View Full Version : 5th Generation Maxima (2000-2003)
  1. Spark Plug Question
  2. Headlight ?
  3. Stock Maxima HID bulbs
  4. Whats the deal with frankencar?
  5. Car Alarm siren
  6. Any difference in 5 and 5.5 gen mufflers?
  7. Will we ever have HID projector headlights??
  8. Light Up Door Sills
  9. Maintenance Question
  10. Grinding noise when coming to a stop in front brakes
  11. Engine Code 0550- Power steering sensor
  12. Car died when first started and started up fine after..
  13. Brake time, (front pads and rotors) worth it to do rear pads too?
  14. need wiring diagram
  15. Car starter install/help
  16. Front Wheel Bearing replacement
  17. Exhaust Kits
  18. hardwire radar detector
  19. Angel eyes/halos/DDEs question
  20. Damn D2's and their damn clunking!!!
  21. Spring compatiblity
  22. Parking Lot Hit and Run
  23. The GAB, what a great little mod
  24. Lowered and Alignment Problem:
  25. What's wrong with my struts?
  26. What would you do 02 Max or 05Altima3.5SL
  27. Plastic Engine Underbody Covers
  28. Want to upgrade my HID's
  29. ebay CAI for 95-99 fit?
  30. Where to buy cheap cat. conv. ? parts question
  31. Fuel pump noise?
  32. Garage Door Opener Controls in Visor
  33. Blackstone Lab recommends Dino oil
  34. Reverse Lights wont come on
  35. 2k SE 135k stalls at idle???
  36. What kind of bumper to get...01-02 and are ebay parts junk?
  37. ES motor mounts Q.
  38. Ebay Yellow Halo Fogs
  39. remote start question
  40. k-sport springs for the 5th gen...
  41. Windshield Wiper Issue
  42. Hub bore on a 2k?
  43. Looking for some AfterMarket speakers
  44. How Do You Think These Wheels Would Look On A 5.5 Gen?
  45. 2k3 Max v. 2k7 G35S - long
  46. safc-II vs vafc-II
  47. 2003 6spd axles, how many splines?
  48. Urgent engine acts weird!!! please check
  49. Axxtion Short Throw Shifter? (anyone running it)
  50. Remove Grill 5.5 gen
  51. freak accident.... ECU dead
  52. 3rd Tranny in 3 1/2 years...!!!
  53. Power Steering and IACV operation
  54. custom CAI plans.. not goin so good
  55. crankcase vent hose question
  56. Anyone have the update disc for GPS Nav system?
  57. Need some clear corners advice
  58. chrome door sills
  59. Do I need a tune up??
  60. Question about Slight Hesitation when starting 2K1
  61. Clutch Pedal Travel Adjustment? (is there one?)
  62. Strut Question
  63. Engine Shakes. Engine light came on...Help 3.5
  64. I think I need a new transmission...
  65. Brake light and battery light On
  66. interchangeable vq35 motors?
  67. HELP!! Car Barely Moves!!!!
  68. Accident, Need Advice...
  69. will 2k stock springs fit on 2k2
  70. cold start....car almost stalls after putting in drive and hitting gas
  71. Mod Suggestion
  72. rear axle beam question
  73. "A/T Check" came on..... HELP!!!
  74. Need your Help guys!!!
  75. Roadside Emergency...
  76. apexi vafc II install instructions
  77. Heavy Engine vibration until 1500 RPM...
  78. White Smoke from Under Oil Cap in 3.5L Engine
  79. 01 maxima blower motor fix
  80. Leaking windshield
  81. ticking noise
  82. My poor Maxmia
  83. the Anatomy of a MAF...
  84. Will a non bose unit work in a bose car?
  85. Bad Bearing,Hub, Or Knuckle
  86. 5.5 Gen/Does engine exhaust come out of exhaust both tips.
  87. Recent Road Trip and Check Engine Light
  88. Alternator voltage regulator?
  89. Check Engine Light- Kind of on...
  90. Great Head.....s......
  91. so no one has "WHITE" rims?
  92. Clutch howling on an 03
  93. header setup/o2 sim question
  94. coils
  95. need help
  96. jeff92se bracket?
  97. Anyone interested in full taillight overlays?
  98. New Cattman Headers - Comments from installation
  99. Exhaust Question
  100. Resetting Flashing Airbag light
  101. What level do you set your volume to?
  102. Suspension mod Question
  103. Anyone wonder how to rip your entire bumper clean off?
  104. Brakes
  105. 40 series on 19inch rims (please help)
  106. Installing replacement ECU
  107. Its Here!!!!
  108. Fixing an AE headlight mod gone bad...
  109. Awesome deal for any 5th genners looking for 19s!
  110. Coil pack problem? Looking for verification.
  111. Cali Max cat ox issues
  112. Computer reflash questions.....
  113. lip on wheel wells
  114. SIDE MIRRORS swap
  115. The Starter failed again!
  116. JIC coilover
  117. So Long Maxima
  118. cattman cat back loud as hell
  119. Advice on new muffler
  120. simulated 02 sensor
  121. took stage 2 LTB off.....yuk!
