- Jerk/thump when releasing clutch in neutral
- Max starts, then dies.
- Has your max done this?
- hesitation/slippage when low on gas?
- Help... Door speaker blown...
- axle bearings
- Click - No power. Electrical relay?
- driving under 1000 rpm
- 01 Bose Sub cut off....
- Keyfob Error
- How do you replace the check engine light bulb?
- 2000 to 2003 Front End Conversion.
- Just upgraded
- Question about phillips D2R bulbs
- starting problem
- Which bearing should I use?
- Would wiring a solar panel to the car be bad?
- WTF!! Happened to this Maxima??
- Does your 02-03 Maxima make a snorting sound?
- A/C is making a weird noise
- Overheating problems (no start)
- Difference in Nissan front brake pads part numbers-help!
- How much can I get for my max
- Illumina Piston Rod nut torque
- What is the year and mileage on your Max?
- One of my parking lights is not working?
- bose speaker dimensions....
- Weird engine start when warm?
- Jumpy Idle at start ups and quick stops
- Willood BIG BRAKE KIT need help!
- WHEN IT RAINS
- Shift Lock Woes -- Shifter Stuck in Park
- Clutch Problems - Random
- Tranny popping out of overdrive on the highway
- Transmision Saving?
- 5.5 Gen ECU Code help
- 00 Digital Climate control lights (Help)
- ENGINE AIR TEMPERATURE SENSOR
- Advice needed on Rusted out & leaky oil pan on 02 SE
- Factory Alarm randomly going off
- Let a relative barrow the car, now i got a blown clutch. Need Help!
- bottoming out with illumina/maxspeed/18"
- THE FIXING DEAD LINKS THREAD!!!!! EVERYONE PITCH IN!
- 5 spd Tranny issue
- How to: Upgrade your 5.5 gen alternator with a 4th gen gle/I30 one
- Speed shift/2-step installed
- Issues After ECM Reflash
- RE: 6th gen caliper fitment for 5th gen
- Engine Tired ?
- So I went to the junkyard and found
- Strut Disassembly
- Quick question in help of newbies...
- car noise?
- Just bought 00 max!
- Gauging Interest: Billet 5.5+ Gen Maxima MAF Adapters and/or MAF Tubes
- Car died. Please help
- power steering fluid disappearance
- Window wont roll up or down
- lower tie bar help stage 2
- RPM Question
- Brake system flush, how much fluid?
- Am I having Transmission problems?
- MAF & P0138 codes related?
- What is needed to remove Upper manifold intake?
- Rattling Noise During Acceleration
- Alternator / UDP Problem
- '03 stock stereo won't power on??
- ES Motor Mount bushings sit lower than OEM-> fitment issues?
- Front Axle Bearings
- Uh, oh... weird sqeal from front-end with knock underneath...
- Drive side seat motor - Big Trouble!
- Thanks for the suspension information
- Nissan FAST
- NGK Laser Iridium plugs
- broken sunroof - gets stuck
- Stillen rear sway bar hitting on lowered '02 SE
- Inspection Question \ HID Headlights
- Motor mounts for an 01 automatic...
- LED License plate lights
- radio install for 2001 maxima
- Knock sensor replacement on Cali spec engine?
- Which ES polyurethane bushings are worth installing besides rear trailing arm?
- rattling
- Grease inside front wheel
- Passenger Side Rear Brake Dragging.
- 2002 compression test results
- Tire rubbed a hole in my fender liner..
- Im baaacck
- Uhh WTF Loud bang noise coming from under car after driving...
- stupid headlights...
- P0132 O2 Sensor Code
- Oil leak...damn!
- Interior LED helpppp
- CAI Idea (Forced Cooler Air)
- Tried to check ABS codes, not working out.
- Sugar in the AT shifter
- When to change the clutch?
- Rotors and Pads....again
- 19" '09 SV Wheels on 5.5 Gen...
- Nissan=FAIL, engine knock revealed: PICS and VIDEO.
- NVIS Problem
- Interior Swap
- Hit a cow
- B8 Crash Zone Sensor Communication Failure
- auto passenger window problem
- Whooping from rear passenger wheel. Definitely not a cheer.
- Few questions regarding Exhaust..
- Car fails to start on first crank at times
- Think I found why my front brakes were making a grinding sound
- The max has been Great for the 5 years that i had it.... Saying goodbye.
- Did I explode my precats?
- Help Please!
- Engine Rebuild Kit
- Yellow Top Battery
- Power bleeding clutch hydraulics?
- Clutch issue. Need help
- foggy headlights.... water leak?
- MOOG VS OEM Front Sway Bar End Links
- otto fstb problem
- ABS sensor problem with a low budget...
