- gas pedal gets stuck...
- Protective Headlight Cover question
- Am I getting ripped off?
- Guage Lighting Problems
- bose radio
- 5th gen pic request
- Some Lighting Updates for my 03' Max SE
- my 2k2 is using up oil....is it the valve cover..
- Sunroof anger
- Ralco Short Throw Shifter installed
- SES Light ON but No DTCs?
- how do i take off the rear bumper cover?
- Clutch Noise
- Roaring sound from passenger side on hard acceleration
- Does anyone know where i can find this piece?`
- edfc install: need help
- Anybody have pictures of the O2 sensor wiring at front of 3.5 engine?
- 6mt HLSD owners. What strut bar do you have?
- abs light comes on and off
- purple lights what do you think
- GOT A PO740 code?
- cam swap
- HELP! My 2000 Maxima SE will not start!
- power window issue
- Brake system Flush
- question about the o2 sticky for soonerfan
- Passenger side Carrier bearing...02 6spd axle
- Drivers side stereo and AC just went out WTF?!?!?
- Brand new 17 x 7 6 spoke SE wheel is $1100
- Stereo and speaker problems
- Weird sound coming from engine???
- I'm thinking my engine is toast......
- Wiring problem ?
- Need a Carpet - 02 MAX
- Ralco vs. Unorthodox UDPs
- anyone konow a good preformance chip for my 2001 max
- Difference between 5th Gen & 5.5 Gen
- Back Up Camera
- Air Conditioner - Temperature not working right?
- concerned about wheel upgrade, staggered setup
- right headlight works on and off
- Short Height Shifter project
- Water pump weep hole
- how do i take off the ac controllers knob?
- Just wanted to warn you guys
- Cracked Windshield and Banged Bumper
- 2002 with P0420 code. Thank you!!!
- EGR Repair
- Car Off. Headlights Stay on Indefinatly!
- Anyone With A Water Leak Behind Glove Box?
- Need help replacing/repairing broken HID headlight lens on 03 Max
- Ignition coil makes the check engine light blink ?
- Progress Springs
- Megan Exhaust:
- 2000 Maxima stalling out
- 2000 Maxima stalls out (frequently after a rev)
- Is the tranny cooler working?
- What to do with old BLOSE HU
- P0300 - Random Misfire
- best price for tokico illumina struts
- Illumina ABS attachment different than stock
- Is there a mileage limit on recalls?
- I did my spark plugs and now I have a P1320
- Rear Diffuser I dunno i got Bored
- Need help asap to remove rear deck cover
- 2002 Maxima SE Transmission Control Module part number
- OEM manual mounts in place of electric mounts
- Oil Pan/Inner Engine Gaskets Need Replacing?
- Timing chain tensioner? more? -Video inside-
- Gas Mileage Sucks
- Car struggles to 3500 RPM then takes off: is this a VIAS or MAF issue?
- Spare Stock HID Bulbs, Where?
- She can still do it!
- rear main seal replacement / oil pan removal
- Trans servicing questions.
- Sunroof Woes
- Auto Shifter Problem
- Sometimes I regret buying this car.
- Parking Brake Light On Persistently
- White film on Exhaust tips:
- SE-R Muffler?
- Just confused with these HID's
- Engine Clatter
- 6th Gen Wheels on a 5th Gen
- Illumina vs koni yellow
- Blown 02 Max Engine
- Great highway gas mileage, not so great city...
- New Rims?
- HID Park lights
- Vaccum line...
- Help: Fidanza flywheel fitment
- About to install Eibachs/Illuminas
- Rough Start, Engine Knocking
- HKS Axle Back Pictures
- Is 100K the killer mark?
- Is there such thing as a Gen 5 with a Gen 4 front end?
- Alright, so i just fixed my VIAS...
- Cheap BBK for 2K-2K1 installed!
- A/C Squeaky when Turn On.
- Wheel bearing going bad again?
- Just got pwned at the stealership
- I want to replace my bearings what synthetic grease should be used?
- Hid conversion help
- N00b here, help with catalytic converters!
- dreaded exhaust issue
- Car doesn't start!!
- wut the hell is causing this?
- Oil leaking where engine and tranny meet
- car died while driving
- s anyone knows if the g35 springs fits the 5th gen max?
- Electrical Promblems
- Question about Rear Sidemarkers.
- any auto 5th gens with the racing line MMI?
- 2001 Stock Diameter Crank Pulley
- maxima meet in upstate ny albany area
- How hard is it to find a 2002+ Black on black leather 6 speed?
- ***Rear ended, what to do?
- Failed Smog, need some ideas.
- Two Problems with engine related or not? any other suggestions?
