- Clicking/grinding noise in engine bay
- ABS SLIP light on please help
- Platinum plugs - gap or pre-gapped?
- Squeaking Automatic?
- EVAP Canister...quick fix?
- Bump Steer Issue
- Tokico Illumina Deals?
- Starting Issues
- Goodbye Maxima...
- Flywheel broken????
- Personalized Tag - Need opinions/ideas
- New noise from the max...not again
- Just got a max!
- So where is the how-to for the HHO thing???
- WTB: GXE double din dash kit
- Aftermarket HU and starting
- Reset ECU on 02 Max
- Blown 02 Engine?
- 5th gen -290 -worc ma
- E-brake & rear caliper question
- 6th Gear Issue
- Exhaust Rattle Wallet Ouch!!
- Anyone in here ever had car repaird after being rear ended?
- 2001 AE 5 SP Maxima endless problems....help?
- Some CEL p codes help
- 2001 MAXIMA AUTOMATIC STALLING AND ROUGH IDLE
- no throttle response???
- Weird Noise from brakes
- Will 2006 nissan factory chrome 18" rims fit 2001?
- S-Techs/Illuminas
- pic needed
- Hey Old people!!!!
- Does fuel MPG decrease or increase with GAB???
- Power Seats..
- Vibrating from glovebox area
- 6-speed clutches...How long has your's lasted?
- LTB/Strut install question..
- tranny swap
- quick question about my hotshots
- need help installing B.co LTB stg1..few ?'s
- 5.5 Underbody Damage
- progress springs on stock suspension?
- to anyone running a hid kit in their heads please step in
- How did you guys seal up your HID fogs after install?
- P0505: What is your resistance value for the IACV?
- My 01 maxima is totaled happened today :(
- DIY Cat-back Exhaust - Earplugs needed!
- P0138/P0139 DTC...part number?
- MAF sensor & Dave Burnette
- REASON WHY 4TH GEN RADIATOR WON'T PROVIDE ADEQUATE COOLING IN A 5TH GEN?
- what does this part do?
- Hard Starts with Warm Engine
- 6th gen intake on 5.5 gen
- $500....TCM
- Ignition Timing
- ignition coil
- Possible to change the color of the AC reader?
- right front suspension noise.
- Replacing Fender / Matching Color from junkyard
- Time to change spark plugs
- brake pedal press too far
- Extreme Hard Starting
- Manual Transmisson clukes into 3rd gear.
- I need help w/ Fed Spec 2K O2 SIM install, somone moved my sensors around? *PICS*
- Belt Replacement on 02 Maxima
- Headlights
- How can i be sure of what motor i have in my "5th Gen"?
- POWER SUNROOF PROBLEM
- Is it a MUST to do grommets and spark plugs seals when doing Valve Cover gaskets ?
- Replacement keys
- Oil pressure gauge Install/ Mounting options.Suggestions?
- 350z engine swap
- a/e headlight mod question
- New Air Filter Improves Mileage
- P0021 Code Camshaft Position Sensor...Just need some more info
- Need Info On Stock Strut Shock
- Starter Motor/Solenoid
- Weird noise???
- 2001 AE Sidemarker Bulb Replacement
- Rear windows to roll down fully
- PR CAI Install: Electrical Issue
- how to remove the front grille 01 maxima?
- Autometer Oil Pressure Sender Install?
- Synthetic Tranny Oil question.
- Cruise Control
- Where to get OEM Maxima Floor Mat?
- What is the AEM filter size for the Berk Intakes?
- Ashtray Stuck Shut!!
- Speedo not working
- What model is this?
- 03 Maxima Aftermarket
- Loud noise/Shakey car
- Roof Rack install (PICS if interested)
- Check out a review of the Nitto Invo [video]
- 350z Clutch on 5.5 2k2 w/ Stock flywheel
- Placing my order for Tokicos
- Info on our HLSD????
- Belt Tension Gauge
- NEW '03 MAXIMA OWNER NEEDS HELP!!!
- knocking noise
- Rolls Royce Umbrella Mod
- 2008 OEM 18" wheels on 2001 SE AE
- DIY Flush Mounted Voltmeter Installation
- fluctuating rpm idle
- odd idle and no codes being thrown? help please.
- Left speaker and Bass goes in and out
- what kinda intake would you get...
- Los Angeles help please.
- EVAP vent control valve
- Power Difference. 02 Max vs 05 Alty SE-R
- strut and shock question on dropped ride
- Motor replacement. Which year block do I use?
- DTC p0171 system too lean (bank 1) HELP PLEASE!
- Weird codes.
- 2006 HLSD 6-Speed in an A33(B)
- Will 95-2000 Rear Sway Bar fit 03 maxima ?
- Changed the alternator last night
- anyone try this lip?
- Paint Estimates
- Dents from hail.
