View Full Version : 5th Generation Maxima (2000-2003)
  1. whirling noise in the front
  2. O2 Sim and Resistor install
  3. Problem with Heated Seat Switch
  4. Bose Display
  5. Removing Fogs/side markers?
  6. Help with my MAX cold start issue
  7. exhasut noise inside the cabin
  8. Nitrous questions
  9. starter flywheel problem need help
  10. Water leaking from the top left corner of windshield
  11. Brake Question
  12. AC control unit swap
  13. Anyone else experienced hesitation while idling in Cold? '00/ '01
  14. Cigarette Lighter
  15. 5.5 Gen tails
  16. Does your trunk open automatically?
  17. Is axle all the way in?
  18. Gauge cluster lights
  19. Inner Tie Rod Spun? Problem?
  20. Are Z32 brakes = R32 brakes?
  21. Cold Acceleration Problems.
  22. Manual temp gauge?
  23. I30 - Something running after ignition stopped
  24. does your car do the same thing?
  25. WTF!!! brand new bearing only 2mo's and this?
  26. Replaced Cylinder #3 Coils
  27. What's leaking from my car?
  28. Look WHat I can Do. (photoshoot) 56k No.No
  29. Time to blow some cash.... Tires/Brakes Suggest
  30. Dimensions of Cat converter?
  31. Broken Gear Indicator switch.. anyone know price?
  32. bearings wearing out, is this common on maximas and at what mils does it happen
  33. got an emissions test coming up need help ASAP
  34. All suggestions appreciated
  35. serpentine replacement
  36. 02 6spd tough to get into 1st and reverse?
  37. $720 labor for clutch and flywheel fair?
  38. Shock sensor write up
  39. Rust issues with pics
  40. who remembers this commercial?
  41. High Speed Lift
  42. Opinion Needed...Found a 2000 SE For Sale
  43. small hole on motor mount
  44. Need some opinions on rims....
  45. Where is the Interior Trim Code
  46. Cattman Newsletter/Sticker Sign-up (G5)
  47. 3" Cattman catback for 00-03 Max/I30/I35
  48. How to make JWT BERK combo work
  49. Jump in RPM = No Acceleration WTF??
  50. help me please!!
  51. I need new aftermarket "HEADLIGHTS" w/ projectors any suggestions?
  52. Help, Car doesn't want to start!
  53. Need help with belt tension bolt.
  54. HELP PLEASE!!
  55. loud high pitch squeak from brakes?
  56. tranny fluid
  57. Need new fog lights, any suggestions?
  58. OEM Wood trim for 2001 5sp SE
  59. HID bulbs for 02 maxima?
  60. sprint springs and bumpstops
  61. Electrical Issue
  62. help taking the cd deck out
  63. Any Replace Front Rotor Shield Before?
  64. Manual Transmission Fluid
  65. Parking Light Question
  66. How to take door apart
  67. LTB Carnage
  68. GLE third brake light
  69. Removing Ignition Cylinder Lock---2 questions
  70. A few Q's on exhaust
  71. 2k Automatic silver trim (PRND) piece
  72. ••ü•• Orion V2 for Maxima 2002-2003
  73. y pipe + catback installation
  74. The newest 5.5 gen owner :lurk:
  75. Low growling sound/clicking when turning at slow speeds?
  76. cali spec y pipe removal problem/question
  77. Illumina/ S. Tech
  78. Rear Defrost Problem
  79. New Here
  80. Question about my air filter
  81. Side Markers
  82. 6 Speed tranny ???
  83. Toruq spec for brake line to caliper?
  84. Bosal OE replacment exhaust
  85. Passed Smog check -- why get the P0430/P0420 codes
  86. Need help on 02 Max engine replacement
  87. 2002-2003 3.5 N/A Build options
  88. vq30det in 2000 max
  89. gas guage
  90. p1320 help-replaced coils
  91. SSIM'd my Car today
  92. SUper Bad Milage/ Need advice
  93. Unstable steering after axle shaft replacement
  94. D2 RS Series Coilovers - Info on a Groupbuy deal - checking for intrest free shipping
  95. how to tell if fuel injector/s bad?
  96. Getting to the washer parts in the hood
  97. Diesel sounds!
  98. Illumina Install: Part number question
  99. P1167, WB02 or new OEM O2 sensor?
  100. Electrical Issue: Loud Click
  101. Odd Noise - Suspension?
  102. Need opinions please!!
  103. Bulbs that match stock HIDs?
  104. egr removal problems
  105. Strut install party
  106. Upgraded cooling fans???
  107. 2000 maxima EGR issues
  108. Passenger inner tie rod replacement help
  109. Black roof and shark fins
  110. Exhaust and Headers Question
  111. A/t tranny slip
  112. Relay Noise !
  113. Help. Missing connection
  114. thinking about...
  115. custom gauge "pod"
  116. how do i reset ecu?
