- Exhaust Tip
- Center Console
- Owners manuals and other tech info
- Brake noises from front....
- Roll Call/ Rim's opinon
- In need of a picture please...
- Muffler to exhaust midpipe mount
- Lookin for some pics
- LED Headlight Mod, Let me know what you think.
- Tseudo Catback...
- How do I
- AC seems weak ...charge it?
- Power Seat (Problem #1)
- HIN @ Flushing NY
- Thank you previous owner
- Rear deck speakers?
- buyin 00+ maxima soon..what to look for
- 2003 6 speed need new floor molded carpet, front rock guard the works help!!
- Bose HeadUnit Buttons dont glow
- WTF is Catalyst Efficiency Below Threshold?
- The rumor has been proved, a K&N CAN knock out your MAF.
- Gear Panel Touchup?
- Maxima Experts Needed : Throttle Body help
- Accident
- black for blacking out hids
- Can you tell from a video...
- Do us 2003 Maxima owners have a knock sensor in our car?
- Ac cycles cold and warm air
- 2k1 MAF on 2K2 = code 0113
- reflace ecm on a 2k
- motor mount swap....
- Remote window opener?
- Changed my plugs today...
- Heat induced brake fade!
- SES code P0442 meens get a new gas cap
- P1320 Primary
- HID theft deterrent brackets
- I need a tranny...
- "New" 03 Maxima SE
- Diagnostic time: What do these codes mean?
- H11 to D2S Adapter
- Car almost died..
- Broken exhaust hangers!!! (Ughh!)
- Anyone ever try to make a new intake snorkle?
- A while back someone posted an awsome page to a bunch of H3s....
- High pitch squeek when turning left
- AC Power Wire Color?
- ES Sway Bar Bushings == 2002 SE
- Made my own Chrome guage rings
- 2k2 HID headlight install on 2k1
- To all of those w/Cleared out Turns signals in 2k2-2k3 headlights
- Customenterprise.com Strut bar; Any good?
- Just got done with oil change.
- Got oil changed...now check engine light is on???:wtf:
- PO171 = Bad #5 injector ?
- How much oil
- No more hesitation
- Climate Control Intake Sensor
- OEM Front Brakes, Aftermarket Rear???
- Ses..........
- help asap
- How high is too high? High beam wattage
- Starting issues...
- Bad tranny?
- Getting rid of pre-cats
- Licsense Plate lights going out...
- Interior Painting and Replacement Project, 56K Beware!!!!!!
- Looking for better brake pedal feel
- Too much oil?
- parkin lights??? wheres the fuse!!!
- KYB GR2s for 5 and 5.5 gens
- Where's the speed sensor?
- What is the fastest 0-60 time for a maxima ???
- Bad Muffler at 64k miles? (plus annoying loud rattle)
- New 5th gen
- anyone ever feel warm air coming in the leg area even when all air is turned off?
- Jumpy Speedometer
- cattman b-pipe ticking
- 1500 rpms wierd noise
- 2002 top speed?
- ECU not saving?
- Timing chain rattle?
- Which Y-pipe for an 02 Maxima?
- M3 Mirrors
- HELP! Knocking Sound From Rear.
- What grille is this?
- Symptoms of blown rear strut
- Is this a fair price to have rotors/pads replaced?
- Aftermarket ECU...who to go with???
- dave b contact
- Idle Air reset not Setting?
- How-To: Changing Spark Plugs on 5th Gen
- dtc 1320
- Towing the Max
- HOW TO: Replace incabin micro filters
- Installing Umnitza DDE's tommorrow
- Suspension Gasket question
- So I let my mom drive my car today...
- Help please: rotten egg smell.....
- Painting Interior Dash Etc
- A/C recharge question
- Does your windshield washer spray a single stream or mist?
- Motivated novice looks to swap out MAF sensor on 2K1
- IACV-AAC valve same as 4th gen?
- Who installed thier own Remote start alarm?
- how to adjust my trunk lid
- suspension troubles.
- 245 / 45 / 18 infiniti wheels, will they fit?
- Arrrrghh!!! ... Help with electrical connector
- want dark tails for 2002
- clutch on 5th gen
- Power Window Problem
- navigation questions
- Another annoying problem
- Location of the A/C evaporator drain tube on an '02?
- Non working windows and door locks Need Help
- Looking for Front License Plate Bracket
- Pinging
- Metallic-Sounding Startup
- Splash Guard Question
- New CarDomain Page Built...
- Got the structural foam in the mail.. things dont look good
- 2k sort of sluggish when accelarating...help!
