View Full Version : 5th Generation Maxima (2000-2003)
  1. 5.0 to 5.5 Gen Headlight Conversion Problem - lights flash
  2. i broke my trunk open button
  3. Resetting SES on 2k2 - Instructions don't work .. please help
  4. 03 Headlight slightly leaking
  5. Tried searching....wheel spacers on 5th gen!
  6. Can't seem to find guide for changing spark plugs...sticky link not working
  7. HELP!!!! Maxima hub fitting question
  8. Need Windshield Wipers... New, Failed Inspection
  9. HVAC LED Conversion
  10. sts twm/activetuning/other???
  11. Has anyone ever?
  12. Which is best?
  13. what u guys think of this deal?
  14. 2003 Coolant Air Bleed Screw?
  15. question regarding the clear 3m paint gaurd on rear 1/4s
  16. Guys, it's been an awesome 5 years.
  17. Brake & Battery Light - Not Alternator...
  18. 2003 Auto Tranmission flush
  19. Headlight Bulbs
  20. favor please regarding rover bbmaf
  21. 2002SE 6MT Throwing P1031
  22. Unconnected Wire...Help please!
  23. Sunroof doesn't not work period!
  24. have done research, need help in deciding brake upgrade
  25. How-To: I30/35 Electric Rear Window Shade in a Maxima
  26. Oil Question
  27. Installing Clutch Slave/Master Cylinder
  28. Thinking of buying a 5th/5.5 Gen? Please post all questions and info here....
  29. What did you pay for your max?
  30. Another Idle problem
  31. E46 Projectors
  32. Home Depot Catch Can
  33. Stalls at idle
  34. 02 headlight Housings.
  35. 01 AE Qestion?? & Help !!!
  36. Weird power/fuse issues
  37. after idling problem
  38. NEW Projectors with LED signals
  39. Front end clunk = oblong stabilizer hole?
  40. Cattman Gen III Headers/SSIM impressions
  41. When should I change the transmission fluid?
  42. Completing My Exhaust
  43. after market steering wheel hub
  44. part # driver axle seal on AE tranny
  45. HID converstion
  46. 01 AE Clutch/Tranny Issue, HELP!
  47. engine mount issue
  48. CAR GOT HIT LASTNITE!
  49. How much does your max weigh?
  50. 2000 se computer?
  51. VAFC II screen rattling
  52. sorry noob question headers searched
  53. Transmission Help!!!
  54. so wat would u guys think?
  55. Early Birthday Present Fun!
  56. Any help with 2002 Maxima SE psgr front window motor
  57. Power Steering Pump Leaking..
  58. cluster slightly dimming.
  59. Erratic Idle. What's wrong?
  60. 22 on a 2001 max
  61. Engine wont rev past 1500rpm
  62. Bad Clutch?? or NO?
  63. Battery Light
  64. 4th gen 5 sp to 5th gen 5 / 6 sp comparison?
  65. service engine soon light is on .. help
  66. Long distance with a Thule
  67. Problem with new HID installation (2K1 conversion)
  68. SSR Type F's on a 5.5 Gen?
  69. Strange noise when turning right
  70. vias question
  71. Car is making a weird noise when turning
  72. warpspeed y-pipe
  73. Squeaky steering wheel
  74. So I decided to debadge!
  75. My Tokico Illuminas have "softened" after 40K miles
  76. Truax SFC finally installed!!
  77. CV Joints..BAD!
  78. Moonroof Shade Out Of Track
  79. spindle
  80. The NEW Great Picture Thread v.2 -READ NEW RULES BEFORE POSTING HERE!!!
  81. fog lights color
  82. exact match bulbs
  83. Driver seat won't move up and down. Anyone ever replace the motor?
  84. fr Dr window regulator going or gone
  85. My SSIM & Polished 3.5 Manifold-56K warning
  86. Blown headlight fuse?
  87. White smoke and water in muffler
  88. power seat not working?
  89. Latest Dyno Results + Video
  90. AE Headlight Mod write-up needed
  91. Bolt almost rounded
  92. Strange 6th gear problem
  93. Sold my Maxima...
  94. Need help for unknown ground cable & Pic inside
  95. P0160
  96. fuel pump question...
  97. Synthetic in an oil burning 3.5?
  98. HELP!!!!Serious Transmission Issues
  99. replacing ac compressor
  100. Need help ASAP on clearing headlights!!!!
  101. grille opinions!!!!
  102. Clutch Problems
  103. Couple of questions for my online friends...
  104. Its good to have my Maxima back!
  105. considering buying 5th gen
  106. Quick help needed on an Anniversary Edition
  107. Need opinions on suspension parts.
  108. Exhaust question
  109. front main seal
  110. TCM location????
  111. P0160 O2 Sensor install question...already used search
  112. radio reception with window tint
  113. BlackbirdVQ hotshot exhaust videos?
  114. 03 muffler question
  115. Has anyone replaced 6MT under CPO warranty?
  116. Wheel Bearing just went... how long do I have?
  117. Confirm NGK Copper Plug Numbers?
  118. Help! My car died!
  119. Copper NGK Spark Plug #'s
  120. Driver door doesnt close straight
  121. do 350z breaks fit on the 5th gen?
  122. SES light - replace EVAP canister?
  123. Well Known/Documented problems with 5 gen 3.0 maxima
  124. Help car won't start in the morning
  125. Throttle Position Sensor?
  126. Really crappy gas mileage
  127. Bose SoundSystem SUCKS!!!!
  128. Car won't start HELP
  129. The ecu smoked when plugged in.
  130. 2001 Have a BCM? Dead battery/parasatic load??
