- Need Help finding 02 Bung Plug.
- supercharger
- i hear/feel my clutch pedal squeaking...?
- shifting issues - no reverse on a decline
- Installing ES Bushings under the Shifter Assembly
- Exhaust question
- Tranny Slip....and yes i already searched!
- Power Seat Problem
- Will 370z wheels fit a 2002 Max?
- Ground control coilver any good?
- illuminas winter settings.. what do you do
- Angel Eyes with HID?
- Blower Motor Dead??
- shifter trim
- Sunroof Control Module in 2K
- Seeking Long Term Assessment on RTP Rotors
- Check engine soon codes! need help,installed berk intake days later light turns on
- Slow 1st to 2nd Shifts (Auto)
- License Plate lights won't light up
- Just installed ES 6spd bushings and STS - My thoughts...
- A belt in my car just popped, battery light came on but the car still drives...
- Overheated Brakes?
- Battery Relocation Installation with pics.
- High flow cat vs. test pipe - sound difference!!
- My ES project... Finally installed!...With pics!!!
- Wondering if I should sell before 2010
- Throttle body cleaning success story
- Megan OE-RS vs Cattman: Anyone tried BOTH?
- How bad is this and anyone else have this problem? Pics inside.
- Another OBX header Question..
- gas smell
- OEM 17" Rims Question
- Ebay exhaust on my 2002
- Broken shifter bracket... oh dam...
- who installed thier own o2 sim?
- Classic Stillen lip paint
- Transmission gets stuck at 2.5K
- car did something strange
- shifting issues 01 max
- Identify the Rusting 5.5 Gen Maxima Part (Fun for All Ages!)
- 6spd tranny fill plug missing?!?!
- clutch set ups?
- Strange symptoms (long)
- Light indicator on dash...
- Need help/Input-odd sounds and smells
- Replacement Alternator - Starter...
- Well, Original Altenator on i'ts way out!
- NEED HELP ASAP, Car will not let me go over 2.4k rpm
- A few minor Projects Completed....
- kyb strut differences?
- Fog Light Rocker Switch Suggestions
- cattman headers
- Are 97-99 radiators interchangeable with 00-01..????
- APEXi S-AFC vs. V-AFC vs. V-AFC II
- anyone use autolumination?
- Weight Reduction - What to remove?
- looking for that old thread concerning the rear axle
- Window motors or regulators? Or..
- weird accelerator surging problem?
- manual swap question
- i know this is dumb but i need help
- Vias problem was causing ANNOYING WHINE?!!
- Strut mount advice.. KYB or OEM
- KYB or OEM Strut Mounts
- pulley fitment question...
- How to definitively tell if your 6 spd has HLSD or not
- WOOD GRAIN INTERIOR
- Where to get Grill emblem?
- Lenses for our fogs
- Hesitation After Warming up
- cleaned up my Max (pics)
- 5.5 Gen Headlight Removal w/ Data Dots...'lil help, please...
- Lifter tap/misfire + safety mode active + SES light on
- what can it be ?
- 6mt problem
- Audio has suddenly upped the suck factor
- Anyone did this thing before?
- Folding Mirror Pinout (The answer you've been looking for)
- IACV crapshoot - to swap or not to swap, that is the question
- Annoying whine (video included)
- look what i bought today
- Car runs but dies when you press throtle
- octane rating higher than 91 bad too?
- Strut questions (not modifications...buying)
- What is the bulb number for the amber/clear corner on 5.5gen headlight?
- After replacing axle, car vibrates
- Cruise INOP, reverse lights on, speedo off
- 2.5" or 3" Electric Cutout?
- Does the GAB decrease power in hot weather?
- Strut mount comfort?/ Replacment
- Is there a lifespan...
- Has anyone put I35 seats in rear of 02-03 Max?
- Accident today :(
- interesting find while adjusting headlight aim
- 2 tranny's in 2 weeks WTF
- Replacing 2001 VQ30DE A/T Radiator
- Struts Shocks springs Installation Price?
- NO HEAT
- HID options poll
- Question
- P1800 code and NWP VIAS Plate
- Cali-Fed adapter question
- MAF sensor Replacement
- quick test pipe questionn
- The connection for the ECU
- 235/55R17's
- P0300 what are the different fixes
- vias repair question
- This has me a tad worried - P0021+smoke
- Front Brake Issues
- Who has a NWP VIAS block plate on thier 5.5 gen?
- best prices for tein s tech??
- Time for some new spark plugs. Suggestions?
- AT S4.1 & S5 Style Grille for Us?
- Real wire mesh grille
- Turnin wheel causes rpm to raise?!?!?!
- Is this sticking out too much?
- Does the 5th gen SE muffler, oval tip, slip off or is it welded in place?
- Wheel gurus please advise!!
- Searching for y-pipe. Which do you recommend?
