- Replacing inner tie rods - need advice
- need some advice....
- Programming the Keyless entry
- flywheel reinforcement plate on aftermarket flywheels
- O2 Sensor Heater circuit resistor
- How is the stock brake pedal pressure suppose to feel? Compared to other cars?
- suspension help
- Hit and Run
- Nismo (Altima) F&R Stabilizer Bars for 5th Gen Max/I35
- Wheel almost fell off.......
- 2003 Projector Headlights
- P0138... But I have an o2 Simulator!
- 4th gen RSB on 5.5 gen?
- CV Boot/Axle issue
- how much should it be?
- Flipping ticked off
- 5.5 gen grill?
- Bumping/Grinding Noise
- MAF dead?
- New brake pads
- tien coilovers
- D2 problems fixed and adjustments explained for 5th genners
- In the middle of suspension install....
- SES Lights, now high/fluctuating idle...what can it be???
- I would like to thank BERK Intake for letting me moisten my pants...
- will be dyno tuning in the morning but need help with settings
- Wtb
- HID Interest?
- 2002 Max se Steering issue Help!!!
- Buying New Front Bumper
- idling, how much fuel does it really burn?
- Grille's???
- 20th Anniversary SE gauge cluster swap???
- Bendix rotors for replacement?
- Can someone help me ID this dash Light?
- steering wheel sawp.
- SEL Gone...Can I Pass Emissions
- Factory Alarm setting itself off!!!
- ABS issues on an '02 SE
- 00-01 Painted Mud Flaps Vs 02-03
- Fixes for 2 blehmco products (LTB and BBK)
- Cefiro conversion
- ........... MAF, O2, Coil ... The $$ is alreay sucking away....
- New Brakes question. Help a noob
- have a question about vb mod?
- Interior buzzing at certain RPM
- need help w/ passenger window
- Aftermarket Headlights
- PA State Inspections & Codes P0455, P1448
- compressor not turning on
- big fuse that comes off battery
- Pending trouble codes?
- Had a minor accident today... Lookin for estimates on price
- Help Identifying Problem
- are 4th gen and 5.5th gen valvebody's interchangeable?
- Other FOB Hidden secrets?
- car shakes when I brake
- Thoughts on Technosquare and throttle response
- Issue? Rear spring on strut perch install position. Look...
- Weird Tire Wear!! Little Help.
- Da Foggies, Da Foggies need replacing
- Traded my 02 Max 4 a 07 Altima but already...
- Lexus yellow capsules and HID fogs?
- Looking for some help/advice ...
- Springs that are good for travel
- z33 intake swap and now brakes are messed up
- does anyone make an aluminum radiator
- I'm Baaaack....Bought a 2000 SE today
- Suggestions needed for Shroud Project
- 99-03 same muffler???
- Hood Support Struts
- Locked keys in car...need advice
- Custom 2.5" Catback with 12" Glasspack
- Inside brake rotors thinner?
- One Tough Axle Nut
- Turning off and on the valve body mod?
- Rattling noise
- 02+ HID Painting & Clearing Journal: PIC HEAVY!
- 2003 SE Stock Headunit
- how do i get the face of
- Anyone have the next gear I.M. gasket?
- sunroof visor
- Were 2000 or 2001 5 speed Grey Lustres built with Black leather interiors?
- What should Nissan HAVE done to make it for you?
- Anyone successfully replace O2 sensor S2B2?
- A Quick Response Please - Mid repairs
- Bad Alternator?
- Side marker
- Torsen limited-slip differential
- HELP!!!!!- Car won't start......need advice!
- HID Replica vs. OEM
- Busted a Brake Line whilt traveling...
- Quick ECM question
- 2000 SE BASS BLown ??? Need replace amp, HELP!
- CV Joints Clicking Only when REALLY COLD
- Does your blower motor sound like a weedeater? Cheaper fix inside..
- Installing Fog Light on GXE Nissan Maxima
- DTC P0135....Can't get this O2 sensor out!!
- Goona try to make a custom "warm air intake"
- Need help: Strut Plates
- What do ya'll think about these headlights
- ABS LIGHT (Can it cause the whole ABS system not to work??)
- Maxima 2002 SE, 6SP, 120000 miles
- Blinkers for 2K1 SE
- Automatic shifter problems...gets stuck in 2nd or 3rd
- on the market for y-pipe...
- Maf Q
- New 3.5 SSV polished intake manifold
- I Hate People!
- Crunking and rattling noise!
- making a plug and play eu ecu harness?
- so long Maxima...
- Just wanted to share a pic...
- po505 help
- Suspension travel is <2 inches. Bottoming out often.
- Info on Big Brake Kits?
- tint
- Car dies as soon as i start it unless i keep on pressing on gas!!!
