View Full Version : 5th Generation Maxima (2000-2003)
  1. Berk intake
  2. advanced timing
  3. Cabin Air Intake
  4. Problems with all links
  5. spark plug part #
  6. Hard Shifting after Highway Driving
  7. Car dies upon startup
  8. Suggestions on Matching Running Lights to stock HIDs
  9. best/smooth struts for 01
  10. Problem with OEM Hid's
  11. Someone please help me...
  12. 00-01 Clutch life and replacement recommendations
  13. About to buy an 03, but have some questions
  14. those who have had eye lids on their headlights + hids, quick question
  15. battery light goes on and off...then everthing dies
  16. Cars sounds like its Rubbing on Stock Suspension / Rims
  17. Need good pics of OEM HIDs beam pattern
  18. 01 SE Bottoming out with a moderate load
  19. Quicker cure 4 check engine light!
  20. 2000 exhaust
  21. HID bulbs: where to buy?
  22. Newbs....READ THIS BEFORE YOUR FIRST POST!!!
  23. Removing REAR Sidemarkers
  24. fstb torque
  25. Newbie here with question about black tail compatability on 02
  26. E-Brake Noise
  27. Annoying tick within engine
  28. Just got my new valve covers (pic)
  29. anyone looking for a 3.5 act flywheel check this
  30. Do I need this piece? (Underbody)
  31. SES light comes on ONLY in certain conditions...HELP v.EVAP
  32. Need suggestions
  33. Ecu pinout diagram?
  34. radar detector
  35. Max won't stay idle.
  36. Replacing axles (CV issue)...what else to do
  37. Installed Hawk HPS brake pads and resurfaced front rotors.
  38. Where can I get lips for all sides for my 02 Maxi?
  39. My maxima is totaled!! Pics inside.
  40. Retro-Fit Fogs to HID's
  41. ABS self diagnosis
  42. Tail Relay for LED Replacement Bulbs?
  43. Clutch..& so POP POP
  44. CV boot protector
  45. Weird radio problem (Bose)
  46. car shaking on idle, SES light blinking...help please
  47. Fuel Pump control module: where is it?
  48. Rotora Rotors
  49. SES light
  50. plz help on rewire a 5 gen headlight to a 5.5 gen headlight~
  51. Removing epoxy?
  52. 2K2 feels like it's about to fall apart..
  53. 2000 -2001 MAF New part number
  54. Thoughts on Akebono brake pads
  55. Does anybody know this grill
  56. 2000 se gas smell
  57. 2003 Nissan Repair/Service Manual
  58. Humming Resonating Sound
  59. Rear wheel bearings bad?
  60. Steering wheel shakes while breaking
  61. clutch pedal to the floor :(
  62. How much to replace front axle on 2000 SE?
  63. Wilwood calipers: use the red ones they sent me?
  64. Ebay angle eye help!
  65. Wheel Studs the same for front and rear?
  66. P0455 -- EVAP large leak detected
  67. 4th gen suspension to fit onto 5th gen?
  68. will front bumper from 2002 or 03 fit 2001 maxima
  69. Video + exhaust sound clip and etc..
  70. Need to replace speed sensor but cant find it!
  71. 03 navigation in a 00 max????
  72. LE BRA
  73. Chrome Exhaust Trim - where to get?
  74. replaced the lights on the door with led's but have a little problem need help
  75. P0171 Code.. O2 sensor?
  76. something is wrong with my infiniit i35. it won't start. read
  77. o2 sensor and MAF
  78. PLEASE ENTER IF: you have ever replaced your ALTERNATOR
  79. How to reduce the noise of blower fan?
  80. p0300, random missfire .....
  81. Online bolt store???
  82. Comment on this cat back system on ebay
  83. Idler pulley bolt
  84. 2001 AE Tranny problem....can it be swapped?
  85. transmission oil leaking?
  86. is it just me or did he paint the brakes and labled them
  87. aftermarket se tails
  88. Axle nut size
  89. something is wrong with my infiniti i35. read
  90. VQ35 heads on VQ30DEK ?
  91. Bose head unit in 2k
  92. Flashing airbag light
  93. MAF Sensor Electrical connector removal
  94. Grounding Kit Complication
  95. Is this normal? problem with locks
  96. Dismantling Home Depot Flood Light
  97. Peel 'N' Seal as sound deadener
  98. 4th gen--->5th gen but Need help!
  99. Update: Later guys
  100. I'm in ur forumz... fixing ur Stickeez...
  101. guage cluster
  102. LED interior
  103. Dropped it + painted front grill body color
  104. Have a Greddy Evo 2? Help??
  105. Parts
  106. Tachometer lighting problems ???
  107. Ordering parts TODAY. Need a few quick answers.
  108. Need some people's opinion
  109. I love raccoons...
  110. Tranny slipping... next step??
  111. Typical Noise for a 02SE?
  112. Rattling noise
  113. Weird Sound
  114. Front Left Speaker Problem
  115. diagnose question
  116. BBS rims on Maxima?
  117. Brake Warning and Charge (Battery) Warning Lights
  118. Power Leather Seat Upgrade
  119. Cricket in the car
  120. Check Enginge Light
  121. starter housing broken, lodged into transmission?
