View Full Version : 5th Generation Maxima (2000-2003)
  1. Coolant Prices
  2. Need help replacing the B-pillar trim in a 5.5 gen.
  3. Frankencar Intake
  4. Stripped crossmember bolts
  5. How To Advance Timing?
  6. Silverstar headlight bulbs problem or a normal electical issue that happens with age?
  7. Where Do You Hide Your HID Ballasts?
  8. Does the dealership fix TSBs for free???
  9. Any BC Racing Coilover Users?
  10. Camry bbs wheels on my sheer silver Maxima?
  11. Need advice, 2001 20th Maxima, P1126 & P0430
  12. Suspension Upgrade - Parts List
  13. What color wheels for grey lustre?
  14. Annihilated Maxima
  15. ebay headers+link.. opinions?
  16. Installed - BRAND NEW Cattman Y-pipe.
  17. cattman catback wo cat.
  18. Temporarily Losing Clutch on Hot Days?
  19. New exhaust I call it Cattman knockoff. Check it out(video)
  20. 5.5 Gen Oil Leak @ Oil Cooler
  21. Power Steering fluid leak. Please Help?
  22. Ypipe, Bpipe, RLKYM..WTHpipes? Im confused
  23. Change in stock tire size
  24. Stupid floor mat clip... any ideas?
  25. Umnitza angel eye upgrade, and clear spoiler light
  26. Got Rid of My Front End Clunking, Rattle, and Squeak
  27. What color caliper on a silver/chrome max? silver or red?
  28. black out badges?
  29. Time To Replace Rear Struts?
  30. Any videos of 5.5 maxima with 4th/5th Gen Maxima headers.
  31. 01 clutch issue, non-returning pedal
  32. Replaced IACV now rpm gets stuck arnd 1500
  33. 2002 SE headunit swap
  34. How does the reliability of an 02 Max compare to 1997 Max?
  35. 6 speed mileage, 31MPG?
  36. Quick Question
  37. sunroof stopped working?
  38. Car Won't Start, Suspect Bad Gas (Vid Inside)
  39. Looking for someone who can RR Trailing ARM Bushings NY/NJ/CT
  40. Figure out what's missing thread.. Yup.. Prize
  41. Resonator Jig!
  42. Timing Chain
  43. Want to paint stock SE rims
  44. strut and rotor question
  45. Front Strut Bar and Rear Strut Bar
  46. Changing my valve covers
  47. My homemade Lowes mod race ramps
  48. Is it safe to drive my car??
  49. 02-03 Owners with cracked fog light(s)
  50. Headers off 01 for my 03???
  51. Water in Catch Can
  52. How much HP would i get.
  53. 3" Testpipe from a 240sx
  54. Looking at buying a maxima: Lifter tap at startup?
  55. Drove through water....HELP!
  56. New Converter?
  57. What is this?
  58. Will a bad MAF cause hard starting?
  59. What do worn motor mounts look like?
  60. new hid, same bulb but different color
  61. IS there a write up for a auto to manual conversion for a 2k max!?
  62. How long should a manual transmission last?
  63. Request Pic of Installed frt sway bar end links on car
  64. electrical parts for headlights...WHERE TO BUY??
  65. Seafoam - yay or nay
  66. Buying electriclal parts
  67. HELP car wont run!
  68. Calipers
  69. Rear windows
  70. Need the min rotor thickness for stillen drilled rotors
  71. Eyelids...to paint or not to paint
  72. Please post pics of your wheels. Looking for maybe Volk GT-C Face 1's??
  73. clicking sound at 2000 RPMs
  74. MimoUSA F1 fenders
  75. Airbag code B6
  76. 02 sensor wire
  77. On the verge of selling my max...
  78. who has vfac?
  79. Hesitation Problem
  80. replacing radiator
  81. Time for a major tune-up
  82. Getting to Bank 2 Sensor 2 (b2s2) Cali
  83. Carbon Fiber Hoods Require Hood Pins?
  84. Check engine light was removed from 5.5 gen
  85. Just got a 5th gen
  86. Injen or Stillen?
  87. Whirring sound before and after turning key and off engine. VIDEO
  88. A little help plz..
  89. Cleaning 5.5 gen throttle Body - with pics
  90. license plate lights r out
  91. Really strange noise
  92. Reflash for O2 issue, whats that going to cost?
  93. Make Custom Headlights (AE)
  94. VIAS fix in progress!
  95. my second time at the track vids
  96. CV shaft nut will not stay tight
  97. no interior lights
  98. Rear Valance? Pic inside
  99. Dumped Axle back, With vids
  100. Searching for 5th gen Maxima video, Supercharged and really loud
  101. alternator problem...maybe?
  102. WTB: 01 yellow fog tint overlay
  103. shock question oem
  104. I found this lastnight
  105. Clutch Rattle
  106. car surges or hesitates while accelerating hard
  107. just venting...but HEY THERES PICS!
