View Full Version : 5th Generation Maxima (2000-2003)
  1. Injen intake sux!
  2. Quick question about interior lighting
  3. Intake for Maxima
  4. Flyin Ice From a Truck got the Best of Me, Pissed!!
  5. Quick Shift Knob Question, 5.5 6 speed owners
  6. Eibach/Tokico Owners...
  7. What mods to go with next?
  8. While replacing the spark plugs, this is what I see
  9. 2002 AT Shift Problem
  10. New Coil Sping Isolators
  11. Blower Fan Squealing - 2003 Maxima
  12. engine power cutting down? Help!
  13. driver seat not sliding back and forth
  14. Home Depot grille mod
  15. P0507 solved yet again
  16. Sticking clutch pedal
  17. Replacement check engine light bulb
  18. air pressure in tires?
  19. the dumbest HID question
  20. Axle Problem 2000 Maxima
  21. P0505 after Injector treatment at Nissan
  22. Code 0430 popped up again
  23. Bose HU fuse?
  24. Do they fit? - KYB Dustboots/Bumpstops on Illuminas
  25. $700 dollars for header install
  26. fuel pressure reg
  27. Please Help!!
  28. Post engine bay photos of you 00-01 CAI/short ram intakes.
  29. Headlight Aiming Prob
  30. wrong spark plugs??????
  31. frankencar exhaust rattle
  32. what's the best???
  33. QUIIK... Place Racing CAI users
  34. Short Shifter
  35. Just ordered a new MAF...
  36. 2003 Driver's seat question . . . ?
  37. Tire Balance issues--WTF!
  38. NEED answer ASAP easy question.
  39. Anyone make a 5.5 to 4 gen convertion harness for the ecu
  40. Any other '01 Maxima's had this problem?
  41. Front Sway Bar
  42. Please help! How do I bleed brakes??
  43. Valve Cover Gasket & Oil Loss
  44. quick question
  45. Confused: Headers or Y-Pipe on 3.0DE-K
  46. IACV Relearn - Another great dealer experience!!
  47. BG44K Emission set - instructions?!?
  48. A $1000 bucks to play with...
  49. Accident/Insurance question
  50. Door Problem
  51. Cold Start issue ... SOLVED!!!
  52. Shocks help?!?!?
  53. front brembos and hawks in, did some painting too (pics)
  54. Cold weather/engine starting issue
  55. eibach vs h-tech for 5.5 gen
  56. New 5.5gen eyelids
  57. Low Pressure in Window Washer Fluid Nossle
  58. 6 speed upgrade on 2000 max
  59. best place to get new caliper slide pins? (front, 5.5gen)
  60. mesh grill insert for bottom bumper openings
  61. Link for expoxy to attach the LED DDEs (angel eyes)
  62. How to replace side view mirror (5.xgen)
  63. Code reader/Scan Tool
  64. posting Pics
  65. Passenger High Beam not working...
  66. Dome light completely not working anymore....
  67. Are these the newer coils? PIX inside?
  68. General Question Gle And Gxe Differences?
  69. Where is the best place to get a door mirror
  70. Side window deflectors
  71. P0507 - CEL - You have got to be kidding...
  72. For all of you that have installed the Ebay LED DDEs please look.
  73. In Cabin Filter MOD!!!!
  74. how many miles before time for a new shocks
  75. Frankencar
  76. Am I going to need a Fog Kit????
  77. Differential/tranny Change (Help)
  78. Looking at a Max tomorrow to replace the alty
  79. Loud Bang, No More Go
  80. blackmax96 intake
  81. Gonna clean my IACV..anything i should know b4 i do this?
  82. Cattman b-pipe with stock muffler
  83. who is the best?
  84. How to video: Seafoam through Brake booster line
  85. aftermarket headlight question
  86. 5.5 gen auto to manual.......
  87. What's the ride quality of Progress Technology Springs?
  88. Traded the 02-SE for an 04-SL
  89. 2000 max now a six speed
  90. what is the diffrence between these wheel spacers.
  91. Wider tire that fits right on SE rims?
  92. What does an O2 simulator do?
  93. Simple PLug and Play HID FOGS?
  94. PIC REQUEST: 5.5 gens with Stillen body parts
  95. 5000K Picture request
  96. AXEL NUT SIZE? (CLICKY AXELS) 5.5 gen, 6spd
  97. NEED A REPLACEMENT CLOCK, don't ask...
  98. AE Shift Knob
  99. Side marker lights issue.
  100. slight thumping/thudding at low speeds when curving right
  101. Fog lights wont turn on. What to check for?
  102. HID diagram needed (I included my lights pic)
  103. Monroe Sensa-trac Shocks
  104. Lawsuit regarding IACV burning out ECU
  105. SUPERCHARGER KIT!!!!!!!! puppet master help ! hahaha
  106. KYB GR-2 or AGX? Please help.
  107. another exhaust question
  108. front seat questions...
  109. Engine Leaking Oil? VQ35
  110. 3.0L 5th gen max injectors
  111. anybody had this problem?
