- Help!!! RR Caliper/piston stuck
- i wonder
- Vents for air/ac:
- Oil on 3.5 cover?
- Curb Rash.... Has anyone done repair on a G35C rim?
- metal clunking noise
- 6 speed swap
- 2000 Maxima Ignition Coil HELP
- Seat Heater Not Working
- Weird Horn Problem
- does bad cat cause stuttering?
- Location of Rear Defogger/defroster relay?
- anybody 2k2 with 2k1 plastic fogs?
- high pitched whining noise from engine
- Chirping sound on 1st to 2nd shift
- piece of *rap bose!!! NEED HELP
- advice - shocks/springs/axle replacement
- Need help to decide which shocks are better.
- Seat Swap
- Interference with radio
- How's impossible to get 02 headlight (wtb)
- Another Cheap lip alternative
- foglights
- Two issues, need help figuring it out
- goodbye maxima.org
- Cattman Catback Reuse
- Uneven tirewear and other alignment problems... pics included...
- Ticking cold start, jitter idle, sluggish engine.
- need some help... code p0171
- 2000 SE Clutch fuild leak... advise pls
- Problem with alignment
- Cam position sensor problems...
- Is anyone has Carfax account?
- Transmission Flaring
- Need your Help
- Do 4th gen Accelerator/Cruise Cables fit '00-01?
- Vibration/low idle in reverse (auto)
- DIY Exterior Mod
- PCV AND REAR MAIN SEAL LEAK
- Crankshaft pulley help
- injen intake
- programing keyless remotes
- Catalytic Converter decision
- Installation instructions (how-to) for clear sidemarkers
- reverse light switch
- MP3?
- How Many Times Do You Shift?
- crazy 5th gen rear...is it on the org?
- harman kardon drive + play
- Tach and odometer lighting problems
- Clutch fluid bleeding
- Need HELP!
- Need feedback on my alignment report
- Winshield washer pump location?
- What will destroy a flywheel?
- Door HInge problems - Driver's side
- Good price for my car?
- New section here on the org
- my new cluster.
- Clutch Pedal Enagement
- Looking for caliper pins and bolts
- suspension question
- Pics of my OSCAI
- has anybody gone from HID's to regular bulb headlights?
- Has anyone ever fixed an 02 headlight after theft
- alternator pulley, quick question
- AFE Air Filters
- ? on Tranny Swap
- HID Fogs
- How high to remove exhaust? (pic heavy)
- The most frustrating project I took on **pics**
- Hitch Question ?
- Whas Better ???
- Looking for a specific type of interior light.
- knockin noise
- Upper Intake Manifold polish
- Need help from 5th gen guys who have had a wreck :( pics later...
- VQ Power Maxima of the month
- Sticky antenna
- Those who have had oil leaks
- exhaust tips?
- 18x8.5 wheels with 20mm wheel spacers pictures?
- Reading CEL flash codes
- 300ZX OEM Wheels
- 2000 Maxima SE New Struts - Rear end now very loose
- stalling
- Pic of Netami FSTB?
- Spark Plug change?
- TSB's? How to deal with Service Dept.
- ECU decoding help
- Excessive Oil Burn, (magically disappearing)
- Dim aftermarket D2R bulbs?
- How long / much to change this out on my max...
- HELP! Cant put gas in the car.
- About to buy max on eBay. need last minute help!!!
- 01 max engine/tranny problems after exhaust?
- how do i remove the scrwes on the bose unit
- Nasty curb hit - did I bend the rear axle?
- Remote starter
- 02 Sensors
- Did my first auto transmission fluid change today: Some observations
- help
- Can't get the battery out!! Help
- need help how to remove the bose unit on my 2001?
- unified meter control unit
- Door Alignment
- headlight clip !!
- Front passenger seat Prob
- Oil Burn = Knocking/Pinging?
- Need a chipped key to unlock door?
- This is really wierd
- WTF - Alternator or Dead Battery? Help!
- P0340 - related to the recall?
- P0300 Random Misfire - not coils
- need help removing back panels.
- Hyperground Impressions
- Oops, disconnected airbag plug under glove box
- Front end clunking?
- what a diffrence
- i think my tranny is done
- Feel ripped off:berk intake
- To All Those With Tachometer Lighting Issues...
- Is this a good deal on a 2000 SE?
- Confirming bad wheel bearings...
- whats the best way 2 replace alternator belt..
- Climate Control Light
- P0303 Code? Yes, I searched first
- Knocking from the right side engine bay
- alternator belt screeching and even louder when driving
- Steering wheel radio controls rattles..
- Suspension
- what happened to the forum/search?
