View Full Version : 5th Generation Maxima (2000-2003)
  1. ECU Question
  2. TS ECU vs New Headers
  3. Calling all 6-speeds that have had the clutch replaced
  4. Attempt on Headlights
  5. what if my oil catch can doesn't have any oil in it?
  6. anyone bought these coilovers?
  7. Mpg
  8. Question: can the projector headlights take d2r/d2s bulbs?
  9. does anyone make or know where to get a 5th gen radiator cooling plate?
  10. how good are new oem brakes?
  11. I need 5th gen owners to check something about baby seats...
  12. Bought 6 new coils $63 each is this a good deal?
  13. VQ35 strikes again...
  14. nismo fuel pressure reg.
  15. Factory 17'' rim width???
  16. Your P0430!!!!
  17. Got TSB NTB03-022 Done today - NICE!
  18. Is it a good deal ?
  19. Favorite/Best Mod under $100
  20. clutch problems - plzzz help!!
  21. Where does 01 cd changer plug in?
  22. searching eBay for black SE tails
  23. Thinking of upgrading to a 5th gen and I've got some questions
  24. P1320 - Ignition Signal
  25. Websites
  26. Radio Fuse
  27. nissan maxima cd changer $60 -- fog lights $60
  28. Thermostat Issues...Please Help
  29. indoor/outdoor thermo & power seats q's
  30. Pic Request: Shifter linkage of a 6-speed
  31. Custom Gauge Pod for Five 60 mm Gauges
  32. Does the Transmission Control Module get programmed by the Solenoids?
  33. White, Black or Stock
  34. Painted stock 5.5 gen grill black
  35. who here has 6k hids on 03 housing?
  36. 6th Gen Engine Cover On 5.5
  37. battery relocation Q
  38. These any good??
  39. Great source for 13" rotors
  40. 2001 AE Engine Cover Question
  41. hardwired radar detector
  42. reservations about dropping my car
  43. New CALIPERS?
  44. Knocking and Pinging Noise
  45. Eyelids..where to buy?
  46. Anybody know anything about "Clutch Shutter"
  47. Spark problem
  48. who has nissan maxima halos from ebay?
  49. brake upgrade
  50. VLSD wearing out?
  51. HID questions...
  52. ebay Halo Crystal Headlights - NOT EBAY PROJECTOR HEADLIGHTS
  53. Gas MPG on a constant decline.. WTF?
  54. Recommended Code Reader
  55. Preferred AT Fluid?
  56. OEM clutch vs. Aftermarket
  57. Does anyone have the TSB for Tranny computer (TCM)
  58. Is it possible to convert 5.5Gen Headlights to 5th Gen?
  59. Pic request. 17" oem altima se rims on a 5th gen
  60. big brake upgrade.
  61. belt changed
  62. Gas Mileage
  63. RPM at 80MPH
  64. o2 sensor
  65. P0720 VSS output speed sensor malfunction?
  66. New Horn ...
  67. Going to invest in new spark plugs for an 03. Anything I should consider?
  68. Is this a good deal? (Used loaded 2k3 6pd w/ 53K)
  69. Driver side heated front seat question
  70. Is $160 too much for a Consult-II ECM update under the NTB03-022 TSB?
  71. New Springs in Front only? Advice?
  72. Would the dealership install 5.5 GEN Headlights in my 2001 GLE?
  73. ----- 2000 SE 'lost its Punch' when accelerating
  74. Specific SES Code Solution
  75. 6th gen IM?
  76. iPod Kits
  77. Climate control fan whistles after filter change.
  78. Shifter cable snapped, help please.
  79. 6th gen brake upgrade
  80. Wheel Bearing Issue?
  81. Weird Idle after TB cleaning
  82. LED Mirror shell (paradox) install help please
  83. has anyone bought this exhaust?
  84. ABS Light?
  85. NOISE coming front right front whell..help!
  86. Looking for clear corner/FRONT SIDE MARKER LIGHT
  87. please help me with this confusing P1320 code..
  88. Maxima.org........thank You For The Great Advice!!!!
  89. check engine
  90. Noise when fan is on
  91. pop tabs under bumper - how to get back in
  92. what does this cable do??
  93. Does an ECU updates include multiple fixes?
  94. Tsb ?
  95. LED tail bulb- now no cruise?
  96. new car?
  97. Car is hard to start when park on a tilted driveway
  98. Clean fuel injectors ...
  99. Otto FSTB - Can't Find... Will 95-99 Work?
  100. 99-01 Cali Spec. SS Y Pipe "Special"
  101. Where can I buy an otto bar for a 5.5 gen
  102. Is 3.0 pre-cat interchangeable with 3.5?
  103. Blown shock?
  104. rear sway bar
  105. URGENT: '03 reprogrammed, now installing Berk Intake; will I lose the reprogram?
  106. Differences between 350Z/G35 and 5.5 Gen ECU?
  107. 02 Maxima recalls
  108. Studdering/Hesitation Problems
  109. Street Scene Front Lip
  110. creaking seat
  111. tranny flush
  112. 2002 Maxima Stock Struts
  113. liscense plate bracket
  114. Opinions on HKS rear section for teh 5th gen.
  115. How much would be the trade-in value?
  116. Wheel Noise
  117. Disconnecting Battery
  118. Pulled my MAF to clean it.. SUPRISE
  119. Foglight lamps?
  120. Should I stock up on Apexi Filters?
  121. thought on SS conversion lines
  122. comparing 00/01 sts's
  123. humming sound from right rear
  124. Found a Code (P1320) need your help please
  125. K&N fit for a '00
  126. Extended Wheel studs??
  127. Engine Noise: Knock? Rocker?
  128. stalls; clogged precat in y-pipe? fed or cali spec?
