- maxima mirrors
- Aftermarket replacement parts?
- Are the Bosch O2 Sensors for 5th and 5.5 gen same?
- Looking for 01 Max Ignition Coil Connectors
- pulsing dash lights
- catalytic converter question
- Utec
- ECM connector help me
- Hard shifts and CEL lights
- Replaced Spark Plugs... Idle Issues
- So, um... Will you take a 3rd Genner?
- 5th gen bulbs?
- Please Help...problem with corner lights, brake lights and dash board illumination
- Clutch issues, keeps slipping
- Bose issues...
- GAB - minus the ghetto
- squeak at 1000 rpms...
- LED tails
- Power Window One Touch Up Problem
- Shifter cut and weld
- Just got Pummled .....:(
- Regarding spring/strut area on an 03
- Cost for a clutch change?
- Rear Rotors wont come off
- SES Mystery
- Coolant leaks. What's wrong here? *pics*
- MAF
- I think my engine is falling out
- On/Off Throttle Feel/Jerk
- P0100 and P0505, car dying at idle...need advice
- Power stering fluid flush?
- Is there anyway
- Muffler Question..
- avital 4400 remote start
- Coolant Leak from the metal Housing
- AXLE PROBLEM HELP!!!!!
- Another strange electrical problem thread...
- Andysautosport.com
- How to find vacuum leaks...
- Check Service Engine LIght Questions?
- Tips/Tricks for Replacing Clutch Master Cylinder on 2001
- Anybody have or seen these installed?
- Anyone had problems with Dorman Control Arms?
- RSTB for the win
- weird P0420
- Timing advance 1st impressions
- soon selling eibach springs
- Download Factory Service Manual?
- stillen rear strut tower brace
- Tein SS Wrenches-Need to Borrow ASAP!!!!
- 5.5 gen headlight disassembly
- $tillen classic lip 02-03
- 2 VIN's on one car? What the f....
- Obnoxious shake - advice?
- Auto Maxima 5.5 Gen - 2nd Gear Power Loss
- ECU SELLERS?
- ECU reset question
- tax return time ( gift for the max)
- yes yes... the popping sound while turning again
- Wheel Bearing and Hub Assembly
- Norkoastal's Part out Sale!!!
- Careful Replacing Rear Side Marker Lights
- 02-03 motor mount how-to??
- HALO headlights with HID conversion
- weird tranny leak problem
- Where can I find those Bright White Lexus License Plate Lights for Maxi?
- 6 sp. 5.5 Gen Maxima
- Installed intake, now it hesitates.
- 02-03 headlamps
- Megan OE-RS exhaust owners
- Braking Advice
- HELP!!! car wont start!
- Knock sensor
- Annoying rear clunk
- 6 Speed Transmission Harness
- Willwood kit Clearance
- Car Drives Like Crap - Please Help.
- 5.5 gen housing
- Instrument lights out, how to replace?
- Please help - dashboard illumination is gone...
- windshield nozzle not working
- Replacing Front Rotors 2002 Maxima
- Turbo or Supercharger???
- TRANNY not flaring on full tank?
- THEFT -Headlights and bumper
- part identification?
- Ebay Retrofit
- O2 Simulators and Secondary (rear) O2 Sensors
- P0150 & P0403
- got her Aligned.
- What muffler will be just louder than factory
- New windshield
- 00 Headlight removal tutorial?
- stage 1 ltb?
- water sound when i accerate
- Cattman Headers installed...
- Has anyone tried the ebay bumpers?
- FAILED EMISSIONS
- Passenger Airbag Torx Size
- Stalling Problem
- Questions about GAB
- Sloshing noise coming from the car
- Failed Fuel Door Actuator?
- Dimming interior lights after new Battery?
- Who can identify these two exterior door parts?
- Headlights turn off when blinker is on?
- squeaky clutch 02
- Rim Clearance
- h4 kit install
- Muffler/exhaust piping repair question
- Another one bites the dust...
- Installing Cattman Headers, what else might I do?
- Magnetic Drain plug for manual trans?
- 2002 SE in Seattle area
- Lexus Capsules How to..
- nismo shift knob
- Cosmo CAI??
- Curious to know what the inside of Cattman's muffler looks like
- metal vibrating sound when the heater is on. what is is?
- Need Help..
- strut mounts and boots
- Spark plug tube seal removal
- Weird Stalling Problem
- Whistle Noise from Throttle body area
- P0303 code. Can I drive with this code?
- 6th gen brakes on a 5.5 HOW TO?
- whats wrong with my window
- Bad battery now whining/whirring noise?
- Tein SS Coilovers...Inputs!!!
