- Noises after RSB install?
- need suspension specifics
- Rear Deck Holes for Air Ventilation ???
- Strange Issue
- Driver Window
- Z32 calipers + R32 rotors = very spongy/lots of travel feeling?
- Motor Mounts
- The dreaded P0420 code...anyone else experience it?
- Anyone want something photoshopped?
- Looking to buy a 5th Gen Maxima and worried
- clear 3rd brake light?
- Injen Short Ram Intake
- Drive BELTS @ Dealer Good PRICE?
- Valve body, $900 to fix, are they ripping me off?
- altima se-r wheels!!
- what can delete the rev limiter?
- power seat stopped working
- question about headlight bulbs.
- Another check engine light question
- SE 23mm FSB vs. GXE/GLE 22mm FSB
- Can clutch hydraulic system cause clutch to slip?
- 5th gen grill options
- Idiots at shop can't properly adjust clutch after cylinder change
- PCV BlowBy -- Oil Type
- Need opinions, Brake light and Battery light on?
- 2000 to 2k2 headlights
- Does anyone have any experience with warranty coverage for KYB struts?
- Chrome Window Trim Replacement?
- Rev Limiter
- How Much For A Paint Job?
- rear window spoiler
- My seat wont move back-- and I'm 6'6!
- 2002 wrx spoiler
- LED Taillights, Metal Maxima Style...PART I: Design. NEED YOUR CRITIQUE!
- condensation in headlight
- NEEDED CLEAR COVER OF BOTH HEADLIGHTS 02 Max
- My 02 6sp is burning a LOT of oil
- Oxygen Sensor needed!
- 01 Body Kit advice
- clutch / throw out bearing question
- need some advice on this test
- red overlay for the SE tail lights
- El Crappo Gas mileage VQ30
- Another Successful AE Mod
- need help please...
- let it idle, or turn off the car, for better gas mileage?
- Automatic Climate Control question
- Hey guys, Cooling question ?
- Solar Gard HPTint - Colors???
- LTB bang = nut strippage :(
- datadots headlights
- Add me to the list, Headlights Jacked, Allentown/Philly area
- insatlling ae side skirts on a non-ae
- need suspension work...what to get?
- 2001 Transmission Control Module in a 2000....
- 1750 rpm rattle???
- Windshield replacement
- Taking car to the dealer..Question
- What intake should I get?????????
- trim tape (pic request)
- Another Victim: Headlights Stolen
- Brake HEEEEEEEEELLLLLLLPPPP..
- Pics please
- thoughts on this....jus curious..
- Let's play "spot the new mod!"
- LED Array for sidemarkers...do I go legal or illegal?
- weird sound right when driving the car after it's started
- can 15" wheels be used on 5.0 gens?
- Any good repair manuals for the 3.5L? Other questions as well..
- Write-ups and review threads
- A few new minor mods *PICS*
- Spoiler
- Airtex Ignition Coils
- Radio Reception Issues
- HELP - programming new remote...
- Time to replace CV joint ?
- Anyone wants to trade 03 stock rims for 04 stock rims?
- Home depot grill mod. You want to see my what!!
- hi-flow catalytic converter
- OEM Electrical System Upgrade II of II: BIG THREE, Grounding Kit Big Brother (HOW-TO)
- 300ZX TT Brakes on...thoughts, comments, and pics
- '01 Maxima GXE rear suspension problem?
- Do i need to gap NGK Copper spark plugs?
- Best Intake
- Clear to black 00-01 tails?
- thoughts on these coilovers????
- 2000 Max "Service Engine" Question
- The Prospect of a Starter goin bad
- Beware Of The Nowhere Land Gas Stations
- P0720 Output Speed Sensor Malfunction happen 2 u?
- Abs
- OEM Electrical System Upgrade I of II: OEM Ground Wire Upgrade (HOW-TO)
- Jacking point
- Headlights - eBay NOT Projectors
- injen intake
- N1 Style exhaust that doesnt sound ricey?
- need help with this issue.......
- quick question about cluster bulbs
- curious question
- '01 AE Muffler
- How do you replace the rear side marker?
- fog light troubles
- 5sp clutch loosing presure...
- Want to do VB Mod and Tranny Cooler
- I am just curious
- brembo drilled vs. powerslot
- Front Brake Caliper Pins
- slowness
- New '03 owner- this forum worries me... Anyone NOT having troubles?
- Temperature/MPH
- parking brake lever play
- POST Fuel Filter Swap Results...NO Difference
- alignment question
- wiper arms rusting..
- did paradox-systems.com get hacked?
- Brake problem
- 311 Saturday in ATL !!!
- It's Official.. My Maxima is Dead
- Quick clip of me ghostriding!
- Please Help....zenon Headlight Problem!!!!
- Is there any way to tell if a 3.5 burns oil before I buy one?
- do vq30 5th gens use the same front calipers as 4th gens?
- Strange Rattle - Help pinpointing
- Need replacement mirror
- rear strut bar, is this true?