- Squealing/Grinding Sound When Turning Left
- Suspension noise ... need to find the source
- Struts
- Request for updated link
- P0301 code...possible cause of SSIM?
- Looking for steel wheels in junkyard for winter tires
- Problem: Car Hesitant to Start
- Help Please: Screeching Sound from AC when car starts
- new coils.....still missing
- Constant SES and need help
- need help on tools and installation....
- Anyone running a scangauge in their 5th gen?
- Replacing Alternator
- P1148 and P1168? What do you think?
- Air Bag Light Flashing NEED HELP!
- DOOR LATCH HELP!!!
- Damp Carpet Under Pedals - Please help
- Ebay Clear Bumper Lights
- where to purchase a new OEM steering wheel?
- PLEASE NOTE NEW RULE IN 5TH GEN FORUM
- Alternator Amperage
- 02 Suspension
- battery not charging.alternator is good..but terminals are corroded green and white
- pink dot coils?
- Steering wheel rattle.... Video inside...
- Weird mechanical whirring noise
- What is the band on the OEM DR2 bulb for?
- what does this plug go to?
- Bulb Size
- Rear Marker Lamp Assembly
- New maxima but power lock problem
- Not sure about my engine
- anyone have a clue?
- Fold down the seats, dent the leather??
- auto tran control device
- Anybody replace their tie rod ends?
- Looking to buy a 2002-2003 maxima 6 speed NEED SOME HELP
- How does my car know it is ICY?
- my car just hit 115k today
- Home Depot Grille
- Tachometer Not Working Fully
- Touch up spray-paint for pearl white...
- question about clutch pedal adjustment
- Quick! Please help save my taillight...
- stalling...please help
- Good ol MAF Sensy
- Blower fan switch, one level only
- how long did it take you to find 5.5 6spd
- 100K
- Lookin For SUPER !!!
- Front Sway bar diameter on 5.5 SE
- Which outlet type for flowmaster muffler
- Interior / center console disassembly
- 2002 se 6spd running sluggish
- Power Seat Base Adjustment Problem
- Suspicious of Water in Spare Tire Area
- Squealing sound from steering wheel
- Loop on remote broken - looking for case
- ECU Reprogram for 2002
- shifting in the manual...
- leaky rear 3.5 valve cover? FS:brand new gasket
- 02+ gated auto shifter modifications
- Mudgaurds
- motor mounts
- redline anyone?
- P0420 code
- Tire wear and steering wheel shake
- Maybe i should buy a seat cover..
- P1147/67 Mfr. Control A/F Metering
- Service Engine Soon (SES) light after new battery was put in ..
- I take it "traction limited" is normal in 1st gear in automatics?
- Acceleration Delay Issue
- lowering susp question...
- Tein H-tech questions
- Removing rain guards...
- Murano Windshield Washer Nozzles, Sprays my Roof!
- Wheel lock nuts
- Spec Stage 2
- Is there a way to hook up the 02' factory bose subwoofer to an aftermarket headunit?
- Exhaust Flange
- Aftermarket Exhaust Rattle?
- Question about rear deck rattle
- ABS question plz
- exhaust gets real loud + rattles...only in rain
- 2000 SE versus GXE manual shift
- How long to replace clutch?
- Farewell Guys!!....My max is gone!!
- Windshield Washer Nozzels
- totaled 2001 max for $500 good deal?
- M3 Lip Spoiler
- Q: will the altima 02-04 leather seat covers fit maxima.
- Finally took the plunge and gutted the IM (SSIM)
- Can anyone here get an accurate oil level reading?
- starter ocasionally wont stop when starting
- Going From 5th Gen Auto to 5.5 gen 6 speed... Questions...
- How do you determine if HID bulbs need replacing?
- eBay Halo headlights! SHOW EM!
- Odometer light not working
- Air Bag Light Blinking - Reset Options?
- Kit/Bezel for In-Dash DVD Player
- Replacing lower oil pan
- 2k Illumina Eibach install notes
- Need to know a part name/part number of and odd part
- Weird Blower Problem
- Had a shop do some regular maintence, now a bit worried.
- Rubbing noise coming from front drivers side wheel
- horn wire missing? help
- will a 3.5 pass emisions with hotshot headers ?
- WTF!? 2 in. of water under my spare tire
- Anyone tried to swap gauge clusters ?
- Heated seat not working need help
- quick question?
- **Non-Bose** rear deck rattle
- 3.5L spec stg 2 disc, sprung or unsprung?
- OEM rotor material - is it special?
- Doh - $20 job almost turned into a $568 job!
- StS Help 5.5 6 Speed
