- Transmission spiking during shift from 2nd to 3rd, please God not a rebuild..........
- 6th generation exahust swap
- Hit granite curb at 25mph - what did I break?
- Lost All Keys
- auto tranny acting up, with a new VB. HELP!!!
- 01 RR ABS sensor help
- Bad Alternator...cause starter bendix to go out?
- wideband cattman headers.
- 02/03 grill possible to put on a 00 Maxima?
- Got SES light on (cant google it and broken link in stickies)
- caliper pins
- Radio or clock not powering on!help!
- Bad Dealer Diagnosis
- steering wheel interface
- Is anyone else totally disatisfied with their Maxi?
- Regular 87 or Premium??
- Problem with my max
- Power Steering Belt Help
- Throttle Pedal Sticking
- SEAT SWITCH
- 5th/4th gen parts compatability
- automatic window roll down on a 2001 maxima
- Repeat Threads/Topics that have been discussed. Suggestion.
- cattman header then CEL
- 3rd Brake light cover
- Matching Stock 5.5 Chrome
- Another Grille Thread
- Dual exhaust in 5.5 gen?
- 5.5 Gen eating my wallet...
- 4th Gen vs. 5th Gen - A thread of Specifics
- Where to buy idle control valve?
- Weird constant brake squeal?
- Did the 03 GLE had the sunroof as an option?
- Climate Control
- stinky carpet?
- Rear Suspension. Does this look normal?
- need help with rear hub bearing
- Is this 5th Gen worth it?
- spoiler installation
- Quick Trip Meter/Tachometer Q
- spark plugs in vq35
- ecu question
- My max sounds like a wookie between shifts!!!!
- No power after 4k rpm
- 01 Maxima SE
- interior lighting advice
- Ebay hid fog conv. any thoughts
- NWP Phenolic spacers
- trans. ?
- help with Apexi safcII instalation please!!!!
- Possible to Replace Analog Climate Control w/Digi Climate Control?
- Wheel bearing?...
- variations of the stillen rear?
- ring question on 3.5
- 5th gen MPG?
- 01 SE AE Hesitation
- $622 For Y pipe ?
- Strange Noise with Steering
- going to buy a 5th gen but pros and cons between 3.0 and 3.5
- 5th Gen Common Issues
- 3 quick questions regarding fog lights and paint
- ABS Light... Help???
- p1126 Thermostat?
- Steering wheel interface
- Seeking Tech Wisdom, Leave MAF Alone?
- Replacing MAF
- Steering Wheel Radio Controls Not Responding?
- vin check someone
- Stock Shift Knob w/ TWM STS
- P0128-thermostat
- Nismo Short Shifter
- 5.5 Model Info & Buying Advice
- Shift Knobs that work with the 5.5 boot
- Need some help with thule fit kit...
- Very nice low mile 5.5 in classifieds
- Rotora or Brembro Rotors, which do you think?
- Belt for underdrive pulley
- 2000 Emission Warranty Questions (Cat and Pre-Cat)
- Heated Seats
- powerslot cryo rotors are great.
- 02 sensor location
- Starting Problem?
- She over HEATED!
- start up outa wack!
- Alternator install - same Alt. for all years?
- Eyelids
- Front and Rear parking light trick
- Need opinion an on an idea I have for my grill
- Race Gas w/vq35
- Weird sound when i back up
- sqeeking sound?
- Weird buzzing/pulsing when braking at low speeds
- tokico illumina questions
- speaker install
- TC ECU?
- Broken wheel lock.. How to take it off
- Right Fog Light will not light up
- sand?
- Replacing both axles. Is left as easy as the right?
- Smoking Lights
- grinding?
- Cattman Gen 1 or Gen 3?
- rear caliper twisting piston to compress?
- Reinstalled wilwoods + 2pc rotors (oh, and have a new baby too)
- Apex'i Intake Filter Size for Berk Intake
- Quick question about fog lights
- buy a blank key?
- gauges, 5spd in a 2002?
- Heater blowing cold air
- Anyone Know Where I Can Buy This?
- 2000 Maxima Motor Mounts
- New Grill
- Clicking noise - HELP!
- Magnaflow true duel exhaust... worth it?
- Wheel hp number for stock 02/03 Max 6-speed?
- good cai to upgrade to.
- On a car with 105k miles...is this warranty worth it?
- p0505 - death of a maxima.
- In the process of buying a new transmission quick question
- rear power windows
- paint code? and DRL ques
- 5.5 Gen 6spd??
