View Full Version : 5th Generation Maxima (2000-2003)
  1. Fuxin Nissan Tranny!
  2. Shocks and Struts
  3. Possible to Weld Exhaust ??
  4. Immediate help plz. Starting issues. New starter
  5. IACV parts/dismantlement
  6. Upgraded my wheels to 6th gener's SE wheels (finally)!
  7. I did it... I posted my car for sale
  8. I got my 02 Max 6spd.
  9. Changing out a 3.5 water pump..
  10. Drive Belts Cracked?
  11. painted fog lights yellow
  12. Help with Exhaust piping...
  13. Periodic start problems
  14. Front end vibration update
  15. MAF Issues?????
  16. VIS hood owners, step in...
  17. wiring through door harnesses
  18. need help to open the for driver side door panel
  19. Floor mat part number
  20. Stillen Hi-Flow, Berk, Injen?? Which intake would you get right now
  21. opinion question. . . .
  22. Have you bought a Nismo shift knob? If so, read me!
  23. Axles
  24. aem intake
  25. What Is This?
  26. Front strut mount question?
  27. Mileage on your 5th gen??
  28. carfax needed
  29. Proposed Solution To Brake Squeaking...
  30. is this too much?
  31. can you turn rotors that have "Hot Spots"
  32. dmpesso
  33. Those who have cleared your blinker light...
  34. Why?
  35. slotted/drilled rotors
  36. Noise comming from the wheels
  37. 3.5 aftermarket flywheels
  38. Dash Rattles?
  39. Opinions Please On Noise Removal
  40. Jerk or kick when slowing down
  41. what size wheel spacers to use
  42. Who was the member that was selling the fog light lenses for 5.5 gen maximas?
  43. Why 2001 and 2003 cost the same?
  44. Car doesnt start after the 5th or 6th try. help.?
  45. replacing trunk lock
  46. Car Badges
  47. z32 calipers
  48. Shift Problem?
  49. Major problem come and take a look!!!!!
  50. Painting Stillen Grille?
  51. Exhaust & Rear Caliper Replacement?
  52. Changed my motor mounts and now i have an exhaust leak
  53. Transmission Pan Gasket question.
  54. exhaust thoughts...
  55. Positive battery fuse number
  56. Clicking sound from front passenger wheel.
  57. Question About Belts
  58. Fog Lights
  59. Headlight Cleansing
  60. splash guards
  61. opion
  62. LTB stage one installation.
  63. Smoked Corners - Front & Rear (Not VHT)
  64. Brake Fluid Reservoir
  65. how to install lexus capsules?
  66. Positive Battery Terminal Question?
  67. ahhh ok who has done a cluster swap
  68. Where's the brake bleeding screw?
  69. So this can't be good....
  70. H&R 15mm spacer stud size for Maximas???
  71. How do I install my new MAF in 2000 SE?
  72. Weird Whistling noise when car starts up or gases.
  73. Any links to online copies of owner's manual?
  74. Clear spoiler Lights
  75. look to get a short shifter
  76. Rear Breaks/Calipers/Rotors replaced - Cant attach Parking break!
  77. 02 vs. 03 Differences?
  78. SES light flashing and rough idle for a period of time...
  79. When to get first tranny serviced on 2k2 Auto
  80. Squeeky Noise from tire.
  81. Man Im Screwed
  82. Wheel Bearing information
  83. 5th gen questions
  84. intake
  85. Broken door handle, no remote entry?, rear lights
  86. black plastic headlight covers
  87. Combined Group buy on Truax Motorsports SFCs
  88. SeaFoaming
  89. Hesitaiton and PowerLoss on High Speed
  90. Power seats in a gxe will it work????
  91. How much did Stillen front lip costed you??
  92. Nnooooooooooooooo - headlights stolen
  93. Ummmmmmm, speed sensor...anyone? VQ35 6 speed.
  94. A/C compressor question..
  95. Replacing clutch on saterday...anyone have any tips?
  96. The best rims for a 5th generation maxima
  97. Valve body for 2k2 auto's?
  98. Suspension noise
  99. Catback Question
  100. Movin' on up...
  101. moisture in clear bumper - which sealant to use?
  102. Warm A/C!!
  103. Car wont start....
  104. choice of FSTB
  105. How comes G35 got a great sound, but 5.5 didnt
  106. how to on this 5.5 grille?
  107. tag frame
  108. Fidanza Flywheel
  109. ABS rear lip question...
  110. Weird Tranny Problems (searched already)
  111. Suspected power loss...
  112. I Need Help About a Blown Engine, Newbie here
  113. 2001 Oxygen Sensor
  114. Not your normal brake problem - noise. 2k Max
  115. Difference in VQ engines
  116. Bar's Leaks products to help 5.5 gen oil burn/loss?
  117. Any one know how to repair Automatic Climate Control other than going to the stealer?
  118. ebay projector headlights
  119. Got a fitment question
  120. Opinions please...
  121. Trick to getting oxygen sensors out
  122. Looking to buy a Max. Need Carfax.
  123. stalling problem
  124. click, click when turning wheel.
