View Full Version : 5th Generation Maxima (2000-2003)
  1. question about 02 headlight install
  2. Making 00', 01' SE TAILS
  3. Brake Problems again
  4. Diffrence between aftermarket rotors?
  5. 03 maxima acting wierd
  6. Rear Turn signal issue
  7. To those lowered w/ 235/45/17 on stock wheels...
  8. What if my HID die...
  9. 5/5.5 seats
  10. aftermarket e-brake handle choices
  11. 2k2 headlights with ebay angel eye mod
  12. The time has come...
  13. need help with Blemco ground wires...........
  14. AC Blower Motor?
  15. Final Exhaust Decision
  16. For those who've baked their head lights... enter
  17. Car won't start. Still have power and I have replaced the starter but still no dice
  18. Short throw kit
  19. Paint Fall or Spring ?
  20. 02-03 Automatic Shift Knob
  21. Just changed brakes - Rear brakes dragging
  22. 4th gen intake midpipe on a vq30dek 5th gen?
  23. Does any body know?
  24. Changing miles on ODO?
  25. So who loves thier max BUT still wants a diff vehical?
  26. Sticky brake caliper? Plus a funny suspension noise...
  27. Engine removal???
  28. 2002 HID Headlights
  29. Suspension setup for the newbie...
  30. 5-speed detents?
  31. Need help with oxygen sensor issue
  32. Question about Illuminas
  33. Feeling Invincible in My Gen 5.5 6-speed
  34. ABS Dynamics Front lip?
  35. Very Strange Problem When Braking
  36. Difficult Nav Swap?
  37. Removing headlights in 2001 AE
  38. P0464 - CEL How do i fix?!!?
  39. Need Help!
  40. Power Steering Hum?
  41. Razo pedals (has anyone used them)
  42. Does anyone have this link??
  43. Need Opinions: '01 AE Maxima or '02 Max SE?
  44. CEL P0420 out of 8/80 warranty... o2, ECM flash or cat?
  45. Wheel 'Humming'...?
  46. Those with Umnitza HID fogs...step in
  47. very quiet ticking while the air is on
  48. Car stutters when engine is cold...MAF issue?
  49. Problem with manual tranny
  50. frozen brake lines?
  51. Groaning Clutch 02 6 spd
  52. Any advice on Stock Brakes?
  53. P0430 - What can I do?
  54. Who sells the trunk floor thingy
  55. Exhaust smoke only out of ONE TIP.
  56. tranny slipping????? need input please
  57. Side View mirror repair: adhesive??
  58. Rear Suspension -- Ping/Ting/Clang
  59. Gentleman, your opinion is needed....
  60. Need help. Do i get these aftermarket fogs
  61. Just saying goodbye to the .org family
  62. Transmission poll
  63. Bye-bye max, hello baby
  64. brakes and battery connected?
  65. exposed rubber pipe behind rear driver-side wheel
  66. Double din gxe dash kit
  67. Interior Swap --- Cloth to Leather --- Can it be done?
  68. Changing inner tie rod ends
  69. Valve Body Mod
  70. Need Help, Cold Start Issues
  71. retrofitted projectors into oem 2k/2k1 housings? anyone done it here?
  72. auto trans makes a hard CLUNK into D after initial startup
  73. 2k Auto Tranny almost dead
  74. Looking for some feedback on the ES bushings
  75. rattling noise
  76. Help with wheel hub removal
  77. Question about Snow Tires
  78. heated seat switch wires
  79. SES light ...what to do
  80. magnaflows are finally on *pics*
  81. Silverstars arent all they are cracked up to be
  82. How particular is Nissan on honoring the warranty
  83. Rear Fog Light (installed)
  84. Gauge pod options for 5th gen.
  85. Please HELP! Warm stall = 'Air Flow Meter'
  86. Searched - Disable DRL?
  87. Can anyone help me out?
  88. Digital Temp Control not working like it suppose to...any ideas?
  89. Fuel gauge not working when cold?
  90. 02/03 Bose to replace an 01 Bose
  91. question:Planning to upgrade with HID's
  92. Let off gas, revs stay up a second?
  93. Swapped out my windshield nozzles!
  94. Does anyone know how to disassemble 02/03 Altezza tail lights
  95. 350z rims on 02 Beige MAX???
  96. Air filter choices
  97. Is there an easy way to swap a 5spd MT for a 6spd Tranny?
  98. Redlinemax.com
  99. Driver Door Sag
  100. Correct Optima battery for the 5.5th Gen
  101. Tranny problem
  102. Question about one touch up/down windows
  103. Front defroster question
  104. Manual Trans Drain
  105. 02...black mesh grille?
  106. Led Doom Light?
  107. Made a copy of my key for my car
  108. 2001 AE alarm problem
  109. Clear Chrome Tails issue (anyone else with this problem?)
  110. Help, 2k2 ECU removal
  111. Who here with an 02/03 6mt has NOT had a 3rd gear crunch?
  112. bumping sound
  113. Bose Hu (cd Stuck)
  114. How to take front speakers out?
  115. OEM Air FIlter Replacement
  116. When to change brakes?
  117. oil consumption
  118. which rims are better looking for the 02-03 maxima???
  119. How many 5th Gen Maximas in the 200,000+ miles club?
  120. Body Rust
  121. How to replace a taillight??...
  122. Clutch squeak and interior lights issue
  123. 5.5, stearing wheel controls supose to light up?
