View Full Version : 5th Generation Maxima (2000-2003)
  1. 2001 - Wheel Alignment Specs ??
  2. back light on mileage indicator
  3. VQ35DE Tuning Software ?
  4. Wood Steering Wheel
  5. Paint code
  6. Magnet in the cup holder lid
  7. clogged cats? symptoms no balls? or transmission?
  8. 6 speed shifter bushings
  9. Handbrake is krap
  10. 5.5 gens with HS headers step in
  11. Non-Bose 2k3 LED 's "Metal" Help needed...
  12. energy suspension motor mounts
  13. Vibration in steering Wheel
  14. Does anyone know how to change the Power seat motor
  15. '03 6spd...good buy?
  16. non-bose stereo.
  17. noise from wheel well? Lets see if you know what it is
  18. techno square ecu for 02' 3.5
  19. 6spd axle seal install
  20. Aftermarket Rotors
  21. Replacement Headlamp question
  22. anyone try this
  23. 6th Gen 5 Speed Auto in a 5th Gen?
  24. Power Steering Leak...
  25. Y-pipe newly installed...
  26. Also replaced my 2k2 MAF with a 2k1 unit.
  27. Customizing Stillen Body kit
  28. 02-03 Maxima Transmission Q?
  29. Engine light still on..
  30. What guage wire to use for a grounding kit
  31. Hey are these Calipers any good?
  32. Anyone dropped with 04' 350z 18's...what combo are you running?
  33. Took my transmission out and this is what I found
  34. People who had oil in the spark plug chamber, step in
  35. Ticking 03 Max
  36. 02-03 Maxima 6spd. or Automatic?
  37. How to Replace AERO in Front
  38. Pic Request - White 02 Max w/ Matchin Grill
  39. Vehicle safety recall
  40. *** long time fellas...whats up?..pics
  41. Crazy OEM Navigation question
  42. Can't take off front license plate holder...
  43. small mods
  44. Pic teaser: Headlights - Gloss Black, Cleared, DDEs by X-Vert
  45. SE vs GLE suspension
  46. 4300K vs 6000k...FYI only
  47. Oil ABOVE spark plug getting in COIL, cyl 5.
  48. Has anyone performed this swap?
  49. Cleaning the MAF and need the org's help
  50. Possible??
  51. is there a trick to downshifting the 6spd? or bad mount
  52. Help with 02 sim...
  53. VQ35DE Valve Cover and Gasket Replacement How-to
  54. rubbing on rear passenger side with 20's on a dropped Max
  55. Start Up Problem
  56. 350z brakes on maxima?
  57. Okay, I am going to re-up.....
  58. Ebay projectors.. Not your typical thread..
  59. replacing fuse for power locks
  60. mpg going up the ***
  61. Need help installing a RSTB...
  62. Poll: Power Steering problems
  63. Question about catalytic converter...
  64. Drop resistor mod with switch
  65. everything seem right with this VAFC-II?
  66. P1320 + P0300 AND got GREY DOT coils
  67. Black 5.5 gen 6MT sighting on Chop Cut Rebuild - CCR - Speed TV
  68. 2000 maxima questions
  69. need QUICK!!!! help Valve timing solenoid?
  70. Painted Dash Pieces W/PICS (Stock Matching)
  71. HID kit ?
  72. 2k1 TPS sensor ??
  73. Clutch Master and Slave
  74. Stillen product arrival
  75. Stain Glass Paint
  76. installed stainless steel clutch line
  77. question on CEL
  78. Shift lever solenoid replacement
  79. Rack and Pinion Question : 2000-01 - 2002 -2003?
  80. Intermittent oil pressure light flicker
  81. Hotshot Install Rear manifold
  82. Trip
  83. LEAKy rear main seal. Need advice
  84. What is the lifespan of OEM brakes???
  85. Smoked out Tail lights using VHT Night shades
  86. dash board clock problem
  87. A/C problem?
  88. eBay HID problem
  89. Stumped
  90. HID bulb replacement questions.............
  91. Removing 6 Speed Shifter
  92. Sticky gas pedal
  93. EVAP Code - Car shut off
  94. Clunk in the rear
  95. Wire Harness Lights
  96. Jack placement and suspenion write up
  97. Help removing my headlights...
  98. Spark Plug
  99. P0160 & NJ Inspection
  100. Need some posible solutions, Car turns off.
  101. 5.5 gen rear brakes
  102. Any Valentine 1 stealth setups?
  103. Fog Light Change How To
  104. h3 mimi fog bulb replacements
  105. ebay chin spoiler ?
  106. It's been a while
  107. Illumina Question?
  108. Been thinking about changing my fuel filter...
  109. Think Twice before replacing your MAF
  110. Want to quiet your intake and improve the low end?
  111. Energy Suspension Motor Mount Install (with pics)
  112. hks sport exhaust
  113. Boss Chen's are in!!! **Pics**
  114. Fuel filter replacement
  115. HELP! Car won't start! Just get a clicking sound when I turn the key
  116. Carbon fiber hood shocks?
  117. Hot Air comming through firewall ???
  118. Need Opinions
  119. Y-pipe bolts...
  120. Can anyone quickly
  121. Two wires in trunk keyhole?
  122. Fog light lenses
  123. 20" wheels on an 01 AE Max lowered
  124. Body Kit Install
  125. Car Beeps
  126. 5th Gen Purchase
  127. cattman headers
  128. If you have installed Boss Chen coilovers, please help...
  129. Broken rear motor mount
  130. Problems with brakes
  131. Y-pipe installation question
  132. Got OEM CF Hood, now further options?
  133. sunroof stopped working.