- Just bought my Tein S-techs
- Y-Pipe Problem
- P1126 code on a 2001 Maxima
- Umnitza Predator Orion V2 = SUCKS.
- NEED: HEADERS/ Y-PIPE INSTALL INSTRUCTION WITH PICS
- 3.5 intake manifold toque & pattern?
- 2003 HID lamp housing dust cover
- Noise under hood while turning?
- Tranny slipping. Need some help please/advice!!
- another ebay thread?
- what order would you fix this...
- Going to replace shocks..do the front or rear first?
- Plug n Play HID Issue
- Anyone on monroe sensatrac
- Bye Bye Maxima and great forum!!!
- Help Diagnosing whining 5 speed tranny
- Steering rack install...without y-pipe or crossmember removal
- Struts bad? brakes bad? HELP
- dome light picture request
- good quiet muffler combine with budget y-pipe and megan racing b-pipe...
- Clarion or Pioneer
- Advice W/ change or suspension Parts
- 00 window ? and key flob
- Has anyone tryed this?
- Front windshield fogging - any ideas?
- Emergency Brake
- Rocker Cover Tightening
- hesitation
- What is recommended? AFC Neo, VAFC2 or what?
- 25mm wheel spacers?
- 02 Maxima I think I found the oil leak!
- weird idle problem?
- Checking and Replacing motors mounts
- Good God, it Works!!!!
- Is it worth to fix it??
- Stock Alarm & Security Issue
- s14 240sx or 02 maxima
- 17x8 +4 17x9 +14 5x114 would fit 5.5 gen?
- Window motor removal pictures
- Check out these wheels!!
- OEM Muffler Replacement Q's
- ABS Speed Sensor replacement cost...(grab a brown bag for vomit)
- max owners with staggered wheels
- ebay radiator?
- Fog light problem
- Stumped!!!! NO horn No Steering wheel controls SRS light
- Bad Cat?
- Lots of road noise
- ebay grille
- Not another spring thread...
- will need a 02 sensor???
- Are these rotors repairable?
- Auto Headlights.
- How to get rid of Warspeed y rattle ?
- Blacking Out Headlights Today!
- Shes goin into the Stealership... i need some advice..
- Y-Pipe or 3" cat-back?
- Coolant empty, but no coolant in the oil
- Fitment Question
- Do these fans ever shut off?
- Looking for some parts..best website
- Trac light, Check Engine, Slip light on but, NO CODES?
- Rotating noise from front passenger wheel
- 235/55/17 on stock GLE rims?
- Clutch Noise? Please help
- Did i f#$% up my alternator
- Squealing noise. What is it???
- Removing dust shields?
- MAF question
- How do you get G35 sound on 5.5 max?
- Slow front windows!
- 6-spd clutch binds when hot
- OEM HID Bulbs? the difference in oem colors... VS age of bulb w/ PICS
- Engine ticking
- Belt issues
- 00vi n00b
- 02 Maxima SE items on E-bay.
- Anyone painted their own Stillen Lip (polyurethane)
- 20's on my maxima, will i run into any problemm???
- Mustang rims on a Maxima
- Steering Rack differences in 5th gen Maxes/I30s/I35s
- In-dash 6-CD changer issue
- Break fluid leak
- 245/50/18 on a 5.5 Gen Maxima
- P0172, P0175 Codes. Car modded and I know it runs rich after 3200rpm
- Rear Hubs
- e-manage blue can't rev pass 2200
- FINALLY DID IT!!! BLACKED OUT
- Ebay Exhaust
- P1065 ECM Power Supply Circuit
- Timing advance in MA
- PCV valve Replacement Gone Bad
- Bose head unit cuts out
- Borla muffler
- 03 Valve Problem
- f/s set of rotors
- Car died today... for the first time with 180k miles
- How to make your own intake on 5th gen
- VQ30DE-K VIAS
- RE: Camber Plates
- Interior LED bulb ?
- Removing offset from rims..
- fuel pump relay location
- Head gasket replace = $2000?
- Home made intake
- How to install rear Stillen lip
- Tensioner
- grill for my 03
- Is getting a extended warranty worth it?
- AT to 6MT swap?
- It's time for this episode of..."What's busted?"
- Alternator install
- The Definite LED Lighting Reliability Thread
- stillen front grill
- Rear left toe is out...how?
- 350z clutch questions. Possible to use the 370z clutch??
- Did STS Mod. Now hard to get into reverse
- Tein SS Coilovers
- SSV4 Suprastick 5.5 gen worst mod
- help<<issue with my maxx newb<
- Fitment question
- Painting side skirts
- Clutch on the way out?
- Headers / test pip / catback??
- 2002 Se Suspension Suggestions
- Who uses O2 sim on an '03? Problems?
- Brightened My Gauges
- Inhibitor Relay = Starter Relay?
- volume adjusts on its own
- new exhaust today..bolt size?
