View Full Version : 5th Generation Maxima (2000-2003)
  1. advice on cleaning air filter
  2. Issues with p0430, pre cats.. does this look alright?
  3. New LED tailight project....maybee
  4. Weird Stutter power change issue
  5. any advice
  6. Ignition switch -- turning over motor (or starter issue)
  7. Jammed sun shade
  8. Cost to replace control arm bushings
  9. loss of acceleration
  10. Slow Windows
  11. Ebay Headers?
  12. Getting 2002 Maxima Repainted... suggestions?
  13. engine whinning at 3.5k RPM after cold start
  14. trimming the bump stops
  15. windshield wiper blades
  16. Stupid question: Do the rear black tails of a 2001/2 max, fit on a black 2003?
  17. Most miles on a 3.5
  18. problem bleeding the clutch line.
  19. Rough Idle mixed with a P0300 SES code
  20. question about cattman exhaust
  21. wich wire goes to the E Brake
  22. Foglight re-wire issue...Im stumped...
  23. tint
  24. excessive heat from rotor
  25. Window won't stay rolled up!
  26. Fuel Pump Relay Location
  27. MPG went down after new engine was installed
  28. Have ES LCA bushings (uninstalled or installed)...step in.
  29. Engine Surge Scare
  30. can someone direct me to eu write up
  31. Nissan fluids vs 3rd party fluids (ATF, Power steering, brake fluid)
  32. HELP!!! bad news from the stealership today..
  33. fitting an 01 berk intake in an 03?
  34. is there a write up for removing rear taillights?
  35. Can someone send me the instructions for removing headlights with AntiTheft kit?
  36. TSC, ABS, AND SLIP lights ALL on at once!
  37. just installed struts and springs and...
  38. Need instructions to install FSTB
  39. ECU reset needed after header install?
  40. Tokico Advanced Handling Kit...
  41. Am I wrong or is this a steal??
  42. engine overheating when AC is on
  43. Alternator brushes?
  44. Bose subwoofer causing extreme rattling on 2003 GLE. Please help.
  45. squeaking clutch?
  46. GM Top engine cleaner
  47. Help: Overheating and Revs by itself when A/C is on (is it my O2 Sim?)
  48. Auto tranny shift
  49. Car is hesitating to start all of sudden
  50. Redline tranny fluid
  51. Axales going bad?
  52. Axxtion STS installed w/ poly bushings, OMFG why did i wait so long
  53. Which ES motor mounts
  54. Winded down window with new tint
  55. Got new tails - Rice or Nice?
  56. My Modified Injen Intake
  57. projector fogs? - ricey?
  58. Stereo Installation Help
  59. Fuel Filter / Air Filter Question
  60. Catalytic Converter Cover
  61. Shock questions
  62. transaxle?
  63. Clutch replacement parts
  64. Chime in LSD owners.
  65. Nissan Remotes
  66. Anyone Try Any Ring Seal products?
  67. Question RE: fuel filter replacement
  68. What is the first performance part you bought?
  69. getting rid of EGR on an 00
  70. Factory Navigation System
  71. Exhaust gasket part numbers?
  72. Who Purchased A Jwt From Cattman Recently?
  73. Spring bearings?
  74. New engine under warranty
  75. Knock Noise from back right wheel when I slow down!
  76. Coil Pack Question...Yes, I have searched already!
  77. Master Cylinder Problem?
  78. Hlsd?
  79. Missing connection
  80. What Exhaust Tips Should I Buy???????????????
  81. 03 Max Fasttttt
  82. Issue with stock exhaust
  83. Removing the SES light
  84. 2000 se won't start, code po340
  85. Intake Manifold Removal
  86. Hood and Bumper repainted and found prior work
  87. Coil Voltage - Engine sounds thin
  88. Working with LEDs for my dome and have a question
  89. 2002 fog lights match
  90. Should i buy an aftermarket y-pipe?
  91. Need to replace CAT converter
  92. Battery Replacement
  93. How long did(have) your Illuminas last(ed)?
  94. Front window(s) roll back down when rolled up
  95. timing with headlights
  96. torque specs
  97. WHERE to order brake pads???!?!
  98. DAYCO POLY COG belts ????
  99. Lost my wheel lock key..
  100. rear main seal
  101. Thule Owners step in.
  102. bad tire day
  103. VB mod.....
  104. question about timing ring bolts
  105. Engine Starts then stops....low idle RPM??
  106. Extreme power loss in high rpms
  107. mil eliminators?
  108. Common Brake Problem?
  109. Couple questions regarding 5th gen Max
  110. P0171 and P0550
  111. Dash Board Clock
  112. Who knows about the EVAP code?
  113. Help,...what's wrong with my car...
  114. New axles!
  115. Question on ECU replacement.
  116. stupid cheep VIAS screws!
