- 00 Max questions...
- Heated Seats Not Working
- VIAS rod spin freely!
- need help with sidemarkers
- All my lights went out!!
- 5.5 Gen Headlight Covers
- Umnitza Orion V2 Angel Eyes
- Replacement for thermistor on 02+ MAFs
- Performance Mods (tax return)
- What clutch setup & how many miles do you have?
- Fidanza Flywheel w/ Stock Clutch
- hid help
- y pipe cattman or obx
- need help mpg problem
- Do our 5th gen autos really shift around 5950 rpm?
- idle issues below 25 deg F
- Bose Woofer Cut Off Problem for 2001 Maxima
- angel eyes and cleared blinker light
- Rear squeeky suspension
- Squeaky shifter in a 2002 6 speed
- Rear end clunk/Knock/Thud noise???
- 3 changes made my car so much more enjoyable
- how many quarts of oil for 5.5gen engine?
- I will now own a 5th gen!
- Fog light Hids installed**Pics**
- 350z Injectors for 5.5gen
- Suggest replacement alternator
- I35 low on oil/burning oil?
- Tranny Swap
- Loud squealing sound on start & sometimes downshift
- What the difference in the 350Z 3.5?
- Wing or trunk Spoiler installation and cost
- HELP PLEASE with rough clutch engagement
- ae heater button left of dash
- New Wheels I Just bought.. check em out!!
- $800+ Bass Controller?
- Need a tip on bleeding my brakes; the thing will not bleed!
- Wiring harness for trailer hitch
- seat heater problems
- Sunroof installation and cost
- Timing advancement on high mileage maxima
- Finally Getting Some Goods Installed
- Annoying rattling sound at 1800-1900rpm's.
- 2002 California Max.. rear O2 sensor wire color and compatibility?
- Car burning massive amounts of oil?
- i got a lowering situation
- Alternator Problem
- Weird Issue with HEAT
- Help diagnosing an ABS problem.
- Help please, car won't start. Weird.
- car was shaking last night
- Heater Core repair day 1
- Sunroof sits a little high in front
- anybody know about this front lip
- 55W HID'S OR 35W HIDS? BIG DIFFERENCE?
- anyone buy rtp slot/drilled rotors from automax?
- transmission swap question
- intake question
- Window Visors???
- Opinion: Turing Radius of 02 Maxima Issues: Steering noise (cracking, rubbing)
- HELP PLEASE!!
- Airbag light flashing but no codes are coming up
- Quaife ATB differentials for 00/01 5MT Maximas
- Fitting 2002 cali-spec B-pipe (Cattman) on 2000 Fed-Spec
- Rear sidemarker wont come off
- too much coolant going into the reservoir
- changing sway bar links
- Power steering pump
- Question after seeing my dyno plot
- NKG Platinum- G Power?
- Power driver seat problem
- Do i modify the bump stops when installing H&R springs on 03 Maxima?
- Replacing radiator - do i flush the Auto Transmission fluid too?
- power door locks not working
- CODES CODES CODES!! SMH!!
- AE OEM brake calliper color?
- Transmission questions
- How low can you go
- head lights??
- Changed o2 sensor mpg plumeted?
- How to remove the HU in a 2k3 with Navi?
- TransGo Shift Kit
- How to deal with rust on right rear quater panel? **PICS**
- Block heater?
- 0138 is normal with no precats..but will it affect mileage?
- Clutch replacement 2001
- I would like to know reviews for the Vias block off and the intake spacer.
- Scratched lenses
- coil pack screws 5th gen
- Help!! Where is all this coolant coming from?
- Strange Window issue
- Stillen FSTB on an 01 AE?
- Weird problem
- coolant leak at start up
- issue # 2 on the trip funny transmission
- need help crazy weird thing happend on trip
- Need Help with Part # for screw (pic inside)
- 2003 Headlights kit
- VSS
- What seats will fit??
- Steel Oil Pan Leak
- How many miles before Inspection after resetting ECU?
- Anyone tried installing a 5th gen Bose headunit into a 5.5 gen?
- Idle Air Volume Learning 2000-2001
- Did the free STS mod... My impressions...
- Cleaned Up The Burger on the Engine Cover
- Heads... How much torque?
- Wanna make $10? let's see if you can solve this starter issue...
- Need some quick help
- Strut Mounts & other Pieces
- Floor mats question
- 02-03 Dome light question
- Incompetent mechanics
- Question on HID
- check out my new B&M
- Time for a tuneup?
- BLACK 20th Anniversary Maxima emblem
- power delivery characteristics on 5.5 auto?
- exhaust cutout 5.5 Gen
- A favor from ones with the stillen rear kit Thanks!
- Need help with this ECU replacement??? 2000 SE auto Fed no traction
- blehmco stage 1 ltb install problems
- If you have HID's in a stock 5gen housing, please post picture of beam plz? =D
- 4th gen intake on 5th gen?
