- ABS light is on...how come?
- Side Marker removal ?'s
- Would this Pathfinder Mp3 unit fit in my car ?
- Will pulley setup fit from a 350z or g35?
- Car won't after changing spark plugs
- PIC request of steering wheels
- oil light?
- Hose that connects to Trans (02 MTX)
- Im sorry but....
- Intercooler to a 5th gen Maxima
- Automatic Transmission Flush
- Tranny Bearing Problems
- is this possible??????
- Used 5.5 Gens
- Anyone Have A Picture Of G35 Sedan Wheels On A 5.5 Gen?
- NOOBS: Injen,Berk,Frankencar,Popcharger,GAB are NOT "true CAIs"
- Problem With Manual Climate Control
- are red stuff brake pads any good?
- Now I'm A Offical Newbe!
- Exhaust is loose...
- Check CV axle
- Ksport help please
- In refernece to the GAB... what do u think about this?
- Shift knob screws??
- Where to get clear lenses for turn signals?
- Service Engine Soon Light
- do headers really make a diffrence in accleration
- Need Pictures of 350Z Deal Pedal
- Cattman/Progress RSP Question
- tail light covers....what's your opinion
- Any luck w/ aftermarket starters?
- ?? for Helios HID fog people...please step in..
- Have an FSM? Look something up for me, please...
- Coolant Temp Gauge (which Sensor)
- Location of oxygen sensor
- Cheapest place to get OEM brakes
- Trouble wiring 2k2 HID's 2000
- Need some help please (rattle)
- vq30de-k manifold question.
- Cool lil pic....
- anyone had this problem?
- Broken Valve Cover Bolt
- replacemnet for aniversay edition lip
- jetchips
- Please see and tell me which one to go for....
- Ignition and flickering base display electrical problems
- Gapping a sparkplug
- What can I do with ALLDATA?
- What do you all think??
- climate controll
- Auto Tranny Guys - did you replace your gasket when dropping pan?
- Can we save gas by having 3.0L
- Need Help
- SPOTTED: 5th gen with NH plate MAXXIMA
- Automatic Transmission slips on last gear
- replaced something under Warranty? step in
- which one is better...
- SES Light: Code P0138
- Vias Fix
- Cattman basic suspension package.
- Clutch pedal adjustment?
- How do I test if there is a draw on my battery when the car is off?
- VIAS Ratttle at 5600 RPM's...
- Idea for the rear door speakers. Plug your ears!
- who makes speaker adapters ASAP????
- Fuse problem...Help!
- Are 4th gen & 5th gen catalytic convertors interchangable?
- Wow! a 5 cyl. maxima!
- Expected 1/4 mile time?
- Is this maxima owner a member of the forum
- aftermarket y-pipe with stock catback
- got the car tuned yesterday
- Need Advice Before JIC Install
- K&N or AMSOIL air filter
- hesitating at first startup
- Wanted pics
- Please take a look and tell me what is it???
- 2000 spark plug gap ...
- Help me with a muffler choice
- intake setups....(pics please!!)
- wheel spacers ?
- Gas Mileage
- ES Bushings
- can't find
- Have automatic, wish it were 6spd...
- Wheel bearing...
- 2001 se
- how much is my car worth??
- HID Fog light problem...
- stut mount bearing replacement advice needed
- Gold CADIUM Plating on Rotors
- how much oil does the vq30dek take?
- squeaky rear springs, stock setup
- New shocks and warranty
- Black Housing Fog Light
- Rattling after shut off ...
- In need of sunroof help.... desperately
- Question About The yellow fog lights...
- exhaust thread
- exhaust thread
- I need a new AE front lip!
- bumper dent repair
- Just Turned 100k this weekend!
- Component to left of rear valve cover
- Axle nuts keep coming loose
- Fast way for L.E.D.'s
- mud flaps
- High Pitch Sucking from intake under 2500 RPM's
- Lost a bolt somewhere in the engine bay
- Transmission fluid change ... part #'s correct???
- Triple Gauge Pod...
- Pic Request!
- Just Gont Done Painting My CALIPERS...please see
- Redline Leather setup pics?
- any fitment problems with 17" 350z wheels
- Quick newb question.
- Stupid Vent trim piece, trying to install radio
- need help asap..please
- Clicking noise while driving
- PCV valve ...
- HELP! O2 Simulator question
- Transmission
- MetalCat Installation Problem
- key fob power window mod???
- Brakes squeak while reversing. Why?
- anyone have a pic of an oem 2k2/2k3 HID ballast?
- Am I gonna be missing something?
- How do you change the climate control/window control lights?
- Air filters ...
- HID bulb type
- Is there such thing as NISMO STS for 5.5 gen?
- Manifold absolute pressure sensor fault??
