- My car is hurtin...any ideas??
- Problem with my radiator fan
- Can someone identify this piece
- broken bolt for coil
- After Converter Pipe
- Nitromethane
- quick angel eyes question
- My A/C smells like shiet... sometimes.
- Hood movement at high speeds
- Wireless Remote Receiver
- Steering vibration
- Aftermarket Hoods?
- anyone have a "how-to" on install for DDE angel eyes?
- Step up!! Who's gonna Buy this 5th gen!!
- Bumpers-urethane?
- Anyone with Fidanza Flywheel on 3.5 Please help.
- Reliability of bad CV boots/Axles
- Best Way to get HIDs
- o2 simulator
- Brake job Issues - [Pictures]
- still a newb
- Key fob Prolems
- Passenger Axle or Strut Noise?
- steering wheel audio controls
- Lexus caps, do they fit in 5.5 fogs or not?
- Stock grill removal
- Pulling Codes
- Door Striker Adjustment
- Need Ideas to replace the factory music head unit and speakers
- how much to change plugs at dealership?
- Need Advice
- Bought a 2k Today and had a few questions..
- Need Help Asap With D2 Install!!!
- eBay "Axle Back" Stainless Muffler Installed! Pics & video!
- Anyone else have this problem?
- K-sports springs ?
- Who has had the ypipe heatshield rattle?
- Will a Nissan Dealership fix TSB problems?
- Help! Need to put my brakes back together:How to back off the piston???
- Engine Replacement...
- anyone seen this and tried it?
- Diagnosing O2 outputs from OBD Reader
- Help with ground wire!!!
- Need opinions on aftermarket clutch.
- All Blacked Out vs. Black with silver
- Bose HU not playing CD's
- tokico Hp/ Illumina question
- tailight question
- Front License plate mount
- Need help with Door Vapor Barrier
- Pressure Plate Over-Torque Results???
- Car running Like Sh@#!!!
- Odd stereo problem
- is this possible
- wanna tune my 3.5..
- P1490 Vacuum Cut Valve Bypass Valve (Circuit) (Nissan, Infiniti)
- S Techs/Illuminas: First impressions
- when to flash ecu / idle relearn?
- need a link
- What the heck is this?
- New Owner here... WOW!!
- 80000 mark, what should be replaced?
- Mini-Meet in CLE?
- What is this noise, and how much will it cost me?
- Search Function????
- very strange noise
- 5.5 6spd, Throw out bearing going out?
- Need help w/ a code
- Correct Remote?
- MAF "below list price"
- Installing heated sideviews on GXE (non-heated)?
- From 1998 to 2003
- Input on frame damage
- Short Circuit
- wtf is my cars problem???
- Another Progress RSB Review
- Rattling
- Electrical Issue
- TCS code P1211
- gauge cluster fuse location help??
- HEAVY Clutch
- Front bumper cover cracked (pics)
- 168 v 194...
- Max broken into :(
- Maxus SFC sale
- Paint question
- Car feels very sluggish
- annoying whine
- Need some help
- 5.5th Gen Down! You gotta be kidding!? -Accident-
- remote entry/alarm
- getting "service engine soon" light after cleaning air filter
- Squeak in left turns
- Stillen body kit...2000 maxima...
- prob....
- 5.5th gen greddy exhaust fitment issue
- 5th Gen Rear Valances
- Is It Possible
- Power window switch problem
- to buy or not to buy...
- 5.5 gen info
- Need Help!! Just got wheel bearings pushed in
- Intake Question
- Suspension Noise? Maybe Motor Mount
- Stock vs. GAB - Soundclips
- How to determine if the cat converter or precats are bad?
- 225-50 tires on GLE rims
- HID projector headlamps
- ebay catback mid pipe fit stock muffler?
- 2000 Power Window Question, Please Help
- 5th Gen Automatic TC Q
- Idle problem question
- 00-01 Knock Sensor confusion!!
- Tranny Ground point
- Ksport coilovers
- Pre maxus subframe deal
- s-afcII settings?!
- How much oil do you fill your car with/traction question
- What about the core charge?
- engine control fuse keeps blowing
- 5th gen hid ballast..pricing?????
- Tokico Springs?
- Cold Diesel like rattle when starting
- so...my max wont rev past3500 rpm help?
- JDM Black housing headlights
- suspension prob.
- rod bearing?
