My Little Project With Pics
  34. Torque Converter Question
  35. A/C behavior
  36. D2Rs in fogs?
  37. oil cooler?
  38. damn headlights.
  39. I must be tripping
  40. clicking sound from left rear of car
  41. Window Tints
  42. Suspension Upgrade-Satisfaction
  43. 03 Rear Bumper replacement
  44. Buying a 5.5 this weekend... need help from you guys
  45. needs new lower tie rod..right price?
  46. Progress RSB Installation
  47. wow your right, this made a bigger difference
  48. need help w/ aunt's maxima
  49. 2000 Calispec question
  50. lights out?!?
  51. Over-charged AC
  52. 2k2 automatic hesitation issue in second gear
  53. weird noise when starting car
  54. intake and rims ?
  55. MASSIVE brake problem...
  56. Passenger Window switch LED replacement
  57. Hotshot headers and polyurethante motor mounts, step in.
  58. Is there a how-to .....?
  59. How hard are the ES bushing to install
  60. Windshield Noise?
  61. Random missfire
  62. they stole my lights!!!
  63. Car not starting, need a little help.
  64. Stillen rear sway bar.
  65. my cars been shot! call the ambulance
  66. Where can i get a base paint spray
  67. HELP - Rear side marker trim piece removal
  68. Alright just a post to make sure I'm not missing anything
  69. 6spd shift knob options!?!
  70. 2003 bose 6 disc head unit
  71. A/C problem?
  72. A/C Problems
  73. Polo/others with ES Front LCA bushings, step in...
  74. BLUE BATMOBILE side marker overlays (**PICS**)
  75. need to locate evap canister & vent control valve
  76. HELP - Changing Brake Pads, QUESTION
  77. Tightening handbrake handle - feels very loose
  78. Run of the mill mods
  79. I was tripping when I saw this
  80. need opinions
  81. Trunk Emblems
  82. how far to compress caliper pistons
  83. drivers side rear window wont go down
  84. bbk problems 300zx/cobra
  85. Extra storage
  86. Best Brake Pads?
  87. Doing a complete tune-up, what should i change?
  88. Engine Code P0420 - Catalyst Effeciency Below Threshold Bank 1
  89. Cattman Exhaust ?????
  90. MTEC fogs
  91. P0420 & P0430 codes... how to fix them?
  92. Tightening Front Bumper
  93. 2K alternator bad!
  94. Want to clarify
  95. Tired of saggy spare tire covers? Step inside
  96. Metal on metal sound on startup?
  97. Looking into grill options
  98. O2 sensor P0138 and P0140 ECU flash
  99. Blehmco Big brake kit questions
  100. help with electrical problem.
  101. P0011- Should I be concerned??
  102. quik question... bout intake
  103. LTB question
  104. Need help installing SS clutch line
  105. Tein SS Drop.......PICTURES INSIDE
  106. Starter replacement
  107. AT leak
  108. 2k2 hid problem
  109. Does anyone make a stiffer FRONT sway bar?
  110. Theft
  111. New Header + Stock exhaust clip *calling puppetmaster*
  112. XM subscribers step inside.
  113. steering wheel vibration after putting on 20's....why?
  114. LSD in an 01 non-AE?
  115. got rear ended...
  116. o2 simulator voltage question
  117. 5.5->6Gen BBK line question
  118. Anybody use Energy Suspension Polyurethane bump stops?
  119. Eibach Springs Installed Pics/Initial Review inside!
  120. 5.5max sounds like it has air coming into the cabin at hwy speeds
  121. Engine Signal wire? Where can I find it?
  122. No more bottoming out with H&R.
  123. Tein SS installed...
  124. 2003 SE vs 2005 SL handling
  125. Quick question about top speed
  126. Dealer take ??
  127. Something hitting the floorboards from underneath
  128. Anyone else's MPG guage way off???
  129. 5.5 Gen Muffler Question
  130. Engine Guru's Help!
  131. Need Help with spring install pics inside
  132. Running low beams with High
  133. anyone have a stillen lip with ae sides?
  134. Bose/Radio issues
  135. has anyone tried these replacement headlights?
  136. Oil change and ABS light
  137. MAF dying today... :(
  138. wtf....
  139. When to do a flush vs. a fluid change?
  140. Catch Can...does it make a hissing noise?
  141. Place Racing + Hybrid CAI - nice results
  142. Exhaust leak threads
  143. any help please..with gearshift
  144. drove a 5.5gen 6spd today......
