View Full Version : 5th Generation Maxima (2000-2003)
  1. Spark Plugs choice..
  2. Quick EZ-Pass questions
  3. Engine Code question PO507 high idle
  4. fujitsubo exhaust
  5. Tokico HP
  6. Door misaligned
  7. Help, headlights+foglights not working.
  8. So, I need a tranny
  9. decided to finally replace my belts
  10. My car shifting hard...(Auto)
  11. testing the waters : fog light protectors
  12. Heated seat problem
  13. Early 2000 SE's with 16" OEM wheels?
  14. M3 trunk lip spoiler
  15. Is this the brake booster line?
  16. Right headlight wont work!
  17. Does anyone know how to wire the fog lights with alarm?
  18. Dash Brake Light on when cold out
  19. how to change side lights
  20. Was not shifting into 2nd gear, high rpm - 2k auto
  21. Anyone have one of these ...
  22. srs airbag resistor
  23. Accurate Price To Replace Axle Boots & Bearings...
  24. 07 infiniti g 3.5l pushin 306hp?
  25. HELP!! Acceleration gone!!
  26. Leaking Oil Cooler
  27. Gas overflow
  28. $560 for 2 O2 Sensor's?
  29. Nothing but Issues....Help!
  30. Thinking about doing a 3.5 swap...
  31. L/100km
  32. Electrical System failiure
  33. Advance Auto Cheap Rotors
  34. TSX projector retrofit in 02-03 headlights **PICS**
  35. problem with loose wheel
  36. Ebay tail lights
  37. P0725 Speed Sensor Malfunction
  38. how to check if i really need to replace my battery?
  39. Question about Swap?
  40. Final exhaust video. stock everything, CATTMAN GEN 1 only. calling puppetmaster
  41. header question...
  42. Maf
  43. please SOMEONE help me with my Headlights
  44. Tokico Blues too soft?
  45. My quest for a proper handling and braking, loooong
  46. Need Help! Can't figure out Problem
  47. New Rotors ...
  48. Oil Leak 5.5 gen
  49. Steering wheel tight
  50. :grinno:
  51. picture request
  52. Starters...
  53. 5th gen fog lights
  54. Decode Model number, Transaxle number, Trim/Color Codes!
  55. Chewing sound while starting car...
  56. front arm rest on 2k2 problem
  57. LTB creaking during turns
  58. Clutch Stop
  59. Installed EBC Rotors...weird noise.
  60. Watkins STS - New Info from Steve Watkins
  61. Weird P0011 Intake Valve TCS Occurrence
  62. Umnitza Angel Eyes Dim for several minutes?
  63. How to get check engine light to turn off?
  64. slipping clutch
  65. ABS Light
  66. Plug Replacement and 335 Code (2003)
  67. 2002 gauge Cluster in a 2001 Maxima??
  68. easy, fast mods?
  69. Where is the air filter???
  70. Grinding Noise
  71. new brakes?
  72. rear beam
  73. Oxgen Sensor Issues...
  74. Question about Clutch Pedal "length"
  75. What is that smell?
  76. How to test if your ECU is bad?
  77. Anyone Ever Tried Raybestos NS (Noise Solution) Brake Pads?
  78. are 5th gen and 5.5 gen rear bumpers the same?
  79. How to diagnose a worn Timing Chain?
  80. $1,000 For A New Airbag!!!!!!!!!!!!please Read
  81. weird IDLE, new IACV - whats wrong?
  82. Need Help! Being Taken Advantage Of!
  83. Signs of a bad flasher?
  84. A bra? Not Victoria Secret :-(
  85. Alignment Question
  86. 5.5Gen 6SPD Shift Bezel in a 01 AE
  87. Gauge cluster ?
  88. low rev
  89. what are these?
  90. Have any of you heard this?
  91. headers and o2 sensor
  92. I wanna get a catback, but have a question...
  93. Bad PIAA Super Plasma GTX Bulbs?
  94. Need Advice…
  95. anybody with 19's dropped with S-techs?
  96. What to put on CV Boots????????
  97. airbag sensors - where are they?
  98. P1126 error troubleshooting
  99. Negative battery cable replacement question
  100. shock sensor
  101. dde owners, how cold for pink eye
  102. GAB mod
  103. my car pic
  104. anyone know how to change a pulley bearing
  105. Replaced IACV now idle is FUBAR
  106. 5.5gen IM question
  107. Lowered my car and now need a camber kit
  108. Strange Engine Noise
  109. can coolant evaporate? or is it leaking?
  110. Smoked side markers (non-DIY)?
  111. LTB 2 Install Advice/Help
  112. OBX headers and y-pipe question
  113. Just wanted to say thanks!
  114. No dash panel lights or parking lights..
  115. P0420 w/ noise
  116. could a big puddle cause p0138
  117. SSautochrome 3.5 Headers
  118. Mileage poll
  119. Steering Wheel Radio Control IN 2000se?
  120. Mice taking up residence.
  121. Steering Wheel Radio Remote
  122. removing door panels?
  123. Headers + high flow cat + B-pipe
  124. what do you guys thinks about this maxima
  125. Trailer hitch?
  126. Windshield washer nozzles that "fan" instead of "stream"
  127. Goodbye Everyone!! It's been fun!!
  128. Does anyone have modified side mirrors?
  129. Headlights & HIDs
  130. anyone here warranty their tokico illuminas?