- heard the stupidest thing today
- Jack Collapse......Any Ideas?
- I need these side skirts
- CV joint noise in the cold?
- Am I ok padding the C Pillar
- Its Official... My Max Is Totalled
- Will a 5.5 GEN grill fit a 01 grill?
- Stock 01' GLE 0-60 time?
- anyone hear of this IM gasket insulator b4?
- Swaping a wing from an SE to a GLE
- what kinda alarm?
- Gas
- Rust-free rotors... does such a thing exist?
- Highway speed noise
- Dash kit removal
- which plugs to get?
- Cheap Ebay Maxima Turbo
- Keyless entry
- Mechanics: Step in. Need a HOW TO.
- Looking for masterswitch...
- Thoughts on Koni "Yellows" and what springs to get for them?
- $$$ to spend need suggestions
- New 2001 Maxima GLE questions
- How do I swap out the thermostat?
- Needed Maintenance
- What pin and wire color....?
- Ebay Projectors
- Sway Bar bushings
- Tranny problems 5/60k warranty question
- VQ30DEK: engine talk
- Energy Suspension shifter bushings
- Anyone have pictures of tinted/darkens 5.5 gen tail lights?
- 04 HLSD Transmission in an 02
- Looking to buy a 2002 Maxima, have questions.
- Loose E-brake...
- Help!! Broke down on the freeway
- Couldn't leave the family (new 5th Gen owner)
- Idle trouble....
- reset SES but not codes?
- Replace trunk mat?
- PBR pads squeaking real bad
- Tuning without afc
- problem w/hood
- 02 Max GLE vs. 98 Audi A8 4.2 Quattro
- 3 moderately serious issues with my 03 SE
- Four Point Harness Question
- Rear Window Spoiler
- SE speedo cluster swap Q
- Coolant leak
- What happened to the 2k1 parts website?
- Any special toold required to replace ball joints.
- Will a 4th gen tranny work with a 2000 max?
- vq35 cam
- HID tech fog yellow fog caps
- 2001 AE Maxima Low Idol
- 2002 Owners Manual
- Sub stopped working
- 2001 AE w/auto - reliability
- Low engine oil rattling noise could be linked to SES light "cam position sensor"?
- Wheel Bearing Front Replacement
- How to get that 5hp that is stock with Special Edition SE max?
- 5.5 Front grill interchangeable with 01?
- Seriously, how?
- 6 speed people with 7000 or 7200 redline
- Farewell post
- Need Serious Help...
- tranny problem
- 4th gener thinking of going 5th gen
- Will an 03 Infinity I35 MAF fit in an 02 Max?
- Help! Stop the Squealing!!! Awful squeal when turning left
- Help with a K&N part number
- Anybody else seen Hotshots website?
- Underbody Neons
- gas mileage went to hell
- rear ended a car. Help!!!
- Need help W/ taking off Transmisson screen/filter, bolt just spins
- Vogtland springs question.
- Rough Idle in Reverse Only
- Stereo Removal - Running into problems...
- VLSD questions
- 77K Service
- having problems with my 2k1- stalllllling
- Traded the Max
- Has anybody tried removing the navigation unit on an 02 or 03 Maxima?
- Y-pipe saga...weird sound...now error codes!
- led power
- BCM Location
- "Marbles in a can" pinging noise under deceleration
- Mod eBay projector headlights
- Timing belt or Timing Chain?
- ECU reflash pricing.....
- Dust off an old chestnut, real aluminum dash kits
- Has anyone tried this muffler?
- Short Shifter??
- Using Turn Signals Causes Hazzards To Flash
- 02 Max having trouble starting......
- safc for $175 bucks used
- LEDs for the turn signals?
- Help reading codes
- Remove Emblem from Center Cap?
- Cattman CAI
- tranny slipping can anybody help me?
- new headers and VIAS
- Dr. Roy this is about CCFL's
- Car wont start after clutch change
- how about these headers??
- Removing headliner from 2k2 to expose sunroof mechanism???
- "Bees in the Can" from Cattman y-pipe? Please help...
- Intake manifold mod
- 2000 Flasher (Relay) placement?
- maxima lights
- Sell or Supercharge
- ABS problems
- New CV Axles still slightly clunk
- exhaust tip finisher
- Got hit again
- Fuel Pump Cut-Off Switch
- i have a question
- Anyone need wipers?
- Door Noise problem
- Accident, hoods: oem vs. cf aftermarket
- Tein S Tech question
- battery problems
- Any first hand experience in evap canistor replacement?
- need help removing spoiler
- Low-Temp Thermostat
- car won't start... Tranny swap...
- I am addicted to Power
- Transmission breather hose?
- Question : Why should the oil dip stick not removed while filling oil
- Which suspension bushings to replace while doing struts/springs
- new motor mounts
