View Full Version : 5th Generation Maxima (2000-2003)
  1. Question about Fuel Pump
  2. Ebay HID kit....whats good?
  3. A/C Bypass Accessory Belt Part Number? (size)
  4. Maxima crash test video
  5. Struts
  6. oil in vias area (intake manifold)
  7. 2k1 Motor mount option...
  8. Check out all my LED mods!
  9. issues with starter
  10. airbag light flashing
  11. HELP!!!
  12. Need HELP Please!
  13. good ebay found!
  14. Ideas for speaker install
  15. I'm back after 5 years!!! From 1997 SE to 2003 SE
  16. question about a Y PIPE
  17. Black interior pictures
  18. custom intake
  19. ABS LIGHT ON?
  20. I want an I35
  21. So my car stalled at the drive thru today
  22. Installed NWP block plate.... DAMN that IM is dirty
  23. Fixed Bose left side cutout!
  24. Banging noise from under the car around trans area
  25. Couple questions...
  26. 55w HID Harness
  27. anyone had this problem?
  28. Hit dip during turn now noise over rough road?
  29. Videos of my flooring it in my brothers max (Problem)
  30. new alternator bad?
  31. Gear whine?
  32. Turn signal and hazards no longer work
  33. TRANNY PROBLEMS please help
  34. Fog Lights: OEM vs after-market ???
  35. help with emanage blue
  36. Mobil1 Synthetic ATF
  37. Snapped ABS wheel speed sensor bolt, looking for opinions
  38. Great!! Not another oil catch can thread!!
  39. Good deal
  40. Sunroof Problem
  41. Interchange seats?
  42. Weird BOSE Radio Problem
  43. ? about es motor mounts
  44. Today's adventure...motor mounts(pics)
  45. Beep to lock/unlock - Installed with pics and video
  46. Turbo Automatic...Won't move in reverse
  47. Maxspeed springs w/ stock struts v. Tein SS coilovers - My impressions
  48. Sidemarker rewire to blink with signal....
  49. Is bedding modern brake pads still needed?
  50. maxima=pathfinder?
  51. 5.5gen Pulley Install - Annoying Problem!!
  52. Transmission Flush
  53. Is this a dead battery or something else?
  54. 5 to 5.5 gen fogs
  55. off/on front vibration
  56. vafc help !!
  57. Evap canister & valve, are these correct?
  58. Codes...
  59. Tranny Drain plug -magnet super clean
  60. Head scractcher P-0420 & P-0420 PD
  61. HELP SES light
  62. Emergency alternator removal!
  63. pkn2 / remote start question
  64. vias block plate, intake and throttle body spacers questions
  65. z tube for intake
  66. Filling up bushing with polyurethane
  67. 2002 Maxima SE tune-up
  68. Your opinion on a transaction
  69. Immobilizer Module
  70. Transmission Problems.
  71. Headlight conversion 2002 to 2000
  72. shifter knob
  73. Need to swap out my exhaust, anyone done it on their own?
  74. 2003 SE Heated Mirrors?
  75. AEM vs. Apex'i Dry Filters
  76. Looking at getting a 2003 6-speed...
  77. what should i expect to pay for a 5.5 gen??
  78. Looking for a dual tip axle back
  79. Rattle while engine is under vacuum
  80. Need opinions on replacement engines for my 5.5:
  81. How to bypass BOSE???
  82. Thinking of selling my 2002 max.. worth it?
  83. My ride is horrible (help please)
  84. any one hav this write up
  85. Smoke sidemarkers....
  86. sunroof issue
  87. O2 Sim installed and yet...P0158 still exists?!
  88. weird interior lights issue???
  89. Engine Covers
  90. Trunk Open Light
  91. Engine missing until totally warmed up
  92. MY D*MN SUNROOF WON'T OPEN!!!
  93. Car Trouble
  94. 6-speed tranny info; which years compatible?
  95. How much are you guys paying for 00/01 dark tail lights?
  96. higher wattage fogs
  97. Glove Box Rattle
  98. What do you think about this deal?
  99. 20x10
  100. Which of these can be done in the driveway?
  101. Stuck fog light
  102. Feels like braking on ice
  103. Starting To Mod
  104. Has any1 blacked out their tail lights this way?
  105. HOW-TO: Black-Out & Add Audi LED strips to your headlights
  106. Body werk Gurus
  107. air condition only works on high
  108. RIMS
  109. Need help on my damn power steering pump belt!
  110. DIY Fuel Filter Replacement
  111. Car doesnt shift out of first gear. 2 tranny's, same problem
  112. any original owners left?
  113. I NEED SOME GUIDANCE
  114. Threw PO138 P0158 and P0159!
  115. Fender Bender ...
  116. Bad experience with Monroe Strut Mounts (pics)
  117. Brake/battery light.
  118. bad alternator?
