- Idle speed ...
- Front Lip Pics!!!!!
- Help with brake problem
- Resistor Removal
- Car stalling in neutral, any ideas
- Intake problem?
- Question about 5th Gen and 5.5 Gen tail lights
- Chrome rings on gle gauges
- What could it damage???
- Quick Help with 20th edition!!!!!
- Transmission Fluid Question
- Suspension knock/noise diagnosis help please
- Need Rear Spindle Nut Torque Spec!
- Have coilovers? I need you to measure a part of your stock suspension off the car
- Car Just Died =(
- Poor Performance at low RPMs
- Clear/Smoked sidemarkers... Step on in!
- WTF... CEL back on after O2 Sim Install
- ebay bumper
- speed sensor wire
- 5th gen forums suck
- Question for those with Hotshot headers and Frankencar cat-back
- jic exhaust, anyone got one?
- 2002 advice needed please.
- Automatic-Downshifting and Overdrive OFF Question
- Where can I get yellow fog lights?
- Question about relay colors
- cattman headers
- obd2 SES light codes p1165 and p1131... Help!
- anyone retrofit 2k headlights for HID
- questions on coil packs tried search didnt get answers i needed
- Adding shock sensor to factory alarm
- "plug & play" 2k1 HID lights...
- angel eyes / demon eyes
- DEPO! Good or Bad or Same as all else
- Owned the car for a month and half and look what I have done already...
- Considering a Y-pipe
- Possibly going 4th gen. --> 5.5th gen. What to expect?
- Suede Interior, pics inside
- Which would be a better option?
- Eibach Spring Owners
- has anyone tried to fit the middle part of the 04 and up maxima grille on the 03?
- O2 senseor
- Are these issues related??
- Changing Power Steering Fluid ...
- HID bulb blown after less than 1 year...
- Where can i find the chrome or aluminum grille OEM replacemnt.
- Anyone have problems with Yellow Top in a 5th Gen?
- rigged up a CAI...is this safe?
- 5.5 gen auto seat position
- P0300 and other codes... need opinion
- rough idle?
- Reservoir tank ...
- Removing Headlights --- NOT HID --- on a 2k1
- another lighting thread
- My tranny is shot...where to get new one with price?
- Need some help with clock panel on 5th gen.
- motor mounts
- Hard Start Problem
- SRS Airbag Light Flashing on 2001 Please Help
- Have anyone heard tittail?
- Gas mileage on 03 6m/t is not good...tune up needed?
- Need new battery? OEM or aftermarket?
- Yellow Foglights?
- Exhaust tip
- Which 1 of this will stand out if replaced with OEM?
- What don't my headlamps and foglights match even though they're both 6000k?
- I need you opinion about these taillights
- serious 5-speed transmission slippage
- how do u get more horsepower?
- Leaking???
- Radio LED
- quick question... about headers...
- Anyone heard of Kaixen? + Another Question
- can this be done?
- question about 03 SE shocks and springs
- Why my oil catch can does not work??
- weird noise @ 1900rpm
- Gas needle stuck again
- Installing gauge pod...
- No heat until its set to 85 deg.
- JiffyLube Undercover Video
- Stock Front suspension makes knocking sounds.... why?
- SES Code P0057 O2 sensor. Help!
- Does the 5.5 gen have any other options for a rear lip besides Stillen?
- squeeky belt on my 02 maxi
- EVAP canister purge volume control valve?
- My Maxima made the news
- My 2002 6sp Max gets into a fender bender!!!
- Getting to rear spark plugs, need help immediately
- Belts
- Intake manifold Torque spec.......
- Need help Picking a new front bumper...
- exhaust clanking noise
- fender bender :(
- lug pattern
- I need some help.
- carbon fiber dash kit
- Error code 0420 and racing pipe?
- Power Steering Filter ...
- Rep your town.....
- Weird Intermittent Sunroof Issue
- Drivers side window - does not open
- programming keyfob
- Gear Shift Question
- Automatic headlights
- Like my new wheels? (Photochop)
- ignition coil. How to replace
- Grit or Film on inside headlight....what to do??
- Any clue on tightining the steering wheel....
- Brake Experts. Please Step Inside.
- best pads with oEM Rotors
- question on energy suspension bushings
- Reprogram my Nissan Key - anyone know how?
- Tranny slip!! HELP!
- rattling sound?
- manual-manual swap-easy?
- Putting A Sunroof In Your Max.....question
- OEM H.I.D. Bulb has Officially Burned Out!
- Frozen Caliper (replace one or both)
- ES Sway Bar Links
- Steering wheel controls 5.5 Gen
- Whirling noise from the EEM electronic engine mount
- The Great Brake Pad And Rotors Thread.
- 5.5 gen rim offset?
