- inquiring about purchase of a max.... again :P
- fog light projector question...
- 4th gear not working
- is my tech messing with me?... (brakes)
- Weird rubbing sound
- Replace Gearbox or Axle bearing?.... Help!!
- Purchased a 2003. Have a few questions.
- The finish on titanium edition rims
- quick question???
- Recommend a new battery with great CCA
- Replacement Flex Section?
- Car Cover Question
- Installed Stillen Intake and FSTB - Impression and Questions
- Clear signal lights pass inspection
- 2002 maxima vibration
- Please help....maxima resonator question
- 2002 Maxima SE Underbody Rattling Sounds
- Ready Monitors Not Ready?
- 2k2 idling too low at 200 rpm when stopped
- No A/C blower at all
- Starting problems, resolved with $$$
- would a 245/45/17 tires fit on stock 02 17" se rims?
- I positive that im burning oil...
- How to tell if a Y pipe is for a '99-'01 vs. a '95-'98?
- Front strut tower brace (eBay kind)
- 2003 Max Making Rattling Sounds In Engine Bay
- 01 with 02-03 HIDz, question
- screwed up my illumina install
- Performance Mufflers
- DYI painting 5.5 grill write ups
- ABS line cut
- 2000 maxima gxe...side bumper lights dont go on?
- Resetting ECU
- rotora rotors?
- loud clunk
- How do i clean an apexi power intake? Please read.
- *Video* of completed touch screen/Climate control relocate/Computer
- what to look for/what goes on 5th gens?
- 1st gear rattle/grind?
- What do you Guys think of these headlights???
- shift linkage question.
- Cosworth adding the VQ35DE
- Can't find anything about this.
- what kind of cat to buy?
- Upgrades / Changes 2000 SE
- New toy.
- Some opinionated questions
- Analog speedometer sticking...
- Oxygen Sensors - Should I replace them?
- new struts get rid of clunking noises
- Need SOme People Opinions
- Might need a mass airflow sensor on my 03
- Requesting picture of VQ35 6sp fidanza flywheel
- Need Pics of Eibach or H&R Springs on 20s
- custommaxima is back??
- how much does a used berk intake go for?
- Maxima wrecked
- Hollow sound coming from front end
- CEL - P0505
- Chrome door lock install
- Probably a repost but...
- Knocking and Pinging
- Kinetix Intake Manifold on 3.5 Engine
- stickie links wrong
- New Mesh Grille option
- Need Help-Fidanza Fly Install
- Alternator went bad on me...
- Where's the A/C drain hose?
- need help will these fit? and is it a good deal
- P0446 code
- Fuse for Sunroof
- Funky noises after replacing Sway Bar End Links
- what a steal
- A/C Drain Info - Water Collection Problem
- Am I ASKING for trouble?
- CEL!!!
- Leaking Windshield?
- Looking for a FOB
- kyowa racing wheels
- Anybody got a Stealin intake? What hardware does it use?
- Install Kit for 02 maxima
- Any way to Duplicate Key cheap?
- Annoying noise coming from the back...**soundclip included**
- Engine Block
- Hot long should front axles take to put on
- BBK Brake distances
- am i doing something wrong... is this how its supposed to be? (shifting)
- P1147 & P0139 codes being thrown, need some help
- ABS sensor
- crazey key fob problem
- 5th Gen's for MOTM?
- Battery or Alternator???!!
- power stering belt makes loud squeaking sound when the engine is cold
- Gas tank help.. help me fix my idiotic mistake...
- Codes P0139 and P1148
- for sh*ts and giggles...
- O2 sensors rip-off?
- 5th Gen Produciton Dates
- How to cut bumpstops properly?
- Some s.o.b...
- seat belt mechanism
- 2000 Climate control issue
- Bad starter or alternator?
- Whats your reason for no stillen side skirts?
- Double Din
- To those w/ Clear/Smoke Rear Side Markers
- Clearing Turn signals on 02-03 Headlights
- My Clear Side Marker fell off!!!
- simple Intake question
- Whos the owner
- CHSML HOLE COVER??????
- Difference Between 5 and 5.5 Gen Muffler?
- Need Advice for 5th Gen purchase
- need input on these headlights....
- HID Ballast Location Pic's
- ABS Troubleshooting - How do I get the actuator/control connector off?
- HELP, new noise in front right wheel
- Interior lights, windows, locks, not working...
- For those with Hawk HPS
- Rear springs/struts bad...replace all?
- problems with LED lights
- MAF, O2 sensors replaced but car still sluggish..
- What to expect in repairs
- tein coilovers opinions/pics
- 02-03 aftermarket OEM fog lights questions
- VIAS?