- auto insurance
- Glad I have a good, reasonably priced mechanic
- transmission grinds into third almost everytime
- Drone (exhaust leak)
- ABS actuator connector
- real stumper. No reverse, now there is.
- Anyone buy HID kids from DDMTuning?
- Smoked or Clear sidemarkers?
- Gas Pumps Don't Like Me
- BIG Rock !
- silver or smoked bumper lights?
- 03 Max suspension in Ny
- Causes of Vibration when Braking (Beyond Brakes)
- Tradein Value -- experience with stealership.
- Would Bad cats cause this??
- Any way to fix the factory (base) HU? The display doesn't light up
- HELP!! DAM BOSE SYSYTEM!!
- 2000 nissan maxima - abs/slip/traction control light on??
- Need to get my front bumper fixed
- Weird gas-mileage
- ES motor mount for auto's
- Both fans running when in "Auto" mode?
- 2000 i30t cv/axle pass. removal problem
- How To Install the USA Spec iPod/iPhone Interface in a Maxima
- Bad o2 sensor =/
- What a difference a new battery makes
- Another MAF question I have searched and searched :\
- ES motor mount question....
- The Great Christmas Precat Punchout - whats the easiest way?
- Umnitza angel eye start up issues?
- rims
- Headlamp Assy Help
- Performance Problem
- hid question
- Another one bites the dust...
- Car goes crazy in cold weather
- I am in trouble!!! Caliper pin bolt stripped & cracked
- One Wheel Drive (OWD)?
- First Trip to the Dyno, Is this about right?
- stock radio issues
- 6th gen transmission ?
- Quick question about HID fogs
- what brand/size wheel spacers are you running
- do i have an option
- Bad t-stat?
- Californian needs inexpensive precat solution 5.5SE
- diy oil catch question
- Carbon Cabin Filter Restrictive?
- Do i need rear alignment on my 03 Maxima? Strange tire wear.
- Car wearing it's winter coating.
- Help pulling ecu codes for free
- A/C Fans going up with RPMs...
- Opinions about fuel filter
- Did I damage the tranny?
- New Maxima
- 93 OCTANE ISSUE
- steering wheel controls
- CF HOOD where can I buy one???
- Automatic Transmission Fluid Change
- Any way to disable automatic door locks?
- Hasn't ANYONE put 5.5gen 4AT in a 5th gen? Are gauge clusters the same from '00-'03?
- 01 tail fit on 02
- HID light Help
- Debating on which ones I should Get anyone?
- "TCS OFF" and "SLIP" lights came on... HELP!!!!!
- Planning a trip to the mountains with the Maxima ... some questions
- Thermostat Issue
- Place Racing CAI install, Question
- 5.5 gen ecu tuning
- ECU reset question..
- 00-01, 02-03 shocks interchangeable?
- Clutch Master Cylinder Problems...Less than 50k on 03 Max
- Timming chain
- Part help
- Put H&R's on the fronts
- New v2OBX headers?
- SSIM INSTALL
- ecu QUESTION
- center console question..
- Brand new exhaust rattling on cold starts
- Headlight/Speedometer out intermittently
- Horrible problem with the wheel bearing!! PLEASE HELP
- Anyone have this on a 3.5?
- Alignment Issue
- VQ30DET Internals On the Way!
- ebay front lip
- wheel help
- Considering a custom exhaust... questions...
- Driver's side fog light gets moody
- Changing 2K Fogs - What a PITA!
- Strut Mount Life
- 2000 GLE Coolant leak
- Why won't a 4AT from an '02 work with my '00?
- WYF WRONG WITH MY CAR?
- 5th gen battery specs
- Catalytic converter? Or less serious
- Found That Notorious Clunking Noise
- VIAS Fix, ECU Question
- 5.5 gen with se-r wheels?
- headlights cut out with turn signal
- 5.5 gen illuminas messed up plz help
- Fog light rewire for 2003 Maxima SE
- Who bought the CM 3" catback?
- push button start on 01 maxima
- can it be? if so, where to get it!
- Flowmaster 40 Series Exhaust - Thoughts?
- need oil catch can instruction link
- Bose HU Skipping on CDs? Possible Solution.
- New Exhaust Mod - Check it out!
- Identification of this griding "creaking" noise from front end
- No start issue
- Speedo and Tach problems
- Made some new tails
- Anyone have carfax?
- SES After new MAF?
- Aiming headlights horizontally
- Odd...could Techron fuel injector cleaner cause a temporary O2 problem?
- A test pipe that fits or Stock cat as test pipe?
- Would i rub?
- Instrument Cluster Removal
- HID in Fogs (H3 vs H3 mini)
- Beginning to regret buying the Max
- Turning radius
- Can I swap for for old style ignition keys?
- SES Light "P1456 -Manufacturer Control Auxiliary emission controls"
- Black / Clear tail lights step two in project pearl