- 3rd gear feels...crunchy, uneasy (cant find the right word)
- Exhaust problems yet?
- Anyone have a Kenwwod DDX-7017, 6019 or 8017 in their 5th Gen???
- Bose bypass with aftermarket deck/ adapter needed or not?
- 6 in dash cd changer for 2000?
- Yellow fog light?
- mechanic can't figure out prob/can you help?
- Are vq30 & vq35 5th gen catbacks interchangable?
- Rotor weights for 5th and 6th gens.
- what are the absolute best PERFORMANCE mods?
- OEM GXE 5th Gen Radio Dash Kit
- Fuel pump problem?
- Resetting ECU - 2k3 Max
- Bose woofer not working
- clutch going out?
- 3.5 6 speeders - gettin' mo special and special!
- Swapped The ECU Questions?????????
- Another Reason Not To Use JiffyLube
- Sudden Bose stereo loudness...
- Got another Maxima and have a question.
- Resonators
- Fan stuck
- Anybody have diagram to tell you which is cylinder 4 on 5gen?
- Reset ABS light
- 02 headlight question
- 5.5 Gen Changed Plugs and Now Transmission not downshifting on time?
- 245/50/17?? too big? input please.
- Before I buy
- What battery do u guys recommend?
- Temporary loss of OD
- Tranny starting to skip: what do you guys recommend?
- Engine Dampener?
- 5th gen to 5.5th gen parts swap
- Thumping noise when driving...bad wheel bearing?
- Did you get yours yet?
- Extra Part??
- air conditioning not as cold?
- Rubber bumper damaged - advice needed
- Battery issues ...
- Are our cars made in the US?
- help picking new rotors
- quick question regarding brake bleeding
- no throttle response?
- who has bike roof rack? if thats what u call it..
- rattling noise..timing chain?
- Wierd Squeatity Squeak
- Pic Request: 5th gen dropped on H&Rs
- All new Rotors/Pads & Spacers *Pics
- Right side high beam not working
- Wrapping Doors is Suede
- Right High Beam not working :-(
- Indiglo Gauges, Where to buy 'um.
- Engine just shut off at idle!
- Help, valve cover gasket leak!?
- Question regarding Cattman Ypipe
- y-pipe with stock muffler..... pointless?
- Emergency brake light always on, where is the switch?
- Power steering flush?
- Replaced PW motor, now have problem with auto up, goes to top and backs down 3 inches
- need help with this issue........
- My GAB quick impressions
- Door pillar removal
- resetting pass side auto up window
- SE Guages
- ES Bushings, Whats the effect?
- Anyone have a Dynomax Super Turbo muffler? Sound clip?
- How to check ECU?????
- can i see a pic of the pvc valve on a dek
- Where Do You 5.5 Geners Buy Your Drives Side Wiper?
- Are the 6th gen rotors worth it?
- Hel: A/C stopped working need input
- What would you choose???
- greddy evo 2 users come in
- Pic request: cargo net attachment
- Just Bought Brake Pads And Rotors, Brake Pads Not Fitting!!!!!!
- 02' warpspeed y-pipe pics????
- Where Is The Write Up For Installing Rear Brake Pads+rotors?
- Need MAF plz help
- how to install S-AFC II unit onto 2000 Maxima?
- moving throttle body to get to 3rd screw on VIAS?
- need help with search of maxima..........
- CV boot torn and spewing grease all over
- Where can I get spare parts for an ADDCO RSB
- installing black carpet
- installing home made black carpet
- Lamin-X... What do you think?
- revised timing chain tensioner
- PICTURE REQUEST: Tinted Taillights w/ lights ON
- tiny nissan sticker
- windshield wiper switch doesnt work, but pullback stalk does? help
- modifying and getting engine light
- Power Window Motor replacement instructions?
- Headlight upgrade install ?
- Picture of rear suspension: Anything wrong?
- Is it a bad ecu, bad wiring harness or could it be the starter etc.???????????
- My clear corners dont fit...pics inside..help needed
- 16s on a 5.5gen?
- 16s on a 5.5gen?
- Air in brake lines!!!
- 5th Gen 5Sp versus 5.5 Gen Auto
- Fresh start low idle, no power, jumpy performance
- LSTB From Matt
- Can I test a Crankshaft sensor On a 00 5spd
- Infiniti 19's?
- need help!!!!!
- Service Engine Question
- Anyone with a black front lip
- The Best Mods
- Compression Test for VQ30DEK motor? Standart Pressure?
- Redline MT-90: was smooth, now notchy as hell
- Could I Just Replace My Rotor And Brake Pads?
- Will progress springs/camber kit void my warranty?
- Help with headlights??
- Smoked Bumper Lights
- shocks KYB gr2 vs tokico blues
- Noises after RSB install?
- need suspension specifics