- cross drilled+slotted Rotors
- Taillight tint covers
- I know im going to get flamed, but......
- 03 SE Question
- 130K Service
- Power Valve (butterfly valve) one screw is missing on 3.5L ...
- key fob buttons worn down with age?
- I need help with ES bushings
- Made the switch from Eibach to H&R...
- Is it possible to replace the plastic housing on my 02's headlights?
- Lack of power.....
- Any vids/pics of turbo 5thgens.(3.5)
- infiniti g35 coupe rims
- Dielectric Grease ...
- Exhaust Help
- Afcii True Or False
- Dash-Clock, Instrament Lights, Hazard lights w/ remote lock, Fuse Help.
- VIAS cup orientation
- A $794.8 service at 39k?
- What else could cuase shake?
- Drive Belt tension gauge
- Best Clutch?
- is it illegal to not have the f&r side markers light up?
- Ebay Tokico struts
- My Trannsmission is shot... NO it's your CATALYTIC CONVERTER???
- New Eyelids, tell me what u think
- Can a bad O2 sensor cause knocking/pinging?
- TCM question
- HLSD installation
- Sound Clip of EBAY Catback Here!!!
- Weapon R Intake
- Battery and Brake lights stay on
- What will a bad tranny do?
- radio issues
- Installed SAFC II and dynoed it
- ELC system 2 fault P1448...what is this?
- need help with fog & headlight bulbs...please advice
- progressive or stillen....
- What are the chances of a belt tensioner going bad?
- ?? from 4th gener for 3.5 owners
- Front End Noise
- Ratings 1-10 Tokico illumina struts
- can an OBDII scanner pick up codes that dont throw CEL?
- Knock Sensor Install Write up?
- abs speed sensor part number
- What Is The Best Spark Plug 2 Use on my max?????
- locking wheel to left, I hear a "crunch" noise...wtf?
- WTB, 2002 Maxima bra
- Gxe Radio/dash Trim/ring?
- Question about Maf
- whats up with my battery? leak?
- Suspension advice
- 100k Maintenance
- anzo projector headlights..
- getting a 2 second squeal on startup?
- Dime-Sized rust spot...
- H3 Reverse Mod?
- Vq35det boreoutkit
- for those who have 2003 headlights on their 2000 maxima
- Synthetic Brake Fluid ...
- Pic request
- Help, might be getting 03 350z rims on my 00 maxima. Need help and opinions!
- Testing Your VIAS
- Place Racing 5.0 Gen CAI
- how to post pics
- difficulty in replacing O2 sensors??
- Yes I searched....tire question 235/50R17 vs 225/50R17
- How to clean crankcase using seafoam?
- Good ole' brake fluid
- Governor on 5.5 gen auto
- Tranny Problems
- Nedd exhaust help
- how could i fix my headlights?
- Custom exhaust plan
- Climate control fan missing speeds
- New Headlights & Grille
- Anyone know about Tranny's & Torque Converters in a 5th gen?????
- Maxspeed springs??
- Rear windows in 5.5 gen...
- ATTN: 6m/t owners...My dilemma...
- 00 and 01 full gasket set different????
- Best Rotor and Pad combo
- Is It Necessary To Clean the AC Condenser? please READ!
- How do you read the VIN #
- Perform TSBs for free?
- Looking to re-wrap steering wheel.
- Ebay catback
- Driver Side Window does not come to a close
- reg gas cause of knock in engine
- Trunk scratch TSB: rust
- New version Faktion STS for 5th gens. Anyone??
- Help !!!
- New Mods for next week, Comments
- Chrome 18" G35 Wheels?
- it is unfortunate that KYB refuses to make the AGX for A33's..
- Spring Compressors needed to install H&R rears?
- 6K HIDS & 6K FOGS...comments welcome
- Power steering fluid leak??
- auto tranny hesistation?
- i35 cluster in the 5th gen 3.0 step in...
- Getting rid of EGR after headers install
- tranny fluid supply line ...
- UPDATE after accident
- o2 simulator
- HIDs in fogs
- Weird rev issue
- Modified Injen intake, and now I think it is the MAF
- replacing headlight bulbs
- Slow with AC on...
- Battery issues
- tranny cooler
- are you suppossed to check ATF when hot or cold?
- Rsx Vs Max Talk
- engine ckeck soon
- Its Official...
- Accident Pic....ahh poor Max.
- WTF!!! Fuel door issue!
- I need a new exhuast....
- Arghhh!!! I hate Eibach springs!
- Got cel for igntion coil, installed new plugs problem solved!
- Need help with Fog lamp - 2000 se
- can someone help me make since of this fuel issue?
- ABS Sensor Replacement
- Stock HID looks purple on one side....??
- My sunroof is semi-broken.
