View Full Version : 5th Generation Maxima (2000-2003)
  1. HID Burnt Out
  2. need advice on correct struts!!!!
  3. P0135 PO155 P0141 AND o2 simulator...help
  4. Having trouble removing fog light bulb
  5. Rear Parcel Deck removal?
  6. Has anybody installed a Remus universal on their 2002
  7. Searched: Car wont start YAY
  8. finally got rid of the noise
  9. L@@K what Mr Catts sent me...
  10. Rear bumper fix?
  11. help... transmission issues
  12. Front suspension questions?
  13. HELP.....CAR STALLING OUT AND IDLEING LOW
  14. berk intake measurements
  15. Losing power mechanic stumped
  16. New MAF requires ECM reprogramming?
  17. noise from front wheel well
  18. HELP PLEASE!!! Fuel injector problems on a 2002?
  19. 2000 I30 Brake Booster Failure
  20. Timing Chain help
  21. end link bushings
  22. Gurgling Sound on Start-up & Dim Lights
  23. Engine light?
  24. Cleared 5th gen tails. New thread for total rework and less clutter.
  25. Need a little help with wiring please
  26. Need help,from any 2k max with 4sp. auto
  27. TCS?
  28. Drivers Seat not working
  29. Anti-Hail Car Cover???
  30. Anybody got exact measurements of umnitza angel eyes for 5.5 gen headlights?
  31. The 2009 Honda And toyota clone
  32. Easiest fix for EVAP code?
  33. Rotor/pad suggestions 5.5 gen
  34. PLEASE HELP with faulty O2 sensor (P0138)
  35. Free Nissan 100 point checkup
  36. Gab Mod & Cel & Misfiring
  37. Car decision
  38. Have to Push Down the Maf sensor plug
  39. My OEM battery finally gave out
  40. piping sizes?
  41. 350z 18" rays on the max?
  42. My key broke from my key ring. Covers?
  43. front brakes & rear Brakes
  44. Removing "service engine soon" light???
  45. Akebono Street Performance Pads
  46. Installed K&N 2KSE, now noticeable miss?
  47. Lowering springs settling
  48. NISMO exhaust
  49. Problem with the shifter
  50. 18" rays 6 spokes rims fitment?
  51. 01gle auto transmission problem - caused by bad tcm??
  52. Clutch not fully disengaging?
  53. knocking noise coming from engine
  54. Brakes become spongy at high rpms?
  55. Air in Power Steering Pump
  56. New 5.5 gen Owner.
  57. Need help identifying a Max sound.
  58. REAR SWAY BAR Design (NOT a repost)
  59. Foglight removal...
  60. steering question
  61. Exterme steering wheel vibration!
  62. Exhaust rattle fix; small write-up with pics
  63. Vacuum Tee (DE-K)
  64. Few questions
  65. coils question
  66. Total cost of ownership
  67. alignment and Rotors need help
  68. H.I.D. question
  69. Transmission flush not possible with high mileage
  70. hood seals
  71. Engines
  72. weird noise when turning
  73. Pics of the 2009 Maxima
  74. Trans Mount (Location)
  75. just had a wreck
  76. Water in the trunk
  77. Cleared my 5th gen tail lights
  78. fuel filter pic... is this the one for our car
  79. ecm reflash NY for cali spec 2000se
  80. Removing large bolt from rear strut...
  81. noisy heater/fan blower
  82. Front Struts
  83. Bad Struts?
  84. 03 Max strut question.
  85. Does anybody know the wattage on stock BOSE headunit lights?
  86. 2002SE AUX switch w/ 6CD Changer
  87. Should I take a chance on these Ilumina's?
  88. Help Car making funny noise
  89. 6speed Hesitation after all common fixes?
  90. Dash squeek
  91. P0420 FIX (OR JUST VOODOO)
  92. Help me please...
  93. The ultimate maintenance service?
  94. How do I remove the park brake from the rear caliper
  95. Just got home from the stealer ship!!!
  96. "ping" sound around 2,000 RPMs when engine is cold
  97. Rear suspension noise
  98. Intake whistle!
  99. Major Oil Leak ! HELP *Pics*
  100. blower motor sound?
  101. Seat covers
  102. MT Front Pump Seal?
  103. Iacv
  104. Tail Lights What U Do Think ???
  105. front bumper dent
  106. Clutch issues - please help
  107. 2003 Max SE O2 problem...
  108. tein-s's with illuminas?
  109. PIAA Xtreme Force H3
  110. 2002 I35 Suspension question
  111. My weekend trip through the mountains
  112. Back brake rubs, never the same side.
  113. Changed my stock fuel filter today... first impressions.
  114. Brake Problem
  115. Wierd Noises after header install
  116. bumper question real quick
  117. My 2002 SE won't start
  118. PCV Valve
  119. Tranny flaring from 1st to 2nd
  120. bbk caliper cleaning....
  121. My interesting experience with different grades gas
  122. Crank pulley Indestructable
  123. sidelamps...