- Oil pan spacer... what do u think?
- Sunroof OffTrack
- Annoying suspension noise..
- wheel locks
- High beam malfunction
- Any opinion on Akebono Ceramic Disc Pads??
- Happy New Year Folks!
- WTF is up with my gas mileage?
- Brake light problem
- How can I open the fog lamp?
- leather install
- where to find bulbs from the "Replace auto climate control bulbs thread"??
- H-Tech front and H&R rear?
- front bumpers/lips
- Maxima's Retirement Age
- SES P1456 - EVAC 03 Maxima
- Product Help Wadda Ya Think
- Is this an easier way to access broken Bose CD cable?
- Hvac Lighting
- Removing "Datadot" headlights for DDE install?
- Putting together a Maxima Calender!
- Window Issue
- diamond plate floor matts!?!?!?
- 2000 auto axle removal
- Pulled Codes P0038 & P0037(twice)
- Hesitation...... when accelerate
- new shocks/struts
- It appears I have a very early '02 Maxima
- Anyone have the VTC sproket replaced by dealer?
- Troubleshooting
- Pulley Noise
- TE conversion to a 02 SE
- bulb question
- Does anyone have these headlights installed?
- Headlight Cleaning--PLASTX-Pics inside.
- Stillen headers
- Swapping 02 OEM seats into an 01
- Raptor Fenders
- FOUND MY MAXIMA!!!! :)
- How to pull TCM codes?
- where to buy cheap spring and struts
- Timing advance
- Temp Gauge Position question
- maxima.org decal?
- Tough Opinion Question
- 01 complete BOSE system
- Friend owned my rear bumper, get a whole new kit or what
- Rear Valve Cover
- FSTB's from racingline
- 5.5 Gen please say tranny is not going!! Help!!
- How do you diagnose bad fuel injectors?
- First Rattle
- voltage stabilizer and grounding kit
- I35 cluster in 02 Max
- Weird idle and 1126 code
- 2002 SE 6 spd -Time Sensative- thoughts?
- what do yall think bout this catback system
- gas fill up problem
- K&N Cone Filter
- Loud squealing w/ Heater on
- 03 Altima/00Maxima Calibers
- Wont stay running? nor rev past 3K
- 5.5th gens what clutches are you guys running??
- Who's car?? 265whp and 7.5K rev
- SES light is on!.....
- are my rear calipers cashed?
- Dynamat - front or back?
- Hi - Output Alternator
- Odd radio issue
- Rear View Mirror Jiggle??
- Merry Xmas
- Transmission Issues in the Cold
- Traction control light
- CF Front Splitter
- Techno Square
- Not starting after alternator replacement
- 5th/5.5 Gen Maxima Configurator
- Nismo / JWT Cams
- Stalling Problem, Please help!!
- what do you think about the ebay ypipe & headers package.
- AE Lip Pix Request
- d2r install question
- Warning:Misfiring Long Story Unfixable?
- fog light how to
- Megan Racing coilover question.
- Fidanza Flywheel, any regrets?
- Bose HU + Cold Temp = Skipping
- Weird engine noise after filling 87 gas
- Show me your LIPS
- 5th gen key replacement options?
- Your thoughts on these rims.
- Deer in Headlights
- Speaker Problem
- Closed
- Side Marker Lights
- Fog light swap from 02 to 01
- Dangerous splash guards in snow
- Leaking Struts????
- Out Headlight $275 to replace!?!?!?!?!?!
- blower motor not working.
- climate control lights out
- How much can you average on Parting an 02 maxima out?
- Going to check out/buy an '02 Max, any tips?
- Photochop help - Stillen rear lip idea.
- does anyone know the thread size for the 2000 Maxima shift knob?
- Key programming
- New shocks?
- Bumper Lips
- transmission
- EGR and Limp Mode - MAF Sensor Problems
- Hidden Button in AC Controler?
- Messed up my headlights trying to clean them need help
- Where is the temperature sensor for 02/03's?
- Power Seat stopped working..
- My headlights, fogs, and tails not working
- Mach Irish44 Lip installed
- O2 sensor attachment...
- Tallest tire for 19" wheels u can fit on 5th Gen?
- Warranty Replacement For the Illuminas?
- Those with Tan Interior
- Blue gauges anyone?
- need advice on maintinence
- What Spark Plugs to use?
- Think I may have got screwed...
- What are you getting your max for xmas?
- just need some side marker advice
- Help!!! RR Caliper/piston stuck
- i wonder