- What kind of clutch does 3.5 have?
- Can I replace only one rotor?
- P0138 & P0139 Questions - after searching
- Symptons of a bad MAF? Will it throw a 'rich bank' code?
- Cracked Windshield
- Non-LSD Tranny in a AE
- CF Hood Incident..
- Pad and Rotor replacement
- opinion on umnitza fog light covers
- Smallest rim on a 5th gen
- A33 engine replacement
- VSS PROB Maybe???
- opinons please?
- 2003 Maxima SE 19K miles worth buying?
- Trouble when re-starting warm (2k SE)
- I Think I Cried When I Saw This
- **HELP**Where is the Fuse for AIR CONDITIONER
- Whats my best option at the dealership?
- p 1320 knock sensor
- Cleared headlight lens question
- Pulstar Plugs?
- Trying to pinout 2000 ecu
- Grime around intake manifold
- new goodies
- Help!! Underdrive pulley issues on 2002 Auto Maxima
- Question about the transmission
- Code P0183 help
- Does the 2000 maxima's CD fit?
- Weird electronic malfunction
- ecu question
- over spray
- new "gearbox" quote
- New struts
- Oil Weight Question
- retrofit question!!!
- Who's got it? Megan Racing OE-RS catback!!
- I need help
- Common Suspension Upgrades on HM vehicle
- To anyone who has a 6speed maxima
- Thinking of swapping my 03 gle suspension to an se setup.
- Permanent/Long Lasting Audio Fix?
- For those 5.5 Gens who have Blehmco LTB II installed...help
- sway bar bushings
- Just bought a used 02 6 speed, clutch adjustment?
- What part is this?
- Black sticky stuff on the back of the tail lights
- FSTB or RSTB
- *** Please help quick ***
- ebay lip kits
- My maxima is moody
- Wheel bearing replacement...
- Injen intake annoying whistle....
- Climate Cotrl fan squeak - What to do?
- Brake lines good anymore...
- Is my mileage above or below average?
- Look what I started
- More led goodies
- Exhaust replacement options...
- All you tuners, please come in!
- E brake light
- 6spd axle bracket pics
- LED window switch mod
- Broke caliper bracket bolt-how to get it out?!
- Big Brake Kit On 2000 Max ???
- p0420??
- exhaust cut out
- What can cause more cranks then usual?
- Using or thinking about using S-AFC please read
- Oil Pan Replacement
- p1130??????
- Worried about my Maxima....
- Angel Eyes Kit For The Taillights!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
- 6speed tranny
- P1800 - VIAS Control Solenoid Valve Circuit Open
- How much is my max worth ?
- ABS light on after alarm install...
- wheel not centered in wheel well.. help!
- Need to get: cheap rebuilt/new rear calipers?
- does anyone have these coilovers?
- Just put the OSCAI back on. Wow!
- Question about our door handles...
- Observations from my latest road trip
- struts
- vibration at 5.5k+ rpm !!
- Speed Sensitive, rhythmic thumping sound?
- NEW OEM air filter
- How to change burnt out HID bulb in 2k3 Maxima?
- Tranny diagram
- Transmission??
- Drove a used and abused 00 SE 5spd today
- New Cattman Cat-back here!
- The car's back from the shop: rebuilt auto
- Rattling under car at 3000-3500 RPMs
- New brakes got no bite!?
- Side marker light lens, 2K2 SE
- My '03 is whistling under acceleration. Any ideas?
- resetting sunroof
- 5th Gen AC bypass belt size
- Got SES buggin' me...
- Been searching for hoods?
- finally back on the road
- P0505 question
- 2002 Xenon Headlight question
- Suspension problems.
- mase air flow
- Need to replace the MAF perhaps?
- WTF! How to install aftermarket speakers into 5.5gen
- i ordered es shifter bushings and.....
- Starting to get a really bad idle.
- Kinetix SSV UIM / Nissanworks Phelonic Spacers on 2003 SE 6MT Review
- Possible bad IAC? need help.
- Rear Tail Light Colors
- is this site legit for clear corner lights?
- Power window gone wild...
- PS fluid
- Buzz noise after engine is turned off...
- JIC Magic
- throttle chamber service
- SS brake line replacement howto
- Torque Specs for oil pan bolts
- Rear Caliper Problem
- car broken into.. where do I find a part?
- advice on cleaning air filter