  134. Dayco belts with UDP
  135. front precat SES
  136. 6 speed swap done in 4 days!!!!
  137. Replace Bose SUB?
  138. Installed HID fogs...Have a few Q's
  139. Write-up for Berk install? (i've searched_
  140. Air Leak only during warm weather..
  141. Air Hissing from Engine Bay
  142. lost my doot
  143. new version coil has no dot?
  144. Strut Mount Replacement
  145. Another Max accident
  146. Wood Removed - Molded Dash installed pics
  147. fog lamps lens
  148. bad whistle sound when braking any idea? please help.
  149. are these the correct bulbs for an HID retrofit from 6k to 4300k
  150. Tein S-Tech and H-Techs for super cheap
  151. does the G35 Maf work???
  152. My Max knows when Inspection is due..Can weather throw a cam/crank code?
  153. ebay speed chip
  154. Longer Wheel Studs?
  155. How many of you went back to stock airbox after WAI?
  156. Strut Bar question.
  157. Sun roof problem
  158. slight squeal noise upon acceleration and deceleration
  159. rattling noise under front of car
  160. 00-01 Exhaust Tip Removal
  161. 3.0 Removal
  162. 2000 black stock headlights on ebay
  163. 02 Maxima SE Bose system acting weird
  164. Aiming headlights + HID upgrade on my 2k1
  165. Cattman Ypipe on a 5.5gen 6mt...worth it?
  166. Supplemental air bag light is flashing
  167. Wheelhop Dilemma
  168. Error F3 CD player
  169. Sandblasted Side Skirts, ball park $ to get fixed?
  170. P0430 Code!
  171. Dealer possibly replacing my o2 sensor under emissions warrenty.
  172. turning the battery sideways
  173. Everytime I press brakes, interior light on dash comes on
  174. JWT Pop Charger Heat Shield
  175. LED's blowing fuses.
  176. Just Graduated to 5th Gen....
  177. hot shot headers , megan test pipe, ebay catback..pics +video
  178. Help with sponsor stickers
  179. Brakes
  180. clutch fluid?
  181. Quick Question about the Brake Rotor
  182. Low idle
  183. is this even possible? autoenginuity Q
  184. Foglight Bulb Replacement Help
  185. Cobb access port
  186. Any known issues with the Nav/Climate control on an 02?
  187. Warranty Question
  188. No Keyless entry and interior lights???
  189. replacing the O2 sensor - where is the wire harness?
  190. Frozen Gas Gauge??
  191. Premium Fuel??
  192. Help with a code please (interpreting it...) I think it's P0455?
  193. Car not sitting even after suspension instal
  194. 6spd drivers axle
  195. Squeaky wipers
  196. need clarification on the check engine light procedure (2k3 max)
  197. Ceramic Coating... worth the money?
  198. LED tails.
  199. Steering Wheel Vibration when going 60MPH+
  200. Good, not best exhaust...
  201. rear bumper removal
  202. Maintenance Ideas
  203. i got 300z brakes
  204. Best place to buy aftermarket OR OEM parts
  205. H.I.D fog lights question.
  206. Should i Seafoam it? 2k3/150K
  207. SES light on and two o2 codes...
  208. stock oem bose sub isnt working.. em i missing anywires
  209. ok newb question time: where is the starter?
  210. 2000 SE, Rough Idle
  211. Got P0140 code need help on current procedure
  212. Alignment Question
  213. moderate bucking in low gears and slight buck in higher gears?
  214. fuel filter on a 2k3 maxima se?
  215. Need some help from the org (sunroof, kinda long)
  216. Driver door sags
  217. Triple Gauge Pod
  218. Motor Mount ?????'s Please help
  219. No rev above 3500
  220. P0455 and P1448 MAX Gods what do I do??
  221. Battery charge light and E-brake light
  222. Fuel Filler Door
  223. Grinding noise from front wheels/brakes area
  224. Cabin Air Filter Queastion.
  225. help with misfire when start up...(P1320 was set, but car runs fine after a minute..)
  226. Jerky/Sticky Clutch
  227. Wheel spacers
  228. i keep bouncing with these springs
  229. Shifting problem after accident. HELP NEEDED PLEASE!!!
  230. Help with oil leak
  231. Best amplified car tv antenna
  232. axle install problems
  233. Illumina Question
  234. Need New MAF
  235. a few questions.
  236. i want to do a 5 speed swap......
  237. Scraping Noise While Turning On 2000 Max?
  238. 5th Gen Grounding kit
  239. Strut Mount Replacment How to
  240. Clunking noise when braking
  241. reprogramming sunroof
  242. 00 auto to 01 AE auto.
  243. Eibach Pro Kit
  244. Thinking of replacing spark plugs...
  245. White Rims
  246. Buzzing noise when releasing accelerator...Oil filter or TB
  247. Just wanted to share yet another compilation.
  248. Another great product for the $
  249. New owner - 2000 SE (56k stay home)
  250. Replacing inner tie rods - need advice
