View Full Version : 5th Generation Maxima (2000-2003)
  1. should i get clear tint all around?
  2. Monroe brake pads
  3. I Need Motor Mounts
  4. 2002 SE Alarm Horn Keeps Beeping
  5. problem with spark plugs
  6. Shift interlock questions
  7. MAF housing direction
  8. approaching 140k miles and need paint job...advice
  9. Your Opinions Needed
  10. Engine is stopped in 10-20 seconds after ignition.
  11. My best upgrade yet...
  12. 2000 Knock Sensor
  13. Torque Specs
  14. Brake & Battery Light
  15. Could it be alternator?
  16. Programming the fob/keyless entry
  17. AE shift knob removal & leather boot ?
  18. Need Exhaust.... Y pipe or not??
  19. Service Engine Soon light - O2 sensor
  20. Engine Shuts Off!! Help!
  21. Wix filters compared to dealer sold OEM filters
  22. 350z wheels on 00 Max
  23. ...this is weird.
  24. Power steering problem????
  25. Recall on 5.5 gen
  26. 5gen 00-01 owner with warpspeed y-pipe how's fitment and are there any noise?
  27. Wanna see engine bay naked ? Pics inside.
  28. Car is playing tricks on me
  29. FYI: How to know alternator is charging properly?
  30. The Max Died...
  31. Help My bumper Fell off
  32. a/c problems
  33. Low Timing
  34. P0223 - TPS Sensor issue after replacing spark plugs
  35. Need help with Tires wearing out on the inside.
  36. spring struct qustion
  37. P0744 - Is it OK to drive?
  38. This Got me ConfuseD.. Oil Prob.. cattman headers prob.
  39. fuse keeps blowing
  40. Driver's side window won't close
  41. VQ35DE swap, which WAI to use?
  42. windshield wiper fluid pressure
  43. Need Help ASAP My A/C doesn't blow air out!!!!!!!!
  44. After Illuminas install.....rear squeak-squeak-squeak. why?
  45. Help!...thumping over potholes!
  46. Goodbye and hello!
  47. SES light after Spark plug change on VQ35
  48. Possible test pipe fitment issues? ***Pic***
  49. 3.5 L. oil burner
  50. help,...i need to pass emissions
  51. P0032 - Need Help
  52. rear brakes
  53. 00-01 Tcm
  54. Is oil on spark plug normal? (large pic in thread, to show detail)
  55. engine stabalizer
  56. Pressure sensor valve stem question
  57. VIAS power rod modifications?
  58. intsalled cattman headers and udp...now have problems.
  59. Motor Mount Question?
  60. Windshield fogging up problem
  61. How I Improved My Maximas Ride Quality For Free
  62. Steering Wheel Radio Buttons.
  63. New paint job
  64. How much to torque?
  65. Cabin Temp Gauge
  66. Led marker light question
  67. Mechanical gurus , I beseech you!
  68. How much is this Maxima worth?
  69. 3rd gear at slips when cold
  70. Changing up the suspension advice needed
  71. Did All 2002 SE Trim come with a Sunroof?
  72. New Clutch Cost- Dave B. vs Queens, NY
  73. Strut Bar Question
  74. 4th gen maxima alt fit a 2000?
  75. Anybody know How to install ES shifter bushing on 5 speed.
  76. Which alternator do I need 110 or 100 amp
  77. 2002 exhaust on a 2000?
  78. Hard Steering
  79. LED Lights
  80. Any body modded rear windows??
  81. ES Rear Trailing arm Bushings = PITA!!
  82. Question about "Banks"
  83. Cat Converter ?
  84. Trunk Wont Close-Help Please
  85. Delayed Throttle Response
  86. anyone have any knowledge of these?
  87. Life Expectancy for Stock Muffler
  88. 2000 Maxima SE and broken wheel studs
  89. Shifter Question
  90. 235/55 17" on an 03 Max any sqeals?
  91. Nissan Maxima Remix!
  92. Car will not start....help needed!
  93. Is an A/F controller absolutely necessary with headers?
  94. Adding OEM navigation
  95. Gauge Pod Question
  96. CD player is oddly messing up, can anyone help?
  97. heated steering wheel interchange from a non heated wheel
  98. where can i get triple gauge pod???
  99. Good oil supply solution?
  100. 02 max died a fiery death
  101. Missed shift..Went from 2nd to 1st....
  102. Ebay projectors turned yellow (pics inside)
  103. Programing Keyfob
  104. Door Molding
  105. Compass says C?
  106. 02 factory NAV system ?s
  107. Power Steering Leak - how to repair?
  108. 2003 Clear Side Marker Install Question
  109. what wire to tap into?
  110. VAFCII, where to mount?????
  111. need help badly
  112. tire size help
  113. ABS light is on Please Help
  114. 2000 I30 Hesitation/Loss of Power
  115. Engine/front-end noises...
  116. Engine Control Relay is buzzing, battery is dead... please help!
  117. How much for a oil pan replacement?
  118. Trick of removing the Center Armrest Console?
  119. Tail Light Question
  120. Accelerator Pedal Position Sensor Bad?
  121. help with my vafc2
  122. is it worth it?