  117. Thinking about an uprade...
  118. Looking at a 2001 SE 5 spd with 26k miles for $11500
  119. Looking for ideas to "spice up" my interior
  120. Apex'i AFC Neo + 2002 Maxima
  121. 8k h3 mini fog kit
  122. Need some help removing a bolt
  123. Brakes & Rotors
  124. Looking to buy 2002 SE
  125. OEM rim, is it 17x7.0 (on a 2003 maxima)
  126. TB Cleaning - How to/Writeup w/pics
  127. Question for those who got new 3.5L engines from Nissan under warranty...
  128. Axxtion STS on ebay (02-03 6spd)
  129. Camber Kit
  130. Drivers Side Power Window Auto Switch
  131. Remus muffler
  132. Nissan Dealership cant figure it out...car wont start
  133. Cant read the codes!!!!
  134. Has anyone seen a msd on a VQ35???
  135. simple question on checking the oil level
  136. Header installed now there are noises
  137. power loss problem
  138. need help with 2k2 tails on 01 maxima.
  139. Header Heat Shield Removal Question
  140. Need custom cluster work for 5.5
  141. new bulbs for stock housings?
  142. SES on, need help
  143. ss auto chrome headers turns on the ses light
  144. way to "disable" the "auto" headlights?
  145. Sunroof Wind Visor + scratches...
  146. Quick question
  147. VIN Number
  148. Help please there is something wrong....
  149. Climate control help - replacing oem nav with HU
  150. VQ35 reaches a new league of oil loss
  151. Remove rear window safety?
  152. HID conversion
  153. Car wont start
  154. I better ask this question sooner rather than later.
  155. Where to get O2(oxygen) sensor and how to install?
  156. does anyone have a write up on switching headlights from 5.5 to 5th gen?
  157. Clutch pedal firmness...
  158. Starter troubles
  159. Gutting intake manifold
  160. problems with stock headunit on 02
  161. need help installed new engine now running to rich
  162. 2K Double Din Radio Kit??? Where to get it..
  163. Why does it tick at low throttle? Octane?
  164. Dyno'd '02 Max SE 6MT with custom intake only...
  165. LTB2 creaking
  166. i'm back to the max community
  167. Help Please
  168. Recommendations... :bowdown:
  169. required maintenance evap line replacement?
  170. Truax SFCs are on. Thoughts/impressions
  171. Muffler Tips? Which ones?
  172. PIC REQUEST: 00-01 stock white eyelids installed
  173. Tranny Question - so many rules, at least let me ask
  174. Weird day working on car... [Optima Input Inside]
  175. How I just cleared by P0430
  176. 3rd Party GPS / Navigation Suggestions
  177. Bumber cover
  178. a couple of q's
  179. Is this electrical grease or sludge??
  180. 350Z Clutch, 03 Tranny, Rear Main Seal...(Pics)
  181. Weird a** noise/howling sound coming from front end?
  182. Oh ****... Now ive done it..
  183. Projector headlight Question
  184. Towing Capacity
  185. VQ35DE - All made the same?
  186. Any tips before I install?
  187. Will an exhaust leak get louder at higher rpms?
  188. Pic Request: Stock 4300k HIDs with 6000k HID Fogs
  189. Just how rare is my maxima??
  190. Slight Hesitation 3-4k RPM's
  191. VIAS fix.. didn't need to be fixed.
  192. PO420/430 issue- need advice
  193. Question about spacers?
  194. muffler on an Auto
  195. Need Help With Front Door Speakers
  196. OK I've had it! Please help me
  197. Wreck.. How much to fix??
  198. Smoke
  199. Need advice buying ECU
  200. 3M Rubbing Compound
  201. Will these wheels fit on a 2002 Maxima
  202. hid planet
  203. DO NOT CLEAN 02/03 Thottle Body
  204. Body Kits?
  205. Wheelbearing Warrenty Replacement Problems.
  206. a/c compressor
  207. ABS light came on. What do i need to do?
  208. What's goin on??
  209. Will having just the front lip look cheezy?
  210. Fuel pump going out?
  211. Help! P1440
  212. What parts besides bumper need to be changed...
  213. Hit and Run :(
  214. stock 03 FM radio always fuzzy
  215. Buying A 2000 SE
  216. How to color-match the 5.5 grill?
  217. PO505 got a question after coming back from NIssan
  218. window auto function
  219. Rear brake pad replacement
  220. Reed Union / NuFinish Scratch Doctor
  221. Power window problem
  222. Will a 4th Gen Stillen FTSB fit a 5th gen?
  223. Gauge Cluster Failure....
  224. IDLE Problem
  225. Hesitation
  226. 00-01 Intake Manifold
  227. 03 A/C not blowing?
  228. transmission
  229. 6speed shift knob options
  230. What intake mani is this?
  231. Anyone have any contact info for John A. Spangler of Hotshot?
  232. Door locks and power window meltdown
  233. Part# and ordered from questions for Frankencar/Apexi filter
  234. 194 Bulbs for license plate
  235. warranty question for 03 max
  236. Suggestion on what color RIMS to get???? PLEASE
  237. 6k H3 Fog Light HIDs
  238. will 15 inch wheels clear 2k2 brakes?
  239. Cali Spec but according to dealer its a FED Spec
  240. Not Another Front end Noise Thread
  241. P1706 Park/Neutral Position switch... on a 5spd??
  242. Can break squeal sometimes be normal?
  243. Heated seat driver's side switch weirdness
  244. Tune-up..just need to make sure...
  245. How to use seat memory without the auto slide feature in GLE
  246. Should I get a V-AFC (fuel control) for a stock 03?
  247. 6th gen engine and wiring harness into 5.5 gen
  248. roaming car
  249. Where is everyone buying their WAI intakes nowadays?
  250. Water in trunk area..