- Question about a swap out>?? Leather Seats
- Strage electrical problem
- How do these plugs look?
- burned out Xenon '02 SE headlight
- Blower motor chirping
- finally able to post up, got a few ?s
- Need help removing brake light switch
- SYSTEM TOO LEAN BANKS 1 AND 2
- Rear Sun Guard
- Driver side door stuck shut
- Issues with SECU and windows
- Bad Coil Diagnosis
- Magnaflow muffler question.
- how hard is it to do this ??
- Priming engine when changing oil--Dummy oil didn't shutoff
- Weird annoying suspension noise
- PLEASE HELP:Fidanza flywheel fitment issue gen 5.5
- 6000K D2Rs with bluish tint
- 5.5 bose hu fit in a 01 ae?
- Help with my custom exhaust setup
- Dealer can't get into the ECM??
- Average Life of Tokico Illuminas
- WTF!! New set of tires = Less mileage
- 5th gen emblem
- Grille Options...
- Leather is in !!
- vq30 to a vq35
- Pre-cats/Exhaust manifold interchangeablility
- code p0172
- SPORT mod
- Showing signs of warn clutch
- Was rear ended last week, need insurance settlement advice?
- Hid issue
- Heads up on the 5th gen - front end noise and clunking and a shakey steering
- If Cattman made a Ypipe with 3" collector... (5.5gen)
- 2002 Max & 2001 Bose HU
- Barely-visible SES light?
- Who bought my max (Wisconsin owner)
- Any tips on wiring power folding mirrors?
- Boo For Accidents :-(
- Driver side mirror
- Brake job.. Ceramic on Max?
- Projector Headlights
- 00' EGR removal
- 105k
- Starting problems
- Anyone here know how to wire 5.5 HIDs to 5th Gens?
- Drivers Window?
- RPM's
- Opinion for Brake Job
- Hit a curb
- odd bose question
- Windshield
- Replaced Heater Blower Motor now airbag light flashes
- 02 GLE ECU Diagram
- Ok, who now has the best deal on Illuminas?
- 5th and 6th Gen Drilled Rotors - No Cracks Allowed
- Auto dimming mirror wiring harness
- Cold Weather car not starting.. help plz...
- Driver side mirror won't heat
- Clutch Issue.
- squeeling brakes
- fog light rewiring help
- Weird high pitched noise with heater on full
- small leak from main seal maybe?
- stillen RSB
- Anyone have trouble removing their fog lights??
- Turn Signal- legal or not?
- bad muffler
- What is this connector??
- Readjusting the seat..
- parking lights...advice/help
- Automatic Adjustmenting Seats
- Possible New DIY Brake Fluid Flush?
- Radio antenna 00 se
- Will 02/03 seats fit in a 2000?
- Intermittent knocking / vibration
- How to tell if the slow 2-3 shifts are from tranny? or valve body
- Emergency brake play (slop)
- HID Fogs installed! (well one of them)
- P0340 - Camshaft Position Sensor (Phase) Circuit (Bank 1)
- Cattman Exhaust FITTMENT ISSUES ANYONE?
- Odd intermittent noise from right vent
- ABS Light
- Usefull TSB Links service bulletin
- Need help with factory headunit swap
- P1147...how to fix?
- New Wheels now car pulls to the right??
- Reliability of stock shocks/struts?
- Anyone had their MAF replaced under warranty even though the car is OOW?
- how many belts
- 5.5 Gen Tokico Illumina's Settings
- Installed my exhaust
- Rear spoiler brake light
- Bad struts. aftermarket route cheaper?
- Help me fix my oil leaks and other small things :)
- Intake and exhaust question..
- Cali Spec ECU - Fed Spec Engine?
- P0420 With Aftermarket Y-Pipe
- Q/A will a 4th gen 97 vq30de fit & work in a 5th gen I30 2000-2003
- Who stocks gen 5.5 aftermarket flywheels?
- HID high beams? (5.5gen)
- 2nd gear grind
- Strange burning smell?
- Should i do it or not ??
- Tranny Troubles......
- MY RIMS JUST GOT STOLEN
- Radiator Cracked Today!
- HID bulb replacement
- Where can I find a window Regulator and Driver side motor for an 03 SE?
- Dimming dash lights
- clutch spacer required?
- Hit Curb on 2001 I30
- Tokico front strut mounts??
- AIRBAG LIGHT CRASH ZONE FAILURE!!HELPPPP PLZ
- what should the RPM should be when the car
- Stiffer steering?
- ok new issue o/d light & high rpms
- Removed towing hitch and now one hanger down.
- Interior color codes??
- Alternator replacement nightmare
