- tach signal
- Getting my 6mt tranny replaced with a 6th gen one
- Finally replaced my cracked fog lens, and....
- Pcv Valve Grommet
- Sunroof sagging from one end
- Eastern Catalytic Converter
- Uneven heat thru vents
- Just finished installing Tokico Illumina's on my i35, impressions and some questions
- Does Anyone know?
- Extended Warranty Opinions
- #4 Ignition Coil Melting
- Suspension Work Needed
- Overheating issues
- Quick Alternator wiring question
- Wheel bearing maintence...?
- I Need a Clutch..help please.
- Has anybody ever gone up against a camaro Z71?
- ABS/noise issue
- Ebay headlights
- muffler from 00-01 fit on a 02-03 max?
- shift knob
- Trunk Supports
- 2000 Maxima Auto Radiator
- A32 Y-Pipe on A33?
- Poll- Engine pinging?
- TPS and APP sensors gone bad
- Still have front end clunking...
- Would this work in place of the oil catch can?
- Injen/Fujita Intakes
- Dumb question about oil level
- Steering Wheel Loose
- Rod bearingsr shot
- 5.5 --> 6th Gen Calipers - Is this Caliper Bent???
- 6MT issues
- Replacing coolant and radiator hoses - do i need special bleeding?
- Consult/blaZt for A33/A34
- weird rev jump.
- H.I.D.s?
- 01 GLE Sunroof Motor Problems (fuse not blown)
- How to know if my maf is no good
- annoying problem with driver side window
- Automatic Tranny Fluid Flush (I've searched!)
- Review of Timing Advance
- Replace ECM Myself?
- Illuminas and S-TEchs or Stock Shock/Strut with S-Techs
- Anyone else interested in a Cattman Y-pipe for a 5.5 Gen?
- 5.5 gurus step in please
- SAFC-II question(s)
- Window problem
- sensor help.. tps/app
- need help
- High beam, low beam
- rear window problem
- CV Joint Fail
- want new exhaust. but i want some preformance too.
- Canadian Max, exhaust Fed spec or Cali spec?
- Nitto Invo - Tire review [video]
- Got P0430 code not sure which O2 sensor on bank 2?
- squeaking sound when i turn left after all the repair and $$$$$
- Hypothetically how much hsould a mechanic charge for this?
- Extending Rev Limit...Possible?
- Who else has this problem with the manual shifter cover?
- Brake Sensor
- doeas anyone know if this will work with factory alarm?
- Car wont start and acting funny (electrical clicking)
- Timing advance from the dealer or Greddy EU?
- Check out the sig
- how much would installation cost for a y-pipe+ headers
- So After $700!....
- OIL in spark plug chamber
- hole in firewall for wiring.
- button under clutch pedal
- Clutch gets tighter when AC Runs and/or Temp Outside is Hot
- replacement muffler
- difference between egr and evap system?
- I have a question about the package I have
- Fuel guage light is out.
- Brake Rotor rust. very very ugllyyy
- Sound when car is in reverse
- Fog Light Relay Problem?
- Buttons not lighting up.
- Any 5.5 6mts with a Y pipe? Need some impressions
- Interior or Engine Bay Location of ABS Sensor
- Winter is coming...Need winter wheels
- tps on a 03 max
- Replacing Ignition Coils, can I replace just one?
- This is driving me CRAZY! TCS/SLIP/SES!!
- My new sticker mod for mawr hp~!
- Schizoid SES Light
- Weird Noise
- need your opinion on ebay generic engine mount
- Opinions on gauge placement
- New Valve Covers to Replace PCV?
- Paradox Rear Strut Bar?
- Need help...any input...
- So....what the heck should I do.
- low idling
- Rough start up and rough shut down
- Seat options for the 5th gen
- Link to VAIS video...
- Exhaust ground strap broken...Problem?
- Vid/Pics of my double din install...
- Idling Issue
- 00-01 headlight eyelid help!!!!!!!!!!!!
- Gerbils under my dash??
- Loose front wheel nut
- Where P0345 camshaft sensor is located?????????????
- Changing rear brake pads!
- AE Lip replica
- nismo shift knob. Will it fit?
- GAB + OSCAI + Resonator Delete done.
- Help - Window wont go up
- Re-aiming headlights after drop?
- ES sway bar bushings installed now front end clunking?!?!
- help me please starting issue after car gets hot!!!
- Cattman Performance looking for a 5th gen Max in SoCal for 3" catback fit
- SHOW OFF your Engine Covers
- I now drive a race car every day!!!
- 2000 Steering gear replacement
- Testing coil packs
- how to clean the engine bay?
- Time to say goodbye
- Drive Belt - Did I get wrong part?
- Keyfob "Unlock" Trigger
- SLUGGISH
- need help with IACV light Symptons in message!!!!!!!!!!!!!!!!!!!!!!!!!