  125. Need help with Auto Climate Control
  126. would staggered 20" wheels fit on a 02 maxima
  127. Car is trying to Stall OUT
  128. P1800...common with O2 sensor code?
  129. My dog likes to rock it in a 5th gen....
  130. oem 6spd starter pics
  131. sparkplugs. oem plats or iridium ix?
  132. Of all the things to break.......
  133. Throwing the P0420...and shutting off
  134. 80 PSI on the low side of A/C Line
  135. I have one of the infamous cars...
  136. Silver G2 Caliper Paint ۞PICS۞
  137. Halo Bulb: PIAA x Sylvania
  138. Lug/Hub question
  139. Air condition Problem
  140. Dealer wants $1200 for A/C Compressor + Left Side Control Arm/Brushings
  141. Clanking noise while braking
  142. Paint Grill Chome Possible?
  143. WTF, Condensation in headlight casing
  144. 2002-03 maxima hid headlights on a 2001??
  145. custom emblems
  146. Car is burning oil like CRAZY!!! Mileage is 54k - Nissan did oil change at 53,125
  147. Eibach hubcentric Spacer fitment issue (15mmF/25mmR, pic included)
  148. Some basic 02 questions
  149. Berk Installed - NICE
  150. is this worth buying??
  151. Manual Transmission Question
  152. Chrome door sills cheaper?
  153. 18x8.5 +45 (Specific question for 5th+ genners)
  154. Anyone interested??????????
  155. Pic request: 02-03 6000k bixenon pics
  156. Side Marker front bulb size
  157. Trunk Lid
  158. hid bulb question
  159. Street Scene grill fit stock 2k2 bumper?
  160. Shouldn't the Transmission level be consistent?
  161. During suspension install, what else should be replaced?
  162. The electrical gremlins have struck :(
  163. common 5th gen problems to look for??
  164. 114K, What Mods To Do???
  165. Best deals on brakes?
  166. Mass Air question
  167. 03 headlight clear and DDE questions
  168. Damage from overreving engine?
  169. Body Kit Opinion/Advice
  170. 2001 Maxima blower works on only SPEED 4
  171. Diesel Maxima!!! just FYI
  172. electrical problem: no dash lights
  173. 2002 Suspension options
  174. wierd problem (a little long)
  175. LCA install update
  176. standard equip
  177. Official SFC installation/write-up/review thread!
  178. good deal
  179. 350z/ 6spd starter compatability
  180. 5th Generation Subframe Connectors are available!!!!
  181. Thanks Soonerfan
  182. Rattling Noise From Hood
  183. question for someone whos chaneg a rack and pinion
  184. Umnitza Angel Eye Problem
  185. Greddy Evo Problem Need Help
  186. Coolant found in oil...uh oh. Assitance please.
  187. Strut replacement and strut mount torque vs steering binding
  188. Ebay angel eye headlights
  189. LED Taillights
  190. Hyper ground finished!! New Code?
  191. Can I put DDE's in the oven again??
  192. Cheaper Alternative for In Cabin Microfilter?
  193. Tire size question...
  194. auto dimming mirror - not auto anymore!
  195. Tiny Rust Spots Everywhere
  196. Is There Anyway To Check Your O2 Sensors?
  197. LCA install advise
  198. Question for those with Hawk brake pads
  199. Ses & Cel Light Question
  200. I saw this the other day...
  201. Horrible Loud Noise
  202. 2000 front bumper with molded stillen lip and black grill
  203. 5th Gen only (not 5.5) throttle plate
  204. 5.5 help for a retard
  205. Where can I buy Billet grillz for 5th gen
  206. Went Offroading
  207. Chirping Sound From Rear Suspension
  208. good news
  209. What else do i need other than new shocks...
  210. 03 HLSD Max, no FSTB from Stillen?
  211. Exhaust question
  212. Had enough engine pinging!!...about to install colder spark plugs
  213. What kind of strut bars are these?
  214. Engine stalling/sputtering?
  215. Drenched In Oil
  216. When is it time?
  217. Car locks on its own
  218. Throttle squeek??
  219. About to hit 100k, anything special i need to do?
  220. Where to buy 5.5 Gen interior pieces?
  221. Idle Problem
  222. Brake dust on one side only
  223. Maxx Tunning Lip
  224. headlight condensation issue??
  225. Maxima.org shutdown yesterday (sat. 4/14/07)??
  226. Two Tips
  227. Car stutters at REAL high speeds??
  228. Strange problem when removing the Bank 1, #2 O2 sensor
  229. Suspension Opinion
  230. My custom semi-cold air intake.
  231. Exhaust customization....opinions
  232. 5 speed swappers 01 gle w. tcs
  233. Question about heater?
  234. Fuel Gauge...
  235. place racing
  236. Popping sound from Hawk HPS + Brembos
  237. Microfilter Question
  238. Best Performance Bolt-Ons POLL
  239. Strange Noise during acceleration Please help
  240. Changing belts
  241. SAMCO hoses installed
  242. 5spd - noise
  243. Rebuilding transmission, have questions
  244. light bulb-out sound
  245. Yellow Lexus Fogs
  246. time to buy a new radiator got a question.
  247. Time for some brakes...thoughts? suggestions?
  248. Er, where does the OBD scanner plug in on a 2k Max?
  249. HKS axle-back only $318 on eBay
  250. Berk Vs Aem for Berk Intakes ??