- 2002 Auto Transmission Cooler
- NOISE From my Tokico Blue struts
- Time For Wheels but I need help....
- Steering wheel clunk...
- does anyone have???
- This is a new one !
- Why does my 2000 keep blowing starters
- two body repair questions
- WTB stuff but I keep posting it in the wrong forum
- brake and battery lightstays on...alternator is brand new!!wtf?
- WTB .... IN LONG ISLAND
- Will eibach coilovers used on a 93 accord fit my 2000 maxima?lemee kno asap
- 5 spd swap?
- Brake Pedal too Close to Gas Pedal
- White or Blue LED for the lights on the doors
- Replacing Door Moulding
- Ebay foglight housings
- window tint
- Vehicle Immobilizer System restart??
- Swapping 03 6spd into 00-01 possible?
- New bulbs
- Sunroof opening at random
- Will I like a Gen 5
- Dual Exhaust [photoshop]
- 2000 se steering problem
- Dim SES light
- 3" maf housing
- 02-03 Maxima w/remote XM satelite mounted?
- fog light poll
- Taillight tint..
- Strange Noise - Help Identify
- My Gauges are Complete!
- Completing My Exhaust
- Where I mounted my drop resistor switch
- Anyone using Mobil1 ATF synthetic in their Automatic 5th gen?
- Do i need a NEW clutch and flywheel?
- 01 MAXIMA WITH 3.0 AND 6 SPEED STOCK?
- P0440 Evap Small Leak Code
- quick motor mount question
- Hood Shaking
- emission control information
- How toget wire through fire wall
- Running angel eyes at night
- Where to buy stainless steel fasteners?
- Oil in spark plug tube guys please chime in
- TCS and LSD
- Where can I get this grill?
- Tint on Grey Lustre...
- memory seats on a 2001
- Re: air filter replacement
- alternator issues
- eBAY Grills? New? Opinions wanted.
- HID's are in......a few pix
- guages in km/h???
- Possible valve noise and solution?
- thermostat
- Moisture on Passenger Floor
- 2000 SE Sunroof Issue
- Rotors and Pads
- frankencar
- Wilwood/fastbrakes install
- window switch reset
- car bouncing
- Attempted thief damage
- Rear brake pad question... quick answer?
- 350Z Clutch doesn't bolt up to my 02 SE (Noise)
- MEMORY SEATS ADD ON!??
- Maxspeed strut combo
- Heated Steering Wheel out of wack??
- What is this stuff on the inside of my rim? Oil/grease look to it.
- EVERYTHING you NEED to know about HIDs, projectors, etc!!
- import showdown in Ga....video
- Need help fast....HID wiring problems
- Listening Test
- Need some input please
- I have the 6th gen brakes ... what about SPARE wheel/tire?
- 2002-03 signal light question
- 100,000 MILES AND @ 2 CODES
- VQ35 injector size.
- jackhammer type noise from front passenger side of car...need help ASAP
- would they clear a bbk...
- Advice/Questions on Springs/ Struts
- Annoying squeaking coming from clutch actuator thingy
- Difference in tint %
- Need to do Emissions Testing . . . ?
- electrical issues
- does anyone know...
- Color Matching High Beams and Fog Lights to HIDs
- gauge cluster lens
- Engine Revs Dropping?
- Oil Filters - PureOne, Mobil 1, OEM ?
- wireing low beams and high beams together
- Need some electrical help - Auto door locks and Int. Lights don't work
- nosiy belt tensioner ...
- None of the FAQs seem to be working and I have a question
- Single Disc Bose to 6 Disc Bose
- where to buy parts
- Looking at a 2000 SE auto that needs an engine
- Alarm Help
- speed sensitive clunking from suspension?
- Possible solution to aftermarket HID glare problems
- Will a 5th gen intake fit a 5.5 gen Maxima?
- Sound deaden trunk to reduce exhaust noise?
- Which head is bank 2?
- Stock nissan HID temp?
- 00-01 fog lights on a 02-03?
- squeaking sound from the front please help :(
- Bypassing the A/C compressor
- The maxima is gone, thanks all
- transmission swap
- From H&Rs to Htechs. Heres my review
- Air Bag light Flashes every second while driving
- car dies when idelling...HELP.....
- Recommended Clutch and Flywheel
- Best place to order OEM Brake pads?
- something i noticed
- Lexus Style Fog Lights
- Fail-Safe MODE...ANyone ?
- It's partytime! Bar table in the Max.
- I had an accident with my maxy :( (pics inside)
- Slow Timing
- Gas Filler neck Pitted? Cause SES
- end link options
- Getting New Suspension..Camber?