- Help Car wont Start
- Ignition switch bulb replacement
- odd question
- ECU diagram access
- A/C cycling and engine temp going up
- 5.5 gen vs 6 gen clutch feeling
- weird question
- Hesitation - I know, please read...
- rear window prob ?!
- My keyless entry got wet on the inside. What should i do?
- Sorry to make this again about shifter trim. help!
- Rear diffuser in the making
- 2002 starting issue
- Need help please oil all the way up dipstick!!
- Anyone have a "Curt Manufacturing" brand hitch installed
- 02 SE Maxima with 117K mile in need of service...
- How to seafoam your 5 gen maxima
- Door Panel Seperation Possible?
- EVAP vent control valve screws
- Easy one: Battery Ground
- What header/y pipe combo is this???
- transmission upgrade
- MAF ? SAFC? Technosquare ?
- can this be a tranny problem
- Viscous Limited Slip Differential - VLSD
- Sooooo I'm nervous. P0300 and white smoke.
- Crankshift Positioning Sensor - Recall
- P0011 & P0021
- HLSD? do I have it?
- Replaced recline motor, seat still won't recline... is it probably the switch?
- What mods have you done to your ash tray area???
- Exhaust fitment question
- Air Ram-Intake Idea
- 5th Gen ECM Swap Question
- BRAKES
- please help!
- Went to a mechanic - is this a fair price?
- Are 03 GLE and 01 GXE struts the same?
- P0021
- P0139 and P0138 Questions
- Question about 5.5 HID
- ebay front bumper cover
- how do u get these headlight bolts out
- Location of lower valve to bleed clutch on 2000 Max?
- H3 Hid Kit
- Leather door panels
- Anyone else notice this ad at the top of the page?
- THOUGHTS ON YELLOW TOP OPTIMA BATTERY?
- looking for deal on rear motor mount
- Car Shudders Violently When Accelerating Hard
- roaring noise.... rotors?
- Eibach owners - cut your bump stops!
- Another hesitation problem
- How to install cattman headers?
- quick air intake question
- Reaching out to 5.5 Gen Owners for easy survey/experiement
- '01 GXE Service Engine Soon light on
- Got to leave the maxima for four or five months
- clutch issue?
- Hesitates when excelerating
- Easy Questions
- Transmission
- Coolant loss ... Unable to find source
- wheel noise and shimmy
- 2k3 maxima hesitating, check engine light, blue smoke... UUGGHHH!!!
- Rear wheel bearing/hub assembly
- 5.5 Gen MT heavy duty axle now available from Raxles
- It's love.
- New Battery - better acceleration?
- need help figure out a problem with my car
- Need some suggestions on where to get exhaust work done
- burning smell after acceleration
- Service Engine Soon - Codes
- VTC Sprockets
- Rear Brake Pad Question
- 18x9 35mm Offset - Fittment Questions
- what to do about my hids
- MagnaFlow
- Installed Y-Pipe.. now I have weird noises..
- Just Bought A 5th Gen!
- Cooling fans
- Starter Problem!!
- trunk badging
- Car Won't Start!!!
- Keyless entry brain
- SES Light came on, blown fuse?
- engine surge, idle speed up to 2k+
- vibration after 70mph?
- My Dyno pulls, numbers, vids, and pics inside
- Tokico Illumina Suspension Kit. Suggestions?
- Blew 120amp fuse, put in 100amp fuse
- umintza projector headlights w/ angel eyes
- rubbing noise
- Shift Knob
- exterior window trim
- Road Noise From 2 Different Sets of Tires
- BBK Upgrade and the pedal is somewhat soft - Any ideas?
- Rear motor mount replacement
- APEXI POWER INTAKE
- Fabricated Wheel Spacers??
- Valve cover gasket, revisited
- auto tranny fluid change
- Front Left Grinding noise
- Cleaned my TB and now I have a SES!!!
- Need to remove front driver power seat - no forward/backward movement.
- Engine Cover Logo Replacement TSB
- usa-spec pa11- nis
- Radio steering wheel controls
- codes......
- stillen classic lip install
- How do I clean behind clock glass?
- Stutter when cold - hesitate under hard acceleration
- Coolant plug on engine block
- 2003 HID healights and Nissan Dealership Anti-Theft Brackets
- new grill
- anti polution canisters?...02 max gle
- hows this test pipe
- P1126 Code - Thermostat or Relay?
- EGR plug for the rear exhaust manifold
- 5.5gen Headlight woes
- So i join the oil burning 5.5 Gen Maxima Owners , Whats next ?
- Gas Mileage
- stinky cabin
- Those with a 6-speed...
- 350Z Muffler/Resonator on Maxima?
- leaking vias control solenoid?
- So What's Your Favorite Pull?
- Mirror
- Rear-End Clunking Noise
- Illuminas/S-Techs installed.