  119. Question: BBK ROTORS & PADS
  120. Re-threading 6MT Shifter
  121. A/C issue
  122. White Smoke Under My Hood at Startup???
  123. Headlight and taillights match
  124. Mesh Grill
  125. any1 got the chrome mesh ebay grill
  126. My Weekend Project
  127. abs lights up on dash
  128. fog lights 5.5 gen
  129. Oxidized coolant
  130. Rear Brakes Relined?
  131. Any new electronics for performance, mileage?
  132. Possible problem with Clutch & Aluminum Flywheel - Need Input!
  133. Struts any good replacements?
  134. Removing the A/C
  135. Just ripped out the stillen hi flow intake
  136. I CAN'T FIND THE TPS ON MY 2002 MAX!!!
  137. 5.5Gen STS question
  138. Starter Grinding
  139. Porting and Polishing the IMs
  140. 5.5 vs 6th Generation
  141. What's our headliner made of?
  142. Tranny Problem
  143. SSV4 Suprastick
  144. Transmisson Problem
  145. new jack w/questions
  146. START-UP ISSUES - YOUR THOUGHTS?
  147. Need some help on P0420 please.
  148. Car Over Heating, Please help.
  149. differences in 4th gen and 5th gen motor/trans
  150. Those with Cattman B-Pipe and Stock Muffler....
  151. True Duals on a Maxima??
  152. Tuning programs
  153. Adjusting Backing plate
  154. Squeak in the wiper motor.
  155. Throttle valve buzzing noise?
  156. Will 15" 4th gen wheels fit a 5.5 Gen?
  157. 2003 SE (Auto) Unplug Engine Mounts?
  158. *New* Pioneer AVIC - U310BT CD w/ Navi [Demo Video]
  159. p0105 questions
  160. Caliper/Rotor question
  161. OBX Headers fitment problem!
  162. 5.5 Fog light spec
  163. Looking for new OEM pedals
  164. long checklist to do-- want some advice...
  165. 5.5 Gen Fender Removal
  166. performance mods
  167. wow
  168. New Problem..Tranny not wanting to shift!
  169. Caliper covers vs paint?
  170. 5 speed troubles. fml
  171. Leaking Rack & Pinion
  172. God I love county trucks
  173. VQ35DE sound
  174. How to FIX your DRL
  175. Bleh Alignment Issues orr?
  176. HELP! backed up into a fence! pictures
  177. pinging and knocking sound from engine? need help
  178. :D Lemme hear it
  179. I have a dumb question
  180. Hawk Performance Brake Deal
  181. Tranny Problem...
  182. Aftermarket steering wheel
  183. ebay fstb vs stillen
  184. Pass side engine mount replace. How hard ?
  185. Really bad mpg after CAI..
  186. discoloration inside headlight..O
  187. Good Deal on I35?
  188. Please help!! cleaned TB now p1102
  189. Brake Question
  190. PPL w/ Roof Overlay's (5.5 gen)...QUESTION:
  191. KYB's Strut mounts Suck
  192. Rough/Loud Engine Noise
  193. Megan racing catback WTH??
  194. NYC potholes-- girlfriend driving...oh g*d!!
  195. Crack noise every time I accelerate VERY loud on hills
  196. did i get taken or what?
  197. Putting my car on a Diet. come in, n help.
  198. Are all 5.5's prewired for heated seats?
  199. how many miles after gas light
  200. Climate control on 5th gen GLE
  201. carfax report
  202. O2 sensor/ running rich question
  203. Ball-joint/wheel-bearing/tie-rod test via wheel play
  204. Please Help, Problems and P0113 codes...
  205. Ticking noise, cyl 2
  206. Interior bulbs
  207. how do i replace teh lights in the instrument cluster + climate control
  208. Stock 2002 GXE and $3k
  209. can you adjust headlights right to left ?
  210. Headlights went out
  211. Misfire Code for Cylinder 3
  212. Odd tranny fluid experience
  213. Exhaust gurus, input welcomed
  214. Whats the website with Maxima DIYs?
  215. Replacing a 2002 Se door with a 2001 GLE door
  216. Intake...will it fit?
  217. 6MT Polyurethane Shifter Bushings
  218. Gauge set.
  219. Rear Suspension Blown??
  220. Quick T-Stat Q
  221. Making the clutch engage sooner
  222. Do I need a rear camber kit?
  223. rear wheel hub wont budge
  224. 3M Headlight Lens Restoration Kit
  225. Installed new plugs yesterday now car chokes upon start up
  226. Cattman 2.5" vs 3" or others?
  227. When to replace belts and is it DYI??
  228. break pedal problem...
  229. wheres the thread for replacing the instrument cluster climate control,clock to LEDs
  230. Good idea?
  231. 7443 Bulbs discontinued
  232. what type of intake?
  233. General Hesitation
  234. 2000-2001 OEM Tailpipe Shroud
  235. Toyo Proxes 4 vs Goodyear Assurance Tripletread
  236. Progress pictures of my new headlights.
  237. need help to sale stuff to someone on the org
  238. y-pipe change
  239. Maxima Folding LED Turn signal Mirrors HELP !
  240. start issue
  241. few more questions
  242. Stillen Classic (Aero) Lip for 2000 max pics requested....
  243. Wheel hopping
  244. Introduction
  245. need some help... location of speed sensor
  246. Darkening/tinting/blackening emblems/badges
  247. bose rear deck?
  248. 5.5 gen hid high beam?
  249. rear tires worn out before front?
  250. ECU reflash to cure odd problems?