  131. Thule Cargo Box ?
  132. Nothing but Cracking coming from speakers
  133. Need Help: ECU reset location
  134. scrapping in a turn
  135. my car vibrates really bad in high speed, why ?
  136. Your Maxima rating
  137. Extended Warranty
  138. will a 2000-2001 ecu work?
  139. A lot of free time... a little interior project.
  140. Shaved Grille Nissan Emblem
  141. Splash Cover
  142. where did you guys purchased the fidanza flywheel??
  143. Were 17"s an option or standard on a 2000 SE?
  144. *Confused!!* Coils or O2 Sensor & Air Flow Meter. NEED HELP!
  145. Time to get a 350Z?
  146. Is there a way to see if a wheel bearing was just replaced w/o taking off the tire?
  147. Vibration and knocking sound; need help with diagnosis
  148. guess whose back?
  149. Axle replacement
  150. Shift Pad Removal
  151. 2000 Maxima tranny question
  152. Stock navi swap???
  153. BRAND NEW Tokico HP's blew after 1 week!?!??
  154. Bad CV Joint?
  155. Megan vs. Frankencar (pic comparison)
  156. Need pictures, please look
  157. Confused about how to read tranny fluid level
  158. Finally installed the modds that were sitting in my room.
  159. Clutch Fluid Question
  160. A33?
  161. How many shims ?
  162. Anyone having SES probs with y-pipe?
  163. ABS light on then car suddenly has no power. What gives?
  164. 5th gen motor in a 4th gen????
  165. Help Please
  166. P0138/P0139
  167. Another project... TSX Projectors into 5.5 gen housings
  168. AIRBAG O_O
  169. Messed up Tranny... again!
  170. weird problem...
  171. All interior lights go out when Headlights are on
  172. ABS Light and Flashing SET (Cruise Control) Light
  173. bad throttle position sensor?
  174. recall help asap
  175. Steering wheel pulling to the right..
  176. Some Codes, Unstable Idle.
  177. Odd 3.5 Thermostat Failure
  178. Can't Identify Noise
  179. Questions on '01 GXE door panel removal
  180. 2K2 DTC P1122 & P1126 - anybody? Suggestions?
  181. Hood Scoop v2
  182. 5th Gen Check Air Bag Light Flashing
  183. Bank 2 not firing at idle when warm
  184. Stock Maxima 6-speed axles work with Sentra Spec-V 6-speed?
  185. Dont forget to check this
  186. Help me diagnose a P0171 code
  187. new maf troubleshooting
  188. Front end clunk when going over bumps/dips....gets worse :(
  189. MrGoodlube "screwed up"Back to doing my own oil changes myself.
  190. Coolant smell no leak.... Help
  191. How can I remove the plug from the coils?
  192. Opinion on replacing '01 factory speakers
  193. "Overkill" Big 3 Upgrade Pics/Semi-Writeup
  194. Blue_Batmoblie's overlay fanatics
  195. "TCS" and "SLIP" light won't go off ...please help!
  196. What ecu can i use?
  197. STI badge
  198. Lowering my 03 on 20's
  199. 350Z rear brakes.
  200. My 00 Max stop breathing after 3 seconds...
  201. Maxima SE TE
  202. last minute confirmation
  203. Throttle Hang
  204. 2002 dash light problem
  205. Buying a maxima.. how to test for oil leaks
  206. Question about alternator mount point for "Big Three"
  207. Flywheel removal: what size bolt?
  208. One last thread for my suspension problem...
  209. connector on rearview mirror
  210. 00 Maxima, can i change the temperature unit from Fahrenheit to Celsius?
  211. How-to remove fog lights on 01 max AE
  212. G35C Seats going in a 5.5 Gen soon
  213. stainless steel brake lines
  214. HotShot Headers Installed
  215. Ebay M3 Mirrors
  216. Ideas on how to unstick the right axle (replacing it)?
  217. Programming remote, Remote Frequency?
  218. gauge swap questions
  219. Weird ticking noise in engine
  220. 20" FX35 rims on 5.5 gen
  221. Rev'ing it up = Battery not like... What in the Hell??
  222. Cannot for the live of me find B1S1 O2 sensor!
  223. Hood Scoop
  224. She wont REV.
  225. Maxima and I35 doors interchangeable?
  226. cheaper ebay hids
  227. Alignment question
  228. Cross Country Trip
  229. Battery Change
  230. Just picked up another Max
  231. Frost Inside Car
  232. ABS and TCS
  233. 90% new 02-03 Maxima Grill
  234. whats cost to fix cv boot
  235. New Struts and Springs, What else should I do while I have them off?
  236. new recall?
  237. 02/03 grill that I found on ebay
  238. P0178 Fuel Composition Sensor Circuit Low Input.
  239. Got 2 codes...unhappy with my car.
  240. 2002 6-spd shifting question...
  241. Officially Joined the Clear Club
  242. Got a how to on CV/Axle replacement
  243. My car got hit last night...
  244. Poll: Still with original Automatic Transmission?
  245. Crank Seal
  246. New MAF and Reprogrammed, But A Month Later Its Back To How It Was....
  247. Where to buy IACV Valve?
  248. Test pipe fitment issues, it's too long... (thats what she said)
  249. Belts
  250. Missing $10 part is going to cost me...
