- Need ECU help...
- Heat shield from catalytic converter fell off
- I did another first for the 3.5!!!
- 5th Gen on 22's, was bound to happen
- Help with DTC P1706
- Chrome gauge rings...where can I get them?
- Newb question :P
- Need one more favor from ANYONE before I finish the LED cluster...
- Steering wheel discoloration issues. White Speckles!
- Need Help With SES Code P0455. Gas Spout The Problem?
- Alumninum CAI machined for 01 MAx AE
- Posting
- Motor mounts?
- Thud Under Right Wheel Solved!
- HID's ?
- lookin for pics...
- Shopping around for H Tech's, just a Q
- will 4th gen rims fit on 5th gen?
- Gas stuff
- Gun Metal 17" Stockers *pics*
- Lookie what I got...
- ground question help
- Why it's important to periodically check the tightness of certain bolts.
- Hid ?
- KYB GR2 Install
- Just totalled my baby :wtc: 56k warning
- Maxx Tunning Lip
- Got My 2000 Maxima GLE! but have a question regarding lug pattern
- How Much Should 90k Maintenance Cost??
- HELP: Which is cylinder #1 on 3.5L?
- pics of aftermarket fog/driving lights (non-bulb upgrades)
- Courtesy Nissan..
- Will an AE key work for an 02?
- SES Code help
- clicking when accelerating
- Passenger Door Rattling Noise
- SE Tails?
- Bike Carrier question
- Removing Stock Spoiler
- Can You Paint Your Sidemarkers With A Specific Kind Of Paint?
- Anyone go from 4th to 5th gen? What are your impressions?
- Side Marker Help Please..YEa I Searched...
- How much did you get your hood repainted for?
- *** new stuff for my ride *** (PICS)
- Fun with error codes
- Looking for a replacement stock Grille for a 2002
- loud random screeching noise -
- So I took out my fogs today, and..huh. Do I need new ones? (pics)
- Has anybody done this rim set up yet?
- help with my climate control
- climate control light went out need help
- In Search Of A 5.5 gen part
- Help please, clutch/tranny problem
- Transmission fluid leaking
- Oxygen Sensor replacement for dummies
- 5th gen compilation video
- Steering Wheel Repair/Replacement
- hot weather...poor performance
- OEM Alternator vs. Optima Yellow Top...guess who wins?
- Price of new cluster? Roughly...
- B1 S2 harness Location for fed spec?
- Shocks and the big decision
- Brake worries?
- 17* ingnition timing
- Blown Illumina < 8k
- berk intake?????
- where could i find a...?
- Rear Squealing Noise
- i need the best struts out there!!!!!!
- 2003 NISSAN MAXIMA SE Hypergrounding Kit PowerPoint Presentation.
- front end jack point?
- Question bout the cat. converter?
- 5.5 Gen Maxima TV Commercials - For Your Viewing Pleasure
- Where To Get Blue Bilbs For My Rear Turn Signal?
- Parking Light out (and one more question)
- ABS Dynamics plastic rear lip fitment.
- "stillen" VS "catman/progress" RSB (stillen worth the extra$$$?)
- Need Help ASAP from ANYONE!!!
- anyone buy 7000k or 9000k d2r's from the helios group deal?
- More problems, No heat, blows ice cold with climate control set at 32*C
- 350Z Intake Plenum with Greddy Spacer!!?!
- 2000 Maxima overheatting
- Warped Rotors
- Obx Udp
- Helios kit on ebay projectors
- are there any other hood styles out there?
- Replacing rear 02 sensor. (question)
- Need Help Bad
- brakes dragging
- just bought a 04 max se
- Alarm Beep Mod??
- Navigation Doble Din vs. GXE Double Din Kit
- Transmission Troubles - torque converter not unlocking while coasting
- Front Suspension Clunk noise! Why??? help!
- Idle problem after starting
- 2001 vs. 2001 AE Owners Manual
- Steering wheel feels funny.
- Finally! My Pics and Initial Review of the Custom SFCs (56k No Way)
- Strut ?
- LED front side marker retrofit (pics inside)
- quick bulb question
- HELP!!! Can't get rid of O2 code!
- quick question
- Anyone else have rust here by the engine? (pics)
- Having a stock Flywheel turned?
- can you clean O2 sensor or must change?
- gold wheels
- In the market for a 5.5 Gen... couple of questions before I decide to purchase!
- Compare 00/01 to 02/03 front bumpers
- Question for people w/ BlehmCo Lower Tie Bar II Installed on 5.5 Gen
- 5.5gen, randomly wont start
- Optima Red Top
- 6th gen rims on 5th gen questions
- CAR AT DEALER -- Emissions Problems - Did I pay too much?
- a/c inside the car
- Belt Tensioner, order of bolts?
- Exhaust Flange rusted out???
- Anyone hear of Street Legal powdercoated calipers?
- Lexus Capsules With HIDs
- Alternator and Brake warning light....wtf?!?!?