  117. MAF NEED YOUR HELP!!!
  118. Car won't start after alternator spark
  119. Heat Shield Fix 2002 Max in NY
  120. rsb installation
  121. MAF
  122. How to remove speaker grille?
  123. Help Me Understand IVTCP Sensors?
  124. Quick One
  125. Need Mounts!
  126. Vented Engine cover the Second** Pics **56kStayAway
  127. Resistor missing on MAF!!!What to do!!!
  128. Need help identifying Leak
  129. Cost of Clutch Master Cylinder
  130. suspension question...
  131. Wiring Question
  132. Finally found a used bumper cover!!
  133. How come a CAI is so much more effective on the altima SE-R?
  134. Car shakes in drive
  135. Saying goodbye to the 5th gen...
  136. transmission ground
  137. SES Studman's guide
  138. makes a load thump while turning
  139. Speedo Problem
  140. ae lip on 03 max
  141. Code P0440
  142. to convert from manual gear (stick) to automatic
  143. exhaust help.
  144. Keyless Entry Doesn't Work Anymore???
  145. Where is the Brake Booster Line?
  146. rattling noise in front pass side
  147. Sunroof tilt works but wont open
  148. Alignment printout
  149. Looking for wiring diagram to install shock sensor
  150. Clutch Problems
  151. 2003 leather seats in my 2000 se?
  152. Why would my sunroof tilt up on its own?
  153. Fairly New Battery but car will not start.
  154. K Sport Question
  155. Bad engine knocking....great
  156. Does the sotck non bose headunit play mp3s?
  157. Am I screwed?
  158. Best location for wideband o2?
  159. IGNITION
  160. Reprogramming TB
  161. Strut Tower Bar or Sway Bar
  162. downsides of buying a used max with high miles
  163. I think I found the source of my exhaust rattle
  164. all i can say is WOW. I love progress
  165. Blower motor won't turn on. What could be the problem?
  166. Mirror Compass not working, and wheel touch up question plz
  167. Just installed most of my grounding kit.
  168. heated leather seats for $200
  169. Strange noises
  170. 01 3.0V6 100/105K mile maintenance items
  171. timing advance and cell question???
  172. 100k mile club :-D
  173. driveshafts gon bad?
  174. does consult 1 work wiht 2001 maxima's
  175. CAR WONT START IMMEDIATELY
  176. Help my tranny!!!
  177. Electrical Malfunctions
  178. this guy does not know what he is talkin abaut
  179. Getting gas is a pain...
  180. MT tranny experts step in please
  181. 200,000 mile club
  182. O2 sensor locations
  183. Shifter bushing/swivel???
  184. 6MT passenger side axle woes
  185. these fell of my car dont know where they go
  186. TB question
  187. Engine/trans compatibility question???
  188. p0455 Help!
  189. New shocks & struts but now it rides like an old Cadillac
  190. Question for those who changed motor mounts
  191. shorter height shifter
  192. WTB OEM bra for 2002 Maxima
  193. code p0420 and TSB 00-070B
  194. What is this part?
  195. Rear Shock Mount Question
  196. BCM.....HELP ASAP
  197. Some Mean Person torched my car!
  198. Starter Problem?
  199. grounding kit?
  200. halo lights
  201. swapping my A.T. tranny with 6th gen?
  202. who can do timing advances....
  203. Center Beam Motor support stripped threads.
  204. Timing advance question...
  205. 03 max BOSE
  206. Spark plugs change
  207. Whats needed to lower my maxima?
  208. AE headlights
  209. How to ground the starter? (making grounding kit)
  210. PCV valve part #? 03
  211. tranny issues
  212. How to Advance Timing using the Nissan consult tool??
  213. Engine pulling advise...
  214. Huge Mileage Problem
  215. Need answers or suggestions?
  216. Vehicle Reliability Survey results
  217. Just got my H&R's and Illuminas!
  218. Lets discuss a theory of mine
  219. Noise after spacer install
  220. Should I resurface my rotors?
  221. How do you program the ignition transponder key?
  222. RADIO QUESTION?
  223. So I got my MAF adapter the other day
  224. so what happens whent he maf goes out?>
  225. What in the name of god has happened to my car!!? Valve help!
  226. 2000 Maxima Stock Radio Trim
  227. Strut Mount Assembly Question
  228. Bridgestone G 019 Grids?
  229. Acceleration problems... please help!
  230. side vent removal?
  231. Maintenance costs over lifetime of vehicle
  232. 22" on maxima slammed?? and Nex coilover SS reivew.
  233. Bouncy tach?
  234. I got Bad Luck!
  235. Just saved my self $110!! GREATEST DAY EVER!!
  236. New Belt squeaking: too tight or loose?!
  237. Dying Alternator?
  238. CF Hood in the winter
  239. hitches for bike racks?
  240. Smoked side markers
  241. front brake pad wear indicators 4 or 2?
  242. How to identify if the tranny I have is a 2003 or 2004?
  243. Ball joint nut
  244. Urgent help needed with tranny fluid flush.
  245. Just installed Starter and now it won't start!
  246. Two questions...odd noise and odd AC behavior
  247. Play in the steering wheel
  248. 2000 maxima se speakers amp and sub
  249. Maxima clutch pedal. feels kinda wierd.
  250. Soo.. someone backed into me. Options?
