View Full Version : 5th Generation Maxima (2000-2003)
  1. Putting in a new AE LSD Auto Tranny. Want to make it better first.
  2. Some autocross action (photos/vids)
  3. HELP ASAP: Axle Boot Cover Thingy Ripped
  4. Help!!!!! Brake paddle goes down doesn't stop!!
  5. clicky sound
  6. can you put front brakes on the rear?
  7. Front Window Problem When Using Remote To Put Windows Down
  8. Parts manufacturers....step inside
  9. Need help with changing brake pads
  10. HELP...SES Light = IVT Control P0021
  11. Ugh, bad ABS Wheel Speed Sensors
  12. How do I clean my Stillen intake?
  13. Having Trouble Removing Rotor From Car!!!!
  14. power window issue...please help!
  15. Brake hardware kit + PBR Brakes. Help!
  16. question about 2k2 m/t shift console
  17. Hard to get out of park
  18. fog light help
  19. Cheap gas sound
  20. Got into a little accident
  21. 01 Motor with 00 Manual Tranny?
  22. pictures of my headlight swap
  23. New Drilled + slotted Roters/ Pads?
  24. 03 to a 01 SWAP?
  25. Tranny Solenoid Price ?
  26. Progress or Stillen swaybar?
  27. Transmission Replacement Cost
  28. Piggy back/New ECU?
  29. IACV & Idle woes. Expert advice needed! SEARCHED
  30. Rustproofing??
  31. Gas Gauge
  32. Need help asap with headlight swap
  33. 2000 Maxima Speedometer: Needle is not lined
  34. How to prevent your rear ABS lip from melting!!!! *PICS*
  35. PCV valve rubber housing ripped open
  36. apexi ws2 or magnaflow street muffler
  37. Muffler change
  38. Grinding In Reverse -- Auto Gurus Help!
  39. Exhaust :) ??
  40. Where To Get Hids? What's The Least They Go For?
  41. question about tires size please help.
  42. Engine Mods AKA getting more power
  43. Splash Guard-Passenger Side
  44. Custom Fender Flares
  45. Clutch has Zero Pressure
  46. I have a few questions about swapping 5th gen headlights to 5.5 gen headlights
  47. How long is our resonator & How hard is it 2 uninstall Bpipe
  48. Question
  49. Headlight Question
  50. question about oil change interval.
  51. help i need how on foglight rewire w/pics
  52. has anyone done the conversion
  53. look at this gheyness
  54. need directions to take off front bumper,, safely!
  55. Please excuse me while I puke.....
  56. Changed caliper now brakes are squishy
  57. Question about 02-03 Maxima CD Changer
  58. Oil loss - diagnosis from dealership
  59. mag width
  60. So it finally happened to me.. my altenator..
  61. Axle seal leaking, end play inside - HELP
  62. Best Place To Buy Calipers, Break Pads, And Rotors?
  63. Grille Kit Adhesive Inserts - Nice touch or cheap look?
  64. Humming Noise
  65. I have an idea for Tail lights
  66. Koni Yellow Install
  67. A/C amb sensor, where is it???
  68. how come?
  69. Difficult question re. computer
  70. GAB CAI in the making... come inside.(pics)
  71. P0442 Code help please.
  72. P1126.. please help
  73. Looking to buy a max, a little help
  74. P1456 - EVAP Emission Control System Very Small Leak (Positive Pressure Check)
  75. Fuel Temp Sensor Code?
  76. Car Cover Question
  77. Diagram needed
  78. 3/8" Husky Mini Air Filter non-existant?
  79. Old owner, new Max...
  80. 00 Grill Removal.
  81. stillen questions
  82. Where To Purchase A Fuel Tank Door? Plus.............
  83. Replacing the Splash guards on 5.5
  84. Looking at buying a 2k2/2k3 Maxima...a few questions
  85. Vibrations and Ride Quality Issues
  86. Sway Bar
  87. time for a change
  88. The noise is driving me nutz!!
  89. Ground Wire Identification
  90. door handles
  91. Installed Blues this weekend - quick review...
  92. Who Has Tien Coilovers?
  93. oil catch can problems
  94. K&N Air Filter?
  95. suspension install help! dr klop, puppetmaster step in! *pics included*
  96. cool sound.
  97. Broke my shift cable
  98. 00-01 Stillen Lip owners...
  99. Installed one wire out of the "Big 3" and wow....
  100. What are the size of bulbs in our headlights? The small ones on the side
  101. can somebody measure there frankencar intake
  102. Parking light won't come on
  103. Car seems slow.
  104. front brake caliper bolt (14mm)
  105. Stupid Brakes.
  106. cheapest place to get h&r springs please
  107. Polishing Plastic Manifold
  108. Grounding Kit Power-Point
  109. Different gap for Iridium?
  110. oil catch can
  111. greddy evo 2 sound
  112. 2002-2003 Fuel Filter Replacement Write Up.