- anyone have the O2 sensor diagram? bank 2 sensor 2 location?
- dash lights on
- Who had the G35 coupe spoiler?
- RPM's going up by themselves
- 3.0 or 3.5?????
- P0430 and P0420 pulled..
- Light bulb help
- What size belt.....
- bose stero acts up with CD's
- Need help ...po430 and po420 question
- clear corner bulbs
- Towing?
- What option should I get?
- About to buy my first Maxima, NEED HELP!
- Guaging Interest In SFC Production
- which intake???
- SS Clutch Line install...what a PITA!
- Easy bolt on 20MM spacer?
- suede?
- 2002 Coolant Bypass?
- what is pinging noise?
- Indications of transmission slippage in 2k SE..?
- SES Light
- Found out 2002 SE I'm looking at is an off-rental.. what to do?
- 5.5 gen Manual AC Climate Control LED Mod
- Do I have any choices for different Auto Transmissions?
- "service engine soon"
- $150 For A Recharge On A/c At Nissan?
- 2000 Maxima SE - First 100K Impressions
- IACV question
- Engine isnt running strong
- LED Tails...first pic
- how to get fog light bulb out?
- So I picked up my new MAx today and...
- RSB ?'s (fishtailing in winter)
- anyone use this- mikes V1 mirror mount?
- having your car learn your style
- Underhood squeak when A/c is on
- Family Drive less Ordinary
- 00-01 rotors same as 02-03?
- Sorry but im having an intake issue
- Auto transmission kickdown
- BlehmCo LTB st. 1 installed (+pics for those who are worried about ground clearance)
- Wheel vibration!
- downloadable 02-03 fsm?
- Soft Brake Pedal
- Funny Feeling in steering
- 00 Seat Covnersion Questions
- Radiator Shroud Update...prototype Is Finished
- holy sh*t! $500 for o2 sensors!!??
- battery and brake light came on, don't knwo what's going on.
- SM 5th gen OEM 17's painted request
- Clicking noise Driver Side
- Door insert ideas needed
- Possible Solutions for Stuck Oxygen Sensor After Header Install
- 2K1 Climate Control
- 01 Maxima steering wheel hub
- Correct Alternator?
- Grinding/scraping while making right turns
- Broken Fogs....again
- abs pin location
- Ae lip 4 a 03 max
- question about my hp numbers
- Failed Inspection
- Another oxygen sensor thread
- I searched but i think i just sucks at searching
- Removing oxygen sensor w/pic
- Overheating
- Screw On Exhaust Tip on my 01
- HELP!!! Car won't start!!!
- taillight ?
- Po 505 ????
- 4th Gen - Upgrade Pending
- 3.5L 5.5 guys step in
- Black Rims/ Blk Max
- Where To Find Freon On My Max 01 Se?
- Projectors 00-01
- fuel pressure regulator
- Homemade O2sim.... need help on sensor theory
- Stock Subwoofer Dead on 2000 Max SE
- no pulsing to the ignition coil???
- help with hotshot header installation
- Squeaking noise
- Max died the last two days, help diagnosing problem...
- Exhaust tip install issue
- Sensor Replacement + Clarification
- my first time driving a stick!!
- swirl control valve... wat is the purpose of this...
- What happened to the Green??
- For those with maxx tuning lip and drop.
- Anyone have the link for the ignition ring LED swap?
- Best springs?
- Just Came From My Local Sound Car Store.
- How To Make Your Headlights Clear Again?
- Weird start-up and warm-up...
- Slow to crank...
- in cabin air filter?
- Crappy find last night..(headers)
- HOW-TO WORKLOG: LED Loaded Instrument Cluster (+60 LEDs!) BRIGHTEST ORG CLUSTER YET
- Greddy Style Stainless Catback Exhaust
- Strange - Blower motor dead or alive
- why do they instruct to reprogram the ecm when mass airflow replaced
- 2K2 Intake Mods to report
- Making sure I did not get ROBBED...
- Clicking sound when applying brake
- all the info. you need for the 6th gen front brake upgrade
- brake question?
- How do I get more H.P.
- Sluggish Below 3000 rpm
- Problem with Power Driver's Seat
- Power Loss after 3k rpm+ VIAS don't know HELP
- Broken Shift Cable Bracket
- alignment necessary after cv axle job?
- Looking at some 00-01 Maximas, need some info please!
- is my A/C compressor broken?
- Changing Drive Belts
- Rattle in front susp, feel it in steering wheel also.
- 2K3 Maxima Resetting ECU problems
- big sractches in rear bumper
- need a/c part
- 15mm H&R rear wheel spacers installed *pics*
- My stock rear shocks/springs gone already??
- ground strap - 2nd cat converter
- **Class-Action Lawsuit anyone???
- 2k MAF Replacement
- Second day owning my car and SES already...
- What Are The Best Tires For Your Max?
- New Photoshopped ideas for a bodykit for 5th gens
- Stealth Front Lip
- Problems tinting back window?