  108. Just installed CAI- Do I need to do idle relearn?
  109. Redlinegoods shift boots...
  110. MOOG ball joints and rod ends
  111. Magic sponges
  112. MT Gear lube?
  113. HID upgrade better than expect in stock housing
  114. Maxima boredom
  115. Rattling
  116. Used Wheel speed sensor
  117. A Maxima is a Maxima
  118. cant drive stick
  119. Roof Spoiler Pics.. Any??
  120. alternator bolt WTF
  121. please help my cruise control won't work
  122. Jdub Side skirts
  123. A/C Squeaking badly...
  124. Removal of front and rear driver's side door panels
  125. Lightweight Flywheel Noise ?????
  126. engine starts then dies
  127. Knuckle Removal
  128. Is it my brake fluid?
  129. Anyone ever seen this bumper?
  130. 2k>2k3 interior swap
  131. 2001 Max SRS Light Flashing: Code saying Passenger Seatbelt Sensor?
  132. Wiper Problems Part 2
  133. Will man motor mounts fit auto cars.
  134. Engine Cover Emblem Needed
  135. What is your Opinion? Buy this car?
  136. are body parts interchangable?
  137. clueless on piggyback
  138. Ipod configuration 2002 Maxima Se NO CD CHG BUTTON OR CHANGER
  139. Best suspension setup for our Maximas?
  140. tokico illuminas off a sc300..
  141. I need help!!! car running in limp mode
  142. I need help!!! car running in limp mode
  143. Intermittent brake light problem
  144. Seafoam is a wonderful product!
  145. 5.5 headlight mod
  146. Illuminas Installed
  147. Where does this hoes connect to?
  148. Load dependent rumble
  149. Need definitive answer on coolant type...
  150. Strange alignment issue(car pulls either way)
  151. 3M Headlight Restoration
  152. Where to buy..
  153. Rear Strut Boot
  154. Would this change my exhaust sound?
  155. Wheel bearing woes
  156. Funny Story
  157. Gutting pre-cats bad for your car ??
  158. Need help disabling factory alarm.
  159. NWP Spacers on 2000
  160. how do u wire subs into the bose system
  161. TOKICO Illumina Shocks
  162. Extremely loud cluck and rusty metal sound
  163. nwp spacer reapplication
  164. Insurance Model Description
  165. Steering wheel vibration at high speeds... several things done... what else to do?
  166. steering wheel "wobbles"
  167. Need pics asap > Evap system...
  168. paint job?
  169. RPMs dropping lower then usual..
  170. What should i look out for
  171. Dead clutch pedal
  172. (A few issues) I hate my car
  173. gas thieving rant
  174. Engine Disaster
  175. New Window Problem... 01 Maxima
  176. Gauge Cluster question
  177. Final Upgrade for the Summer?
  178. Am i upgrading or Down grading???
  179. Confused about SSIM..Spacers...block plate.
  180. Whining noise coming from engine
  181. ECU AND FOG LIGHT QUESTION
  182. 5.5 gen grey lustre
  183. Burnt Steering Wheel
  184. Wire problem
  185. Nismo Thermostat?
  186. Air bag light blinks
  187. How long is my max gonna last?
  188. Hot restart no start problem
  189. Wheel Bearings problems?
  190. engine may be shot or bad crank pulley
  191. illumina impressions after a few months
  192. Driver side Window Issue
  193. Ground Wire Diagram and/or Ground Wire Kits
  194. Intake Swap!
  195. Carbon fiber hood
  196. bad balljoints?
  197. OEM keyless remote isnt working
  198. Questions about HID Highs and Fogs
  199. EVAP codes GONE! but now two new codes :( O2 sensor(s) help/thoughts? easyto replace?
  200. Suspension Plans for 2010 – Tokico Blues, mounts, and what else?
  201. whats the difference between 4th gen max LSD tranny and 01 AE LSD
  202. Oil Cooler issues??
  203. HID conversion issues. help?
  204. Unique Transponder Key Question...
  205. struts
  206. Transmission fluid
  207. I remember when my car used to get good gas milage...
  208. New ES Control Arm Bushings installed today
  209. Ur kidding me...No write up for auto trans Replacement?
  210. Sell AT for MT? Is this worth it?
  211. The MAF and I
  212. cruise control set light blinks sometimes
  213. security light stayed on
  214. Wheel bearing help needed
  215. Please help with grinding issue!
  216. Help Needed about Bushing!!!!
  217. Black or Frost Interior
  218. How to replace wiper switch
  219. Power steering suprise
  220. My Auto Tranny is Rediculous!!
  221. The Auto Trunk Lock Kaput
  222. P1130 CEL Code
  223. i need help please
  224. Advice on some 5.5gen headlight work
  225. bad alternator belt
  226. ABS Light and 350z rims?
  227. underbody molding
  228. Clearance/Marker Lamp Keeps Blowing!?
  229. Will a 6th gen axle work on my 5.5 gen?
  230. CATBACK help
  231. Aftermarket clutch/fidanza combo chatter
  232. Car still pulls to the left and worse under hard acceleration.
  233. who has halo's
  234. ebay replacement D2R xenon bulbs
  235. VQ35DE problems
  236. Quick question about buying o2 sensor
  237. Passenger side axle question
  238. WHAT MADE YOU BECOME A MAXIMA FANATIC???
  239. heavy vibration under accleration, please help!
  240. I have weird headlights.
  241. Timing chain replacement
  242. Just a question out of curiousity...
  243. Tail Light/Stop Light Wiring
  244. STS MOD! JUST FINISHED. WOWWWW
  245. power door locks, rear defrost, dome light don't work
  246. Which H3 fog bulbs are you using today?
  247. Punctured tie rod end
  248. Well got a SES......when it rains it pours!
  249. Not a big fan of body kits, but...
  250. ABS light