  122. Injen intake -- how long between filter cleanings?
  123. Squeak from front end...
  124. Projector Head Lights
  125. booo injen warm air intake
  126. Replaced IACV-AAC Valve, Now My Car Doesn't Start
  127. Read the ignition coil resistance thread - but got strange results
  128. Pot holes!!!!
  129. Coolant replacement...should i pay or do it myself
  130. Ignition misfire codes, need some recommendation!
  131. Check engine light wont go out
  132. 00 Max wont stay started - all advice wanted
  133. Anyone have the NAV upgrade disc?
  134. Air Blower Issues
  135. Has anyone tried these fog housings for the 5.5 gen?
  136. How to inspect Swaybar endlinks ?
  137. Quick Y-pipe and ECU question...
  138. Need your opinions...
  139. Short Shifter
  140. Merry Xmas!
  141. Where to find part #s.
  142. Question to everyone with 3.5L engine
  143. HELP... really screw up my car... really really need your help!!
  144. 02 I35 side skirts forsale
  145. Got Hit Last Night....
  146. Air conditioner making clicking/clunking noises?
  147. B pillar tape
  148. HP Gain Estimate?
  149. need help with a cat-back
  150. Problem with chrome rings on 2k1 SE
  151. Calling all suspension guru's
  152. Hight Mount 3rd Brakelight Question
  153. Buying a 2002-2003 Maxima sugesstions?
  154. Heater Problem 2000
  155. carbonfiber engine cover
  156. stock HIDs
  157. HELP with dents
  158. Problems getting NAV CD to work
  159. Help, Fan Rattling behind dash when AC is on.
  160. Bad strut......HELP
  161. wierd knock at low rpms
  162. Thinking of buying a 01 max...HELP PLEASE
  163. 2001 ae tranny
  164. crazy 18th birthday..........
  165. Am I missing something?
  166. Lookin for Stillen Front Fascia.
  167. does anyone know where the IACV located on 2k1 max.
  168. Front right end rattling noise any ideas?
  169. Had the ECU reprogrammed this morning for the TSB 2500-3000 RPM stutter...
  170. remove stock stereo
  171. 2002 Maxima Stalled, Tach Dead, Hard to Start - P0335 Code
  172. SO, i just found out my car has frame damage. (never knew)
  173. Security System Problem Help!
  174. opening hood from outside??
  175. a few questions...
  176. Need help for tranny
  177. hood pin switch
  178. rear quarter panel repair
  179. Daytime Running Lights Install
  180. throttle body coolant bypass
  181. Custom Enterprises WTF!!!! Upset!!
  182. cleaning the manifold
  183. SES light just went off....
  184. My Max IS NOTTTTTTTT Good Shape
  185. Code P0160 O2 Sensor - Just want to make sure I order the right one
  186. Pinging noise when accelarating
  187. New MAF. Should I replace my Stillen Intake?
  188. Tune-Up
  189. Stillen Classic Front Lip 00/01 vs 02/03 question
  190. ABS sensor install
  191. cleared out my blinker which bulb to use for amber light
  192. Tune Up
  193. 03 Compass Mirror installed on 02
  194. 01 Maxima.. How to remove windsheilf washer nozzles??
  195. transmission went bad with only 90k?
  196. Carb cleaner and fule inj cleaner
  197. bad cat smell when "DRIVING" my car a little hard, normal?
  198. My car doesn't burn oil, how rare is that???
  199. bit the bullet - all new coils - have question
  200. never experienced anything like this!
  201. Loose Steering
  202. Remote Start
  203. angel eyes -ebay leds and ebay ccfls updateing
  204. Just got Fast blinking LED turn signals. do you like them?
  205. Decided to use 5W20 synthetic oil
  206. How to roll the rear fender?
  207. Changing Guages questions on a 2000
  208. Body Kit Question
  209. Max wont start (long)
  210. speed limiter?
  211. 02' grille
  212. CODES Please Help!!! P0420 & P0440
  213. Need Help ASAP with IAC Module
  214. Anyone with autozone blue/white PCV valve?
  215. Control arm question
  216. maxima acting up, vets please enter
  217. replacing PCV valves makes any diffrence?
  218. Silverstar Ultra
  219. How to reinstall sideview mirror?
  220. 02 gauge cluster lights
  221. What to do when the SIM won't help (P0430)
  222. Dash / running lights out, fuse keeps blowing
  223. right passenger wheel?
  224. what resistor for SRS airbag fool?
  225. Please Help.. 2001 Maxima is possesed!!
  226. Sounds like my wheel is going to fall off!
  227. those with silverstar fogs (5.5 gen)
  228. help aiming headlights
  229. hose just for looks?
  230. Custom CAI
  231. does Infiniti I30 wheel bearing/hub fit 5th gens?
  232. Beyond the BIG 3
  233. Help Installing Helios HID kit
  234. Looking at a car, what should I be aware of?
  235. My Car after a accident and repairs...
  236. angel eye options for AE only
  237. Owned by Depo Fog light?
  238. I need help
  239. HID in the fogs
  240. Accelerator??
  241. Camber Kit
  242. How come I can't search?
  243. any small mod ideas guys?
  244. Selling MISC parts.
  245. How to remove headlights with data dots?
  246. Does anyone have DaveB's phone number?
  247. Clunking when turning or going over bumps??
  248. Question about paint
  249. VAFC-II or AFC Neo
  250. question about 02 headlight install
