- SES Light "P1456 -Manufacturer Control Auxiliary emission controls"
- Black / Clear tail lights step two in project pearl
- Wierd noise coming from my exhaust
- Sudden HARD cold starts, SES, TCU & Slip lights just came on at the same time as well
- What Nissan models have the same tranny as my '00 Maxima?
- '00 GLE - It Rose Like a Phoenix (the bird, not the Pontiac)
- Catalytic Converter Help
- Starter Location Details, Pics - Urgent
- Overlays trouble
- ocasionall starting difficulty.
- 02-03 headlights in 01
- Wheel part number?
- 1st gear is sluggish when engine is cold
- Poor gas mileage
- Those with an aftermarket exhaust, please step in...
- Place Racing CAI... where to buy?
- Clutch/Flywheel Install, what else should be done?
- o2 Simulator Questions
- search not working... radiator? how much
- Fuel trims, 02 sensors, and MPG (technical) questions
- what color is this?
- Please check out the story.
- Climate Control Fan Click Sound
- bump stops (HELP)
- HELP! Alignment pulls right.. they suggest camber?
- Tail happy suspension
- What should I do next?
- Near Miss
- Computer upgrades?
- 5 speed transmission shot at 66,000 miles
- Picking up 4at tranny w/TC, can I haul in Maxima's trunk?
- Driver Side Wiper Arm Not Moving
- 2002 I35/Maxima ... P0021 and flashing SES (misfire?)
- Just want a second opinion (codes)
- What is cracked here?
- Cracked Rotors
- Official color for 2003 SE
- Fog light goes out
- ( VID ) sound of my new exhaust!!
- WTF, left side head light is completly dead along wiht the auto matic lights
- Transmission Rebuild Code
- head unit swap
- is the SECU on the 20th AE different than the other models?
- My bad luck continues
- Smoked 120a Fuse
- Japanese Wiring Diagram of Door locks
- after suspension mod, still not stiff??!?!???
- what wheel stud do i need
- FIRST TIME MESSING WITH THE CAR
- vq35 coilpack on a vq30dek
- Instrument Cluster Question
- FSTB and RSB for 2000 Maxima
- AC Question
- Help ASAP: How to get new key made?
- REPLACING MIRROR
- wheel inset with lowering. Spacers needed?
- 5th gen that works at meadowlands nissan
- 2003 radio
- Ratchety sound on startup
- HID foglight conversion how-to?
- Need Help, New Battery Car wont do anything
- 4th and 5th gen parts the same?
- Knocking noise.
- Can someone Identify/Verify if this is a 5th gen. seat?
- MAF clean it? Or Replace it?
- getting BA9s to work correctly in map lights.. do i need to reverse wires?
- Trunk torsion bar
- Trouble finding part #'s for TB + IACV-AAC Valve Gaskets
- Black Friday Did my 5.5 gen dirty
- Struts Loose and Sway Bar End Link Makes Noise
- 2001 maxima door lock system negative or positive trigger?
- 2000 Max In Cabin AIR filter
- none of my seat buttons work
- This Morning - A Total WTF Moment!!!
- ECM Replacement
- 3.5L Hard start, stumble after start
- 6th gen BBK related question to set something straight
- MPH and MPG, are the computer calculations accurate?
- Air Filter
- Weird Noise?
- Catalytic converter is rattling like crazy
- power steering
- 01 SE won't start on 3* incline on cold mornings
- Code P0508
- icv or maf...?
- tsw snetterson fits but doesnt fit....
- Squeeky drivers side window
- pillow ball upper mounts?
- POSSIBLE to get bilsteins for 5th gen?
- Any good website to buy HID bulbs?
- Why isn't this max sold?????
- P0420 related to bad/wrong fuel?
- I am doing a 6th gen brake conversion, need lots of help!!
- Mixing AT fluids?
- Carbon Fiber front lip overlay
- Wiring issue?
- Anybody ever try the OEM fog lights off eBay?
- Front Axle squeaks when tiring the wheel??
- 2001 GLE ECU
- CV boot kit or new drive axle?
- RPM's dropping too fast
- Ran my first Autocross today
- No throttle response maybe a sensor?
- WORKLOG: Fiberglass Eyelids
- wheels from 92 Max fit?
- intake install question
- Car Studdering (again)
- Recirculation button on Climate Control not working
- blows radio question
- ABS kicking in at 10mph
- INTERIOR OVERHAUL WORKLOG (V1.2): Corrections & Upgrades
- 4th gen rear pads?
- MAF Sensor/IACV codes tripped: HELP!
- Graduated last night
- Anyone running lightweight wheels, especially 16"s?
- Front end vibe, hwy speeds, mostly when car is cold!
- 2K to 03 Headlight Swap
- six speed swap
- Diagnostic HELP!! 01 GLE
- Supercharger
- Dash mounted gauges
- 2002 PCV Valve Replacement
- I'm stumped (engine problem, I think)
- starter rebuild kit?