  122. Automatic seat stuck...
  123. Stock HID problem!!
  124. Will this exhaust setup work
  125. Misfiring
  126. Officially in the 150K club!!
  127. Replacing High Pressure Pwr Steering Hose 02
  128. Loud Gurgle when engine starts
  129. Can lug nuts/studs flare from use??
  130. 2K Front Grills: What are the options??
  131. Exhaust Question
  132. wierd noises commin from drivers side!!
  133. A/C Condensation...on the inside
  134. Ok, exhaust help (unique setup)
  135. Any have the Stillen BBK?
  136. HELP!!! Suspension Problem
  137. D2 Coilovers --> Progress/Illumina review.
  138. Skyline R33 Caliper for BBK?
  139. need help guys...big time
  140. pulley question
  141. Gonna buy a new car, which one is better?
  142. FSTB causes understeer?
  143. Ok I think I have a problem here...someone help
  144. Memory Seats
  145. Merlot Maximas Please Post
  146. Merlot Maximas Please Post
  147. New 5.5 Gen in Town
  148. SES question
  149. new 03' se te owner
  150. Does Hitachi make Maxima Starters?
  151. My 3.5 now officialy has full bolt ons :-D
  152. Anti-freeze
  153. question before a 4hr drive to miami
  154. Electrical Issue
  155. Should I buy?
  156. SES Light Came On First Time
  157. strut Bar/Rear sway Bar?
  158. Clearing Headlights & Side Markers on Black 5.5
  159. Starter starting to fail?
  160. Valve Cover Torque Spec (Search is not working)
  161. Just bought 01 Max
  162. FRONT BUCKET SEAT ISSUES
  163. Ported/Polished Headers For VQ35
  164. how to...
  165. GRILL INSERT UPGRADE 2K TO 2K2 TRENZ
  166. Tranny Flush... found a problem
  167. Replacing Steering Wheel Audio Controls
  168. Fuel filter location
  169. CV Axle
  170. 02 sensor bank 2, rear
  171. sorry another front end noise problem
  172. VQ30 Rods & Pistons
  173. Hotshot headers installed on 03 max...problems
  174. Spark plugs?
  175. Fuel Door Issue
  176. found possible cause of rattle in dash over bumps
  177. clicking during steering!
  178. Engine dead in the water..... HELP Starter?
  179. Engine trouble. Whats the culprit?
  180. Cheapest place to get 5.5 gen SE TE OEM rim?
  181. Best process for paint touch-ups?
  182. resonator-2003 exhaust
  183. Odd Engine Noise
  184. How much is my car worth? (Chicago, IL) 2kSE5spd bk/bk
  185. 5th gen lights (In cabin)
  186. Anyone has a 02 FSM for download? G20.net doesn't work
  187. Need Help Nowww!
  188. Help: Used 02 Maxima GLE but fogs not working
  189. rear question...
  190. Power supply to lights cut off
  191. Airbag Light Again!!!!!!!!!!!!!!!!!
  192. questions about 5th gen and 5.5 gen
  193. Starting Issue...Help Please
  194. Installed a test pipe :-)
  195. Why does everyone sell their k-sports after theybuy them
  196. Finally got my Max! Need advice!
  197. Need Advice On Front Axle And Belts
  198. BBK question
  199. Replacing plugs and found this.....
  200. Which nissan/infinity ECU harneses are 5th gen compat?
  201. Stupid Exhaust Question
  202. Purchasing a new max. NEED OPINION
  203. mobil 1. unsettling engine noise after switch.
  204. Please help anyone know how to fix a vibrating hood 02-03 Maxima
  205. 350Z clutch kit installed in 5.5 gen. Where?
  206. Ground control Coilovers or others?
  207. looking for How-to for ES control arm bushings install
  208. TL rims on Maxima!
  209. First ever - Modified Axle Bracket
  210. Leds????????
  211. Who running E-85?
  212. A/T Tranny not changing properly
  213. Possible new shift knob for 6spd guys.
  214. Installed new blower motor! ONLY $66 shipped!!
  215. Mods and Dealership Warranty advice
  216. help with LED angel eyes
  217. How to repair body scratches....
  218. AC Gave Out
  219. A new noise! Sounds like studded snows! Any suggestions?
  220. How to replace ball joints
  221. Why are the back of these two headunits different if they are the same year? LOOK!
  222. How happy are you with your fogs & which do you have?
  223. Will 02-03 Stock headunit work and fit properly in a 2000/2001 maxima? Quick Question
  224. My 01 got smashed tonight
  225. Stillen Y-pipe...Y not?
  226. Broken fan
  227. 5th gen hotness
  228. Need HElP ASAP please!!
  229. Bose Screen Display
  230. Bose stereo issues
  231. SHIFT_whistle
  232. in need of some help
  233. Time for Alternator replacement?
  234. JWT Popcharger, ES Shifter Bushings, Redline MT-90, Free STS Install and REVIEW
  235. What is this plastic jug?
  236. shifter knob
  237. 150K approaching... looking at some options
  238. Fog light rewire
  239. Land rover MAF housing
  240. Pulse plugs vs Spark plugs
  241. Help/Suggestion For Removing O2 Sensor
  242. Engine Noise
  243. A way to extend the Rear windows all the way down?
  244. Interior speakers
  245. Aftermarket ECU?
  246. VQ35DE A/C problems
  247. Need Help From A Fellow 5th Gen Owner / Someone With Some 5th Gen Knowledge
  248. ABS Light On - Not sure why
  249. should i get clear tint all around?
  250. Monroe brake pads