  129. Welcome me to the family
  130. Drops.
  131. "Service Engine Soon" light question..need advice.
  132. can a 02-03 nissan maxima headlight fit i35.
  133. New HU
  134. Selling my Max guys... come check it out
  135. Rear Sway Bar Break-in?
  136. Increased hesitation/cranking during starts?
  137. ventilation button led's burned out...
  138. 5 gen headlights
  139. front stabilizer links
  140. Strip paint
  141. Aftermarket Keys Won't Program
  142. where do u get your oil filters?
  143. Hey guys
  144. Finally NEWBE ABLE TO POST!! Just bought an 02 maxima!
  145. Hard 1-2 shift on 03 4AT transmission
  146. Bad gas mileage on 03 maxima
  147. Can this really happen? What the heck ...
  148. Thinking of getting an 2003 SE 6speed.What should I look for?
  149. Express Paint
  150. Should I add the SE spoiler?
  151. Seat Covers?
  152. MAXIMA hamburger on the trunk
  153. Switch to Leather Interior
  154. What the Hell
  155. frankencar K&N filter
  156. Again with the knocking....
  157. Engine/ maybe even tranny probs?
  158. Why so low?
  159. Did the 2K1 MAF mod for my 2K2, now I've got O2 error codes
  160. Corporate Lease
  161. To all owners of HID fog lights....
  162. taking dash apart
  163. Cant Unscrew Bose Headunit. Need A lot of Help Soon.
  164. weird alarm issue
  165. shift light...
  166. To All Led Know It Alls
  167. Question on Front Grille Fitment.
  168. Question about 3rd brake light??
  169. 2k2 vias
  170. couple of questions I need answered
  171. SunRoof Rattles?
  172. Gah! I knew this day would eventually come...56K warning
  173. ecu
  174. Is it possible to add the memory seat option
  175. No Start!!
  176. Anyway to make seats heat up faster?
  177. Ae Door Sill Part Number?????
  178. How Do U Remove This F'ing Pinstripe!! I Hate It!!
  179. Got some extra cash -- Which Mod?
  180. Would appreciate all your HELP ...
  181. help!!!! car stalled
  182. signal bulb question
  183. Heater Core Flush, Please I Need Help
  184. Dashkit intrest
  185. 00-01 owners w/ stillen classic front lip
  186. OK what is causing this jittery drive?
  187. Fixing the Dumb Seat Motor
  188. can a maxima front bumper fit a i35.
  189. SES light on then off
  190. Battery dash light - when should it come on?
  191. Is There a Way 2 Test DIY O2 Sim?
  192. my heaters dont work :(
  193. Front/Rear Strut Bars
  194. Keep blowing a fuse.Need help!
  195. Car seems tired
  196. 4 years of ownership, still in love with her.
  197. intake mani. question
  198. I heart you forum contributers
  199. Part # Question(s)
  200. New Tokico struts
  201. Why/Where is my exhaust falling off? 2003 Max
  202. Pics of 00-01 w/ AE Engine Cover
  203. Pros/Cons 4th Gen v. 5.5 Gen
  204. car accident but whose fault?
  205. 5.0 and 5.5gen guages interchangable?
  206. Gearbox Done(missing gears)
  207. Wrong plugs CAN cause CEL...
  208. New Mod. Maxima to Minima
  209. P0302 (guess what everyone)
  210. Feels a little sluggish
  211. old woman in a maxima
  212. 5.5 335 questions on crank sensor
  213. Ebay Angel Eye burnt out - 1 on each side?
  214. Just sold my '97 max... trying to enjoy the '03..
  215. Clear sides: Multiple manufacturers/quality, or same mfr w/ different distributors?
  216. Car is not willing to start
  217. P1320 and P0301
  218. FOG light replacement HOW TO?
  219. 6MT - Is switch from synthetic back to dino bad news?
  220. Where Can I find an IACV?
  221. Differences between Frankencar and Berk Intakes (Apexi version)?
  222. Upper grill options for 02-03
  223. 5th Gen on Autoblog!
  224. 2000 max hard to start
  225. 2000 Maxima Accident, their insurance is covering a front bumper swap.. please help
  226. Which OBD2 Scanner to Buy
  227. car "hangs" in 3rd gear...normal? MAF issue maybe?
  228. driver's seat will not move
  229. What should I do?
  230. will a modified valve body from a 4th gen tranny fit a 5th gen tranny?
  231. will these yellow fogs fit my 03?
  232. Shifter bezel pops loose going into Reverse!
  233. blue or yellow film
  234. Sorry, one last time w/ my sunroof
  235. what are the symptoms of a bad tranny solenoid?
  236. After I get my new MAF...
  237. question about the diffrent grade of oil use.
  238. Motor and Transmission mounts
  239. 5.5 Gen Seats fit in 5.0 Gen?
  240. odometer wire??
  241. Question: How can a bleed brakes with mighty bleeder
  242. Black grill 2k2-2k3
  243. Performace clutch
  244. Is it safe to use 02sim for a P0159 ?
  245. low toned exhaust
  246. Removed brake line bolt on rear caliper. Need to bleed?
  247. Stillen FSTB
  248. My 2001 died on the highway...now won't stay running
  249. 20 Amp Draw while the car is off?? Please help!
  250. Stupid mistake. Busted lug bolt. Need quick advice.