  131. Any New Thoughts?????
  132. Brake "tightness"
  133. Is it possible to swap Frost Leather Interior for Black?
  134. RSB Install
  135. what are these problems?please help
  136. Upgrading suspension.......who has purchased Tokico Illuminas?
  137. Ayone know what it means when the following two MIL's come on at the same time?
  138. o2 sim
  139. How much for a tranny job?
  140. P0130 and P1148... Any relations?
  141. Getting the 6-speed moving smoothly
  142. Add HID high beams to headlights?
  143. To keep or not to keep
  144. 5.5 new header choice
  145. can we fit 2k1 coils in 2k maxima?
  146. Heated Steering Wheel - Off after 5 mins?
  147. Climate Control Temperature Adjustment
  148. Manual Transmission Fluid Level Check.
  149. Changing rear wheel bearings
  150. Down on power. What's going on?
  151. People with Coilovers, Especially JICs Step Inside
  152. Acceleration Problem
  153. poor gas milage , low idle no cel light on 3.5
  154. Radiator Hoses replacement
  155. Coils for $58 W/ Lifetime warranty
  156. PIC Request: Redline Leather boot + aftermarket shift knob
  157. Got rear-ended Saturday night/Sunday morning... (big pics)
  158. leather shift knob restoration
  159. PAC-X Switch for 2k1 who has installed ?
  160. Anybody running Warpspeed High-Flow CATs? (And Y-pipe)
  161. Can any1 post up Haynes manual pages or photos of 00-01 VIAS/Upper Intake Manifold ?
  162. Y-pipe Questions/Concerns
  163. Disabling Daytime Running Light Feature
  164. rear shock shot thru the mount.. any ideas?
  165. how to change the PCV valves on 5th gen?
  166. which one is better to go for...? help.
  167. MAF replacemant for 5.5 gen.
  168. Moderators - 5th gen forum suggestion...
  169. Which Dead Pedal?
  170. 2000 I30 parts the same as in a 5th gen?
  171. Problem with wheel bearings...
  172. Tranny shifts slow?
  173. I35 Cluster Swap into a 2002 Maxima
  174. Before I bribe the Nissan mecanic ...
  175. squeaky rear suspension, who has this problem?
  176. iintrument cluster compatibility question
  177. Aftermarket key fob
  178. 5.5 gen grill painted black
  179. 6000k or 8000k D2R
  180. Need headlight assembly
  181. Yes LED bulbs for our Gauges.
  182. AE Fog Light Replacement - How to's
  183. What To Do At 60k Miles?
  184. Can Nissan dealers do a history report on a used vehicle?
  185. Too lean?
  186. quick help (tire question)
  187. Installing RSB this weekend...have question...
  188. Opening up taillight housing
  189. Will my wheels get destroyed this winter if I don't go to steel wheels?
  190. MAglight
  191. need help please: regarding the spark plugs.
  192. My Max is no more.....
  193. NEED HELP from coil readers!!
  194. How-To Change Coils on a VQ30DE-K
  195. optima red top part number?
  196. First impressions (cleaned MAF and TB)
  197. What causes "ICY" to come on under the tach????
  198. Selling my 2k Max
  199. Another Stolen Headlight NJ area - But this one is interesting....
  200. need help with the right part number of coils.
  201. 3rd Party Extended warranty recommendation
  202. Is It Def. MAF???
  203. Need to know if 2003 350z 18" rims will fit on my 00 max. Will 8.5'' fit the rear?
  204. Touchup Paint on Sterling Silver 03 Max
  205. Falling In Love Again
  206. Cheap mod....
  207. 2003 Maxima Crankshaft & Camshaft Sensor Recall - I got hosed by the dealer
  208. MAF cleaning update...
  209. Boss Chen coilovers review
  210. does anyone know... how long those
  211. LED in Keyring always on?
  212. pinging and knocking sound went away
  213. MAF compatibility question
  214. Tokico Suspension
  215. go faster stupid thing..
  216. Small Crack Formed on Dash
  217. Power loss over 2500 rpm. Help!
  218. Painted dash
  219. Upgrading needed!
  220. Suggestions on custom exhaust components
  221. Any 5gen owner with only y-pipe and Cattman/HKS muffler?
  222. LED Gauges
  223. TB and Intake manifold
  224. raplacing maf
  225. Hlsd ?
  226. Replaced rotors now they grind?
  227. How do I take off my brake lines?
  228. Which Cat?
  229. Been a while... diagnosis possibilities, gurgling sound?
  230. Are these the right spark plugs I should go? Pic inside
  231. Exhaust Question
  232. Crappy shifting on 6 Speed - Is it me or the car?
  233. does anyone have samco silicone radiator hoses?
  234. Wheel Bearing Replacement
  235. any 5.5 gen'z remove their reverse gate?
  236. Just bought 2000 max and it has no balls help
  237. Borla exhaust
  238. shipping from dave b?..
  239. **p0172**
  240. front sway bar links
  241. Service Engine Light
  242. how to remove front bumper?
  243. help! Car does not want to go more than 1/2 throttle!
  244. Question concerning replacement of Coils
  245. New Car Knocking on Startup!
  246. Wierd knocking problem upon cold startup. Help!
  247. I have two questions...
  248. ECU Question
  249. TS ECU vs New Headers
  250. Calling all 6-speeds that have had the clutch replaced