  145. 5th gen on ebay... see a problem?
  146. SES Light - HELP please!
  147. Sea Foamed -> white smoke/deposit -> orange deposit
  148. is my slave cylinder broke?
  149. H4 bulbs in foglight??
  150. need to confirm a few thing about suspension
  151. Transmission Pan, Help Immediatly
  152. 2000 maxima top speed
  153. spark plug question
  154. Removing Rear Struts/Springs
  155. Exhaust tips w/o cutting stock exhaust
  156. Brake bleeding procedure?
  157. SES after car was on lift... twice
  158. '02 Base model SE 6MT ???
  159. "performance" alignment?
  160. New Tail lights?
  161. Finding the right 5.5 gen :(
  162. Oil found on tip of spark plug...
  163. To ANYONE who has non-installed aftermarket springs...step in
  164. Question On Codes/Check Engine
  165. An update after 15K miles with new brakes :(
  166. Clutch & flywheel question
  167. o2 sim problem
  168. Is it drive skills: '01 GXE 5-spd vs. Infinity G35?
  169. Flywheel position sensor
  170. problem,,,please help!!!
  171. frikin brakes again
  172. Sporatic Brake light
  173. Tinting Sunroof
  174. Oil leak in the spark plugs...
  175. rear brake light
  176. 5spd vq35de
  177. 2000 gle turning off
  178. anyone seen 300zx wheels on 5th gen?
  179. Need help choosing springs
  180. Are you using alignment kit w/ your lowering springs?
  181. Got Brake Fade Today need some info
  182. Cutting Bumpstops does this sound right?
  183. Front drivers side noise
  184. is 1000 high idle & IACV
  185. Flashing Airbag light
  186. Question for those with 2k4 Caliper Upgrade
  187. Halo Preojectors Headlights
  188. Strut dust boots - anyone have "aftermarket?"
  189. Spent 2 hours doing my first brake job...but questions
  190. Help with piggybacks!!
  191. Descreening MAF?
  192. Question about wheel bearing
  193. Quick code that dissapears?
  194. which rear brake pads to get?
  195. Fog Lights in a GXE
  196. HLSD problem?
  197. 9005 Piaa bulbs...problem...please help
  198. front strut bar
  199. Alternator Replacement HELP!
  200. Are the 350z cams the same
  201. e-brake "problem"?
  202. courtsey MAF replacement...
  203. Engine light goes on and off depending on weather
  204. Possible Additional Mounting location for SFCs
  205. rattling on acceleration
  206. Hella Supertones - Must use Hella Relay?
  207. Beating a dead horse--> 02 MT lips same as 02 Stillen Aero??
  208. Where to get shock/strut boot?
  209. warspeed y-pipe
  210. should i sell my auto and buy a stck??
  211. Installed MAF improperly?
  212. Illuminas w/ Front Springs Installed Only??
  213. 5.5 gen leather seats fit in 5th gen?
  214. E-brake replacement on 01 available?
  215. Sticky caliper: suggestions...
  216. Another POS Ebayer...
  217. 3.0 Six speed ???
  218. cheap wheel bearings?
  219. trying to find something out for a friend [selling a 2k SE auto]
  220. shattered sunroof
  221. Cf Hood
  222. VB mod what is it?
  223. Is Cold Air Intake causing this?
  224. Fog Light Rewire drain battery?
  225. Blinker problem...
  226. Change Flywheel leave stock clutch?
  227. engine valve clack
  228. Anyone tried these grill kits
  229. The Good And The Bad 56k warning
  230. Brake pads for 5th gen maxima(2000)
  231. Widest tires w/out rubbing?
  232. Window Tint Hahahahaha
  233. Stillen: oil cooler
  234. Do you need camber plates with the EIbachs?
  235. is this normal?!!
  236. Stop and Go = High Idle
  237. P0138 & P0158 codes
  238. Need Ya PPLZ Help!!!
  239. shaking while braking/driving
  240. Will 02 Place Racing intake fit 00 Maxima?
  241. super lean a/f ratio at idle!!!
  242. I cant believe this.... I'm so upset
  243. air/fuel ratio guage
  244. Car Shakes while applying the brakes
  245. dealer says timing can't be changed HAHA
  246. hate my seat....anything better out there?
  247. SES Appears & Disappears in 300 mi.?????
  248. which rear sway?
  249. New 5th Gen Owner!
  250. Big Thanks in order!!!!! IRISH44J AND EVERYONE ELSE INVOLVED