- Help!! replacing stock HU with Alpine HU
- bumpstop question?
- Replacing interior carpet
- RAXLES CV/Driveaxles....review.
- Installing new alternator: SUCKS, FTL!
- Which glasspack for resonator?
- A/C clutch gong bad? Too full?
- I got owned by my ABS Rear tonight
- belt tensioner????
- How to fix this...
- wts used injen filter
- Weird Question But has anyone attempt to change 5th gen front end over to I35?
- HELP!!!... intake and idle problems
- Strange noise when starting
- Muffler question
- Needed: Exploded diagram of 5th gen 5MT
- reverse light doesn't work properly
- How much cash would you offer for this
- timing cant be advanced?
- cruise cant be set past 100..all or just mine?
- will water/rain damage maf sensor
- Lighting question
- steering wheel not straight...common issue?
- Catman/Progress RSB is in...wow!
- Changed Oxygen Sensor...SES still on
- Squeaking noise from wheels when driving?
- Yellow fogs on ebay?
- Replacing oil pan
- 2k-2k1 OEM headlights vs JDM projector headlight pics...?
- HELP, strage brake broblem
- How hard is it to replace the serpentine & power steering belt?
- Would these make my car look better? Wheel spacers
- Want a stiffer steering wheel
- Stolen Car
- planning on lowering my ride (need help)
- Projectors vs. Stock HID's
- timing chain....question!!! (please reply)
- help with angel eyez
- Bought used Max with extended warranty?
- aftermarket intake > maf
- 4th;5th gen cv boot intrchangeable?
- Need Front Wheel Bearings
- wtf Nissan + changing headlight bulbs FTL + how to?
- Problem with my engine/transmission?
- need help fast! stuck caliper piston
- Took Out Side Markers, Now My Engine Light Came On!!
- Factory corrosion warrenty?
- trunk tension rod replacement
- O.k. - taking votes on an oil pressure problem
- Problem/play in the steering
- PO158 & PO159 bank 2 sensor 2
- HID Installation?
- 5.5 gen Turbo thread?
- Correct harness?
- I just discovered ABS dynamics
- Max dies on the Road!
- Yellow Lens on 02-03 HID Headlights
- Racing seat question:
- Was this color combo made available?
- Warranty upto 160k?
- would a se-r front sway bar fit?
- What bulbs?
- Are these rotors any good?
- Black Nissan Burger Logo
- Restrictor plate...
- Washer fluid filler filter
- Metal scraping sound from exhaust
- HELP, rough start after washing engine bay
- I need stock exhaust pics
- 2000 maxima thermostat replacement
- Front Pipe??
- High idle RPM's, does it hurt? fix?
- LTB II and RSB squeaking/thumping
- Exhaust leak :(
- P0300 and maf?
- Half on some spacers.
- Anyone have any tips on Optima Install?
- Intake Noise question
- Time for tune up?
- Wheel Spacers
- Mass Airflow Meter sensor sellers?
- Whine when accelerating - transmission?
- HID lens cover
- Transmission or something else ?
- Clicking and Thumping
- Problems I need help plz
- Can't top certain speed - is this normal?
- window problem
- Monroe Sensa-Trac
- Resetting ECU
- ksports
- trunk bolts
- Oscai
- HowTo: Homemade O2Sim for <$10
- Wheel squeaking all the time.
- Ashtray?
- Oxygen Sensor Blues : P0140 & P0160
- KYB GR2's now listed for '02-'03 5.5 gen...
- After 5 months my painted Gunmetal OEM 17s look like......
- For the 5.5 owners with stock intake
- True or False? Only 10K 01 AE's Produced?
- checking the timing
- Overheating (solved)
- Does the 5th gen springs fit the 4th gen???
- Car broke down
- front end colision got Q a/t headlights.
- Funny viberation in steering wheel.
- where do you guys buy your brake pads?
- Camber Kit Needed? Going with Eibach Pro and Illumina's
- 5MT digging in the wallet again.
- Full time VAIS
- Quick question to all
- intake question
- Sterling Mist AE's
- TRANSMISSON PROBLEMS!!..help..
- thread pattern?
- Custom Radar Detector Mounts
- What the? Ever find this in your airbox?
- Intermittent Misfire
- How To: Air Filter Change :wall:
- Not happy with the viberation
- reverse light bulb number...
- Anyone have pics of their cargo net installed?
- loose hand break, cant seem to tighten..help
- 5spd owners...
- Whats wrong? Slower than a 4th gen....
- Need some Ideas on How to inject structural foam into the SFCs