- 6th gen rims/tires
- Help Me Please!!!
- Its been a month...
- 5.5 gen alternator change write-up
- Last map light help attempt *pics*
- Tokico Struts - Where to buy!!
- OEM springs question
- you still think ebay fstb is just as good as anything else?
- Brembo + Hawk = GREAT!
- draytime running light question...
- Super Charger Kit For 5.5 Gen Max And Up!
- PROBLEMS in my MAXIMA
- New Car need advise
- Airbag Replacement and Center Console Removal..
- I need help with charging system
- Memory Seats
- Does your Max experience the "shakes"?
- 00 Maxima 5 spd misfire DTC P1320 and P0300
- whadaya think?
- Will a VQ35 fit in the back of a 98 Rav4?
- how do I replace the rear side markers?
- brakes last you how long?
- Front passanger clunking sound
- Top 5 Suspension Mods
- data dot removal
- D2 Coilover Replacement advice
- Umnitza Bulb/Ring question
- Problems with my MAX need help
- 5.0 Gen KYBGR2s on a 5.5?
- $98 for a ECM Reprogram...do I have any options?
- Does the 5.5's have stock remote starters?
- Oil and the 5th Gen, did I use too much...
- Dual exhaust
- Broken seat
- 2003 Grounding Kit-DIY
- Rear Camber Alignment
- Speedometer having problems
- camber issue, what should I check?
- tranny question on a 5.5 6 speed
- So what's the deal with MAF replacement under warranty?
- ES sway-bar bushings install *PICS
- Air Bag light question
- Just so you know....
- Where to Buy Floor Mats?
- HOW-TO: Install Aftermarket horns w/ relay (FIAMM, STEBEL, etc...)
- 5.5 gen oil burning and what type of oil you use.
- a few favors for those with 5.5 gens
- Help Deciding
- quick question about bose
- Possibly a new cause of the P0430
- Airbag Reset on '01
- LED bulbs???
- Solid steering column bushing to tighten up steering?
- Adv. Timing permanently retarded because of regular gas?
- Aftermarket Rear View Mirror
- Hyperground Kit? LOL
- did I get the right ones?
- why isnt this working?
- HELP/Suggestions re:P1320 & P0505... yes I searched already!!!
- Rear Exhaust Pipe Broke, Need Advice
- Hmm perhaps anthor oil burning 3.5....
- Dave B still around?? Bought parts from him several years ago
- 00' engine misfire
- Power window problems, drivers side
- Car fine at idle, but dies in gear??
- Redoing My headlights..... With Projector
- Those that installed their own Stillen kits...
- 1st Cheap Mod For The 5.5th Gen?...
- what are some simple tune up tips
- UR S pulley vs. UR Sc pulley vs. motostorm
- Sunroof issue on a 2k
- Project: New-style Front Lip - Done!
- service engine soon dummy light
- The Max is SHAKING...what is going on??
- Anyone know the price for a 2002-2003 3.5L V-6 MOTOR ENGINE COVER?
- Supercharger Kit For The 3.5 Maximas
- Yo Wtf
- Want to get a valentine 1, have a question
- Battery, Starter or Alternator?
- Intake setup question
- Intake install
- Weird sound when AC is on, and turning right
- 01GXE top speed ?
- My HIDs were stolen, and I have a question
- Problem starting the Car in Park.
- Chrome Door Sills
- Oh Gawd! here we go again.
- headlights
- how many different leather color are there?
- "dte"???? what duz this mean?
- 02 SE New MAF but no difference! What could be wrong?
- Window molding issue..
- Trying to remember who had a good carbon fiber hood
- 01 GXE..what color SHOULD gauges be?
- Installing JICs
- ECM Recilbration Kit
- how much to replace rear brake caliper?
- 5.5 gen oem side skirts
- Door adjustment?
- Howto: Y-pipe Install for cars that see winters
- Need a How-To on LED Mirror Shell Install
- Alternator replacemnt write-up?
- Routing wires through dash clock.
- Lost/confused - spring issues
- 5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
- When Replacing Your Calipers, Rotors..............
- Need help! Car wont start
- BlehmCo Suspension Modifications
- Tires and speedo change?
- Need a Nissan Part # for 2000-2003 Ventilator Assembly
- Crisco grease on my headlamp wiring harness?
- Another "car won't start" thread
- question about torque braking...
- MAF Replaced Last month. Update...
- Change from Auto To Manual on a 5.5 Max!
- 03 max 6spd spd?....for 13k????
- 4th and 5th gen brakes similar?
- Temperature sensor location for gauge cluster?
- REQUESTING PICS...5TH Gen w/ Black wheels...
- de see me rollin on....??
- Camber is F-ed, Ideas?
- The switch Greddy to Cattman
- Trunk Insulator
- REALLY thinking about AE'ing the headlights on the Max... (pics)
- Could a tank of bad gas throw a p0011/p0021 code?