- Catalytic Converter is shot, what are my options?
- Brakes
- My new grille
- P0151,P1151,P1167
- Clearly My Tranny Rebuild Failed...
- VIDEO: Less than 95k, knocking, need new (used) motor?
- Need some help fixing my car.
- Maxima Floormat in I30
- Oil leak at filter/cooler base
- tranny swap Q
- 2001 LSD tranny part number..???
- 5th Gen CF hood install issues, need help.
- Mileage
- Maf went out 2k2
- No pressure in brake pedal
- Infamous Soft Brake Pedal?
- Stalling problem only when car is warm???
- 2001 serpentine belt change help
- loud clunk sound when acceleration hard?
- Estimate to fix power seat? No longer reclining...
- PO 731 DT Code---leads me to???
- Car won't start ... new battery, won't turn
- Dealer charge for air bag repair ?
- Aftermarket Angel Eyes compatible w/ Xenon?
- Quick question...
- Flowmaster Exhaust
- Any special type of fluids we have to use for our cars?
- Engine Will Not Hold 2500 RPM Unloaded
- No spark...
- any one here have a DIY air intake?
- Clanging sound when turning
- Buying 5th gen advice please
- Instrument Clusters
- Need Urgent Help for Valve Cover Issue
- O2 sim install question
- Weird AC problem.
- 350z intake on a 5.5 gen
- car didnt start!!!!!!
- Need new grill for a 2003 Maxima
- do you guys mind helping me with some codes?
- misfire problem
- Car wont rev when in gear (03 6MT)
- tranny swap question
- Input Shaft Bearing?
- leaky radiator
- PIAA Superwhite Lights Parking Lights
- Paid off my Maxima and 4 business days later have title
- So I can't move my shifter into the 1-2 position..........
- how do i take the side mirrors apart?
- Energy Suspension Front Control Arm Bushing rumor
- Engine hates cold shut down??
- Tranny and Cat question
- weird power loss
- My car won't stay on help please!!
- Radiator Cooling Fans
- 5spd tranny swap
- ebay projector retrofit
- Valve Cover for an 02 Max
- lifter tick
- How can this be? Knock Sensor and Oil
- Front strut mount question
- Swapping VIN plates on dashboard
- lowering springs
- Rear window broken
- Header question.
- AC Button
- idle relearn not working, need help!
- Strange Problem..
- 191,000 miles on my 03 means way overdue for some seafoam (video)
- 5th gen 5sp's how good are they?
- 4th Gen dude thinking of joining 5th gen.
- codes P1148? need help! Please.
- Brake & Battery light on at same time
- Removing passenger seat - disabling SRS Airbag
- Coolant leak comming from under intake manifold
- Joined the Eyelids Club
- Federal Emissions Long Term Warranty Question
- Smart Entrance Control
- Nice price on Fidanza flys for VQ35DE/6MT
- Uninstalling the Bose HU in a 2002...
- Trying to avoid paying a dealer $600 to change fuel pump
- P1448 and P0455
- Threw a rod in my VQ
- Blew an O2, is an O2 simulator the way to go?
- catalytic converter
- GAS SMELL
- Need to paint muffler "sleeve", what paint to use
- Guidance on how to open the steering wheel on 03 maxima
- Gas mileage issue on 03 Max. Dash shows around 14mpg!!!
- HELP - bad fuel pump???
- added new muffler to the ride
- Gauges installed in DIN Position.
- How to clean MAF under $10 w pics
- Door Strips.
- what is the number of the bulb on the light ring where the ignition is
- Is this a good deal?
- SAFC II SAFC NEO Stock Engine
- lazy gas pedal
- What all is wrong with your max? LOL
- blower motor problems
- need some help with bump stops,dustcover
- is this a good deal???
- All Black Interior - Lightening it up
- Engine slugging on 2000 maxima
- tranny missing p0720 help please.
- Suspension Help..Spring/Strut Combo
- Eibach springs, will my jack fit?
- illumina rear adjustment no knobs
- Buying a 5th generation soon... quick question
- Looking for TSB PDF'S (not in stickies)
- Installed Stillen RSTB and Love It!
- Just Curious...Who's still paying on their 5th Gen?
- Well this just sucks...
- Passenger Power window does not work
- Dropped Bolt in Belt/Pulley Area
- Sun Roof Visor
- 2000 5spd Shift Linkage
- passenger window.....stuck...rain coming
- Viper 5900 problems
- This sounds real stupid but...
- Map light LED bulb:
- New Recaro "Racing" Seat LOL
- UUMMM?
- Using 89 Octane Fuel (10% ethanol blend)
- For those with HID fogs....
- Can I put my old 00 door handles in my new 02 se? Anyone know how? thnx
- Pics of my busted wheel
- 5th Gen Blacked out headlights
- Front End Rebuild
- gas pedal gets stuck...