  123. Installed some hid but having trouble help please!!
  124. 5.5 Gen 6spd Clutch/Flywheel Trouble
  125. Gas Smell?????????
  126. Non JB-Weld VIAS fix
  127. Question Regarding Fidanza flywheel for 2000 & 2001 maxima
  128. What is the deal?!?
  129. Bolts for the MAF Sensor
  130. Officially Joined the H&R/Illumina Club
  131. Popping out of 1st
  132. Check out Da New Wheels!
  133. Will 6th Gen. seats fit in 5.5 gen?
  134. Another "reprogram ECU for new MAF" question
  135. Removed my IM butterfly valve
  136. for people installing 02-03 tails in a 00-01 max
  137. Timing advance...who has it?
  138. Dealer charging me 720 bucks to replace Power Steering Pump
  139. HLSD? How do you know?
  140. A part near the tranny that seems to be leaking?,not sure what it is (pics inside)
  141. Anyone who has replaced front strut mounts, please step in.
  142. Help, Clunking
  143. maxima and I35steering wheel interchangeability
  144. 2000 SE Engine 'Stumbles?'
  145. Well VIAS Solenoid crapped out on me. Bypassed VIAS...
  146. How many 2k2 Blk/Blk 6MT where made?
  147. Where Can I Buy Tokico Illuminas?
  148. 2000 SE, engine knock, no code plus weird groan
  149. Tokico Illuminas Installed...results
  150. angel eyes, best brand and prices??
  151. Installing spacers stripped out studs
  152. CD stuck in 2002 non-Bose...
  153. Sway Bar Bushings
  154. Hid conversion in 2k headlights
  155. Moog Sway Bar Link
  156. ViS CF hood or ABS cf hood?
  157. Rear Brakes
  158. Steering Gear Box Leaking
  159. HELP~DID engine swap~ odo/spedo does not WORK!
  160. 2000-01 Grill Size same as 2002-2003?
  161. Question on Front Struts
  162. Wow, replaced main ground wire
  163. Possible ECU Problem??
  164. Gone for a while, Replaced the Maxima
  165. How to remove front grill?
  166. Time to buy rims
  167. oil cooler problem
  168. maf
  169. Regional Meet (Nov.) Poll in S.E. Forum
  170. How-to change O2 Sensor (Bank 2 Sensor 1) SES Code P1147/0139
  171. Thingking about to have fire extinguisher.
  172. Loud Fan Rattle
  173. How hard is it to fix a noisy fan?
  174. threads chewed up wen takin out o2
  175. All Aluminum Radiator???
  176. help...small crack in radiator
  177. 5.5 gen 4 speed > 6th gen 5 speed auto swap
  178. a little help with the emission spec... did the search, just want to make sure...
  179. 01 AE Redline Shift boot?
  180. Clock/Alarm In Center Dash
  181. Thanks ORG
  182. New Plugs & Coils, still getting P0300 - Help!
  183. tranny
  184. Air Conditioner Using Extra Gas?
  185. Question for O2 sim users...
  186. Having Problems With Car Again
  187. Question about AFR with headers...
  188. Sunlit sand car, opinions w/ painted wheels?
  189. P0032 and P0037 any other ideas?
  190. Anybody got a carfax account?
  191. 5.5 short shifter
  192. P0720 Sensor Location w/ Link 2 pix.
  193. 2001 SE 5MT has a huge bog after ~4500rpms, culprits?
  194. Cleaning AC Vents
  195. 2003 Auto Shifter
  196. Brake caliper rubbing
  197. Trouble code p720
  198. group buys
  199. will a 5th gen bose hu fit a 03 infiniti i35.
  200. Codes p1706 on a 6MT
  201. Bigger TE wheels
  202. rear view mirror
  203. Big PROBLEM!!! please help.
  204. Lifetime Warranty Break pads
  205. Fuse box layout....
  206. That infinti sound..
  207. Replacing sparkplugs on a 2k2+ -- Some questions
  208. Weird Growling Sound, Please Read
  209. Car Overheats When AC Is On
  210. Just bought a max and inherited problems
  211. rebuilt trans 6 times, in 8 months
  212. CHeck these MAX's out...I might be back...
  213. Question About Knock Sensor
  214. Megan Racing cat back
  215. Wheelskins Steering wheel cover
  216. Tranasgo shift kits
  217. Tranny fluid has metal in it
  218. ULTIMAX BRAKE DISC SET anyone?
  219. Cattman Y pipe
  220. Weird clicking on rear axel - 2000 SE
  221. Officially Joined the Eibach/Illumina Club...
  222. Wheel Spacers
  223. NEED a contact for brushed aluminum dash kits..help?!
  224. Bose Headunit and Temperature Display Goes off when head lights are on??
  225. swap 5spd for 6spd?
  226. 698 dollars to fix wheel bearings?
  227. Pedal Learning Procedures Q
  228. power
  229. Broke MY LinkaGe... PICS.
  230. Window gutters: need educated advice
  231. Suspension loose
  232. how to install unorthodox pulley? can anyone help.
  233. Delayed Throttle Response
  234. 5.5 gen stalks in 5th gen...
  235. Keyless entry?
  236. New and improved SPW FSTB
  237. Fog light Disassembly
  238. Speed Sensor location help - Picture attached
  239. Throw Out Bearing.... who has replaced this?
  240. A very tricky situation - help!
  241. Clutch ...
  242. Vehicle Speed Sensor
  243. Service Engine Soon....P1147 & P0139 Code?
  244. New Noise
  245. Lets go green (H.I.D.)
  246. Used Auto...yuck..
  247. headlight issues, brights and daytime lights work
  248. Suspension is Coming ! =D Few Qs
  249. H-Techs new or used with stock?
  250. Absolutely WEIRD... Electrical Gurus, Step Inside.