- leak in engine bay
- door lights acting funny..staying on...
- 6th gen rear brakes?
- OE O2 sensor supplier
- Carfax Dont tell all...
- P0138 - and a smelly cat
- Crappy Driver took out my Passenger side mirror
- fuel injector pigtail replacement
- CEL =(
- Gas Mileage
- Limited Slip bad for towing?
- 2000 GLE RPM Related Rubbing Noises
- Rattle on cold start
- Is checking the oil supposed to be this difficult?
- Replacing struts
- can u swap 5.5gen with 6 gen suspenion
- 6speed gearsets and HLSD
- Replaced Alternator and battery brake light are still on.
- 2002 Nissan Maxima GLE (New Member)
- 2 problems maybe you guys can help me figure out?
- Lowered Maxima pulling to one side
- Wiring harness Diagram
- G.I. 2.5" test pipes for 5.5 gens
- Retarded window switch
- Anyone else still waiting for their Megan Racing catback?
- tires safe for stock AND dropped (Vogtland) ride height?
- Fuel Injection wiring connector-help
- BLOWER MOTOR...OR RESISTOR?
- Replaced Rear VC Gasket this weekend: Pics and Observations
- Stillen Street Scene Grill on 5th Gen?
- From Greddy EVO catback to HKS rear section.
- Questions about LED turn signal
- OEM Clutch
- weird clutch..
- 03 Max Headlights
- Purchase-Alternator-replacement
- Bosal OE exhaust -- Part numbers
- LED light bulb #'s?
- 00' Spoiler light
- sprint booster
- Random water leaking....
- Ticking, Lifters and cleaning....
- Trany?ICV?Something?Cash?
- Noise is uppder strut mounts, help!
- adding aftermarket subs to bose
- Need video from 6-speed owner.
- Anyone with Stock Springs & Illuminas?
- AT problems, goes into 2nd, how to get the codes?
- Any tip on getting this rear caliper compressed?
- Front end crackel sound back...wtf
- what the hell? crazy dash
- Who has 00-03 black projectors for cheap?
- 05 Altima SE-R Brakes
- Strut pieces...
- Cattman Questions
- Throttle Position Sensor oil residue
- certified mechanic and what to check when buying a used car
- i tried and tried
- 6th gen brakes on 5.5 gen
- Smoked clutch now shimmying on take off?
- Pioneer AVIC F-Series Navigation [demo video]
- Hood wont pop open
- p1572 and p0456 codes
- 6th Gen Brake Calipers?
- Check Engine = Bad Alternator
- testing coils and injectors
- Nismo 05-08 Intake on a 5th Gen?
- LTB with headers (pics)
- Brakes!!!
- screeching noise
- If anyone knows part # for 00vi
- Bought a GREDDY EVO 2!
- Lexus capsules + 3000k HID = YERROW! :)
- body parts
- Horn sounds different all of he sudden???
- Can some1 tell me how to paint my 00 grille black & what brand of paint I should use?
- @#$% Are there any RELIABLE Aftermarket Y-Pipes?
- 6th Gen Brake Discussion with Write-Up and Pictures
- Question about 5th gen clutch pedal bracket
- P0037-how is it different from P0138?
- a few peoblems i need help with
- pulley compatibility 3.5L max vs. 3.5L Z
- LED's for map lights
- Lightning Strike
- Pricing on Blower Motor
- Did my Sway Bar End Links last night: Some Observations and How To's
- Question about intake, udp and timing advance
- A33 power folding mirrors.
- Techosquare ecu question
- Does anyone make a 1/2" spacer lift?
- Can A 02-03 Grille fit on my 00 Max?
- Any Dual pod a-pillars around?
- 02-03 OEM grille removal
- Injen CAI air filter replacement.. where do I buy one?
- 1-2-miss while cranking
- Appreciate
- Bugs in 5.5 gen tailight
- Doggone RUST! -- Exhaust related
- Need part# for PO455 & P1448 issues
- gasoline smell
- Planning Rear Valve cover gasket: Need input
- cheap intake
- Catalytic IM Not Ready
- changed end links now a new problem
- Did my strut mounts this weekend: Some Observations
- alarm/lock electrical issue help
- RPMs drop too slow, what causes that?
- Strange problem with clock and stereo/cilmate lights
- FPR or Fuel Pump?? Help
- Constant Lean
- raise front bumper
- Window switch compatibility
- Heated seat issue
- Bizarre noise from muffler
- messed up my speedometer cluster sum help please
- Help! Stuck in Wyoming..
- Is she a gonner?
- Temporary & Semi Permanent Fix for Broken Center Console
- Yet again Asia has coolest parts...
- TrimBrite
- Sunroof issues...
- Help a n00b: Which g35 Exhaust components are compatible w/ VQ30DE-K?
- Rear Bracket for Rear Bumper 03
- 2000 Airbags good for a 2001 car?
- moisture in taillight
