- AGHHHH Cant Find Fuse
- Eibach Spring Question
- p0430- but no light?
- I Need Help W/ Stock Headunit Removal
- SES and codes
- Help with installing DDE's
- How Many VQ35's have done SeaFoam and Got CEL?
- Found a great deal on Brembo blanks 90.80 shipped
- hot cold guage is cold when moving. need help
- Best place to splice for a hardwire XM
- dash fan making noise
- Clockspring Assembly???
- oem intake question
- apexi fliter
- MIL Eliminators $12 bucks? Anyone have experience with this?
- Oil Filter Cap...
- Alarm question
- weird problem, i think its my tranny
- "Y" pipes
- 6spd shifter control arm
- battery issues
- o2 Sensor Replacement/ECM Reset Required?
- Noisy 5 speed?
- Gauge cluster bulb replacement....
- power steering leak
- Battery died -- checking on the o/p voltages
- Anyone have pics of 5.5 gen with 35th anniv. 350z wheels mounted?
- **random But Important Please Help**
- accident advice
- stealership woes!
- When to replace Air Filter, Cabin Micro Filter, Plugs and Fuel Filter
- How to remove the freon in the A/C line ?
- cattman catback clunking
- Hookin up power seats. Need some Help.....
- Plugs are showing lean
- Bose Subwoofer Cut out Problem
- Ground Control Coilovers Installation
- Ah... The infamus tranny problems...
- Where to buy for 2K3: Bushing for manual shifter. At end of shift cable. For STS....
- Lemon Law
- for those who have installed walbro fuel pump
- skipping issue continues......
- body kit?
- Need Help...
- Ignition Amplifier, how does it work?
- 6spd shifter cable bushings
- Need help w/ P1320. Beyond just coil packs and have searched.
- Belt Broke!! Help Need Immediately
- Headlights on with Wiper Blades
- Damn Ignition got me stumped!!!!
- which hella horns
- Front Bearings: hub+bearing or bearing only?
- Crazy accident need advice
- Phenolic Spacer Development for VQ35s
- exhaust leak or tranny slip???
- Looking for Advice... Factory Navigation
- Maf Excellent....shifting Not
- Possible Transmission Problem -- Confirm/Deny
- New exhaust vid with new headers.
- Dim Door open light?
- Help!!!!! Key Ingnition Problem
- clunking noise when i make turns
- Wierd 5.5 stalling problem
- Battery/Alternator Fuse on 2k2
- 5th gen comercials
- Odd light activity
- 2002 Speedo bulbs
- Groaning Sound Turning Left At Slow Speed - Opinions
- ECU are they really worth it?
- front suspension work....DIY?
- Milky oil in catch can. Is it due to the cold?
- AEM Dryflow
- !!wind Noise!!
- Help Me Understand!
- My custom LED lights
- Where does this hose go?
- Are we still buying y-pipes or is everyone getting headers?
- Finally did the GAB mod!
- Help! My trunk won't close!
- 95-96 Greddy SP on my 2k2
- Got Problem With Illuminas / Teins - What Do You Think? (pics)
- ? about ebay projectors/swap with bosch e46
- STS Users please step it...
- 6-speed swap (people who care only)
- To 5.5 gen. owners clutch question
- 02/03 front turn signal wire harness
- Spring question
- Upgrades!!!!
- EGR Tube
- bleeder valve???
- 00 Ignition switched locked
- ?? re: Engine Replacment for OIL loss
- You have got to be kidding me!
- Hood Latch alignment
- intake plenum spacer???
- For any with Tokico Illuminas and S.tech combo
- unlocking doors
- 5th Gen Wheel/Tire Specs Thread
- Any white maximas with black wheels??
- VB mod?
- CEL and no code? what gives?
- Pics of TSX projector retro w/ebay proj
- Clear taillights on a 5th gen
- Clutch Hydraulic Line install HELP PLEASE
- After Markt Headlights with Philips balast?
- 5th gens in 3d
- Housecor aint got nothin on me!!!... (56K beware)
- trouble deciding on a tranny
- 6th to 5th steering wheel swap
- Trunk Carpeting replacement
- getting outta snow, only one gear in auto?
- 3.5 Swap
- Very Sucky Accident - Feedback Plz
- someone stole my bumpers and headlights
- 2000 SE 5 speed, what tranny oil ??
- Yes the MAx rules in deep snow !
- MAF and S-AFCII Q's
- Fascing a serious suspension dilemma.
- Where can i buy clear side markers?
- Snow in wheels threw wheels off balance!
- Hate to ask... Anyone have sound clip of ONLY berk intake?
- Cleaning Throttle Body On 5.5 gen (2002-2003 only) - Yes or No
- 2003 6 speed tune up help/suggestions on parts etc
- Rear wheel bearing problem
- Effect of lowering on the CV joints
- How to remove teh axles from the tranny...