  124. Question: Cold Morning car cuts off
  125. Inpection blues
  126. Qyestion about the Fuel Injection Cleaning.
  127. Spark plugs
  128. Speedometer trouble...Need Help
  129. MAF Going out Slowly.
  130. LED Tails: The video
  131. Help me get the dealers back!
  132. 2002 Maxima Map light bulbs help and mysterious passenger ghost window
  133. starter for 2000
  134. 2001 se hard to start after fuel pump replaced
  135. Need help
  136. Tilleys99 can you clean out your inbox
  137. 2k GLE problem
  138. What's wrong with my new alternator?
  139. Nature Strikes!
  140. Starter Finally Quit on me?
  141. Any winter driving suggestions?
  142. wtf, are 5th gen STOCK springs impossible to put on??
  143. AT Going out..... Help needed!!!
  144. New 5th gen owner
  145. New Brake Problems
  146. 01 Maxima with 105k - need a checklist before buying
  147. Should I buy 6000k Bixenon kits?
  148. Quick question about Autolumination 7443 LED's
  149. Auto Park Option
  150. Ok... 5.5 Grille Painters... Step Inside...
  151. Advancing base timing :D
  152. Where to purchase a transmission?
  153. Replace Broken Wheel Stud DIY??
  154. injen cai cone filter
  155. any harm done?
  156. Question
  157. Headlight painters.... Flat black or Glossy?
  158. maf reprogramming?
  159. Where can i get a mass air flow sensor
  160. purchasing OEM replacement parts
  161. Spark Plugs
  162. Clear Corners question
  163. New Y Pipe Install
  164. 5th gen to a 6th gen, worth it?
  165. New Maxima owner, ? about noise.
  166. Does anyone know what this means?
  167. Max ground kit
  168. 5.5 gen stock whp?
  169. Feed back: Code reader
  170. I35 side skirts
  171. translucent led red lights for the clear/chrome tails
  172. 5th Gen LSD Options
  173. 5.5 Gen Auto to 6-Speed swap
  174. catback exhaust options ?? 2002-2003
  175. MAF cleaning
  176. O2 Sensor
  177. Changing Air Bags!!!
  178. Bad ECM
  179. Changed MAF - What is Idle Learn?
  180. code P0171
  181. Brighter Dash Cluster
  182. Problem with front right wheel?
  183. Ever dealt with DAVEB on 5th gen parts? step inside...
  184. sunroof problem
  185. A33 Maxima 20th VQ30DE 2001 Oil Filter 9E000 65F00 Dealer warnings, please help
  186. Which brand is better and will last long?
  187. idle problem after bored out throttle body install
  188. How to remove the governor from your Maxima
  189. Is my clutch about to go on my 02?
  190. Weird Window Problem
  191. exhaust questions
  192. Need Help!!!!
  193. 2000 maxima is slow?!
  194. My CAR is Having a hard time starting
  195. Trip from Phoenix to Chicago.
  196. power cable routing :(
  197. Need Strut boots
  198. Did FrankenCar go out of business?
  199. y-pipe rubbing on cross member
  200. Is my exhaust on its way out?
  201. 2 questions..DRL's and rubbing
  202. 5.5 oil and filter
  203. Neighbor's Maxima had a "computer board" burn out. Dealer wants $1500!!
  204. questions about 300zx bbk
  205. Back to the Max- Some ?'s
  206. Weird dome light problem: turns on when bulb is pushed up
  207. Rear Struts
  208. So who makes the Best CF hood? (CF hood guys)
  209. searched first, no luck - Need help with installing sub on base (not bose) system...
  210. $1083 For Airbag Update!!!!!
  211. battery fuse ?
  212. Heated Seat stopped working? Heres why...
  213. Need help with Bose 2001....
  214. light blinking fast
  215. MAF Bolt Size
  216. Help...Car feels slugish and slow !!
  217. 300ZX projector retrofit?
  218. Question About Pealing AE Shift Knobs
  219. For You with INTERIOR NEONS!!!!!!!
  220. greddy evo II fitment (from 02 to 03)
  221. Got these 2 codes poped up (please help)
  222. Noobie guide to getting that G35 sound for FREE
  223. Best Option for Upgrading ECU on 03 Max
  224. camber question
  225. 00 ecu pinout
  226. 2006 Turkey Day(or stay the f**k away from in-laws)
  227. oil pan ?gasket? leak
  228. Need Your Help With MAF Issue. please!!!
  229. what is this hose to intake?
  230. infiniti sound
  231. WTF umnitza!!!!!
  232. Has anyone install Koni Sport w/ stock springs?
  233. Black 5.5 gen headlight housing
  234. Power Steering Leak… what should I do?
  235. PO650 Code
  236. RIght headlamp WON'T TURN OFF!!
  237. remote starters?
  238. Car dies after being started...starts up okay later
  239. Speed odometer help!!!!
  240. Is Auto Transmission Swap Possible?
  241. help with stereo
  242. Please help...My headlight doesn't work
  243. DDE Light Intensity Help
  244. OEM Strut part #'s?
  245. greate...
  246. 2K3 Bumper On 2K1
  247. what can cause the engine to stall?
  248. Will 02-03 GR2s work on 00-01??
  249. Install New Radiator On '02 SE?
  250. 2000 ignition coils (again)