  112. 6spd trans mount pics
  113. just ordered these taillight tint covers
  114. exhaust sound
  115. CEL codes P0011 and P0021
  116. Am I getting ripped off?
  117. UDP...Is it really worth it?
  118. shifter swap
  119. Where can I buy clear corner markers?
  120. Trouble Code
  121. I think my ECU needs an update..what if it's already had it? 420/430
  122. Re-Installing Stock Bumpers
  123. some problems im coming across
  124. Found a VIP style 5th gen...
  125. Rear cup holder insert???
  126. Do you have to pay for a TSB fix?
  127. 2000 Maxima No power @ WOT, no codes
  128. What type of fuel do u use 02-03 maxima owners
  129. 5th Gen 5-spd Swap Parts
  130. 2000 Fuel woes
  131. Shiny Door Trim
  132. Changing PCV on a 2000 Maxima?
  133. Any interest in front door speaker spacers/adapters?
  134. Urgent held with rear brake calipers? Do I need to replace them!?!?
  135. Interesting problem:
  136. Differences between 02 and 03?
  137. spark plugs
  138. sounds like a squeak
  139. Is This Really Possible
  140. Air bag question
  141. Cleaning headlights
  142. Cylinder # and placement
  143. which connector to tap into
  144. Warspeed y-pipe??
  145. Battery connection problem
  146. lip spoilers
  147. Which is better?
  148. Torque Converter?
  149. which o2 sensor????
  150. Convert to Daytime running lights
  151. Can I replace non-heated mirror with a heated one?
  152. What are some of the little things that need maintenance/tune-ups?
  153. Jet Computer Chip Upgrade
  154. CD speakers, problems
  155. Need lots of info on the 00-01 VQ30
  156. Alright I did my homework on the vafc-II
  157. Hole In Firewall??
  158. headers
  159. Funny noise coming from front driver side during start-up
  160. any using metra 70-7551 nissan amp integration harness?
  161. Car flattens out at certain RPMs-no check engine!?
  162. Vibration around 2k rpm? bad motor mount?
  163. Best time to fill up??
  164. 02 Factory Alarm Question
  165. license plate lights
  166. How do you replace burned out gauge bulb??
  167. Need Remote starter installed
  168. Upgrade to a 5.5, what to look for.
  169. Po420 code??
  170. Do they make perimeter billet grilles for 2001???
  171. Hawk Pad users step in please...
  172. Need new tires
  173. Opening up 02-03 Taillights
  174. 1700-2000rpm rattle solved(on my car anyways)
  175. Transmission mount
  176. 2002 Power moonroof
  177. SMASH!! My Maxima got crashed :\
  178. 2002 in the shop. Tranny getting looked at!
  179. Warpspeed y pipe
  180. AE Tail light Q
  181. Its probably here somewhere....5spd Q's!!!
  182. Toyo Proxes 4 in 5th gen stock 17" size? Do my eyes deceive me?
  183. buying AE Tailights
  184. What kind of clutch to get?
  185. 5.0 gen flywheel question:
  186. climate control
  187. Knock Off PR Style CAI?
  188. Help Front Strut Tower Brace install
  189. anyone using NGk BKR6E-11
  190. do not buy speed racer y pipe
  191. DR MOD is on crack
  192. Starting in 2nd with automatic?
  193. VAFC-II wiring
  194. what kind of role does this thing play under the hood? Help
  195. Replacing clutch
  196. Weird sound from my Right Rear part of the car
  197. Sunroof Control Problems
  198. Question for electric component pros!
  199. Engine oil DipStick.
  200. D4R bulbs....will they work in our max??
  201. what is the best 6000K HID bulb out there??
  202. my LED int light
  203. best carbon fiber
  204. 2k HU VS. 2k1 HU
  205. Cusotm DIY Angel Eyes! (5.5 headlights)
  206. How much do you think it will cost to fix??
  207. LED Tails - Done with Pics
  208. Stick with 5th gen, or swap for 6th gen?
  209. HID woes - how do you replace the bulbs!?!
  210. check engine light on after intake install
  211. Programming Key Fob for 2K MAx
  212. Exhaust question
  213. My baby's been hit
  214. Spark Plug replacement - 3rd set at 149K
  215. Reverse Light Switch
  216. 2001 SE Audio Question - Stock Cd player with Amp+Sub
  217. Time for a D2 rebuild...
  218. 2k2 Transmission Problems
  219. Sub
  220. P0420 linked to MAF?
  221. Speedo Bulbs for 2002
  222. Pic Request- In dash screen
  223. How many miles on your stock MAF?
  224. SES light??
  225. Considering buying 5th gen
  226. Speakers
  227. Cold Start
  228. Has Anyone had to rebuid their tranny and......
  229. Tranny Question
  230. vis r34 bumper
  231. HELP! Question about nissan stealership.
  232. dash lighting out
  233. For those of you with the "Blower Motor Only Works on Level 4"
  234. Have you used AUTO-RX in your 5th gen's engine?
  235. Memory Seat Qst
  236. stillen has injen intakes forsale
  237. Leds that put the sun to shame
  238. does anyone have these fog lights?
  239. Tranny getting lazy...
  240. SE heated side view mirrors?
  241. Heated Seats - interesting Q!
  242. Spacers 15mm or 20mm?
  243. 2k2 headlights in a 2000
  244. Brake pads problem. Please help.
  245. speed racer performance y pipe
  246. noise on startup,....cant be good
  247. 6 speed
  248. Master Key Issue
  249. VCT Solenoid Replacement?
  250. Air intake (K&N) bad for a car?