- 142,500 mile maintenance
- Cold Air Intake
- 5.5 Gen - Tail light question
- Condensation in driveside headlight, help fixing it please!
- Sooo....MAJOR TRANNY PROBLEM!!!!!
- Cons with running stock intake resonator w/ APEX-i?
- Thought i would introduce myself and my new car
- Power Seats Shedding Chunk-O-Rubber
- For those considering GAB
- should i rather keep stock tails than going for these?
- When to reset the ECU? What Changes?
- Anyone know how to get in touch with SR20DEN??
- Idle Relearn question...
- O2 Sensors
- 6spd trans mount ?
- Does Cattman Y-pipe have a distinctive sound
- Strange Noise coming from throttle
- Staggered set-up
- vafc-II
- Aftermarket Heated Seats
- 90 k tune up
- MAF Advice
- Wind noise coming from front end
- 00-01 SE tail lights on 02-03 Fit?
- Auto headlights didn't shut off
- Need conformation on Metra kit for 5.5
- need help please
- Vehicle Speed Sensor - 5spd Swap
- Noise while turning while car is cold
- New oxygen sensors = lower MPG??
- Brake Light On Spoiler not Working
- how much does a 5th gen weigh..to settle a debate
- Proud new 5.5 Gen Owner :)
- Does anyone know... headlight aiming question
- 5th Gen 5spd swap, write up as I go. FOLLOW MY PROGRESS HERE
- Oil loss plus idle problem:weird
- Ordering HID harness's: Questions
- Will fogs from a 00 fir my 02
- Exhaust woes
- Toolkit ( crowbar, etc) missing
- SLIP and TCS OFF lights are lit up.
- Sunroof Controls on 2K2
- Budget B pipe
- Transmission Acting Weird
- 8000K bulbs for 5.5 are they any good?
- Maxspeed -vs- Gold Line lowering springs.
- Cheap/Fast Place to get Blues?
- Have you tried this Injector Cleaner?
- Need Helps On Insurance Claim
- finally smoked the tails
- Strange Suspension Noise out of Drivers side Front
- 2 exhaust questions...
- Squeaking noise...help.
- 2000 5 Speed Tranny Question
- Airbag light is flashing steady...where to get diag.?
- My 5th gen got T-boned: Need Advice
- Removing the axel bolt....
- JB Weld VIAS fix.
- Manual to Auto Climate Control
- Can you identify what this is under car? (pic)
- which resistor to get for led?
- Please explain Cat/Y-pipe to a beginner
- Bad gas mileage
- P0420 Code - My Repair Options - How do I get around dealer diagnositic fee?
- Port and Polish IM
- Broken Engine Mount/Humming Muffler
- removing gauge needles
- Does anyone know what this part is?
- Question about this molded dash kit
- Installed new MAF...
- MAF Replacement Question
- Wheel dilemma
- Remote Starter with OEM FOB
- Lower Tie Bar stage 2 pictures
- Thermostat Replacement in 20th AE
- Heating woes...
- K&N Intake for 2k2 recommend???
- Q for experts 4th to 5th gen
- A horn quesiton.....
- Front lip
- any 5th gens with 19" infiniti M45
- how about some 2k/2k1 se LED taillights
- Going to Nissan to reset ECU for new MAF...
- Wheel Spacers
- Bolting in different seats ie: 350Z seats, etc...
- Hit something on the highway. (no 56k)
- Auto Dimming Headlights
- Stock Suspension after 5 years (GLE vs. SE)
- stiffneses in brakes on cold mornings
- engine rebuild?
- driver side wiper isn't working... help
- 2002 Spark Plugs - Please Help
- VQ35DE Pinging Dilemna
- Tranny question regarding Auto
- Help! no idle..
- Cons of not using premium gas.....does everyone use it
- Front Bumper Painted
- ~~~~~~~~~~CaN i use 300 zx calipers????
- Temp read-out in 5.5 Max.
- Acronyms / Descriptions -What The Letters Mean
- look at an '03
- suspension help
- Noob question
- suspension noise??????????
- What do you guys think?
- Anyone know ever use this before?
- Throttle pedal frozen/stiff when car is cold. Why?
- Were can i get lesxus yellow fog caps.
- Electrical problem
- Transmission Faliure
- My Max isnt running like it used to.... need some advice please.
- misfiring when cold/bogging when warmed up
- Used 2k2 SE - What to look for
- Coolant Leak Question
- Starting Problem
- Passenger window malfunctioning
- i apoligize
- Hmmm, should I be mad?
- So I did the 6th gen BBK
- Price check on a 2k2
- The Great Intake Debate....
- P0139...first time O2 sensor dead. HELP!
- Injen intake sux!
- Quick question about interior lighting