  124. Window spoiler??
  125. Shift Knob Removal
  126. Constant sqeeks
  127. suspension question
  128. Install aftermarket parts at dealership?
  129. SES codes P0159 & P1167
  130. My grounding kit, let me show you...plus some questions
  131. spacers ..........................
  132. Loud bang at rear right when going over bumps
  133. Who would win?
  134. Steering Column Squeak
  135. Glove Box issue
  136. Brake Problem
  137. Idle air volume learning
  138. painting.
  139. Heated cloth seat & steering tempature?
  140. Max is gone...
  141. Slight but very annoying squeak on 01 maxima
  142. ES Engine mounts
  143. grinding noise
  144. Replacement flex section for hotshot headers
  145. strange "whine"
  146. ECM / ECU Engine Computer Compatibility & repair
  147. Strut Tower nuts and bolts
  148. Which color?
  149. New Transmission Question
  150. Any thoughts on the VGX silent silver pads?
  151. Megan Racing Headers for Altima?
  152. Megan Racing catback installed- VQ35 sound clip
  153. 250K Miles
  154. Mesh Advice
  155. oxygen sensor 2000 se fed
  156. Wheel spacer/wheel base question
  157. Fuel filter and other parts
  158. Short ram
  159. angel eye problems
  160. Revolution Speed Sensor
  161. Changing MAF, questions
  162. Replacing Engine Control Harness....
  163. replacing IACV- I have a few questions
  164. Seized Pulley??? My car moans like a monotone hooker
  165. Has anyone here replaced their stock Airbox/Snorkel Setup?
  166. Need help installing Hella Supertone horns
  167. Help!! Cruise Control Light Goes On Does Not engage.
  168. To The Person Who Did The 5.5 Gen Auto to 6SP Swap
  169. Help Brake Problem
  170. Projector headlights
  171. Do 95-99 calipers fit 00-01?
  172. "Weathered" exterior trim
  173. Help! Foolish spring release connectors
  174. euros...
  175. 6th Gen Trans In 5.5th Gen?
  176. my winter tires rubbing with Illuminas
  177. Strange noise coming from intake
  178. Smoke gets into the Car!
  179. Alarm Question
  180. Question about turn signal switch
  181. Diameter of signal on 5.5 gen headlights
  182. This was not a good start to the day...
  183. extended warrenty
  184. Photoshop wheels
  185. ES motor mounts for AT tranny
  186. r33 front bumper?
  187. 2001 I30t shifting problem and bunch of codes
  188. PLENUM GASKET?????
  189. Legit H-Tech's for 181.60 shipped?
  190. how to increase poor braking
  191. Small amount of whine while accelerating
  192. nasty boom sound from trany
  193. Tranny Swap/Rebuild or VQ35 Swap?
  194. Is this a safe jack spot?
  195. failed inspection with p0135 code/check engine light?
  196. Funny noise at engagement point of clutch
  197. For those of you who use ramps..
  198. Inner tie rod ends
  199. What's the downside of o2sim to fix p0420?
  200. Diagnosing Bad Motor Mounts
  201. catback noise
  202. 2k2 GLE owner sick of dim dash
  203. Exhaust pipe broken. Have questions.
  204. HID headlight Question
  205. MAF doesn't want to come out..
  206. Which would you buy: Cattman rear section or Megan rear section + B pipe?
  207. Humor my alternator question if you will...
  208. New Clutch Installed
  209. Fitment issues with H3 HID fogs?
  210. Big problem, really need some help ASAP
  211. Violent shaking on the highway
  212. Poor 5th, just got hit
  213. Cold Air Suggestions?
  214. Bose Woofer Cut Off Fix For 2000 Maxima
  215. Serpentine belt: is my idler pulley stuck in place?
  216. BURNING OIL??
  217. What size tires for 18x8 g35 wheels on 02
  218. Just got some pics taken of my new 2003 SE TE by a professional photographer
  219. light situation
  220. Where's the OBD connector on 2001 Maxima?
  221. i think it's leaking tranny oil
  222. MAF again...winter vs summer problem?
  223. Intakes!
  224. MAFS & ECM Reprogramming Question
  225. Left side of Gauges are not lit
  226. idle screw location
  227. Altima Se-r caliper pads
  228. 2k3 Intake install
  229. A few question i need a few help on go easy on me im new
  230. NLEV Exhaust Questions
  231. vq35hr clutch with fidanza flywheel
  232. Can Anyone Confirm This Rims on our 5th Gen Please.
  233. Warning: Do not use Restore
  234. PLEASE HELP!!! SES light
  235. what cats to replace?
  236. Plug fell apart while sound deadening passenger door
  237. transmission flush
  238. B&M Tranny Cooler
  239. need help finding the right lug nuts
  240. Looking for a write up on HID bulb shield covers
  241. HOusecor's fog light mod
  242. stuck in park and I did search but need help please!
  243. Exciting Keyfob Thread
  244. My Engine i sout and I got the car for sale.
  245. Hypelinks dont work
  246. AC Questions
  247. major power loss
  248. OHOH... Engine Knocking After Oil Change and Restore!
  249. Engine Stalling
  250. 2 rattling noises