- Location/Picture Camshft Position Sensor
- transmission swap + 350z clutch + fidanza
- change engine need help
- Nissan centercaps on my G35 wheels.
- What should i do about taking out Screws for VAIS?!
- Please educate me...
- which o2 sensor do I need to buy? help
- power seat is jammed!
- Stock Speaker Size?
- Sunroof Leaking?
- SES Light?
- BlehmCo 300zx Big Brake Kit... Anybody done the front and rear???
- Apexi Filter replacment
- Illumina question
- New bumpers, can I get a good paint match?
- Y-Pipe Poll
- Intake
- Random O2 Codes after service
- Exhaust idea
- Anyone have this grille?
- can I detune for better mileage?
- MAF Installation Questions
- Exhaust help/opinion
- Ground kit question
- 5th gen maf orientation?
- 5spd swap issue...
- I love deer =)
- My luck keeps gettin' better by the day...
- AC/heat switch
- RPM Fluctuating
- Diagnostic Code P0420
- Reset the VAFC2?
- what a freaking day
- NEED HELP(I know what parts I need & their #'s) using courtesynissan.com.
- Bose Display Turning Off?
- how to convert 2002 maxima front foglight with 00-01
- Remember that bad day...good to go now!!
- bad exhaust
- Pictures Need, All Colors and Years of Maxima
- Which would you buy and why........
- For those of you still wanting to match the fogs to the HIDs
- Strange noise coming from back wheels
- Flywheel/Clutch
- A couple problems!!! steering wheel controls and blower motor
- Are These Headers Any Good?
- Keyless Entry Remote
- HELP.. Need wiring diagrams
- Fuse blows, car wont start. Need help
- How long for computer/SES light to reset after clearing?
- Shocks/struts install shop in toronto?
- Problem Getting Car Started, pro's Please step in
- Z clutch fitment issues?
- Shifter Trim
- Won't Roll Backwards...
- need to replace
- Compatible AC Compressors
- Noise from front passenger side wheel well while turning
- rear springs or shocks bad? please help
- Cost of a rebuilt/used 6 spd tranny?
- Pics of my next project...
- 03 Maxima CAI MAF Sensor
- Code checking error
- Replacing Driver Side Door Speaker
- car stereo
- tranny oil???
- No power widows or locks
- Grinding Rear Brakes
- New Version of LED Tails on EBAY - Poll
- Do alternators go bad?
- Illumina problem
- Starting Issues
- bbmaf help
- 01 ABS Light HELP!!
- Just installed new Megan cat-back.
- Quick question about the stupid cam position sensor
- Help: 2k2 Hid conversion wiring on drivers side
- new leather seats
- Blacked out headlights/grill... Pics of process.
- Glow gauges? Where?
- Video in response to....
- Passenger front window regulator change-how to
- Factory Alarm
- Strange similar sounds from the front right suspension and engine
- Ok I read the Sticky and....
- blacked out headlights
- An Old Problem Revisited
- Car stalls while idling...
- 4-wheel allignment... kit?
- OE Spoiler Question
- Rear suspension leaking oil...wtf
- Questions Wheel Hub Assembly
- Brake Squeal with Brembo and Hawk HPS
- Who needs an 02 sim??? *pics*
- ES Poly End Bushing part # request.
- Radiator cooling fan drains my battery and I can't determine why - Help!
- Assistane with trying to find "rattling" sounding noise
- need help please ses light on
- Ratling noise from Engine - audio file attached - please help with the diagnosis
- getting worried .....white smoke
- Whining under partial throttle
- Starting problem
- Frozen Caliper and bad seal?
- '00 fed spec O2 sensor help! **pics**
- MMI installed
- MAF sources
- Need pics of 3.5 Ring Gear (or timing ring) asap! PLEASE
- HID
- Stuck rotor, can I use heat?
- Diagnosis Help!
- Is it OK and safe to MIX Auto tranny fluids?
- Uneven Drop: ALL FOUR WHEELS!
- Trying to "perfect" my exhaust note...
- AE Headlight Replacement
- Clunking
- Timing chain tensioner guides
- For those of you installing headers yourself... few extra tips
- Torque steer after axle replacement
- Does This Part EXIST ?
- Will a AT transmission from 2002 SE fit into 2000
- Help Please with P0505 Idle air control valve ECM and Throttle Body! Very frustrating
- Apexi neo install help
- 02-03 6speed maxima shift lever measurement?
- Service engine light but no code?
- engine ticking
- Dual tip Muffler
- Stealership upgrade checklist
- Gas Door?
- Alternator?? Not batt light!
- P0171
- Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
- Anyone In Northern Cal?