  113. Pic request: white max with black wheels
  114. Soundclip - 00 Max w/Cattman Y, Frankencar Catback, PR CAI
  115. Help! - Need to order a new caliper bracket (torque member)
  116. Is it a MAF issue?
  117. Is Nissan Required to Fix TSB's?
  118. Radiator Leak
  119. Fix for rusted exhaust?
  120. A/T fluid change?
  121. Alternator replacement issuses
  122. Timing Advance & Frankencar Intake Done!
  123. For all with HID fogs, where did you mount the ballast and igniter?
  124. Urgent question please - Are there only two bolts to get our fogs off?
  125. MAF test?
  126. Which STOCK 5th gen tail light you like best?
  127. Suspension + OEM Components
  128. CCFL Angel Eyes anyone?
  129. aftermarket ebay key
  130. Clutch slipping, or something else?
  131. Maxima God has blessed me
  132. the campfire will be around my exhaust...
  133. Evap Canister Trouble Code
  134. Re: Changing My Injen's Filter
  135. Which trim to go with, Navi or GXE?
  136. Color Matching
  137. Brake Pad Comparison?
  138. NEED HELP ASAP: muffler question
  139. Need some headlight help ...
  140. Rear Axle
  141. Same SES Code - Twice!
  142. N1 CAT back legal?
  143. Wheel Bearing
  144. shifting into first really stiff!!!!
  145. Rotors and pads ...
  146. I need your help on nissan maxima side window
  147. Why does a CAI make it louder?
  148. Failed Smog (high NOx)
  149. Has anyone ever replaced their throttle body?
  150. Dumb question about o2 sim.
  151. headlight bulb change
  152. Has Anybody Fixed There Calipers?
  153. Really LOUD radiator fans
  154. HELP, car starts then dies, but drives great
  155. Strut Bar
  156. 2 noob questions sry!
  157. 02sim install... What a pain in the a$$!
  158. Tokiko Suspension Kit
  159. Question about front grill crome trim
  160. Tsudo Catback Silencer Removal Solved
  161. XM install recommendations
  162. Removing front seats with airbags
  163. 350/g35 plenum
  164. Help protecting my Maxima...
  165. Rotors and Pads for my 2K
  166. New Front Lip / Bumper Replacement???
  167. Tsudo Catback Installed
  168. Help, transmission issue???
  169. 00 Maxima(Auto) overheating help needed ASAP
  170. Need HELP ASAP Diagram/Picture of Rear Shock Assembly
  171. Loss of power
  172. Belt Replacement Guides and Suggestions
  173. Transmission Problems
  174. Wheel Locks on 5th gen?
  175. Sppark Plug Replacement... Unfortuanately
  176. how to tell if shocks are blown while taken off the car?
  177. Airconditioning Condensate Drain
  178. wtf is going on?
  179. Weekend elbow grease, plugs, oil, etc...
  180. gring third gear....
  181. sunroof programing
  182. Part # for NEW ignition coil
  183. maf and reflash
  184. New exhaust clip w/video
  185. New Rotors, Lines, Pads, & a quirk?
  186. Bracket underneath the car broke
  187. JDM I30 found
  188. i'm getting a LTB.........
  189. Battery and Brake Light Displayed At Same Time
  190. How much do our doors weigh?
  191. Hood Dents
  192. Air Conditioning not as cold at idle
  193. Possible Power Loss?
  194. Fuel economy
  195. Wobblie Streeing wheel. Help please!!!
  196. VIAS stripped screws
  197. Brakes...what could be wrong?
  198. Removing Hood Insulator
  199. Pics of Blue Batmobile overlays
  200. Broken rear caliper bolt pin
  201. AC Compressor
  202. Need help please and ive only had her a month!
  203. Opinions, Opinions
  204. How to
  205. post your pictures of your 5th gen with axis seven mods
  206. New fuel filter for 2003 ... does this even look right?
  207. Your OPINION please
  208. Fan Belt Noise
  209. SES light went on????
  210. 2k-2k1 headlight housing problem & Q about AE mod
  211. Passenger rear view mirror just broke off from the base
  212. any suggestions?
  213. Body kits ( I searched)
  214. not as much pep as she used to have
  215. Any OEM mp3 player available for our cars ?
  216. Where to buy bulbs?
  217. still safe to drive
  218. HID protection
  219. Bulb Help ?!?!
  220. New max owner here, few questions
  221. OBD II Code 0011
  222. bose screen goes blank while radio is on???
  223. BWUHAHAHAHAH....Puppetmaster FTW!
  224. Third Brake Light Option...
  225. TACHOMETER Recalibration
  226. Optima Red Top install
  227. Creaking noise from rear suspension
  228. Loud Noise Coming From My Right Rear Tire!!!!!
  229. Headlight Covers?
  230. Where can I buy a TPS sensor?
  231. who has eibach front only drop? or any other front only drop?
  232. Bushing Question
  233. 5th Gen / 5.5 Gen Header Thread
  234. 5th Gen Sterling Mist with Lexus Capsules(56k beware)
  235. watkins sts
  236. HELP with LED taillights
  237. have the hlsd pedel's but acording to the vin i have to hlsd?
  238. Ignition Coils
  239. Money better spent on an Exhaust or Intake?
  240. Staggered Wheels On 2000 Maxima Se?
  241. 2000 - Battery help ...
  242. This sucks.
  243. What happens when the VQ wears out?
  244. First thing to go
  245. GXE fog light hole filler sucks
  246. help real quick!
  247. 02 Fog light install, bumper off or not?
  248. Finding the cure for Bose subwoofer
  249. Exhaust Tip
  250. Center Console