- installing 2003 maxima rear view mirror on a 2001
- Car Won't Start
- AFTERMARKET GRILL?
- Techone HID's install
- SES Codes P0011/P0021
- Intermittent Alt warn light
- ny input on these carbon fiber hoods or any other brands that is under $500
- Metallic knocking in front right wheel over cracks in the road?
- rpm dropping below 1000
- SES Reset I/M Relearn Procedure
- Why does my AC sounds like it revs up too much?
- So... my max got hit
- Is it time for new rear brake pads ....or maybe a wheel bearing?
- I30 15" BBS Wheels, will they fit?
- Good Quality Head Lights
- Clutch & radiator - HELP!
- 5.5 gen Stearing wheel wear. cover pealing off
- Safe to put oem headers and precats back? ***pics***
- Does SES light reset with #of turns of key
- 01 intake/headers comparison
- P0420 SES disappearing act.
- BOSE 6 CD Changer head unit question....
- homelink transmitter problem
- Understanding Maxima stock security
- Lubing a Squeeking Strut
- Air Conditioner Problem
- Berk Intake- AEM or Apexi
- Nissan Sport magazine!
- Head Gear??
- wire that leads to starter solenoid in ignition cluster.
- manual climate control
- Whirring/ faint grinding noise when accelerating
- power steering fluid is boiling!
- red taillight overlays
- replaced rear calipers...
- Riding height + front lip recommendations
- Clicking/clunking after start up when engine is completely cold.
- My car TOTALLED - But what a story!
- VAIS and intake...dirty???
- Quick question about window visors for the 5th gen
- carputer or the headunit i have now?
- reverse lights switch/sensor
- side marker connectors
- Weird noise coming from suspension....
- How to Paint your Engine Cover
- bad abs sensor? clean it or replace it?
- K sport strut replacement
- how to remove nuts withoput breaking their heads?
- Emergemcy Brake Question
- 03 maxima stalls right after startup when engine warm. Please help!
- Running real lean please help
- how do i erase the abs light?
- No Start - I'm thinking ignition switch
- which wheel spacer
- Disconected battery, cluster not working now..
- Strange problem, car sputtering when in drive...
- will a 2003 maxima's abs sensor work on a 2001?
- Hail Damage
- Question about rear illumina install
- Is it really possible?
- BLower motor!!
- Help Car won't start.
- No power locks, dome lights, or rear defroster
- can some one please tell me what i'm doing wrong here?
- question about 01 maxima brakes.
- NEED HELP ASAP KEYFOB QUESTION
- projector lights
- 6th gen caliper - price tripled!!! Other Options?
- Press-in ball Joint
- All 5.5Gen 6MT owners Step in .
- Keyfob question???
- Can someone help me find the Shift solenoid test thread?
- clutch grinding at high rpms??
- how to remove the tie rod ends on 2001 maxima
- 00 tranny shifting out of gear while driving
- O2 Sensor Headache, Fast Relief! 03MaxSE
- SS Clutch Line Install - Need Guidance
- how tight should i tighten the control arm nuts?
- 2000 transmission
- MAF cleaning on 02 maxima?
- TCM related question
- Oil on top of plug?
- $46.19? Cheapest price for a drop in K & N air filter?
- Clutch pedal engine vibration when completely depressed
- is it normal to have metal shaving on the magnets on the tranny oil pan
- My maximas starting problem. very odd (pics and videos inside)
- Cattman Performance continuously in business since 1998
- Keyless Remote Type on '02 Maxima
- A/C Screeching and then stops
- tranny is still leaking
- Conversion from HID to Halogen
- H&R or Eibach
- 00 Maxima making a screeching noise
- Fuel pressure drop after shut down
- HELP ME CAR NOISE
- Red Mud Flaps/Splash Guards
- Strange noise
- Looking through some old stuff.
- Driver Side HeadLight - Relay
- Starting problem
- What Els Can Be Wrong?- Can Anyone Help Me Please!?
- OEM Muffelor to the extension pipe is shot - HELP!
- Valve cover
- Radiator Fan Problem
- Aem Dryflow
- OBD Problem
- trying to trouble shoot P0335 code!!!
- where can i get the clear lenses for the 5.5gen headlights
- Noise coming from steering wheel
- Where to get a B pipe from?
- Can't remove O2 sensor...help!
- Unveiled: Pioneer AVIC F-Series Car Navigation [PICS]
- Dim Door Ajar Light
- Coil pack replacement DIY anyone?
- Headlight / Fog Wiring Harness?
- Bad Links in the Stickies..!
- 00 Max GLE vs 03 Max GLE
- some kind of gel
- Installing Hitch on '02 Max
- After market front pre-cat
- Stereo Harness Wiring Diagram, '03
- Alternator Ampere Output
- Jerk/thump when releasing clutch in neutral
- Max starts, then dies.
